  2. Announcements
  3. 💬 Battery Powered Sensors
battery
347 Posts 55 Posters 226.6k Views 53 Watching
  • skywatchS
    skywatchS
    skywatch
    #313
    @Gilles-BILLARD IT took me some time to work it out and get it working.
    I suggest you install MiniCore library - it is easy to follow simple steps and takes a minute or two.
    Then burn a bootloader into the atmega, I always use 3.3V, disable BoD and 4MHz or 8MHz internal clock. You can use one arduino to program another or just get a USB programmer from your preferred source (about $2).
    Once your pro mini is booeloaded and you have your sketch in installed , remove the Power LED (or the series resistor for the LED) and also remove the voltage regulator (or cut the tracks as shown in the battery powered page).
    You won't get down to <10uA in sleep unless you do all of this.
    G 1 Reply Last reply
    • G
      G
      Gilles BILLARD
      wrote on last edited by Gilles BILLARD
      #314
      Thanks Skywatch,
      My Pro-Mini boards are comming from Aliexpress, so, I was also thinking about the bootloader... what else ?
      I'll do what you explain ASAP and be back to say what...
      BTW: I already have cut the tracks powering the LED & regulator
      • skywatchS skywatch
        G
        G
        Gilles BILLARD
        #315
        @skywatch NO WAY ! So bad !
        I burned the MiniCore bootloader quite eazily using a second Pro-Mini loaded with Arduino BootLoader ( juste a file name error; looking for optiboot_flash_atmega328p_UART1_115200_16000000L_B5.hex but only optiboot_flash_atmega328p_UART0_115200_16000000L_B5.hex on the folder, so I just changed 0-->1 in the file name) and the résult was:
        avrdude: Version 6.3-20201216
             System wide configuration file is "C:\Users\billa\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.0/avrdude.conf"
             Using Port                    : COM7
             Programmer Type : STK500
             Hardware Version: 2
             Firmware Version: 1.18
             Topcard         : Unknown
             Vtarget         : 0.0 V
             Varef           : 0.0 V
             Oscillator      : Off
             SCK period      : 0.1 us
        Reading | ################################################## | 100% 0.04s
        avrdude: erasing chip
        avrdude: reading input file "C:\Users\billa\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.0/bootloaders/empty/empty.hex"
        avrdude: writing flash (0 bytes):
        avrdude: 0 bytes of flash written
        avrdude: verifying flash memory against C:\Users\billa\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.0/bootloaders/empty/empty.hex:
        avrdude: load data flash data from input file C:\Users\billa\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.0/bootloaders/empty/empty.hex:
        avrdude: input file C:\Users\billa\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.0/bootloaders/empty/empty.hex contains 0 bytes
        avrdude: verifying ...
        avrdude: 0 bytes of flash verified
        avrdude: reading input file "0x0f"
        Writing | ################################################## | 100% 0.04s
        avrdude: verifying lock memory against 0x0f:
        avrdude: load data lock data from input file 0x0f:
        avrdude: input file 0x0f contains 1 bytes
        avrdude done. Thank you.
        Then I loaded it with Blink demo...
        At this point all's OKay. Both Po-Mini are blinking
        Blink
        Then I've loaded the 2nd with that:
        #define MY_RADIO_RF24
        uint32_t SLEEP_TIME = 4000;  // sleep time (in seconds * 1000 )
        pinMode(LED_BUILTIN, OUTPUT);
          sendSketchInfo("Test Prgm", "1.0"); // Send the sketch version information to the gateway and Controller
          digitalWrite(LED_BUILTIN, HIGH);
        delay(1000);
          digitalWrite(LED_BUILTIN, LOW);
        delay(1000);
        sleep(SLEEP_TIME);
        and...
        the result is...
        No blinking
        NO BLINK
        (draining more or less 2mA; Varying quickly from 1600uA to 2000uA; I should put a scope probe on that....)
