  3. serial reading
serial reading
34 Posts 5 Posters 19.6k Views 2 Watching
  • E Offline
    E Offline
    epierre
    I've managed to make my first emaitter/receptor !
    Now I'm trying to read from the serial port on the controller and get
    0;0;4;11;Message available on pipe 1
    0;0;4;11;Sent ack msg to 255
    0;0;4;11;Rx: fr=255,to=0,la=255,ci=255,mt=4,t=5,cr=136(ok):
    255;255;4;5;
    serial api documentation says the message is "radioId;childId;messageType;subType;payload\n", but I can't match them all given the sensor is an humidity DHT11.
    in a perl script reading the serial interface I get only "255 255 4 5", not the last value, any clue ?
    • E Offline
      E Offline
      epierre
      I restarted both, it seems the sensor can't get an id
      Sensor:
      Started sensor. 0 0 0 0
      Relay=0, distance=1 0 0 0 0
      No radio id found in EEPROM fetching one 0 0 0 0
      from sensor net gateway
      Relaying message back to gateway.
      Tx: fr=255,to=0,la=255,ne=0,ci=255,mt=4,ty=5,cr=136:
      Ack: received OK
      Ack: received OK
      Gateway:
      0;0;4;11;Arduino startup complete.
      any hint why the gateway doesn't answer ?
      • E Offline
        E Offline
        epierre
        other point: I have the external antenna... and tried the gw.begin(AUTO, RF24_PA_LOW) but I get:
        SerialGateway.ino: In function ‘void setup()’:
        SerialGateway:50: error: invalid conversion from ‘int’ to ‘rf24_pa_dbm_e’
        SerialGateway:50: error: initializing argument 1 of ‘void Gateway::begin(rf24_pa_dbm_e, uint8_t, rf24_datarate_e, void ()(char))’
        any hint ?
        I've moved to a standard emitter, same issue as above
        • W Offline
          W Offline
          wannabee
          225;255;4;5 is the first message sent from a node at startup if it hasn't a RADIO_ID in it's EEPROM.
          255 is the startup ID
          255 is node or the arduino it self.
          4 is internal message
          5 is I_REQUEST_ID
          The node expect to get a
          255;255:4;5;<RAIDO_ID_THAT_YOU_WANT_TO_ASSIGN_TO_THE_NODE>
          It's an automated way to assign RADIO_ID from the controller. usally a Vera or in your case your perl script needs to do that.
          Or if I rember correctly you can set the RAIDO_ID in the arduion when compiling the code:
          change in the .ino file.
          sensors.begin();
          to
          sensors.begin(<RAIDO_ID_THAT_YOU_WANT_TO_ASSIGN_TO_THE_NODE>);
          To decode the messages sent to and from a node check the tables in http://www.mysensors.org/build/sensor_api#the-serial-protocol
          /WB
          • E Offline
            E Offline
            epierre
            Thanks for your answer, this is what I thought but I don't understand why it can't get the node from the gateway ? I flashed it again but with no more success.
            The correct method is gw.begin(1) in my case.
            Now it answers with all the presentation, but get stuck in sending mesurement unit:
            0;0;4;11;Rx: fr=1,to=0,la=1,ci=255,mt=4,t=13,cr=73(ok):
            • E Offline
              E Offline
              epierre
              it looks like the gateway never answers, any hint ? bad wiring ? other issue ?
              • E Offline
                E Offline
                epierre
                similar issue here, I regroup it:
                link text
                • H Offline
                  H Offline
                  Controller normally answer the unit setting requests from sensor. You have to answer manually (or from your perl program).
                  Check the Troubleshooting section on our website if you're unable to communicate.
                  E 1 Reply Last reply
                  • H hek
                    E Offline
                    E Offline
                    epierre
                    @hek right, I've not read thoroughly what @wannabee told me about who sets the ID. I'll know it for the next time.
                    Should I answer also for the metric ?
                    I have a strange behavior having commented out the metric line although they are close::
                    0;0;4;11;Relaying message back to gateway.
                    0;0;4;11;Tx: fr=0,to=0,la=0,ne=0,ci=255,mt=4,ty=13,cr=52:
                    0;0;4;11;Ack: receive timeout
                    • W Offline
                      W Offline
                      wannabee
                      You perl program needs to tell the arudion Gateway if it Imperial or Metric it should you for it's number. The gateway will forward that information to the node
                      Here is post where I explain how it works.
                      http://forum.mysensors.org/topic/62/#315
                      Basicly the arduion gatweway don't controll high level stuff. It only controlls the low level stuff. the raido communication.
                      Your perl program needs to do all the higlevel stuff like responed to request from the network about raido_id, metric system, storing the data,etc. This is what the vera does. you are replacing the vera with your program so now you have to do all the stuff. a quick way forward is to translate https://github.com/mysensors/Vera/blob/master/L_Arduino.lua to perl. You have to build some more function since the Vera is doing stuff like storing data and configuration hat is not in the lua-file.
