1.1k Posts 105 Posters 790.5k Views 98 Watching
  • bjacobseB bjacobse
    @berkseo
    Clever idea to use SN74LVC1G00 as while both inputs are same voltage it only consume ICC = 10uA (10 mircoA) in whole voltage range 1.65V -5,5V
    @bjacobse said in What did you build today (Pictures) ?:
    @berkseo
    Not when when you have a low power comparator available that runs with only 0.5µA...
    • berkseoB
      berkseoB
      berkseo
      Wireless expansion module for very cheap soil moisture sensor from Aliexpress :)
      https://youtu.be/Toto1Cw4QBo
      • zboblamontZ
        zboblamontZ
        zboblamont
        Finally the round-tuit UPS got built after the last power cut clobbered the Controller/Gateway system, lesson learned...
        Meanwell AD-55A, 7.2Ah Acid gel battery, two usb 5v buck converters, a spare socket for raw volts, and a 15 euro IP66 box from the local shops.. Some drilling and filing to the lid, couple of brackets, spare bolts, banding, soldering and hot glue...
        A bit bulky, but disappears in a void under the stairs, two tiny drill holes let the buck converter leds shine threw...
        No monitoring as yet, but sailed through a power cut this morning and the Pi didn't skip a beat.. First up is the Pi's RTC then can put the cover back on the Controller...
        tbowmoT W 2 Replies Last reply
        • zboblamontZ zboblamont
          tbowmoT
          tbowmoT
          tbowmo
          @zboblamont is the battery and switch mode psu just in parallel? Or do you have a switchover / charge circuitry?
          • tbowmoT tbowmo
            zboblamontZ
            zboblamontZ
            zboblamont
            #834
            @tbowmo The Meanwell AD-55A is a purpose made 12v UPS type with all controls onboard. There is an optional version with monitoring brought out to a connector block, but I couldn't find one.
            The photo angle is misleading - Channel 1 +/- is to load, Channel 2 +/- is trickle charge to battery, power failure switches seamlessly to the battery as source..
            It's a fairly comprehensive arrangement with an array of safety features including battery protection, eg - If during power failure you disconnect the battery, it's reconnection will not restore load power, and resets only on mains supply.
            Case ventilation made using a metal bracket with a matrix of holes as a drill through template so it looks neat, but as the PSU barely gets warm to the touch it proved to be overkill.
              W
              W
              wergeld
              @zboblamont Do you have any more info on this? Components and schematic? I am looking to do this as well as Florida is now fully into storm season.
              • W wergeld
                zboblamontZ
                zboblamontZ
                zboblamont
                #836
                @wergeld Sure, but this is where I first read about it as part of a comparative link text when I was trying to decide on a UPS after a series of outages (frequent out here in the sticks).
                The dual buck converters were the only real variation (in case one blew). Following kind advice after querying buck converters on this forum, this is the type I ordered but off eBay, but this is very similar layout... link text
                I should explain that I would have gone for a commercial UPS had a decent USB supply been quoted, but the reality is that for most the USB is of secondary consideration to backup mains...
                I gets interesting when you consider the actual Ah capacity before the battery low cutout operates, I reckon well in excess of 12 hours...
                Have fun... ;)
                • epierreE
                  epierreE
                  epierre
                  not with mysensors, but could have been: CNY70 water sensor meter (rotating wheel) with extended wifi range, the heart of it is a Particle Photon pushing to domoticz
                  z-wave - Vera -> Domoticz
                  • berkseoB
                    berkseoB
                    berkseo
                    #838
                    Today I finished printing the case. Turned out to node with sensor bme280 and e-ink display, running on nRF52840 from SKYLAB
                    In one of the photos still have the sensor with bme280 working on nrf52840 from EBYTE. ...This is the previous project.
                    upd.
                    4_1564616740093_photo_2019-07-31_23-46-16.jpg 3_1564616740093_photo_2019-07-31_23-36-20.jpg 2_1564616740093_photo_2019-07-31_23-35-07.jpg 1_1564616740093_photo_2019-07-31_16-23-05.jpg 0_1564616740092_photo_2019-07-30_20-24-08.jpg
                    • kalinaK
                      kalinaK
                      kalina
                      I have soldered the first sample of "xRoom" board.
                      TODO: testing and detail description of the project))
                      W 1 Reply Last reply
                      • kalinaK kalina
                        W
                        W
                        wergeld
                        @kalina That is some excellent solder work. Last time i tried to do SMD work it ended up being 110% solder, 5% PCB, and 0% component at the end.
