  3. My Slim 2AA Battery Node
498 Posts 71 Posters 599.4k Views 69 Watching
  • badmannenB
    badmannenB
    badmannen
    wrote on last edited by badmannen
    #471
    Good evening!
    I had a bit of a break from this forum (approx 3-4 years...) And just got back into it . I managed to put a bootloader into my 328p-pu chip
    can anyone just confirm if it is OK to use this bootloader with the version 2.0 board here.
    I understand that it should run at 8Mhz to be stable . so I assumed I could use the bootloader that comes with Arduino IDE ?
    I flashed this one onto the chip at the moment and will start to solder some of my boards soon. but would like to be sure that it is correct before I go too far =)
    atmega328bb.name=ATmega328 on a breadboard (8 MHz internal clock)
    atmega328bb.upload.tool=arduino:avrdude
    atmega328bb.upload.protocol=arduino
    atmega328bb.upload.maximum_size=30720
    atmega328bb.upload.speed=57600
    atmega328bb.bootloader.low_fuses=0xE2
    atmega328bb.bootloader.high_fuses=0xDA
    atmega328bb.bootloader.extended_fuses=0x05
    #atmega328bb.bootloader.path=arduino:atmega
    atmega328bb.bootloader.file=atmega/ATmegaBOOT_168_atmega328_pro_8MHz.hex
    atmega328bb.bootloader.unlock_bits=0x3F
    atmega328bb.bootloader.lock_bits=0x0F
    atmega328bb.bootloader.tool=arduino:avrdude
    atmega328bb.build.mcu=atmega328p
    atmega328bb.build.f_cpu=8000000L
    atmega328bb.build.core=arduino:arduino
    atmega328bb.build.variant=arduino:standard
    rPi 3 - UNO R3 - Mini - Nano - custom
    • badmannenB badmannen
      Good evening!
      #472
      @badmannen Welcome back. The good news is that there's now a mysensors bootloader, which is even better because it allows over-the-air firmware updates for the atmega328p: https://www.mysensors.org/about/fota
      badmannenB 1 Reply Last reply
      • badmannenB
        badmannenB
        badmannen
        Daaaaang ... it is a good time to be alive and come back to this I see =) ... thanks a million to you guys that made that one .. that certainly makes changes a whole lot less painful!
          badmannenB
          badmannenB
          badmannen
          @neverdie Alright , that took me a couple of days of fighting with Arduino/Linux/windows/drivers/bootloaders etc etc etc but I got it all running with my updated gateway+repeater-node + mailbox-node. did not try the update function yet but surely it should work. just need one or two more repeater-nodes since I have way to thick cement walls here for this signal.
          • badmannenB
            badmannenB
            badmannen
            OK I had some fun the last couple of days and actually got something done =D !
            Managed to update my gateway and repeater-nodes to latest version and boot-loaded all nodes and future nodes so they are FOTA enabled .
            So far I managed to assemble 3 nodes and after a bit of swearing and soldering and de-soldering and re-soldering I got:
            1 - DHT11 TEMP / HUM node, on Battery (Slim 2AA) - surprisingly accurate actually
            2 - DOOR-SWITCH - on Battery (Slim 2AA) - to be used in my mailbox, got the idea from someone here in the forums, so thank you, I don´t remember who it was since I probably read a million posts by now =D
            3 - a 220V Relay switch, with the PA LN radio, and works as repeater ( runs on a NANO )
            just wanted to say a huge thanks to the MySensors group and all people here on the forum for helping me get started (Had a little break for a couple of years =)
              Let us know when you get it to FOTA update.
              badmannenB 2 Replies Last reply
                badmannenB
                badmannenB
                badmannen
                @neverdie
                Just tried it by mounting an "empty" 328P in the node just with the
                fuses set to:
                0xE2
                0xDA
                0xFE
                and with the MYSBootloader .
                Amazing ! . worked at the first try! (this time around =D )
                ( tried and failed a couple of times earlier, but I know I burned 0xFD instead of 0xFE so set the BOD to the wrong value, and that does not work )
                  badmannenB
                  badmannenB
                  badmannen
                  @neverdie Actually... I run into another problem ..
                  After I make a FOTA and upload a sketch . it runs as it should, no problem.
                  But if I try to update it again , it never tries to upload the sketch to the node.
                  The only thing I could find that was clever to do to make it work ok with a battery node was to use smartSleep();
                  which I do ... is there anything else in the code that needs to be present ?
                    Hopefully someone who knows can chime in.
                      badmannenB
                      badmannenB
                      badmannen
                      @neverdie OK, that person who knows something is now ME ! =D ... RTFM ... as always , it worked strangely enough to update ONCE with some slightly wrong Fuses set... reloaded the bootloader with soem correct fuses agian .. ( hopefully alst time .. and VOILA! now it works to update the node multiple times .. yeaa.
                        What were the winning fuse settings that you finally settled on using? Trust me, a year from now you won't remember, and you'll be glad you posted it.
                        • badmannenB
                          badmannenB
                          badmannen
                          OK MY solution was actually the fuses that I said earlier . but confused myself by changing them back and forth a couple of times and downgraded Arduino to the previous version etc.
                          So the fuses for my barebone 328P are:
                          proMYSBL8.bootloader.extended_fuses=0xFE
                          the biggest issue I had was probably with ARduino IDE .. that one I enver manged to set the fuses ( I read somewhere it should.. but maybe I´m wrong) . Anyway it works when I set the fuses and upload it with AVRDUDESS.
                          (note: hello me 1 year into the future, just do what I say ! )
                          • badmannenB
                            badmannenB
                            badmannen
                            #483
                            I just add another note to myself ( And anyone else that lost their hair wondering why the bootloader was lost....)
                            DO NOT UPLOAD SKETCH ONLY WITH USBASP ... it deletes the bootloader .
                            yes I know it is mentioned on the foru m.. just found it .. but I mention it again...
                              badmannenB
                              badmannenB
                              badmannen
                              @badmannen
                              and here is a good simple explanation of the fuses
                              http://www.martyncurrey.com/category/atmega/
                                FYI: If you run the ceramic resonator at 8mhz, with the zero wake up fuse setting, you can wake the atmega328p up in less than 4usec. This is a huge power savings compared to all other options.
                                  badmannenB
                                  badmannenB
                                  badmannen
                                  @neverdie aa thanks for the info. Might be useful for some other nodes I will do.
                                    #487
                                    @badmannen You're welcome. I even measured it on an oscope just to be sure, so I'm certain it is true.
                                    • badmannenB
                                      badmannenB
                                      badmannen
                                      This style?
                                      € 1,09 8%OFF | 20pcs Ceramic Resonators ZTT 4M 6M 8M 10M 12M 16M 4/6/8/10/12/16MHZ DIP-3 Crystal Frequency Element
                                      https://s.click.aliexpress.com/e/mRfXWk8Nd
                                        This style?
                                        @badmannen no. It's built in. You already have it.
                                          badmannenB
                                          badmannenB
                                          badmannen
                                          @neverdie aa ok sorry got confused there for a second. I'm running the internal, so I guess I will pop them off again now then and burn that fuse for a quicker startup 👍🏻
