  3. Request for contribution - controller selection matrix
27 Posts 12 Posters 12.8k Views 11 Watching
  • fetsF
    fetsF
    fets
    I see that Domiticz supports MYS MQTT can someone explain how, please ?
    Couldn't find anything on that on Wiki.I thought that Domoticz only supported its mqtt format !
    • J
      J
      jkandasa
      Kindly update MyController.org changes. Updated in this doc
      • J jkandasa
        Update done. Thanks @jkandasa !
        • G
          G
          Guillermo Schimmel
          OpenHAB was a little outdated. Updated the column in the editable google sheet. Thanks
          • G Guillermo Schimmel
            Thanks @guillermo-schimmel. I have updated the controller table.
            G 1 Reply Last reply
              G
              G
              Guillermo Schimmel
              @mfalkvidd Hi there. It is still the same table on:
              https://www.mysensors.org/controller
              How can I help in order to update it?
                @guillermo-schimmel The update is a 100% manual process. I looked in the changelog of the Google spreadsheet and updated everything I could find. If something wasn't updated, it's because I was unable to see that it needed to be updated.
                Maybe you could mark the cells that need updating with a different background color (in the Google spreadsheet), to make it easier to find them?
                Preferably, we could find a way to ditch the manual table update and embed the google spreadsheet directly.
                • rejoe2R
                  rejoe2R
                  rejoe2
                  In case someone wants to add FHEM to the controller list, here's the state to date:
                  0_1543595331112_8cb7492f-dc71-441e-a41d-89f3ec6c638f-grafik.png Controller, (Sorted by alphabet, if filled) FHEM
                  Complete list of S & V types supported (V2)
                  S_DOOR Y
                  S_MOTION Y
                  S_SMOKE Y
                  S_LIGHT Y
                  S_BINARY Y
                  S_DIMMER Y
                  S_COVER Y
                  S_TEMP Y
                  S_HUM Y
                  S_BARO Y
                  S_WIND Y
                  S_RAIN Y
                  S_UV Y
                  S_WEIGHT Y
                  S_POWER Y
                  S_HEATER Y
                  S_DISTANCE Y
                  S_LIGHT_LEVEL Y
                  S_ARDUINO_NODE Y
                  S_ARDUINO_REPEATER_NODE Y
                  S_LOCK Y
                  S_IR Y
                  S_WATER Y
                  S_AIR_QUALITY Y
                  S_CUSTOM Y
                  S_DUST Y
                  S_SCENE_CONTROLLER Y
                  S_RGB_LIGHT Y
                  S_RGBW_LIGHT Y
                  S_COLOR_SENSOR Y
                  S_HVAC Y
                  S_MULTIMETER Y
                  S_SPRINKLER Y
                  S_WATER_LEAK Y
                  S_SOUND Y*
                  S_VIBRATION Y
                  S_MOISTURE Y
                  S_INFO Y
                  S_GAS Y
                  S_GPS Y*
                  S_WATER_QUALITY Y*
                  V_TEMP Y
                  V_HUM Y
                  V_STATUS Y
                  V_LIGHT Y
                  V_PERCENTAGE Y
                  V_DIMMER Y
                  V_PRESSURE Y
                  V_FORECAST Y
                  V_RAIN Y
                  V_RAINRATE Y
                  V_WIND Y
                  V_GUST Y
                  V_DIRECTION Y
                  V_UV Y
                  V_WEIGHT Y
                  V_DISTANCE Y
                  V_IMPEDANCE Y
                  V_ARMED Y
                  V_TRIPPED Y
                  V_WATT Y
                  V_KWH Y
                  V_SCENE_ON Y
                  V_SCENE_OFF Y
                  V_HVAC_FLOW_STATE Y
                  V_HVAC_SPEED Y
                  V_LIGHT_LEVEL Y
                  V_VAR1 Y
                  V_VAR2 Y
                  V_VAR3 Y
                  V_VAR4 Y
                  V_VAR5 Y
                  V_UP Y
                  V_DOWN Y
                  V_STOP Y
                  V_IR_SEND Y
                  V_IR_RECEIVE Y
                  V_FLOW Y
                  V_VOLUME Y
                  V_LOCK_STATUS Y
                  V_LEVEL Y
                  V_VOLTAGE Y
                  V_CURRENT Y
                  V_RGB Y
                  V_RGBW Y
                  Advanced (new) types
                  V_ID Y
                  V_UNIT_PREFIX Y*
                  V_HVAC_SETPOINT_COOL Y*
                  V_HVAC_SETPOINT_HEAT Y*
                  V_HVAC_FLOW_MODE Y*
                  V_TEXT Y
                  V_CUSTOM Y
                  V_POSITION Y
                  V_IR_RECORD Y
                  V_PH Y*
                  V_ORP Y*
                  V_EC Y*
                  V_VAR Y*
                  V_VA Y*
                  V_POWER_FACTOR Y*
                  * Untested
                  (sorry for part of the table format has disapperared)
                  Kind regards.