        YveauxY T 2 Replies Last reply
        • G Gilles BILLARD
               Using Port                    : COM7
               Hardware Version: 2
               Topcard         : Unknown
               Vtarget         : 0.0 V
               Varef           : 0.0 V
               Oscillator      : Off
               SCK period      : 0.1 us
          Blink
          delay(1000);
          delay(1000);
          sleep(SLEEP_TIME);
          and...
          the result is...
          No blinking
          NO BLINK
          @Gilles-BILLARD from the photos it seems you didn't connect a radio. If that is the case, the loop will not be entered and your arduino won't sleep!
          • YveauxY Yveaux
            G
            G
            Gilles BILLARD
            @Yveaux
            YESSSSSS !<
            That was the last problèm to solve.
            Back with my own MySensors routine all is perfect ! (8uA in sleep mode)
            I am very happy now and I thank all those who assisted me.
            You've made my day !
            Gilles
            skywatchS 1 Reply Last reply
            • G Gilles BILLARD
              @Yveaux
              YESSSSSS !<
              Gilles
              skywatchS
              skywatchS
              skywatch
              @Gilles-BILLARD @Yveaux beat me to it! - But I bet you are a very happy person after that - it is easy when you know how! :)
              • G Gilles BILLARD
                     Using Port                    : COM7
                     Hardware Version: 2
                     Topcard         : Unknown
                     Vtarget         : 0.0 V
                     Varef           : 0.0 V
                     Oscillator      : Off
                     SCK period      : 0.1 us
                Blink
                delay(1000);
                delay(1000);
                sleep(SLEEP_TIME);
                and...
                the result is...
                No blinking
                NO BLINK
                tssk
                @Gilles-BILLARD Damn! Why did I order UNO if I could use another Pro Mini for programming... :)
                • T tssk
                  G
                  G
                  Gilles BILLARD
                  @tssk My Pro-Mini's are 3.3V, so this way I avoid the resistors dividers wiring to change 5V (Uno) to 3.3 (Pro-Mini);
                  May be you love creating problems where there are none ;-)
                  • G
                    G
                    Gilles BILLARD
                    #321
                    Hy guys; So sorry but the procedure ran just once :-/
                    When I reproammed my soldred Pro-Minis (via the radio socket + 1 air wire to the reset pin) none was running as expected; The issue was a kind of permanent reboot..????
                    I tried to burn the MinCore bootloader and load my sketch into several brand new boards and the result was the same...
                    So I simplified and simplified again the sketches until this one:
                    /*This sketch is cycling wether you comment MY-DEBUG.....
                    SERIAL MONITOR report:
                              2021-04-04 17:20:04.426 Status: MySensors: Node: 20, Sketch Name: Temperature Sensor Test
                              2021-04-04 17:20:04.426 Status: MySensors: Node: 20, Sketch Version: G.B.
                              2021-04-04 17:20:15.378 (GiBi-Home) Temp (Temptest)
                              2021-04-04 17:20:15.368 Status: MySensors: Node: 20, Sketch Name: Temperature Sensor Test
                              2021-04-04 17:20:15.368 Status: MySensors: Node: 20, Sketch Version: G.B.
                    ......or running as it should do if you uncomment MY-DEBUG
                              2021-04-04 17:22:52.558 Status: MySensors: Node: 20, Sketch Name: Temperature Sensor Test
                              2021-04-04 17:22:52.558 Status: MySensors: Node: 20, Sketch Version: G.B.
                              2021-04-04 17:23:02.654 (GiBi-Home) Temp (Temptest)
                              2021-04-04 17:23:12.717 (GiBi-Home) Temp (Temptest)
                              2021-04-04 17:23:22.781 (GiBi-Home) Temp (Temptest)
                    NOTA: wether bootLoader is ordinary AVR bootloader or MiniCore's one
                    #include <OneWire.h>
                    #define ONE_WIRE_BUS 3 // Pin E/S de mesure
                    OneWire oneWire(ONE_WIRE_BUS); // Instanciation du OneWire
                    DallasTemperature sensors(&oneWire); // Passage de l'instance du OneWire à Dallas Temperature.
