  3. πŸ’¬ Micro (nano) ampere meter (double)
measurement
39 Posts 16 Posters 17.9k Views 15 Watching
  • E
    E
    Enzo65
    Hi, pin A+ and pin B+ are connected together, on the same terminal block?
    • metceynM
      metceynM
      metceyn
      @mfalkvidd If you have something related to this project, can you share it? (circuit schema or something)
      mfalkviddM Nca78N 2 Replies Last reply
      • metceynM metceyn
        @Metin-Can-AYAR sorry, I have nothing.
        E 1 Reply Last reply
        • metceynM metceyn
          @metceyn said in πŸ’¬ Micro (nano) ampere meter (double):
          Hello, I will try to work again on this project in the coming days, I have made one years ago but reused (then broke !) the screen so it's not fonctional now. I will use another screen and make a functional one again as I will need it for some project.
          metceynM 1 Reply Last reply
          • Nca78N Nca78
            metceynM
            metceynM
            metceyn
            @Nca78 Thank you for your answer. I'm looking forward.
            • Nca78N Nca78
              @rvendrame said in πŸ’¬ Micro (nano) ampere meter (double):
              @Nca78 , my HX711 board looks like yours. I'm a bit confused on how to connect the J1 pins to the load / power. Can you share how did you connected it? Thx!
              Soldering is a bit messy and not helping much to understand, so I did a (gorgeous) drawing. I think I'll frame that in my living room :D
              And in case you want to increase the data rate
              metceynM
              metceynM
              metceyn
              @Nca78 Where do i attach the probes? How can i measure?
              • metceynM
                metceynM
                metceyn
                Is the result we get ac or dc?
                • Nca78N Nca78
                  @rvendrame sure, I'll do it tomorrow morning as I cannot do it right now. In case I forget, don't hesitate to ring me ;)
                  L
                  L
                  ligteltelecom
                  @Nca78 said in πŸ’¬ Micro (nano) ampere meter (double):
                  Hi to all,
                  These two resistors are 1K ? (betwen E+ and A+) and (E- and B+) ?
                  Need I use Diodes to ground ?
                  • L ligteltelecom
                    Hi to all,
                    E
                    E
                    EdCali
                    @ligteltelecom said in πŸ’¬ Micro (nano) ampere meter (double):
                    There a way you may have a chance to correct me, I have ordered everything I will need to build this project. I need your help to make a Scheme and how to wire part and connect the load, I have to 2 days trying to figuring out but I yet I need to understand it. You are the last user who visited the project. Thank you in advance if you are able to.
                      E
                      E
                      EdCali
                      @mfalkvidd HI, There's a way you may help to do a circuit schema I am studying it, but yet I need to understand many thing how to wire it. If are able to. Thanks.
                      • E EdCali
                        @EdCali sorry I don’t understand. I don’t know how this device is designed.
                        With your input, this post could be even better πŸ’—