                        • alowhumA
                          alowhumA
                          alowhum
                          #841
                          I didn't build this myself, but I did create the code. It's a MySensors CO2 sensor that is part of a 'privacy friendly smart home of the future' which will be launched later this year.
                          It was made by artist and jeweler Dinie Besems. All her creations feature small 'skirts' that you can lift to see the data, or cover up the screen if you have visitors and don't want them to immediately see your data.
                            mcchots
                            Etched and soldered a new gateway after the original one I had failed.
                              #843
                              Meet Janus project, a premium USB dongle by Tekka and me :sunglasses:
                              Dual RF gateway with external antennas.
                              • nrf52840 with 20dB PA + SMA connector. So it can be compatible with MySensors, and/or zigbee..
                              • rfm69hcw/rfm95 long range + SMA connector . module has all DIO pins routed for sw driver optimizations.
                              • reset button
                              • user button
                              • RGB led
                              • high PSRR RF/analog 700mA LDO
                              • usb protected
                              • 4layers board
                              • enclosure size : 52x21 (thickness 11mm). compact!
                              Enclosure is just a quick proto, I'll improve quality, or I would like to try online multijet service, I'm curious :)
                              It's very recommended, for better performance, to have some distance between antennas.
                              So, for example, I'll use a shorter antenna (without cable) for 2.4ghz, and a "remote" antenna (with a cable) for 433/868/905Mhz, so it can be used with different kind of antennas.
                              We choosed external antennas, because
                              • versatile use
                              • better range especially when dongle is close to lot of stuff which could affect range in case of a pcb antennas
                              RedferneR Nca78N berkseoB 3 Replies Last reply
                              • scalzS scalz
                                • reset button
                                • user button
                                • RGB led
                                • usb protected
                                • 4layers board
                                • versatile use
                                RedferneR
                                RedferneR
                                Redferne
                                @scalz ohh! Where can I order one?
                                • scalzS scalz
                                  • reset button
                                  • user button
                                  • RGB led
                                  • usb protected
                                  • 4layers board
                                  • versatile use
                                  Wow @scalz that's a badass gateway dongle, any pictures of the inside ?
                                  Do we have more chances to see that becoming available, than HALO and Aeos ? :D
                                    #846
                                    thx for interests guys :)
                                    I'm just not sure if there would be enough interest for me to produce. I've not really thought about it! It's the first board of the batch.
                                    I call it a premium dongle because
                                    • it's 4layers. It's just a little bit more expensive than 2layers. But quality is a lot increased (better impedance, full gnd plane, better routing etc). It's also recommended by lot of rf module manufacturers for topnotch perf
                                    • I uses the high quality BT840XE module. As you know, it's a well documented and known module, and it's CE/FCC (better, as it includes a 20dB PA).
                                      Actually I just use a few pins on edges, and 18 pads under it..
                                      I had the choice to use this module, or to design mine with a frontend, but for once, I decided to go "simple" for a quick debug. And the price difference vs homemade, maybe +10€, is worth it imho, time saver, and I don't mind I just need one!
                                    Why did I make it? Because I can and would be pity to deprive myself :)
                                    And we can have a nice and reliable dongle for the team, just in case.
                                    You're right I have others hobby projects, they're not dead.. :sweat_smile:
                                    • just lost a bit of interest on Aeos release, I agree on this, because I prefer subghz for mysensors, and would like to keep 2.4 for others protocols.
                                    • Halo is not dead, actually it's one my favorite. I just need to find a way to include Janus in my "serverless" project which is mostly ethernet based (I made a full webapp, that I'm porting to true native crossplatform sw, android phone+tv, windows, linux, for better experience). "serverless" meaning optional rpi/computer
                                    Oki, I'll post others pics soon.
                                      This evening I assembled another dongle (and a few other boards).
                                      @nca78 as you asked, here is a pic during tests. Tiny dual rf dongle board, isn't it :)
                                      :sunglasses:
                                      berkseoB 1 Reply Last reply
                                      • scalzS scalz
                                        • reset button
                                        • user button
                                        • RGB led
                                        • usb protected
                                        • 4layers board
                                        • versatile use
                                        berkseoB
                                        berkseoB
                                        berkseo
                                        @scalz How do you plan to use your dongle? Just as coordinator? or only as a gateway mysensors? Have you tried using it as a combo? zigbee quite unceremoniously uses the resources of the mcu.
                                        • scalzS scalz
                                          :sunglasses:
                                          berkseoB
                                          berkseoB
                                          berkseo
                                          @scalz said in What did you build today (Pictures) ?:
                                          This customization boards adafruit? I've customized the Board Sandeep Mistry.
                                          scalzS 1 Reply Last reply
