  2. Announcements
  3. πŸ’¬ Battery Powered Sensors
battery
347 Posts 55 Posters 226.6k Views 53 Watching
    @Sebex said in πŸ’¬ Battery Powered Sensors:
    Regarding the BOD, what happens if I disable it? Will it run for longer as it does not shutdown? Or is any voltage below 1.8v bad for the arduino?
    1.8V is the minimum voltage according to the atmega328 datasheet. Below that it might work, but it might also do all sorts of strange things. We've seen reports of nodes getting stuck on continuous transmit, blasting radio signals all the time which blocks all other nodes from communicating. So keeping the bod at 1.8V is probably a good idea. 2xAA have almost no power left at 1.8V anyway. See https://www.avrfreaks.net/forum/aa-alkaline-discharge-curve-5ma for some discharge curves.
    SebexS
    SebexS
    Sebex
    @mfalkvidd thanks makes sense, eventually I will switch to NiMh. Had a look at the different cases, gives some good inspiration thanks for pointing in the right direction!
    Now that I want to desolder the regulator and LED on the Nano, I just want to verify something, since the video shown is about the mini pro.
    (1) Is the circled part in the image below, indeed the regulator on the Nano?
    (2) On the battery powered sensor page, step 4 states to cutout the Vout pin. Why does this lower power consumption, and how can I locate this on the Nano?
    • SebexS Sebex
      #216
      @Sebex I have never tried to run a Nano on battery, so I don't know but that looks like a regulator.
      The Nano operates at 5V and consumes much more power than a 3.3V Pro Mini.
      Yes, the regulator will consume power if it is not disconnected.
        sundberg84S
        sundberg84S
        #217
        The big chip to the left is also a serial-usb converter which needs to be removed, making it not possible to program from the usb socket. Along with these components there are resistors and other components that might blead current so i dont think its that easy compared to just doing it to a Pro Mini.
        SebexS 1 Reply Last reply
        • sundberg84S sundberg84
          SebexS
          SebexS
          Sebex
          Ok thnx guys, guess I'll be ordering a pro mini very soon!
          • SebexS Sebex
            sundberg84S
            sundberg84S
            @Sebex - i think thats the easiest way, but sometimes its fun to try to create something new - its not impossible, but I would try to reverse engineer the nano (already done - search arduino nano schematic) and there you have to identify all "not essential" components and remove those (ie, making it a big pro-mini) to be able to get the current down as much as possible.
            • SebexS Sebex
              @sineverba thanks, I got it working and it's up and running. Still have to desolder the led and remove the regulator, will do that later.
              A bit off topic maybe, but I was wondering how the 'pros' around here make the sensor small and sturdy for Arduino's with Si7021+ 2xAA battery pack. My DuPont wires seem a bit loose, so I'm wondering whether I should solder them. And perhaps someone 3d printed a case for an Arduino+Batterypack or some sorts.
              Puneit ThukralP
              Puneit ThukralP
              Puneit Thukral
              You may want to try wire wrapping. It’s faster than soldering, sturdier than DuPont and you can connect multiple wires on same pin. Works wonders for gnd and vcc. Of course if the project is yanked harder, the wire wraps come out.
              I made this small video for my home automation group in India. - hence prices for the wire wraps and tool are mentioned in local currency. I leant about this amazing technique from Andreas Spiess
              my video
              guy with Swiss accent
              skywatchS SebexS 2 Replies Last reply
              • Puneit ThukralP Puneit Thukral
                my video
                skywatchS
                skywatchS
                skywatch
                @Puneit-Thukral Both DuPont and wirewrap are generally considered as prototyping methods. For final device build and production more secure connections should be implemented.
                Puneit ThukralP 1 Reply Last reply
                • skywatchS skywatch
                  Puneit ThukralP
                  Puneit ThukralP
                  Puneit Thukral
                  @skywatch Agree with every word of yours. Not justifying myself here but wirewraps are deployed all over my house. I pour some hot glue to ensure that they don’t come loose. And then a 3D printed enclosure takes care of the elements.
                  Also, it helps me to quickly repurpose the hardware.
                  It’s just another approach.
                  In an ideal world - where PCB shipments never arrive from China and locally they are a but expensive , this is my poor man’s alternative. 90F6D2B8-A1BA-4156-A23E-B7783A89FA49.jpeg 97A8362E-7B49-433F-8709-42E49469B161.jpeg Example photos. The coin cell holder is diy. Used shaving blades and wrapped wires and taped to create a circuit.
                  skywatchS 1 Reply Last reply
                    skywatchS
                    skywatchS
                    skywatch
                    @Puneit-Thukral I understand 'poor mans alternative' soooo well! ;)
                    Glue on the wirewraps will help keep them in place and mitigate thermal stress to some degree and also stop dust and moisture. But over time the glue will change and shrink/crack and things will start to become strange with that arrangement.
