  3. #error No forward link or gateway feature activated - when including MySensors
11 Posts 3 Posters 1.0k Views 4 Watching
  • T Offline
    T Offline
    timo4583
    Hello everyone,
    I know this topic exists more than once in this forum, but I couldnt find a solution until now. Im not a c++ expert, so the solution might be obvious.
    Im always getting the mentioned error when splitting files and including <MySensors.h>
    here is the error then compiling:
    In file included from src/Example.h:5:0,
                     from src\Example.cpp:1:
    C:\Users\timo\.platformio\lib\MySensors_ID548/MySensors.h:426:2: error: #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
    And here is my simplified code... Im trying to write external files for recurring code over serveral projects.
    src/main.cpp:
    #define MY_RADIO_RF24
    #include <Example.h>
    src/Example.h:
    #ifndef _example_
    #define _example_
    #include <Arduino.h>
    void someFunction(int test);
    src/Example.cpp
    void someFunction(int test) {
        Serial.println(test);
    Environment:
    • VS Code with PlatformIO
    • MySensor lib 2.3.1
    It seems that the <MySensors.h> - include in the example file has no access to my defined constants and somehow gets executed first?
    Im not able to get rid of this problem.
    It compiles successfully if I leave out the include of MySensors in the Example.h
    Any help is appreciated :-)
    • T timo4583
      Hello everyone,
      src/main.cpp:
      src/Example.h:
      #ifndef _example_
      #define _example_
      src/Example.cpp
      Environment:
      Welcome to the MySensors community @timo458!
      The message tries to say that you haven't selected any transport method (which is required for a MySensors node to work), nor have you configured that you want a gateway (which can be used without a transport). So if you were allowed to upload this code, MySensors would not work, which would be pretty pointless.
      The getting started guide will probably be the quickest way to get up to speed. Perhaps https://www.mysensors.org/about/overview can be useful as well.
      • T Offline
        T Offline
        timo4583
        wrote on last edited by timo4583
        Yes. But the first line of my Code is selecting the nrf24 as radio. So it should work. And indeed it works if I comment out the include of my example :
        // #include <Example.h>
        void setup() {}
        void loop() {}
        This works and compiles without error. It has to be something with the include of MySensors in the Example.h file. But I dont know why.
        edit:
        This is a corresponding github issue I found:
        https://github.com/mysensors/MySensors/issues/485 - But it has no solution :-)
        • T timo4583
          void setup() {}
          void loop() {}
          edit:
          @timo4583 I see. Thanks for explaining.
          I have no experience with Platformio but the Arduino IDE has some very strange behavior when using multiple files. Could be a side-effect of that.
          • mfalkviddM Offline
            Maybe the trick mentioned in https://forum.mysensors.org/post/51634 can be useful
              https://github.com/mysensors/MySensors/issues/1079 might be related
              • T Offline
                T Offline
                timo4583
                Thank you very much for your help. I found a solution which is a little ugly, but it works. Splitting to header(.h) and code(.cpp) files does somehow not work with MySensors, or Im not able to find the right solution.
                For now Im no creating a seperate code(.cpp) file and put evertything to the header(.h). This works:
                /src/main.cpp:
                void setup() {}
                void presentation() {}
                void loop() {}
                src/Example.h:
                // HEADER PART
                #ifndef _example_
                #define _example_
                // IMPLEMENTATION PART
                This way, it will be easy to split the files again, as soon as I find out how :-)
                • electrikE Offline
                  electrikE Offline
                  electrik
                  What happens if you first include the example and then the Mysensors library?
                  I also use platformio and it works perfectly.
                  • electrikE electrik
                    T Offline
                    T Offline
                    timo4583
                    @electrik Okayy.. that makes me curious. Did you try the exact same files and code like in my first post and it compiles? Changing the order does not work for me.
                    • electrikE Offline
                      electrikE Offline
                      electrik
                      No I didn't try that, just out of experience.
                      But now I see you include Mysensors.h again in the example. If you want to use mysensors functions in the header file you should just include
                      #include <core/MySensorsCore.h>
                      See also https://forum.mysensors.org/topic/6646/solved-multiple-source-files-including-mysensors-h-problem/2
                        T Offline
                        T Offline
                        timo4583
                        @electrik Oh yes, that did the trick. Thank you so much
                        12.1k
