  3. serial reading
serial reading
34 Posts 5 Posters 20.8k Views 2 Watching
  • W
    W
    wannabee
    225;255;4;5 is the first message sent from a node at startup if it hasn't a RADIO_ID in it's EEPROM.
    255 is the startup ID
    255 is node or the arduino it self.
    4 is internal message
    5 is I_REQUEST_ID
    The node expect to get a
    255;255:4;5;<RAIDO_ID_THAT_YOU_WANT_TO_ASSIGN_TO_THE_NODE>
    It's an automated way to assign RADIO_ID from the controller. usally a Vera or in your case your perl script needs to do that.
    Or if I rember correctly you can set the RAIDO_ID in the arduion when compiling the code:
    change in the .ino file.
    sensors.begin();
    to
    sensors.begin(<RAIDO_ID_THAT_YOU_WANT_TO_ASSIGN_TO_THE_NODE>);
    To decode the messages sent to and from a node check the tables in http://www.mysensors.org/build/sensor_api#the-serial-protocol
    /WB
    • epierreE
      epierreE
      epierre
      Thanks for your answer, this is what I thought but I don't understand why it can't get the node from the gateway ? I flashed it again but with no more success.
      The correct method is gw.begin(1) in my case.
      Now it answers with all the presentation, but get stuck in sending mesurement unit:
      0;0;4;11;Rx: fr=1,to=0,la=1,ci=255,mt=4,t=13,cr=73(ok):
      • epierreE
        epierreE
        epierre
        it looks like the gateway never answers, any hint ? bad wiring ? other issue ?
        • epierreE
          epierreE
          epierre
          similar issue here, I regroup it:
          link text
            Controller normally answer the unit setting requests from sensor. You have to answer manually (or from your perl program).
            Check the Troubleshooting section on our website if you're unable to communicate.
            epierreE 1 Reply Last reply
              epierreE
              epierreE
              epierre
              @hek right, I've not read thoroughly what @wannabee told me about who sets the ID. I'll know it for the next time.
              Should I answer also for the metric ?
              I have a strange behavior having commented out the metric line although they are close::
              0;0;4;11;Relaying message back to gateway.
              0;0;4;11;Tx: fr=0,to=0,la=0,ne=0,ci=255,mt=4,ty=13,cr=52:
              0;0;4;11;Ack: receive timeout
              • W
                W
                wannabee
                You perl program needs to tell the arudion Gateway if it Imperial or Metric it should you for it's number. The gateway will forward that information to the node
                Here is post where I explain how it works.
                http://forum.mysensors.org/topic/62/#315
                Basicly the arduion gatweway don't controll high level stuff. It only controlls the low level stuff. the raido communication.
                Your perl program needs to do all the higlevel stuff like responed to request from the network about raido_id, metric system, storing the data,etc. This is what the vera does. you are replacing the vera with your program so now you have to do all the stuff. a quick way forward is to translate https://github.com/mysensors/Vera/blob/master/L_Arduino.lua to perl. You have to build some more function since the Vera is doing stuff like storing data and configuration hat is not in the lua-file.
                This is what I have done in python see https://github.com/wbcode/ham and it transform the mysensor api to/from openhab api.
                /WB
                • epierreE
                  epierreE
                  epierre
                  perfect, this is what I was searching for...
                  I'm too much accustomed to RFX433 or z-Wave that handles many things themself, I now understand that only the basic is here.
                  I can read easily lua, logic can be simple, afterward I have my scripts, in fact I thought of doing the bidirectionnal integration with domoticz and/or cosm/xively for I've got already many of it. For the first, I guess some local logic must be implemented, discovered devices can be created through JSON, and then updated/queried as you already know, so the glue is possible ;-)
                  jendrushJ 1 Reply Last reply
                  • epierreE epierre
                    jendrushJ
                    jendrushJ
                    jendrush
                    @epierre +1 for Domoticz integration
                    Do you want to make gateway working in the same way as RFX433?
                    • epierreE
                      epierreE
                      epierre
                      @jendrush could be a possibility... but to have it exaclty the same, the gateway should do all the work meaning push when a new node is discovered, give all values... the whole vera programm should be built inside the arduino... I don't know how it would fit, but in the meantime some outside scripts can do it.
                      • W wannabee
                        /WB
                        epierreE
                        epierreE
                        epierre
                        @wannabee I'm desesperatly (as a newbee ) trying to send the message back, but it doesn't seem to work with
                        echo -en '1;255;4;13;M' > /dev/ttyUSB0
                        any idea ? my script doesn't seem to write too, strange...
                        hekH 1 Reply Last reply
                        • epierreE epierre
                          @epierre
                          Don't forget the newline character.