                      This is what I have done in python see https://github.com/wbcode/ham and it transform the mysensor api to/from openhab api.
                      /WB
                      • E Offline
                        E Offline
                        epierre
                        perfect, this is what I was searching for...
                        I'm too much accustomed to RFX433 or z-Wave that handles many things themself, I now understand that only the basic is here.
                        I can read easily lua, logic can be simple, afterward I have my scripts, in fact I thought of doing the bidirectionnal integration with domoticz and/or cosm/xively for I've got already many of it. For the first, I guess some local logic must be implemented, discovered devices can be created through JSON, and then updated/queried as you already know, so the glue is possible ;-)
                        J 1 Reply Last reply
                        • E epierre
                          J Offline
                          J Offline
                          jendrush
                          @epierre +1 for Domoticz integration
                          Do you want to make gateway working in the same way as RFX433?
                          • E Offline
                            E Offline
                            epierre
                            @jendrush could be a possibility... but to have it exaclty the same, the gateway should do all the work meaning push when a new node is discovered, give all values... the whole vera programm should be built inside the arduino... I don't know how it would fit, but in the meantime some outside scripts can do it.
                            • W wannabee
                              /WB
                              E Offline
                              E Offline
                              epierre
                              @wannabee I'm desesperatly (as a newbee ) trying to send the message back, but it doesn't seem to work with
                              echo -en '1;255;4;13;M' > /dev/ttyUSB0
                              any idea ? my script doesn't seem to write too, strange...
                              H 1 Reply Last reply
                              • E epierre
                                H Offline
                                H Offline
                                @epierre
                                Don't forget the newline character.
                                • H hek
                                  @epierre
                                  E Offline
                                  E Offline
                                  epierre
                                  @hek right the -n option removed newline, but I have still the same behavior. Can both gateway and sensors on the same machine usb port make a difference in this ?
                                  So this one should be good, but no behavior change (same when writing from perl to the port):
                                  echo -e '1;255;4;13;M' > /dev/ttyUSB0
                                  does reading through perl locks it ? well I'm new on this ...
                                  • E Offline
                                    E Offline
                                    epierre
                                    Looks like one got to the sensor:
                                    Sent ack msg to 0 0 0 0 0
                                    Rx: fr=0,to=1,la=0,ci=255,mt=4,t=13,cr=57(ok): M 0 0 0 0
                                    Message addressed for this node. 0 0 0 0
                                    675 Relaying message back to gateway.
                                    Tx: fr=1,to=0,la=1,ne=0,ci=1,mt=1,ty=0,cr=216: 20.0
                                    Relaying message back to gateway. 0 0 0 0
                                    Tx: fr=1,to=0,la=1,ne=0,ci=1,mt=1,ty=0,cr=216: 20.0 0 0 0 0
                                    676 Ack: received OK
                                    T: 20.00
                                    Tx: fr=1,to=0,la=1,ne=0,ci=0,mt=1,ty=1,cr=162: 56.0
                                    Ack: received OK
                                    H: 56.00
                                    T: 20.00
                                    Ack: received OK
                                    H: 56.00
                                    707 Relaying message back to gateway.
                                    Tx: fr=1,to=0,la=1,ne=0,ci=0,mt=1,ty=1,cr=84: 55.0
                                    H: 55.00
                                    Tx: fr=1,to=0,la=1,ne=0,ci=0,mt=1,ty=1,cr=84: 55.0 0 0 0 0
                                    Ack: receive timeout 0 0 0 0
                                    H: 55.00 0 0 0 0
                                    then nothing...
                                    I unplugged the node, plugged it back and it is asking again the metric...
                                    • E Offline
                                      E Offline
                                      epierre
                                      • E Offline
                                        E Offline
                                        epierre
                                        I'm getting closer, since I launched the arduino console log my scripts works, and is able so write back the answer...
                                        Starting
                                        1 255 0 17 1.3b3 (67f4ca1)
                                        1 255 4 7 0
                                        1 255 4 14 Humidity
                                        1 255 4 15 1.0
                                        1 255 4 13 0
                                        W : 1;255;4;13;M
                                        1 1 1 0 21.0
                                        1 0 1 1 52.0
                                        looks like it is sleeping forever ?
                                        • E Offline
                                          E Offline
                                          epierre
                                          Looks like it's good, in one hour I've had 12 metering values, given I modified the timer in the sensor to 10 instead of 30. It is reporting only changed values which is smart (should be documented, extra value !)
                                          1 1 1 0 21.0
                                          1 0 1 1 52.0
                                          1 0 1 1 53.0
                                          1 0 1 1 54.0
                                          1 1 1 0 20.0
                                          1 1 1 0 21.0
                                          1 1 1 0 20.0
                                          1 0 1 1 55.0
                                          1 0 1 1 54.0
                                          1 0 1 1 55.0
                                          1 0 1 1 54.0
                                          1 0 1 1 55.0
                                          1 1 1 0 21.0
                                          12.2k