                  rejoe2R 1 Reply Last reply
                  • rejoe2R rejoe2
                    S_DOOR Y
                    S_MOTION Y
                    S_SMOKE Y
                    S_LIGHT Y
                    S_BINARY Y
                    S_DIMMER Y
                    S_COVER Y
                    S_TEMP Y
                    S_HUM Y
                    S_BARO Y
                    S_WIND Y
                    S_RAIN Y
                    S_UV Y
                    S_WEIGHT Y
                    S_POWER Y
                    S_HEATER Y
                    S_DISTANCE Y
                    S_LIGHT_LEVEL Y
                    S_ARDUINO_NODE Y
                    S_LOCK Y
                    S_IR Y
                    S_WATER Y
                    S_AIR_QUALITY Y
                    S_CUSTOM Y
                    S_DUST Y
                    S_RGB_LIGHT Y
                    S_RGBW_LIGHT Y
                    S_COLOR_SENSOR Y
                    S_HVAC Y
                    S_MULTIMETER Y
                    S_SPRINKLER Y
                    S_WATER_LEAK Y
                    S_SOUND Y*
                    S_VIBRATION Y
                    S_MOISTURE Y
                    S_INFO Y
                    S_GAS Y
                    S_GPS Y*
                    S_WATER_QUALITY Y*
                    V_TEMP Y
                    V_HUM Y
                    V_STATUS Y
                    V_LIGHT Y
                    V_PERCENTAGE Y
                    V_DIMMER Y
                    V_PRESSURE Y
                    V_FORECAST Y
                    V_RAIN Y
                    V_RAINRATE Y
                    V_WIND Y
                    V_GUST Y
                    V_DIRECTION Y
                    V_UV Y
                    V_WEIGHT Y
                    V_DISTANCE Y
                    V_IMPEDANCE Y
                    V_ARMED Y
                    V_TRIPPED Y
                    V_WATT Y
                    V_KWH Y
                    V_SCENE_ON Y
                    V_SCENE_OFF Y
                    V_HVAC_FLOW_STATE Y
                    V_HVAC_SPEED Y
                    V_LIGHT_LEVEL Y
                    V_VAR1 Y
                    V_VAR2 Y
                    V_VAR3 Y
                    V_VAR4 Y
                    V_VAR5 Y
                    V_UP Y
                    V_DOWN Y
                    V_STOP Y
                    V_IR_SEND Y
                    V_IR_RECEIVE Y
                    V_FLOW Y
                    V_VOLUME Y
                    V_LOCK_STATUS Y
                    V_LEVEL Y
                    V_VOLTAGE Y
                    V_CURRENT Y
                    V_RGB Y
                    V_RGBW Y
                    V_ID Y
                    V_UNIT_PREFIX Y*
                    V_HVAC_FLOW_MODE Y*
                    V_TEXT Y
                    V_CUSTOM Y
                    V_POSITION Y
                    V_IR_RECORD Y
                    V_PH Y*
                    V_ORP Y*
                    V_EC Y*
                    V_VAR Y*
                    V_VA Y*
                    V_POWER_FACTOR Y*
                    * Untested
                    Kind regards.
                    rejoe2R
                    rejoe2R
                    rejoe2
                    @rejoe2 said in Request for contribution - controller selection matrix:
                    As recently a lot of MySensors features have been added to the official FHEM module (smartSleep, heartbeat, RSSI-requests, OTA), here's the most recent list for addition to the controller matrix overview. Please do not hesitate to contact me for other formats (upload of xls is not allowed here)
                    Last update date / update frequency	FHEM base: continuously/MySensors-Modules: when needed
                    MySensors Types
                    Basic S & V types	All
                    Advanced S & V types	All
                    MYSensors Functionality
                    Heartbeat support	Y
                    node ID generation	Y
                    Ack support	Y
                    OTA support	Y
                    Request	Y
                    Smart sleep	Y
                    Gateways
                    Serial Gateway support	Y
                    LAN Gateway support	Y
                    MQTT gateway support	Y
                    Multiple gateway support	Y*
                    Scripting
                    IFTT alike programming
                    Blockly	n
                    Other
                    Hardware platform(s)
                    Propietary	n
                    Windows	Y
                    Unix	Y
                    Raspberry	Y
                    Other	Y
                    Software
                    Licence/ Open Source	GPL
                    Programming language	Perl
                    Interfaces
                    Web interface	Y
                    Android app	Y**
                    Apple app	Y**
                    Windows app
                    	*limited support for active components like switches or displays directly attached on a GW
                    	**3:rd party
                    S_DOOR	Y
                    S_MOTION	Y
                    S_SMOKE	Y
                    S_LIGHT	Y
                    S_BINARY	Y
                    S_DIMMER	Y
                    S_COVER	Y
                    S_TEMP	Y
                    S_HUM	Y
                    S_BARO	Y
                    S_WIND	Y
                    S_RAIN	Y
                    S_UV	Y
                    S_WEIGHT	Y
                    S_POWER	Y
                    S_HEATER	Y
                    S_DISTANCE	Y
                    S_LIGHT_LEVEL	Y
                    S_ARDUINO_NODE	Y
                    S_LOCK	Y
                    S_IR	Y
                    S_WATER	Y
                    S_AIR_QUALITY	Y
                    S_CUSTOM	Y
