  3. Help: Some explanation requested regarding NACK
26 Posts 5 Posters 7.0k Views 4 Watching
  • O Omemanti
    oke,
    well will look into the lost mssg.
    But my biggest question might be, why the node thinks they are NACK, but my gate tells me their fine?
    @Omemanti Because the node can't receive the ack message so it assumes it's lost: could the the gateway didn't receive it or the node itself couldn't receive the ack from gateway. It could me many reasons, so you need to address it one by one until you find it 😀
    • O
      O
      Omemanti
      @gohan said in Help: Some explanation requested regarding NACK:
      mjah, ofcourse,
      Well I'll build me some more of these, see If the same things happen with some other nodes.
      thnx for the help so far!
      • O
        O
        Omemanti
        wrote on last edited by Omemanti
        After some time off I made more nodes. but somehow they all give me NACK's. (also changed the gateway, antennas and added more caps.)
        The strange thing still is that even if I get NACK's the gateway seems the handle them..
        Should I just accept this? Or am I missing something?
        MYSController :
        291	27/07/2017 22:46:03	RX	15 - Zolder	0 - S_HUM	C_SET	NO	V_HUM	49.1
        292	27/07/2017 22:46:09	RX	15 - Zolder	1 - S_TEMP	C_SET	NO	V_TEMP	25.5
        293	27/07/2017 22:46:09	RX	15 - Zolder	0 - S_HUM	C_SET	NO	V_HUM	49.2
        294	27/07/2017 22:46:16	RX	15 - Zolder	1 - S_TEMP	C_SET	NO	V_TEMP	25.5
        295	27/07/2017 22:46:16	RX	15 - Zolder	0 - S_HUM	C_SET	NO	V_HUM	49.2
        296	27/07/2017 22:46:23	RX	15 - Zolder	1 - S_TEMP	C_SET	NO	V_TEMP	25.5
        297	27/07/2017 22:46:23	RX	15 - Zolder	0 - S_HUM	C_SET	NO	V_HUM	49.2
        Serial Monitor
        227573 !TSF:MSG:SEND,15-15-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=5,st=NACK:49.1
        227655 !TSM:READY:UPL FAIL,STATP
        227885 MCO:SLP:MS=5000,SMS=0,I1=255,M1=255,I2=255,M2=255
        227950 MCO:SLP:TPD
        227966 MCO:SLP:WUP=-1
        227999
        Loop
        228524 !TSF:MSG:SEND,15-15-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=NACK:25.5
        228982 !TSF:MSG:SEND,15-15-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=1,st=NACK:49.2
        229294 MCO:SLP:MS=5000,SMS=0,I1=255,M1=255,I2=255,M2=255
        229359 MCO:SLP:TPD
        229376 MCO:SLP:WUP=-1
        229408
        Loop
        229933 !TSF:MSG:SEND,15-15-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=2,st=NACK:25.5
        230391 !TSF:MSG:SEND,15-15-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=3,st=NACK:49.2
        230703 MCO:SLP:MS=5000,SMS=0,I1=255,M1=255,I2=255,M2=255
        230768 MCO:SLP:TPD
        230785 MCO:SLP:WUP=-1
        230817
        Loop
        231342 !TSF:MSG:SEND,15-15-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=4,st=NACK:25.5
        231800 !TSF:MSG:SEND,15-15-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=5,st=NACK:49.2
        231882 !TSM:READY:UPL FAIL,STATP
        232112 MCO:SLP:MS=5000,SMS=0,I1=255,M1=255,I2=255,M2=255
        232177 MCO:SLP:TPD
        I should add that booting up takes a couple of tries, but after a minute of the folling it pulls through and starts the previous shenanigans.
