  3. πŸ’¬ Micro (nano) ampere meter (double)
measurement
39 Posts 16 Posters 17.8k Views 15 Watching
  • AWIA AWI
    @mfalkvidd the 'local adc' library is the hx711 library which I placed in the sketch folder. Sorry for the confusion
    @AWI where can I download it? It does not seem to be compatible with the hx711 library I found through the Arduino IDE Library Manager :(
    EDIT: Seems to work with https://github.com/bogde/HX711 (if installing it manually)
    • rmtuckerR
      rmtuckerR
      rmtucker
      I am confused the 1k resistors seem to be wired differently in AWI photo's and Nca78 photo's.
      I would like to build this but not certain how it is wired now
      Nca78N 1 Reply Last reply
      • rmtuckerR rmtucker
        @rmtucker said in πŸ’¬ Micro (nano) ampere meter (double):
        If you do like drawn on my post from July 7, it works.
        rmtuckerR 1 Reply Last reply
        • Nca78N Nca78
          rmtuckerR
          rmtuckerR
          rmtucker
          @Nca78 said in πŸ’¬ Micro (nano) ampere meter (double):
          Are the blue and green resistors you have drawn on the back of the adc module the 1k resistors?
          Have you soldered them on the other side?
            Yes & yes.
            • Nca78N Nca78
              @rvendrame said in πŸ’¬ Micro (nano) ampere meter (double):
              @Nca78 , my HX711 board looks like yours. I'm a bit confused on how to connect the J1 pins to the load / power. Can you share how did you connected it? Thx!
              Soldering is a bit messy and not helping much to understand, so I did a (gorgeous) drawing. I think I'll frame that in my living room :D
              And in case you want to increase the data rate
              alexsh1A
              alexsh1A
              alexsh1
              @nca78 Exactly the same pin of the IC can be connected to the next pin (VCC) to change the refresh rate.
              https://github.com/iforce2d/thrustTester/blob/master/README.md
              • alexsh1A
                alexsh1A
                alexsh1
                I had some spare time and all parts so decided to assemble ampere meter.
                Firstly, the sketch has to be changed. The lib Button.h does not exist (it has been renamed). It has to be changed to JC_Button.h. This has to be added to setup {}:
                myBtn.begin();
                in order for the button to work.
                My question is this - reading are jumping like a yo-yo despite having a separate power supply (power bank). After calibration, reading maybe +30% or -30% off needless to say that its drifting dynamically. So constant current of 120uA is read +90 or +150 jumping up and down. Is this the way this meter is supposed to work?
                  soroush_habibi
                  Can you make a schematic of this circuit please?
                  I need this project.
                  • V
                    V
                    vidalv
                    Hello, is there, somewhere, a real complete diagram of this project? This subject is interesting but not clearly documented ... It's a shame! Thank you.
                    • E
                      E
                      Enzo65
                      Hi, pin A+ and pin B+ are connected together, on the same terminal block?
                      • metceynM
                        metceynM
                        metceyn
                        @mfalkvidd If you have something related to this project, can you share it? (circuit schema or something)
                        mfalkviddM Nca78N 2 Replies Last reply
                        • metceynM metceyn
                          @Metin-Can-AYAR sorry, I have nothing.
                          E 1 Reply Last reply
                          • metceynM metceyn
                            @metceyn said in πŸ’¬ Micro (nano) ampere meter (double):
                            Hello, I will try to work again on this project in the coming days, I have made one years ago but reused (then broke !) the screen so it's not fonctional now. I will use another screen and make a functional one again as I will need it for some project.
                            metceynM 1 Reply Last reply
                            • Nca78N Nca78
                              metceynM
                              metceynM
                              metceyn
                              @Nca78 Thank you for your answer. I'm looking forward.
                              • Nca78N Nca78
                                metceynM
                                metceynM
                                metceyn
                                @Nca78 Where do i attach the probes? How can i measure?
                                • metceynM
                                  metceynM
                                  metceyn
                                  Is the result we get ac or dc?
                                  • Nca78N Nca78
                                    @rvendrame sure, I'll do it tomorrow morning as I cannot do it right now. In case I forget, don't hesitate to ring me ;)
                                    L
                                    L
                                    ligteltelecom
                                    Hi to all,
                                    These two resistors are 1K ? (betwen E+ and A+) and (E- and B+) ?
                                    Need I use Diodes to ground ?
                                    • L ligteltelecom
                                      Hi to all,
                                      E
                                      E
                                      EdCali
                                      @ligteltelecom said in πŸ’¬ Micro (nano) ampere meter (double):
                                      There a way you may have a chance to correct me, I have ordered everything I will need to build this project. I need your help to make a Scheme and how to wire part and connect the load, I have to 2 days trying to figuring out but I yet I need to understand it. You are the last user who visited the project. Thank you in advance if you are able to.
                                        E
                                        E
                                        EdCali
                                        @mfalkvidd HI, There's a way you may help to do a circuit schema I am studying it, but yet I need to understand many thing how to wire it. If are able to. Thanks.
                                        • E EdCali
                                          @EdCali sorry I don’t understand. I don’t know how this device is designed.
                                          With your input, this post could be even better πŸ’—