                    MyMessage msg(0,V_TEMP); // Init temp msg
                    void before()
                        sensors.begin();// démarre le OneWire
                      sendSketchInfo("Temperature Sensor Test", "GB.1.0");
                      present(0, S_TEMP);
                        float (temperature) = sensors.getTempCByIndex(0);   // acquisition du résultat
                        temperature = float(int(temperature * 10)) / 10;    // cast pour 1 seul chiffre après la virgule
                        send(msg.setSensor(0).set(temperature,1));
                        sensors.requestTemperatures(); // ordre de mesure
                        // ************Sleeping test ***************
                        #ifdef MY_DEBUG
                            delay(10000); // 10 secondes
                            sleep(10000);
                    and then this one
                    // Simplest test to to highlight my problèm
                    // Ordinary delay function used on DEBUG
                    // Sleep is used without DEBUG
                    // Successiv Serial prints should be printed if loop entered
                     Without DEBUG Serial monitor screen copy
                     ⸮⸮ `_⸮       ⸮ߟ⸮
                    ⸮  ⸮o  ⸮⸮   ⸮/ _⸮⸮⸮` ⸮⸮⸮ ⸮ ⸮⸮ `ߟ⸮  ⸮⸮⸮  ⸮ ⸮⸮`⸮⸮⸮
                    ⸮ ⸮⸮/⸮ ⸮ ⸮ ⸮ ⸮_⸮⸮ ⸮ / ⸮ ⸮ `⸮ ⸮/ ⸮⸮⸮/ ⸮`⸮⸮ ⸮⸮⸮/ ⸮⸮⸮
                    ⸮⸮⸮  ⸮_⸮⸮⸮⸮, |⸮_⸮⸮/ ⸮⸮ߟ⸮⸮⸮ ⸮⸮⸮_⸮⸮/⸮⸮⸮_/⸮⸮⸮  ⸮⸮⸮⸮/
                            ⸮⸮ߟ/`                    `2.3.2
                    ⸮é⸮u⸮ ⸮⸮ ⸮⸮⸮⸮
                     ⸮⸮  ⸮⸮       ⸮ߟ⸮
                    ⸮  ⸮/  ⸮⸮   ⸮/ ⸮⸮⸮⸮  ⸮⸮⸮ ⸮ ⸮⸮  ߟ⸮  ⸮⸮⸮  ⸮ ⸮⸮ ⸮_⸮
                    ⸮ ⸮⸮/⸮ ⸮ ⸮`⸮ ܟ⸮⸮ ⸮ / ⸮ ⸮ ⸮⸮`⸮/`⸮⸮⸮/ ⸮ ⸮⸮ ⸮ߟ/ ⸮⸮⸮
                    ⸮`⸮ `⸮`⸮ ⸮⸮⸮ ⸮⸮⸮⸮⸮ ⸮ `ߟ/ ⸮`⸮`ܟ⸮ ⸮ `⸮` ⸮ ⸮  ܟ⸮ ⸮
                    ⸮⸮⸮ `⸮⸮⸮⸮⸮⸮, ⸮⸮⸮⸮⸮/ ⸮⸮ߟ⸮⸮⸮ ⸮⸮⸮⸮ߟ/ܟ⸮⸮o⸮⸮⸮` ⸮⸮⸮⸮o
                     `  ` ` ⸮⸮ߟo`` `  `  `  ``        2.3.2
                    ⸮⸮i⸮⸮⸮`⸮⸮`⸮⸮⸮⸮
                    ⸮  ⸮/` ⸮⸮ ` ⸮/ ⸮ߟ⸮  ⸮⸮⸮`⸮ ߟ `⸮ߟ `⸮⸮⸮ `⸮`⸮⸮ ⸮ߟ
                    ⸮ ⸮⸮/⸮ ⸮ ⸮ ⸮ ⸮ߟ⸮ ⸮ / ⸮ ⸮ ⸮⸮ ⸮o`ߟ⸮/`⸮`⸮⸮ ⸮ߟo ⸮⸮⸮
                    ⸮`⸮  ⸮ ⸮ ⸮⸮⸮ ⸮_⸮⸮⸮`⸮``⸮⸮/`⸮ ⸮ ⸮⸮⸮ ⸮ `⸮` ⸮`⸮ `⸮ߟ`⸮
                    ⸮⸮⸮` ⸮⸮⸮⸮ߟl`⸮⸮⸮⸮⸮o`⸮ߟ⸮⸮⸮⸮ ⸮⸮⸮ߟ⸮/⸮⸮⸮⸮o⸮⸮⸮ `⸮⸮⸮⸮/
                     `      ⸮⸮⸮⸮/   `   ``` ```        2.3.r
                    etc....