                    S_DUST	Y
                    S_RGB_LIGHT	Y
                    S_RGBW_LIGHT	Y
                    S_COLOR_SENSOR	Y
                    S_HVAC	Y
                    S_MULTIMETER	Y
                    S_SPRINKLER	Y
                    S_WATER_LEAK	Y
                    S_SOUND	Y*
                    S_VIBRATION	Y
                    S_MOISTURE	Y
                    S_INFO	Y
                    S_GAS	Y
                    S_GPS	Y*
                    S_WATER_QUALITY	Y*
                    V_TEMP	Y
                    V_HUM	Y
                    V_STATUS	Y
                    V_LIGHT	Y
                    V_PERCENTAGE	Y
                    V_DIMMER	Y
                    V_PRESSURE	Y
                    V_FORECAST	Y
                    V_RAIN	Y
                    V_RAINRATE	Y
                    V_WIND	Y
                    V_GUST	Y
                    V_DIRECTION	Y
                    V_UV	Y
                    V_WEIGHT	Y
                    V_DISTANCE	Y
                    V_IMPEDANCE	Y
                    V_ARMED	Y
                    V_TRIPPED	Y
                    V_WATT	Y
                    V_KWH	Y
                    V_SCENE_ON	Y
                    V_SCENE_OFF	Y
                    V_HVAC_FLOW_STATE	Y
                    V_HVAC_SPEED	Y
                    V_LIGHT_LEVEL	Y
                    V_VAR1	Y
                    V_VAR2	Y
                    V_VAR3	Y
                    V_VAR4	Y
                    V_VAR5	Y
                    V_UP	Y
                    V_DOWN	Y
                    V_STOP	Y
                    V_IR_SEND	Y
                    V_IR_RECEIVE	Y
                    V_FLOW	Y
                    V_VOLUME	Y
                    V_LOCK_STATUS	Y
                    V_LEVEL	Y
                    V_VOLTAGE	Y
                    V_CURRENT	Y
                    V_RGB	Y
                    V_RGBW	Y
                    V_ID	Y
                    V_UNIT_PREFIX	Y*
                    V_HVAC_FLOW_MODE	Y*
                    V_TEXT	Y
                    V_CUSTOM	Y
                    V_POSITION	Y
                    V_IR_RECORD	Y
                    V_PH	Y*
                    V_ORP	Y*
                    V_EC	Y*
                    V_VAR	Y*
                    V_VA	Y*
                    V_POWER_FACTOR	Y*
                    	* Untested
                    • U
                      U
                      user2684
                      During the last year I've invested my spare time in re-designing and re-architecting my old Home Automation project called myHouse which was also acting as a MySensors controller (https://www.mysensors.org/controller/myhouse). Now, I've given the project a brand new name (eGeoffrey - https://www.egeoffrey.com) and despite the basic principles are the same (likewise MySensors support), now is supposed to be way simpler to configure, use, customize and extend. Before doing any change, @AWI is it the correct approach if I delete the existing myHouse entry from the controller section, add a new one for eGeoffrey (since it is replacing it) and do the same with the column of the matrix? (do I need any special permission for editing the spreadsheet?) Thanks!
                      YveauxY mfalkviddM 2 Replies Last reply
                      • U user2684
                        @user2684 Unfortunaltely @AWI hasn't been online recently. Maybe @hek can chip in?
                        • U user2684
                          @user2684 no special permissions needed for the spreadsheet. Rename the column sounds like the easiest way.
                          About https://www.mysensors.org/controller/myhouse, we can either delete it and add a new page, or just rename it.
                            wrote on last edited by hek
                            #23
                            @mfalkvidd, I think he doesn't have permissions to update the mysensors.org page.
                            UPDATE: Hmm, I now see it's owned by user2684... so I guess he CAN update it using the login on openhardware.io.
                            @user2684, just PM or email me new screenshots and textual changes on hek@mysensors.org and I'll update the page.
                            • U
                              U
                              user2684
                              Thanks all, yes I do have privileges to edit pages. Will work on it and when ready publish directly the changes. Should I face any issue in the process I'll get back here. Thanks again!
                              • U
                                U
                                user2684
                                Done it! (https://www.mysensors.org/controller/egeoffrey). I've already removed the legacy myHouse project and updated the spreadsheet. If there is anything wrong in the changes, just let me know. Do I also need to create a subcategory under https://forum.mysensors.org/category/3/controllers? Thanks!
                                  Wow, you've got an market place for plugins already. Cool! And great looking website!
                                  U 1 Reply Last reply
                                    U
                                    U
                                    user2684
                                    @hek thanks! It took us way more than expected to re-architect all the thing but now that is ready, happy with the result so your positive feedback is appreciated :-) Legacy myHouse issue was mainly around extensibility hence this distributed, plugin-based architecture allowing users to package functionalities and/or contents without me doing any change in the core code. And turning it in a cloud-based service (as an option) could be also really easy. But for now the hope is to build a little community around it so to make it evolve further. Just as a starting point :-)
