  2. Announcements
  3. MySensors 2.3.2 released
28 Posts 14 Posters 17.0k Views 13 Watching
  • tekkaT
    tekkaT
    tekka
    wrote on last edited by tekka
    Yet another early holiday gift, MySensors 2.3.2 has finally been released!
    Highlights
    • Add support for RPI4
    • Transport and crypto HAL update
    • Rename "soft ack" to echo
    • Add log parser
    • RF24 improvements
    ...and many other bug fixes and tweaks
    Release notes and changelog: https://github.com/mysensors/MySensors/releases/tag/2.3.2
    Important information:
    If you encounter compilation issues, update your board definitions:
    • AVR 1.8.2
    • ESP8266 2.6.2
    • ESP32 1.0.4
    • SAMD 1.8.4
    • nRF5 0.6.0 (Sandeep Mistry)
    • STM32F1 2019.12.8 (stm32duino)
    Special thanks to the following people who have contributed code to this release:
    • Alfredo
    • desander
    • hannesweisbach
    • ltigges
    • Mikael Falkvidd
    • Patrick Fallberg
    • pragtich
    • Rik Jansen
    • tekka
    • Yveaux
    ...and a little teaser: 2.4 will come with a set of new features some of you have been waiting for... stay tuned :)
    J 1 Reply Last reply
    • alowhumA
      alowhumA
      alowhum
      Exciting! Next Christmas? :-)
      Practically: will code that uses ACK still work ok? I believe the answer was 'no' earlier, but I want to make sure.
      • alowhumA alowhum
        @alowhum the real ack still works the same way as before.
        The stuff that was called ack but wasn't ack and confused the hell out of everybody still works the same way as before, except that the naming is now "echo" to better reflect what it actually does (and has been doing all along). See https://github.com/mysensors/MySensors/pull/1292 for more information.
        • alowhumA
          alowhumA
          alowhum
          Ok, but practically: I have a lot of Candle users whose version of MySensors will auto-update. But the code they will be uploading still has:
            if( message.isAck() ){
              Serial.println(F("-Got echo"));
              return;
          So.. I should quickly change the code to also accomodate Echo. The question is: how?
          Will this work?
            if( message.isAck() || message.isEcho()){
              return;
          tekkaT 1 Reply Last reply
          • alowhumA alowhum
                return;
            Will this work?
                return;
            tekkaT
            tekkaT
            tekka
            @alowhum No need to substitute isAck() - it is marked deprecated but remains fully functional in the 2.x code. However, it is advisable to use isEcho() in the future to avoid confusions.
            alowhumA 1 Reply Last reply
            • tekkaT tekka
              alowhumA
              alowhumA
              alowhum
              Thanks @tekka, that's a load off my mind :-)
              Is there a way to use #define based on the version of the library?
              • alowhumA alowhum
                @alowhum yes you can use the macros defined in https://github.com/mysensors/MySensors/blob/development/core/Version.h#L49
                • mfalkviddM
                  or https://www.mysensors.org/apidocs/group__Versiongrp.html#details
                  • franz-unixF
                    franz-unixF
                    franz-unix
                    Hi guys, thanks for this release! :+1: Tested with a Pi 4 and a dual ethernet gateway (RFM69 + NRF24): it works!
                    My /boot/config.txt is here.
                    • D
                      djvl
                      Hi, thanks as well! Upgraded half of all my sensor nodes without any issues so far.
                      • pvojP
                        pvojP
                        pvoj
                        Thank you for the new version!
                        I run my network on 2.3.1. Should I update the serial gateway to 2.3.2 (or stay with 2.3.1) and leave some of my nodes on 2.3.1 and the new ones on 2.3.2?
                        Are they compatible?
                        • pvojP pvoj
                          @pvoj they are compatible so you can do any way you like
                          • K
                            K
                            keithJ
                            hi, i upgraded to 2.3.2 and my serial gateway stopped working in openhab, so i had to revert back to 2.3.1.
                            I can only think this is because the mysensors binding also has to be upgraded?
                              minousoso
                              Banned
                                minousoso
                                Banned
                                @mfalkvidd I can only think this is because the mysensors binding also has to be upgraded?
                                • M minousoso
                                  @minousoso sorry, I don't know. I don't use Openhab.
                                  • EmeE
                                    EmeE
                                    Eme
                                    wrote on last edited by Eme
                                    Upgraded MS library and my my serial gateway sketch from 2.0.0 this evening - went well. Then noticed Nodes nolonger connect... Status LEDs no longer blick. Tried updating one node to 2.3.2 but it still won't conect. Is there a step by step guide? I have over 10 other nodes that Domotics can't find.
                                    skywatchS 1 Reply Last reply
                                    • EmeE Eme
                                      skywatchS
                                      skywatchS
                                      skywatch
                                      @Eme DId you erase the eeprom using the mysensors clear eeeprom program? If not then run that once and try again.
                                      EmeE 1 Reply Last reply
                                      • skywatchS skywatch
                                        EmeE
                                        EmeE
                                        Eme
                                        @skywatch thanks for the update. Should l write this sketch to the Gateway alone, on each node or on both? Are there any step by step guides to gracefully migrate with? I'm very cautious, I've nodes in faraway places, wouldn't want to have to start all over again.
                                        • EmeE Eme
                                          EmeE
                                          EmeE
                                          Eme
                                          @Eme cleared eeprom with the sketch and loaded the Gateway Serial. I now have an error for an #include <nrf.h> I've updated boards and libraries but still can't get past the error
                                          "NRFS Radio is not supported for this platform. " does this mean my Serial GW can't be upgraded since l use NRF24 radios? What am l fling wrong? All my nodes are down. Please help.