                    It's hard to beat a good soldered joint in the end, that's why all the commercial kit is done that way.
                    Nice case BTW. I also am working on 3D printed cases for some nodes. Another 6 weeks of lockdown and I should have started on them! ;)
                      my video
                      SebexS
                      SebexS
                      Sebex
                      @Puneit-Thukral interesting! Seems as a better option than Dupont, I'm gonna look into it.
                      You mention hot glueing the wires yourself as extra protection. But I imagine you can also put a layer of solder on it right?
                      • SebexS Sebex
                        Puneit ThukralP
                        Puneit ThukralP
                        Puneit Thukral
                        @Sebex yes, of course. I have done that as well. In case I need to repurpose something , removing solder completely away is a tougher job for me than peeling away a layer of glue. Guess, I am just lazy. πŸ˜ƒ
                          SebexS
                          SebexS
                          Sebex
                          @Puneit-Thukral haha okay I see.
                          Another question, your case that you use in the video snaps onto the pins perfectly it seems. Did you 3d print that yourself? I'm looking to 3D print a case for my pro mini and some other sensors that snaps in a similar way so that nothing moves around. However I'd rather copy a proven design than figuring out the tolerances myself.
                          • SebexS Sebex
                            Puneit ThukralP
                            Puneit ThukralP
                            Puneit Thukral
                            @Sebex Yes, I 3D printed on my ender 3 and I am using this on nodemcu running ESPhome. But I did not design it. Here is the Thingiverse link to it.
                            Nodemcu case
                            I would love to do similar case and a larger case like this to fit other boards. Its rock solid. I do not have skills to make a linear pattern like this. I think I should figure out how to do it.
                              Nodemcu case
                              SebexS
                              SebexS
                              Sebex
                              @Puneit-Thukral cool, from what I read the pins are the same size as on Arduino's. I'll use this design to create one for myself.
                              • SebexS Sebex
                                Puneit ThukralP
                                Puneit ThukralP
                                Puneit Thukral
                                @Sebex Do share the STL - it will be great and if you use Fusion360, then may I request for the F3D file.. I am semi-skilled when it comes to designing
                                  SebexS
                                  SebexS
                                  Sebex
                                  @Puneit-Thukral Will do!
                                  After closer inspection the pins of the NodeMCU seem to be a lot bigger in size. However I am struggling to find the correct sizing of Arduino Pro Mini pins (width/thickness). The spacing between pins and length of them are easy to find but I cannot find the thickness at all. Do you have an idea?
                                  • SebexS Sebex
                                    Puneit ThukralP
                                    Puneit ThukralP
                                    Puneit Thukral
                                    @Sebex Will this help
                                    https://grabcad.com/library/arduino-pro-mini-1
                                    and should we move this conversation to another topic /PM as this is not relevant to this thread.
                                    • E
                                      E
                                      evb
                                      @mfalkvidd, on the image I see the following marking in red
                                      VCC ==> N/C
                                      Do you know what the meaning is?
                                      This VCC pin and the other VCC pin at the bottom of the image are connected. I verified with the multimeter.
                                      So, what's the purpose of this remark?
                                      These pins at the right are used to program the pro mini. I had no problems to program after removing the led and the power regulator. The programmer used the VCC to power the pro mini without any problem...
                                      • E evb
                                        VCC ==> N/C
                                        skywatchS
                                        skywatchS
                                        skywatch
                                        @evb I believe that the reason is to physically (and electrically) isolate the voltage regulator from the circuit. Then only VCC will work and not RAW.
                                        Essentially the same as removing the led or it's series resistor (only one or the other will do) and the regulator from the board.
                                        E 1 Reply Last reply
                                          E
                                          E
                                          evb
                                          @skywatch, you mean that in normal conditions with the power regulator, we connect the power supply (max 16VDC) to the raw pin and can take 3.3V or 5V, depending on which version, at the pin VCC?
                                          And that now it isn't possible anymore with the regulator removed?
                                          I would propose to change the picture :
                                          • there are 2 VCC pins, so the current picture is confusing
                                          • adapt the drawing and mention to connect the battery (2xAA) 3V directly to VCC pin at the bottom (not the VCC pin in the programming row of contacts!)
                                          @skywatch and @mfalkvidd, what do you think?
                                          skywatchS mfalkviddM 2 Replies Last reply
                                          With your input, this post could be even better πŸ’—
