  3. 💬 Easy/Newbie PCB (RFM69 HW/W edition) for MySensors
mysensoreasynewbiepcbmysx
106 Posts 20 Posters 57.0k Views 19 Watching
  • ferroF ferro
    Hi @sundberg84, on Easy/Newbie PCB rfm69 version PIN3 of MysX connector is connected to 3.3V resp. to the output from voltage regulator. When I compare with Easy/Newbie PCB nrf24l01 version, MysX PIN3 is connected to input of voltage regulator (to 5V). Is this a mistake in design of Easy/PCB rfm69 version?
    sundberg84S
    sundberg84S
    @ferro - Hi no - the RFM version is 3.3v only. nrf24 data pins are 5v tolerant but the rfm radio isnt so thats why.
    ferroF 1 Reply Last reply
    • sundberg84S sundberg84
      ferroF
      ferroF
      ferro
      @sundberg84 - ok thanks, it makes sense ;). I was asking because I connected your Dimmable Led Strip daughterboard via MysX to this Easy PCB. Dimmer daughterboard is providing 5V on PIN3 (when LM2940CT voltage regulator is used on it). This would bring 5V to output of voltage regulator on Easy PCB so I disconnected PIN3 connection between dimmer daughterboard and Easy PCB. I connected PIN3 from dimmer board by wire to >3.3V power input of Easy PCB instead. Other option I'm thinking of would be not using voltage regulator on dimmer daughterboard at all but use its 12V raw voltage provided by dimmer board via MysX PIN1 (+ raw jumper on Easy PSB) and use voltage regulator (LE33) on Easy PCB only.
      • N
        N
        Nigel31
        Schematic rfm69 version.
        Needs updating, as it shows nrf radio.
        • N Nigel31
          sundberg84S
          sundberg84S
          @njwyborn - you are correct, thanks for noticing! Its been corrected!
          • E
            E
            eMdzeJ
            Hi, I've lipo battery pack with 4,2v maximum voltage (3,6v nominal). Can I safely use it with this board? Do I need any modifications?
            • E eMdzeJ
              sundberg84S
              sundberg84S
              @emdzej - I'm not sure but it's designed for 3.3v. you have to check the rfm radio for Max input voltage on VCC and io. I think it's 3.3v so you might have to regulate down your lipo battery to this.
              • sfozzS
                sfozzS
                sfozz
                Hi can you add the kicad files for the latest rev pls?
                • K
                  K
                  kiesel
                  Has anybody any experience with pcbway? I ordered via the link provided here (7 weeks ago) and only received a message from paypal. I haven't gotten a tracking number and pcbway says they can't help me without an ordernumber (which I don't have).
                  • K kiesel
                    sundberg84S
                    sundberg84S
                    @kiesel - i checked my page as well but I dont have any ordernumbers. I can see some orders to PCB way latest weeks and they are marked as "shipped".
                    @hek - do you have more intel on this?
                    K 1 Reply Last reply
                      K
                      K
                      kiesel
                      @sundberg84
                      I ordered the 3rd of september (paypal mail says this: tirs. 03. sept. 2019 13:04:13 CEST (UTC+2)), are there any orders around that time?
                        @sundberg84, I will try to solve this with @kiesel over PM.
                        • K
                          K
                          kiesel
                          Could you add a 5 pieces option? The reason is the danish customs slaps an additional "fee" of ~24eu on imports over 12eu from china.
                          PCBway let's you choose 5 pieces on their website.
                          I tried using the gerber files but before I can upload them there is a host of settings which I don't know how to set.
                          • K kiesel
                            sundberg84S
                            sundberg84S
                            @kiesel - the number is set to 10 and this is nothing I can change, sorry. You can PM me about which setting you need to set and I can help you.
                              So I have made the adjustment for low power/battery mode (removed the LED, voltage regulator and sleeping most of the time).
                              Im having a hard time to trust my Multimeter at this point... showing 5.1uA in sleep() mode while sending shows almost 2mA! This cant be right???
                              At the moment im all out of boosters... I was sure I had more so I didnt order.
                              What I have done now is uploaded a sketch sleeping 15min, running the vcc check (since I dont have a booster) and reporting it back to me. Lets see what happens...
                              E
                              E
                              evb
                              wrote on last edited by evb
                              #100
                              @sundberg84, I know this is already an old topic, but I was sure that I did read somewhere a sleep consumption of 5µA, so I'm not completely insane :-)
                              I've had recently a question about this in the battery powered topic : https://forum.mysensors.org/topic/4796/battery-powered-sensors/248, because my setup with a modified pro mini (no led and no power regulator) and a connected RFM69HW only, was consuming a 133µA at sleep state.
                              @Yveaux pointed me to the fact that in the beginning of the site article https://www.mysensors.org/build/battery, it was mentioned that a 120µA was to be expected.
                              So how did you get this 5µ sleep consumption?
                              Is it the build quality of the pro mini?
                              I did a test with only a pro mini and the sketch of lowpowerlab and was also measuring 133µA.
                              • E evb
                                sundberg84S
                                sundberg84S
                                #101
                                @evb - Hi, to be hones I don't even remember. I dont have any exact equipment to measure except a normal multimeter, so that can be that my reading is way off, or it was without the radio? Sorry, no documentation about this and no memory at this point. But here is the battery of my EasyPCB RFM + Dallas temp sensor. I changed the batteries 3 months ago as you see and currently is about 87%.
                                E 1 Reply Last reply
                                  E
                                  E
                                  evb
                                  @sundberg84 thanks for the update.
                                  Is the graph done with Grafana & InfluxDb?
                                  • E evb
                                    sundberg84S
                                    sundberg84S
                                    @evb - correct!
                                    H 1 Reply Last reply
                                      @evb - correct!
                                      H
                                      H
                                      hlehoux
                                      @sundberg84
                                      For those who use this wonderfull PCB, it is possible to use it with a regulated 5V input or with a lithium 3.7V battery :: with the following two actions:
                                      • as a booster use a "1.8V 3V 3.7V 5V to 3.3V Boost & Buck Low Noise Regulated Charge Pump 2 in 1 DC/DC Converter"
                                        This will convert anything between 1.8 - 5V to 3.3V
                                        • works with regulated 5V down to 3.3V
                                        • works with lithium battery that start at 3.7V above 3.3, and then after sometime the battery goes down less than 3.3 and is boosted to 3.3
                                      • connect the "BAT" jumper so that input goes through you DC/DC converter
                                      • H hlehoux
                                        @sundberg84
                                        H
                                        H
                                        hlehoux
                                        • sundberg84S
                                          sundberg84S
                                          @hlehoux - nice once! Thanks for sharing!