                            @epierre
                            epierreE
                            epierreE
                            epierre
                            @hek right the -n option removed newline, but I have still the same behavior. Can both gateway and sensors on the same machine usb port make a difference in this ?
                            So this one should be good, but no behavior change (same when writing from perl to the port):
                            echo -e '1;255;4;13;M' > /dev/ttyUSB0
                            does reading through perl locks it ? well I'm new on this ...
                            • epierreE
                              epierreE
                              epierre
                              Looks like one got to the sensor:
                              Sent ack msg to 0 0 0 0 0
                              Rx: fr=0,to=1,la=0,ci=255,mt=4,t=13,cr=57(ok): M 0 0 0 0
                              Message addressed for this node. 0 0 0 0
                              675 Relaying message back to gateway.
                              Tx: fr=1,to=0,la=1,ne=0,ci=1,mt=1,ty=0,cr=216: 20.0
                              Relaying message back to gateway. 0 0 0 0
                              Tx: fr=1,to=0,la=1,ne=0,ci=1,mt=1,ty=0,cr=216: 20.0 0 0 0 0
                              676 Ack: received OK
                              T: 20.00
                              Tx: fr=1,to=0,la=1,ne=0,ci=0,mt=1,ty=1,cr=162: 56.0
                              Ack: received OK
                              H: 56.00
                              T: 20.00
                              Ack: received OK
                              H: 56.00
                              707 Relaying message back to gateway.
                              Tx: fr=1,to=0,la=1,ne=0,ci=0,mt=1,ty=1,cr=84: 55.0
                              H: 55.00
                              Tx: fr=1,to=0,la=1,ne=0,ci=0,mt=1,ty=1,cr=84: 55.0 0 0 0 0
                              Ack: receive timeout 0 0 0 0
                              H: 55.00 0 0 0 0
                              then nothing...
                              I unplugged the node, plugged it back and it is asking again the metric...
                              • epierreE
                                epierreE
                                epierre
                                • epierreE
                                  epierreE
                                  epierre
                                  I'm getting closer, since I launched the arduino console log my scripts works, and is able so write back the answer...
                                  Starting
                                  1 255 0 17 1.3b3 (67f4ca1)
                                  1 255 4 7 0
                                  1 255 4 14 Humidity
                                  1 255 4 15 1.0
                                  1 255 4 13 0
                                  W : 1;255;4;13;M
                                  1 1 1 0 21.0
                                  1 0 1 1 52.0
                                  looks like it is sleeping forever ?
                                  • epierreE
                                    epierreE
                                    epierre
                                    Looks like it's good, in one hour I've had 12 metering values, given I modified the timer in the sensor to 10 instead of 30. It is reporting only changed values which is smart (should be documented, extra value !)
                                    1 1 1 0 21.0
                                    1 0 1 1 52.0
                                    1 0 1 1 53.0
                                    1 0 1 1 54.0
                                    1 1 1 0 20.0
                                    1 1 1 0 21.0
                                    1 1 1 0 20.0
                                    1 0 1 1 55.0
                                    1 0 1 1 54.0
                                    1 0 1 1 55.0
                                    1 0 1 1 54.0
                                    1 0 1 1 55.0
                                    1 1 1 0 21.0
                                    • epierreE
                                      epierreE
                                      epierre
                                      well... I tried to replicate this on a cubitruck2 (IBOX), does not work...
                                      I did on the i5 a test to see conf of usb port that works with:
                                      stty -F /dev/ttyUSB1
                                      speed 115200 baud; line = 0;
                                      kill = ^H; min = 0; time = 0;
                                      ignbrk -brkint -icrnl -imaxbel
                                      -opost -onlcr
                                      -isig -icanon -iexten -echo -echoe -echok -echoctl -echoke
                                      I tried to replicate it to the cubie:
                                      stty -F /dev/ttyUSB1 cs8 115200 ignbrk -brkint -imaxbel -opost -onlcr -isig -icanon -iexten -echo -echoe -echok -echoctl -echoke -ixon -crtscts kill ^H min 0
                                      but still nothing... any idea ?
                                      • epierreE
                                        epierreE
                                        epierre
                                        my bad, wrong reading script... works straight with the above parameters, should check if it works without... well no arduino ide run before it works for me now, I'm a bit farther than the arduino.cc forum ;-)
                                        • epierreE
                                          epierreE
                                          epierre
                                          Works like a charm, I now receive the DHT11 values and I am able to post it to a (now) static node in domoticz (could be used for every system with a json posting interface).
                                          This is where it can be tricky, you need both Temp and Humidity to report, so I have to wait to have them both in memory to push a report.
                                          I expect to use a sqlite3 database locally to handle the last known value and the status/association of a node and its device. Doing so requires that either I handle all in a conf file, or that creation of device are driven by the script which I can handle too (maybe specific to domoticz).