                    * With DEBUG Serial monitor screen copy
                    ⸮  ⸮/  ⸮⸮`  ⸮/ ⸮⸮⸮⸮  ߟ⸮`⸮ ⸮⸮` ⸮⸮⸮  ߟ⸮` ⸮ ⸮⸮`⸮⸮⸮
                    ⸮ ⸮⸮o⸮ ⸮ ⸮ ⸮ ⸮_⸮⸮ \ / ⸮ ⸮ ⸮_ ⸮/ ⸮⸮⸮/ ⸮ ⸮| ⸮⸮⸮o ⸮⸮⸮
                    ⸮ ⸮` ⸮`⸮ ⸮⸮⸮ ⸮⸮_⸮⸮ ⸮  ⸮⸮/ ⸮ ⸮ ⸮⸮⸮`⸮  ⸮ `⸮`⸮` ⸮ߟ ⸮
                    ⸮⸮⸮` ⸮⸮⸮ܟ⸮,`⸮⸮ߟ⸮o ⸮ߟ⸮⸮⸮⸮`⸮⸮⸮⸮⸮⸮/\⸮⸮⸮o⸮⸮⸮` ⸮ߟ⸮/
                            ⸮ߟ⸮/ ` ` `                2.3.2
                    16 ̓⸮:⸮⸮⸮:⸮Ή⸮`⸮⸮⸮⸮,⸮⸮=⸮Ύ΁---,⸮Q=8,⸮⸮⸮=2u5,⸮E⸮=2.3.2
                    28 ⸮⸮⸮:⸮⸮⸮⸮
                    28 T⸮⸮:⸮⸮⸮:⸮⸮=0
                    s6`⸮⸮⸮:⸮Ή⸮:⸮Ӑ ⸮⸮
                    38`⸮⸮⸮:⸮I⸮:⸮K,⸮D=25
                    40 ⸮⸮⸮z⸮Ё⸮
                    45 ?⸮⸮⸮z⸮⸮⸮:⸮⸮⸮⸮,25-25-255-255,⸮=255,⸮=3,⸮=7,⸮t=0,l=0,⸮⸮}0l⸮⸮}0,⸮⸮=⸮⸮:
                    10t0`ԓ⸮:⸮⸮⸮:⸮⸮⸮⸮,0-0-25,⸮=255,⸮}3,⸮=x,⸮⸮=1,⸮=1,sg=0:0
                    1046 T⸮⸮:⸮⸮⸮:⸮⸮⸮R ⸮⸮,Ʉ=0,⸮=1
                    20u4 ⸮⸮⸮:⸮Ё⸮zϋ
                    2054 ⸮S⸮:⸮⸮
                    2056 ⸮⸮⸮:⸮⸮:⸮⸮
                    2058 ԓ⸮:⸮Ќ
                    2064 ⸮⸮⸮:⸮⸮⸮:⸮⸮⸮⸮,25-25-0-0,⸮=255l⸮=s,⸮}24l⸮⸮=1,⸮=q,⸮⸮=0,⸮⸮=0l⸮⸮=⸮⸮:1
                    2076 ⸮⸮⸮:⸮S⸮:⸮⸮⸮⸮,0-0-25,⸮=255l⸮=3,⸮=25,⸮⸮=1,⸮=1,⸮⸮=0:1
                    2082 ⸮S⸮:⸮⸮⸮:⸮⸮⸮⸮ ⸮⸮C⸮,H⸮=1
                    2084 ⸮⸮⸮zՐ⸮z⸮⸮
                    2086 ⸮⸮⸮:⸮⸮⸮ę:⸮⸮=25,⸮⸮⸮=0,⸮⸮⸮=1
                    2099 ⸮⸮⸮:⸮⸮⸮:⸮⸮⸮⸮,25-25-0-0,⸮=255,⸮=3,t=15,⸮⸮=6,⸮=2,⸮⸮=0,⸮⸮=0,⸮⸮=⸮⸮:0100
                    2107 ⸮S⸮:⸮Ӈ:⸮Ł⸮,0-0-25,⸮=255,⸮=3,⸮=q5,⸮⸮}6l⸮}2,⸮⸮}0z0q00
                    2117 ⸮⸮⸮:⸮Ӈ:⸮Ŏ⸮,ru-25-0m0,⸮=255,⸮=0,⸮=17,⸮⸮=0,⸮}5,⸮⸮}p,⸮⸮=p,⸮⸮}⸮⸮:2.3.2
                    21r9 ⸮⸮⸮:⸮⸮⸮:⸮⸮⸮⸮,25-25-0-0,⸮=255,⸮=3,⸮=6,⸮⸮=1,⸮=1,⸮⸮}0,⸮⸮=0l⸮⸮=⸮⸮:p
                    2142 ⸮⸮⸮:M⸮⸮:⸮E⸮⸮,p-p-25,⸮=255,⸮}sl⸮}vl⸮⸮}0,⸮=1,s⸮=0:⸮
