  3. loadState in 2.3.2 is not a happy function....
6 Posts 2 Posters 651 Views 2 Watching
  • skywatchS
    skywatchS
    skywatch
    I am trying to get another node done and using saveState and loadState in the node for power cut recovery.
    Although I can get saveState to work in the receive function (wasn't expecting that to complie I must admit), whenever I try to loadState in setup I get an error like this.....
    Arduino: 1.8.9 (Windows 10), Board: "Arduino Pro or Pro Mini, ATmega328P (5V, 16 MHz)"
    C:\Users\captain\Documents\Arduino\MYS-M_BED_LED-0.2\MYS-M_BED_LED-0.2.ino: In function 'void setup()':
    MYS-M_BED_LED-0.2:69:23: error: too many arguments to function 'uint8_t loadState(uint8_t)'
    loadState(10, lights);
    In file included from C:\Users\captain\Documents\Arduino\libraries\MySensors/MySensors.h:433:0,
                 from C:\Users\captain\Documents\Arduino\MYS-M_BED_LED-0.2\MYS-M_BED_LED-0.2.ino:32:
    C:\Users\captain\Documents\Arduino\libraries\MySensors/core/MySensorsCore.cpp:550:9: note: declared here
    uint8_t loadState(const uint8_t pos)
    exit status 1
      Serial.begin(9600);
      // loadState(1, SOUND_Armed);
      // loadState(7, Auto_lights);
      if (lights == 1) {
        newcodeRX == 1;
        code = 0xFFA25D;
      irrecv.enableIRIn(); // Start the receiver
      LightMeter.begin();
      wdt_enable(WDTO_8S);
    So I wonder why saveState(10, lights); compiles and loadState(10, lights); does not? What am I not knowing about this as I have not had this issue before.
      Do
      lights = loadState(10);
      skywatchS 1 Reply Last reply
        Do
        skywatchS
        skywatchS
        skywatch
        @hek You are a star!
        That works as expected - so I guess that saveState should also have this construction.
        Did this change recently or have I just been lucky doing it the way I originally had it?
          It has always been like this. In order to do like you propose, you'd have to send in a pointer for the light variable into the function to be able to update it. This would be a bit awkward and none standard for simple scalar values.
          • skywatchS
            skywatchS
            skywatch
            Just tested this and my assumption was incorrect it seems (using arduino 1.8.9 and mysensors 2.3.2).....
            Correct usage is......
            lights = loadState(10); //to read value from eeprom to variable.
            saveState(10, lights); //to write value from variable to eeprom.
            Now I got it!
              skywatchS
              skywatchS
              skywatch
              @hek Thanks! Our posts crossed in the matrix!
              I even got this right on a previous sketch, but a lot has been going on for me lately and I am finding it difficult to concentrate on things.
