  3. My Slim 2AA Battery Node
498 Posts 71 Posters 584.8k Views 69 Watching
    Look also at AAA/AA size LiFePO4 as it will need just one cell instead of 2 as the normal alkaline/nimh ones
    • joaoabsJ
      joaoabsJ
      joaoabs
      wrote on last edited by joaoabs
      #465
      Maybe a silly question, but where did you get the library for the Vcc.h ?
       #include <Vcc.h>
      compilation terminated.
      exit status 1
      Error compiling for board ATmega328.
      I couldn't find any VCC in the MySensors library set and also doing a search for vcc in the Arduino Library Manager I can't find it either...
      [EDIT] : Found it in other thread. Leaving here for reference: https://github.com/Yveaux/arduino_vcc
        martim
        @gohan said in My Slim 2AA Battery Node:
        LiFePO4
        • ร
          ร
          รอเรือ
          I have 29 panels of the latest version of the PCB. It's more than I can use. Please PM me if you are interested in them.
          • I
            I
            iteafreely
            As information for everyone, I suggest that if you get sockets for the ATMEGA, that you get
            these: alt text
            rather than these: alt text
            The reason being that the former have a much wider gap in the middle than the later. Because of that, the .1 puff #104 monolithic multilayer 5.08mm pitch capacitors called for in the BOM fit nicely. If you use the later ones, you will need to remove material from the socket to fit them.
            • I
              I
              iteafreely
              I just made a new case for a LiFePO4 magnetic sensor implementation of this. Thanks for the excellent work on this handy node design!
              https://www.thingiverse.com/thing:3034907!
              a picture
                With 2 mini solar panels on the sides and an harvesting circuit, you could run it indefinitely 😁
                • badmannenB
                  badmannenB
                  badmannen
                  wrote on last edited by badmannen
                  #471
                  Good evening!
                  I had a bit of a break from this forum (approx 3-4 years...) And just got back into it . I managed to put a bootloader into my 328p-pu chip
                  can anyone just confirm if it is OK to use this bootloader with the version 2.0 board here.
                  I understand that it should run at 8Mhz to be stable . so I assumed I could use the bootloader that comes with Arduino IDE ?
                  I flashed this one onto the chip at the moment and will start to solder some of my boards soon. but would like to be sure that it is correct before I go too far =)
                  atmega328bb.name=ATmega328 on a breadboard (8 MHz internal clock)
                  atmega328bb.upload.tool=arduino:avrdude
                  atmega328bb.upload.protocol=arduino
                  atmega328bb.upload.maximum_size=30720
                  atmega328bb.upload.speed=57600
                  atmega328bb.bootloader.low_fuses=0xE2
                  atmega328bb.bootloader.high_fuses=0xDA
                  atmega328bb.bootloader.extended_fuses=0x05
                  #atmega328bb.bootloader.path=arduino:atmega
                  atmega328bb.bootloader.file=atmega/ATmegaBOOT_168_atmega328_pro_8MHz.hex
                  atmega328bb.bootloader.unlock_bits=0x3F
                  atmega328bb.bootloader.lock_bits=0x0F
                  atmega328bb.bootloader.tool=arduino:avrdude
                  atmega328bb.build.mcu=atmega328p
                  atmega328bb.build.f_cpu=8000000L
                  atmega328bb.build.core=arduino:arduino
                  atmega328bb.build.variant=arduino:standard
                  rPi 3 - UNO R3 - Mini - Nano - custom
                  • badmannenB badmannen
                    Good evening!
                    #472
                    @badmannen Welcome back. The good news is that there's now a mysensors bootloader, which is even better because it allows over-the-air firmware updates for the atmega328p: https://www.mysensors.org/about/fota
                    badmannenB 1 Reply Last reply
                    • badmannenB
                      badmannenB
                      badmannen
                      Daaaaang ... it is a good time to be alive and come back to this I see =) ... thanks a million to you guys that made that one .. that certainly makes changes a whole lot less painful!
                        badmannenB
                        badmannenB
                        badmannen
                        @neverdie Alright , that took me a couple of days of fighting with Arduino/Linux/windows/drivers/bootloaders etc etc etc but I got it all running with my updated gateway+repeater-node + mailbox-node. did not try the update function yet but surely it should work. just need one or two more repeater-nodes since I have way to thick cement walls here for this signal.
                        • badmannenB
                          badmannenB
                          badmannen
                          OK I had some fun the last couple of days and actually got something done =D !
                          Managed to update my gateway and repeater-nodes to latest version and boot-loaded all nodes and future nodes so they are FOTA enabled .
                          So far I managed to assemble 3 nodes and after a bit of swearing and soldering and de-soldering and re-soldering I got:
                          1 - DHT11 TEMP / HUM node, on Battery (Slim 2AA) - surprisingly accurate actually
                          2 - DOOR-SWITCH - on Battery (Slim 2AA) - to be used in my mailbox, got the idea from someone here in the forums, so thank you, I don´t remember who it was since I probably read a million posts by now =D
                          3 - a 220V Relay switch, with the PA LN radio, and works as repeater ( runs on a NANO )
                          just wanted to say a huge thanks to the MySensors group and all people here on the forum for helping me get started (Had a little break for a couple of years =)
                            Let us know when you get it to FOTA update.
                            badmannenB 2 Replies Last reply
                              badmannenB
                              badmannenB
                              badmannen
                              @neverdie
                              Just tried it by mounting an "empty" 328P in the node just with the
                              fuses set to:
                              0xE2
                              0xDA
                              0xFE
                              and with the MYSBootloader .
                              Amazing ! . worked at the first try! (this time around =D )
                              ( tried and failed a couple of times earlier, but I know I burned 0xFD instead of 0xFE so set the BOD to the wrong value, and that does not work )
                                badmannenB
                                badmannenB
                                badmannen
                                @neverdie Actually... I run into another problem ..
                                After I make a FOTA and upload a sketch . it runs as it should, no problem.
                                But if I try to update it again , it never tries to upload the sketch to the node.
                                The only thing I could find that was clever to do to make it work ok with a battery node was to use smartSleep();
                                which I do ... is there anything else in the code that needs to be present ?
                                  Hopefully someone who knows can chime in.
                                    badmannenB
                                    badmannenB
                                    badmannen
                                    @neverdie OK, that person who knows something is now ME ! =D ... RTFM ... as always , it worked strangely enough to update ONCE with some slightly wrong Fuses set... reloaded the bootloader with soem correct fuses agian .. ( hopefully alst time .. and VOILA! now it works to update the node multiple times .. yeaa.
                                      What were the winning fuse settings that you finally settled on using? Trust me, a year from now you won't remember, and you'll be glad you posted it.
                                      • badmannenB
                                        badmannenB
                                        badmannen
                                        OK MY solution was actually the fuses that I said earlier . but confused myself by changing them back and forth a couple of times and downgraded Arduino to the previous version etc.
                                        So the fuses for my barebone 328P are:
                                        proMYSBL8.bootloader.extended_fuses=0xFE
                                        the biggest issue I had was probably with ARduino IDE .. that one I enver manged to set the fuses ( I read somewhere it should.. but maybe I´m wrong) . Anyway it works when I set the fuses and upload it with AVRDUDESS.
                                        (note: hello me 1 year into the future, just do what I say ! )
                                        • badmannenB
                                          badmannenB
                                          badmannen
                                          #483
                                          I just add another note to myself ( And anyone else that lost their hair wondering why the bootloader was lost....)
                                          DO NOT UPLOAD SKETCH ONLY WITH USBASP ... it deletes the bootloader .
                                          yes I know it is mentioned on the foru m.. just found it .. but I mention it again...