                    2154 ⸮⸮⸮:⸮⸮⸮:⸮⸮⸮⸮,25-25-0-0,⸮=r55,⸮=3,⸮=11,⸮⸮=0,⸮}9,⸮⸮=0l⸮⸮=0,⸮⸮}⸮⸮z⸮⸮⸮⸮ ⸮⸮⸮⸮
                    r1v6 ⸮⸮⸮:⸮⸮⸮:⸮⸮⸮⸮,25m25-0-0l⸮=r55,⸮=3,⸮=12,pt=0,⸮}6l⸮⸮=p,⸮⸮=0,⸮⸮=⸮⸮:⸮⸮.2np
                    217t ̓⸮z⸮⸮⸮:⸮⸮Q
                    2179 ⸮⸮⸮:M⸮⸮:⸮⸮⸮⸮,25-25-0-0,⸮=255,⸮=3,⸮=26,⸮⸮=1,l=1,⸮⸮=0,⸮⸮=0,⸮⸮}ϋ:2
                    2187 ԓ⸮:͓⸮:⸮Ł⸮,p-0m2u,⸮=25u,⸮}3,⸮=27l⸮⸮=1,l=1,⸮⸮=0z1
                    r1ys ⸮⸮⸮:Љ⸮z⸮⸮ą`⸮Ň=q
                    2q97`⸮⸮⸮:⸮G⸮:⸮T⸮
                    2199 ̓⸮z‡⸮:⸮⸮⸮T ⸮⸮,⸮⸮⸮=1
                      Serial.println ("Début du test");
                      sendSketchInfo("Test Prgm", "GB.2.0"); // Send the sketch version information to the gateway and Controller
                    Serial.print (":.");
                    #ifdef MY_DEBUG
                            sleep(10000);
                    I have included the Domoticz log in the 1st one and the serial monitor report for the 2nd.
                    You can see, if "delay(xxx)" is in use, all's Okay, but if "sleep(xxx) is employed, the sketch is cycling in both sketches....
                    What is happening?
                    Prog.setup
                    Test setup
                    • G Gilles BILLARD
                      void before()
                        present(0, S_TEMP);
                          #ifdef MY_DEBUG
                              sleep(10000);
                      and then this one
                       ⸮⸮ `_⸮       ⸮ߟ⸮
                              ⸮⸮ߟ/`                    `2.3.2
                      ⸮é⸮u⸮ ⸮⸮ ⸮⸮⸮⸮
                       ⸮⸮  ⸮⸮       ⸮ߟ⸮
                      ⸮⸮i⸮⸮⸮`⸮⸮`⸮⸮⸮⸮
                      etc....