        32 TSM:INIT
        49 TSF:WUR:MS=0
        81 TSM:INIT:TSP OK
        98 TSM:INIT:STATID=15
        131 TSF:SID:OK,ID=15
        147 TSM:FPAR
        163 TSM:FPAR:STATP=0
        196 TSM:ID
        212 TSM:ID:OK
        229 TSM:UPL
        393 !TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
        2490 TSM:UPL
        2654 !TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
        4751 TSM:UPL
        4915 !TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
        7012 TSM:UPL
        7176 !TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
        9273 !TSM:UPL:FAIL
        9289 TSM:FPAR
        9306 TSM:FPAR:STATP=0
        9338 TSM:ID
        9338 TSM:ID:OK
        9371 TSM:UPL
        64274 TSM:ID
        64290 TSM:ID:OK
        64307 TSM:UPL
        64487 !TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
        66584 TSM:UPL
        66748 !TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
        66846 TSF:MSG:READ,0-0-15,s=255,c=3,t=25,pt=1,l=1,sg=0:1
        66912 TSF:MSG:PONG RECV,HP=1
        66945 TSM:UPL:OK
        66961 TSM:READY:ID=15,PAR=0,DIS=1
        67158 !TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=NACK:0100
        69402 !TSF:MSG:SEND,15-15-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=1,st=NACK:2.1.1
        69648 !TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=2,st=NACK:0
        69746 TSF:MSG:READ,0-0-15,s=255,c=3,t=6,pt=0,l=1,sg=0:M
        70172 !TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=11,pt=0,l=6,sg=0,ft=3,st=NACK:Zolder
        70418 !TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=4,st=NACK:1.0
        70860 !TSF:MSG:SEND,15-15-0-0,s=0,c=0,t=7,pt=0,l=0,sg=0,ft=5,st=NACK:
        70942 !TSM:READY:UPL FAIL,STATP
        71286 !TSF:MSG:SEND,15-15-0-0,s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=NACK:
        71712 !TSF:MSG:SEND,15-15-0-0,s=2,c=0,t=4,pt=0,l=0,sg=0,ft=1,st=NACK:
        71811 MCO:REG:REQ
        71974 !TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=2,st=NACK:2
        74219 !TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=3,st=NACK:2
        76464 !TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=4,st=NACK:2
        78708 !TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=5,st=NACK:2
        78790 !TSM:READY:UPL FAIL,STATP
        80805 MCO:BGN:STP
        Si7021 Found
        Setup compleet
        80969 MCO:BGN:INIT OK,TSP=1
          it seems as the node can't receive correctly or the gw is not sending correctly. How far are they? If you put them a couple of meters apart do you see any change?
          • O
            O
            Omemanti
            The node gateway is in the room below me (wooden floors) about 2 to 3 meters from my node.
            • O
              O
              Omemanti
              Funny Part still is, that once the connection is made, everything also if produced with a NACK is received by the controller. thats what im curious about. If I get errors, why does the controllers receive them without bottering.
                As I said, the GW is receiving the packet correctly but then the node doesn't get a good response so it throws a NACK. You could try and put them in same room and see if gets better or change channel just to avoid a possible interference
                • O
                  O
                  Omemanti
                  How can I change the channel? Can you point me in the right direction.?
                    Go in myconfig.h and search for "channel", you should find it in the nrf24 section, change the default channel there and recompile all your nodes and gateway
                    • O
                      O
                      Omemanti
                      Stupid question.. because I use the rfm69. Will the also comply?
                        Of course not. What version of rfm69 and frequency are you using? Are you sure you got the antenna of the right size?
                        • O
                          O
                          Omemanti
                          Rfm69w 868mhz , springcoil antenna from ebay.
                          will test a long single wire right away.
                          • O
                            O
                            Omemanti
                            Springcoil on the gw, straight line on the node, still the same
                            • O
                              O
                              Omemanti
                              Thnx for the help so far, Ill let it rest for a while, Im thinking of rebuilding the whole thing..
                              K 1 Reply Last reply
                              • O Omemanti
                                K
                                K
                                kiesel
                                @Omemanti
                                Where you able to solve this? I am also experiencing a lot of NACKs in my rfm69 network (868mhz)
                                O 1 Reply Last reply
                                • K kiesel
                                  @Omemanti
                                  O
                                  O
                                  Omemanti
                                  @kiesel said in Help: Some explanation requested regarding NACK:
                                  Nope, not that I can remember.
                                  BTW: I ditched the rfm69 and moved over to the NRF52.
                                  R 1 Reply Last reply
                                  • O Omemanti
                                    R
                                    R
                                    ricmail85
                                    @Omemanti
                                    I had exactly the same issue with Rfm69 and latest version of mysensors. The only solution I found is to use the 2.2.0 version. With this everything works perfectly.
                                    I don't know why with latest releases the messages are NACK even if they actually reach the gateway.
                                    • R ricmail85
                                      @Omemanti
                                      K
                                      K
                                      kiesel
                                      @ricmail85 I solved my problem by soldering a cable to the reset pin of the chip and the (in my case) raspberry pi. This or the dupont wires I used were glitchy :D
                                      • K kiesel
                                        R
                                        R
                                        ricmail85
                                        @kiesel thanks for reporting! I've also a Raspberry gateway but I left the Rfm69 reset pin unconnected. How did you connect it?
                                        • R ricmail85
                                          K
                                          K
                                          kiesel
                                          wrote on last edited by kiesel
                                          #26
                                          @ricmail85 sorry for the late reply. I soldered it to a free pin on the pi and reconfigured the gateway.
                                          Use this as part of your configure
                                          --extra-cxxflags="-DMY_RFM69_RST_PIN=29"
                                          If you connected to pi pin 29.
