  3. πŸ’¬ Micro (nano) ampere meter (double)
measurement
39 Posts 16 Posters 17.9k Views 15 Watching
    soroush_habibi
    Can you make a schematic of this circuit please?
    I need this project.
    • V
      V
      vidalv
      Hello, is there, somewhere, a real complete diagram of this project? This subject is interesting but not clearly documented ... It's a shame! Thank you.
      • E
        E
        Enzo65
        Hi, pin A+ and pin B+ are connected together, on the same terminal block?
        • metceynM
          metceynM
          metceyn
          @mfalkvidd If you have something related to this project, can you share it? (circuit schema or something)
          mfalkviddM Nca78N 2 Replies Last reply
          • metceynM metceyn
            @Metin-Can-AYAR sorry, I have nothing.
            E 1 Reply Last reply
            • metceynM metceyn
              @metceyn said in πŸ’¬ Micro (nano) ampere meter (double):
              Hello, I will try to work again on this project in the coming days, I have made one years ago but reused (then broke !) the screen so it's not fonctional now. I will use another screen and make a functional one again as I will need it for some project.
              metceynM 1 Reply Last reply
              • Nca78N Nca78
                metceynM
                metceynM
                metceyn
                @Nca78 Thank you for your answer. I'm looking forward.
                • Nca78N Nca78
                  @rvendrame said in πŸ’¬ Micro (nano) ampere meter (double):
                  @Nca78 , my HX711 board looks like yours. I'm a bit confused on how to connect the J1 pins to the load / power. Can you share how did you connected it? Thx!
                  Soldering is a bit messy and not helping much to understand, so I did a (gorgeous) drawing. I think I'll frame that in my living room :D
                  And in case you want to increase the data rate
                  metceynM
                  metceynM
                  metceyn
                  @Nca78 Where do i attach the probes? How can i measure?
                  • metceynM
                    metceynM
                    metceyn
                    Is the result we get ac or dc?
                    • Nca78N Nca78
                      @rvendrame sure, I'll do it tomorrow morning as I cannot do it right now. In case I forget, don't hesitate to ring me ;)
                      L
                      L
                      ligteltelecom
                      @Nca78 said in πŸ’¬ Micro (nano) ampere meter (double):
                      Hi to all,
                      These two resistors are 1K ? (betwen E+ and A+) and (E- and B+) ?
                      Need I use Diodes to ground ?
                      • L ligteltelecom
                        Hi to all,
                        E
                        E
                        EdCali
                        @ligteltelecom said in πŸ’¬ Micro (nano) ampere meter (double):
                        There a way you may have a chance to correct me, I have ordered everything I will need to build this project. I need your help to make a Scheme and how to wire part and connect the load, I have to 2 days trying to figuring out but I yet I need to understand it. You are the last user who visited the project. Thank you in advance if you are able to.
                          E
                          E
                          EdCali
                          @mfalkvidd HI, There's a way you may help to do a circuit schema I am studying it, but yet I need to understand many thing how to wire it. If are able to. Thanks.
                          • E EdCali
                            @EdCali sorry I don’t understand. I don’t know how this device is designed.
                            With your input, this post could be even better πŸ’—