                              ⸮ߟ⸮/ ` ` `                2.3.2
                      28 ⸮⸮⸮:⸮⸮⸮⸮
                      28 T⸮⸮:⸮⸮⸮:⸮⸮=0
                      s6`⸮⸮⸮:⸮Ή⸮:⸮Ӑ ⸮⸮
                      38`⸮⸮⸮:⸮I⸮:⸮K,⸮D=25
                      40 ⸮⸮⸮z⸮Ё⸮
                      20u4 ⸮⸮⸮:⸮Ё⸮zϋ
                      2054 ⸮S⸮:⸮⸮
                      2056 ⸮⸮⸮:⸮⸮:⸮⸮
                      2058 ԓ⸮:⸮Ќ
                      2084 ⸮⸮⸮zՐ⸮z⸮⸮
                      217t ̓⸮z⸮⸮⸮:⸮⸮Q
                      2q97`⸮⸮⸮:⸮G⸮:⸮T⸮
                      #ifdef MY_DEBUG
                              sleep(10000);
                      What is happening?
                      Prog.setup
                      Test setup
                      @Gilles-BILLARD what pro minis are you using? The 3v3 version only goes to 57600 baud, so 115200 is likely too much
                      • YveauxY Yveaux
                        G
                        G
                        Gilles BILLARD
                        @Yveaux Yes Yveaux, you're probably righ, but, if I use AVR bootloader and Test Nb 2 the serial monitor says:
                         __  __       ____
                                |___/                      2.3.2
                        16 MCO:BGN:INIT NODE,CP=RNNNA---,FQ=8,REL=255,VER=2.3.2
                        28 TSM:INIT
                        28 TSF:WUR:MS=0
                        36 TSM:INIT:TSP OK
                        38 TSF:SID:OK,ID=20
                        40 TSM:FPAR
                        45 ?TSF:MSG:SEND,20-20-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        657 TSF:MSG:READ,0-0-20,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                        663 TSF:MSG:FPAR OK,ID=0,D=1
                        2054 TSM:FPAR:OK
                        2054 TSM:ID
                        2056 TSM:ID:OK
                        2058 TSM:UPL
                        2062 TSF:MSG:SEND,20-20-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                        2070 TSF:MSG:READ,0-0-20,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                        2076 TSF:MSG:PONG RECV,HP=1
                        2080 TSM:UPL:OK
                        2082 TSM:READY:ID=20,PAR=0,DIS=1
                        2086 TSF:MSG:SEND,20-20-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                        2095 TSF:MSG:READ,0-0-20,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                        2105 TSF:MSG:SEND,20-20-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.3.2
                        2115 TSF:MSG:SEND,20-20-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                        2125 TSF:MSG:READ,0-0-20,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                        2134 TSF:MSG:SEND,20-20-0-0,s=255,c=3,t=11,pt=0,l=9,sg=0,ft=0,st=OK:Test Prgm
                        2146 TSF:MSG:SEND,20-20-0-0,s=255,c=3,t=12,pt=0,l=6,sg=0,ft=0,st=OK:GB.2.0
                        2154 MCO:REG:REQ
                        2156 TSF:MSG:SEND,20-20-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                        2164 TSF:MSG:READ,0-0-20,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                        2170 MCO:PIM:NODE REG=1
                        2174 MCO:BGN:STP
                        Début du test
                        2177 MCO:BGN:INIT OK,TSP=1
                        and Domoticz log is:
                        2021-04-08 08:08:24.328 Status: MySensors: Node: 20, Sketch Name: Test Prgm
                        2021-04-08 08:08:24.329 Status: MySensors: Node: 20, Sketch Version: GB.2.0
                        NB: On the Sérial monitor, only the last line matters
                        One more point: Once the Pro-Minis are burnt with MiniCore library, I'm not able to revert on standard AVR bootloader; They are somehow bricked on MiniCore bootloader
                        G skywatchS 2 Replies Last reply
                        • G Gilles BILLARD
                           __  __       ____
                                  |___/                      2.3.2
                          28 TSM:INIT
                          28 TSF:WUR:MS=0
                          36 TSM:INIT:TSP OK
                          38 TSF:SID:OK,ID=20
                          40 TSM:FPAR
                          2054 TSM:FPAR:OK
                          2054 TSM:ID
                          2056 TSM:ID:OK
                          2058 TSM:UPL
                          2080 TSM:UPL:OK
                          2154 MCO:REG:REQ
                          2174 MCO:BGN:STP
                          Début du test
                          G
                          G
                          Gilles BILLARD
                          @Gilles-BILLARD
