  3. 💬 MySensors Linky
💬 MySensors Linky
mysensorslinkyedfenedismysensorarduinoarduino pro mini
12 Posts 6 Posters 2.6k Views 4 Watching
  • openhardware.ioO
    openhardware.ioO
    openhardware.io
    https://www.openhardware.io/view/744/MySensors-Linky
    hekH 1 Reply Last reply
      @Fumée-Bleue
      Maybe you could add an image and description to the project?
      • jeremushkaJ
        jeremushkaJ
        jeremushka
        Nice project. I have done something with jeedom plugin through USB connection in a raspberry pi. However, how do you auto power supply your system?
        On my linky i just use the 2 pins I1 and I2 to get the information and then i have 4m of cables until my raspberry pi to power on all the system. With NRF will be more usefull.
        • Fumée BleueF
          Fumée BleueF
          Fumée Bleue
          jeremushka,
          I updated the project description and added arduino sources. The pins I1 and A are used for power supply, and I2 for the datas.
            secator
            hello,
            well done for your project. I am interested but I have an error during the compilation. I'm bad at programming. can you help me.
            C:\Users\Maison\Downloads\TeleinfoMySensors\TeleinfoMySensorsDecode.ino: In function 'void traitement_trame(char*, int)':
            C:\Users\Maison\Downloads\TeleinfoMySensors\TeleinfoMySensorsDecode.ino:69:7: warning: unused variable 'i' [-Wunused-variable]
            int i;
            C:\Users\Maison\Downloads\TeleinfoMySensors\TeleinfoMySensorsDecode.ino:65:39: warning: unused parameter 'len' [-Wunused-parameter]
            void traitement_trame(char *buff, int len)
            Le croquis utilise 9328 octets (30%) de l'espace de stockage de programmes. Le maximum est de 30720 octets.
            Les variables globales utilisent 921 octets (44%) de mémoire dynamique, ce qui laisse 1127 octets pour les variables locales. Le maximum est de 2048 octets.
            thank you
            • S secator
              hello,
              int i;
              thank you
              @secator are you getting any errors? Doesn’t look like any problems in the part that you posted.
                secator
                @secator said in 💬 MySensors Linky:
                int i;
                this messages are normal ?????
                • S secator
                  int i;
                  @secator maybe not normal, but definitely labelled as warnings and not errors.
                    secator
                    Do you use an Arduino Pro Mini 5v or 3.3V ?
                    • Fumée BleueF
                      Fumée BleueF
                      Fumée Bleue
                      wrote on last edited by Fumée Bleue
                      @Secator,
                      I use an Arduino pro mini 3.3 V in order to voltage compatible with the NRF24L01
                      • Fumée BleueF
                        Fumée BleueF
                        Fumée Bleue
                        I created an 1.0.4 version without warning compilation. I removed "i" and "len" unnecessary variables.
                          secator
                          thanks for you reply Fumée Bleue.