                          Update: Today, using Arduino UNO as ISP (instead of a ProMini as ISP), I was able to "unbrick" one Pro-Mini and revert to standard AVR bootloader
                          • G Gilles BILLARD
                             __  __       ____
                                    |___/                      2.3.2
                            28 TSM:INIT
                            28 TSF:WUR:MS=0
                            36 TSM:INIT:TSP OK
                            38 TSF:SID:OK,ID=20
                            40 TSM:FPAR
                            2054 TSM:FPAR:OK
                            2054 TSM:ID
                            2056 TSM:ID:OK
                            2058 TSM:UPL
                            2080 TSM:UPL:OK
                            2154 MCO:REG:REQ
                            2174 MCO:BGN:STP
                            Début du test
                            skywatchS
                            skywatchS
                            skywatch
                            #325
                            @Gilles-BILLARD Something is not right with either your set up (wiring etc), settings or installation of arduino IDE/libraries.
                            I just tested a 3V pro mini and was able to to back and forth freely between MiniCore and AVR bootloaders without issue. Two blinks for Minicore and one blink for AVR.
                            A USB programmer is usually cheaper than an uno, so why not try one and see. That is what I use and the only difference is less cabling and only one arduino in the mix.
                            In one photo you show nrf24 - are you using FOTA? Is this connected when bootloading the chip?
                            The error you described a week ago about optiboot should not happen and you should not need to change anything. Try reinstalling the MiniCore library again following the instructions to the letter. Have you in any way modified your boards.txt or changed your arduino ide from default settings or installation path in any way?
                            G 2 Replies Last reply
                              G
                              G
                              Gilles BILLARD
                              #326
                              @skywatch When I try to use the red ISP (based on a FT232R ) you can see on the pictures I joined, I receive an error msg like :
                                       System wide configuration file is "C:\Users\billa\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.1/avrdude.conf"
                                       Using Programmer              : usbasp
                              avrdude: error: could not find USB device with vid=0x16c0 pid=0x5dc vendor='www.fischl.de' product='USBasp'
                              That is the reason why I used or Po-Mini Or UNO as ISP.
                              I tried to change and test many others drivers for my FTDI (for 2 days) unsuccessfully
                              are you using FOTA? Is this connected when bootloading the chip? As you can see on one picture, in the programming section, NRF is NOT wired to the programmed Pro-Mini.
                              Neither it was when I tried to reprogram the wired Pro-mini because I was using the NRF socket to acces the Arduino pins.
                              .....or installation of arduino IDE/libraries I checked that as well and installed the new Adruino IDE 2.0.0 beta.... same problèms :-//
                                G
                                G
                                Gilles BILLARD
                                @skywatch said in 💬 Battery Powered Sensors:
                                ....... Two blinks for Minicore and one blink for AVR.....>
                                Thay is not my case; 1 blink for AVR and NO BLINK for MiniCore !?!?!?
                                • G Gilles BILLARD
                                  G
                                  G
                                  Gilles BILLARD
                                  @Gilles-BILLARD Now it is OKay with that blinks; 1 for AVR boot and 2 for MiniCore and I can revert from one to the other and vice-versa.
                                  ( I removed all concerning MiniCore and reload it )
                                  But sleep() is still giving the same issue
                                  • G Gilles BILLARD
                                    skywatchS
                                    skywatchS
                                    skywatch
                                    #329
                                    @Gilles-BILLARD You remembered to connect the nrf before going to sleep?
                                      G
                                      G
                                      Gilles BILLARD
                                      #330
                                      skywatch: You remembered to connect the nrf before going to sleep?
                                      @skywatch Yes, of course;
                                      I'm 67, retired, and after 9 days (part time) on this issue, I give up !
                                      I am therefore torn between crushing all that stuff between between a big hammer and my anvil or to discard everything to the trash can.
                                      These sensors are useless if consuming 20mA H24-7/7 because they they should normally be used outside (in my greenhouses) powered by a battery 18650 + a solar cell.
                                      • G
                                        G
                                        Gilles BILLARD
                                        #331
                                        Can anyone let me know if he sees something wrong in that log after a Min-Core bootloader burn in a Pro-Mini 3.3v
                                        (I do not!)
                                        I ask because it not the same file as the 1st one (the 1st was including the nb "115200" (bauds?) and now it is "38400" )
                                        NOTA: Directory is this one:
                                        C:\Users\billa\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.1\bootloaders\optiboot_flash\bootloaders\atmega328p\8000000L
                                                 Using Port                    : COM8
                                                 Hardware Version: 2
                                                 Topcard         : Unknown
                                                 Vtarget         : 0.0 V
                                                 Varef           : 0.0 V
                                                 Oscillator      : Off
                                                 SCK period      : 0.1 us
                                        avrdude: reading input file "0x3f"
                                        Writing | ################################################## | 100% 0.02s
                                        avrdude: verifying lock memory against 0x3f:
                                        avrdude: load data lock data from input file 0x3f:
                                        avrdude: input file 0x3f contains 1 bytes
                                        avrdude: reading input file "0b11111111"
                                        avrdude: verifying efuse memory against 0b11111111:
                                        avrdude: load data efuse data from input file 0b11111111:
                                        avrdude: input file 0b11111111 contains 1 bytes
                                        avrdude: reading input file "0b11011110"
                                        avrdude: verifying hfuse memory against 0b11011110:
                                        avrdude: load data hfuse data from input file 0b11011110:
                                        avrdude: input file 0b11011110 contains 1 bytes
                                        avrdude: reading input file "0xe2"
                                        avrdude: verifying lfuse memory against 0xe2:
                                        avrdude: load data lfuse data from input file 0xe2:
                                        avrdude: input file 0xe2 contains 1 bytes
                                                 Using Port                    : COM8
                                                 Hardware Version: 2
                                                 Topcard         : Unknown
                                                 Vtarget         : 0.0 V
                                                 Varef           : 0.0 V
                                                 Oscillator      : Off
                                                 SCK period      : 0.1 us
                                        Reading | ################################################## | 100% 0.05s
                                        avrdude: reading input file "C:\Users\billa\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.1/bootloaders/optiboot_flash/bootloaders/atmega328p/8000000L/optiboot_flash_atmega328p_UART0_38400_8000000L_B5.hex"
                                        avrdude: writing flash (32768 bytes):
                                        avrdude: 32768 bytes of flash written
                                        avrdude: verifying flash memory against C:\Users\billa\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.1/bootloaders/optiboot_flash/bootloaders/atmega328p/8000000L/optiboot_flash_atmega328p_UART0_38400_8000000L_B5.hex:
                                        avrdude: load data flash data from input file C:\Users\billa\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.1/bootloaders/optiboot_flash/bootloaders/atmega328p/8000000L/optiboot_flash_atmega328p_UART0_38400_8000000L_B5.hex:
                                        avrdude: input file C:\Users\billa\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.1/bootloaders/optiboot_flash/bootloaders/atmega328p/8000000L/optiboot_flash_atmega328p_UART0_38400_8000000L_B5.hex contains 32768 bytes
                                        avrdude: 32768 bytes of flash verified
                                        Writing | ################################################## | 100% 0.05s
                                        • G Gilles BILLARD
                                          skywatchS
                                          skywatchS
                                          skywatch
                                          #332
                                          @Gilles-BILLARD I understnad your frustration - I have been there myself.
                                          I suggest s simple node to test with, something like the door/window sensor with just one switch.
                                          Take your promini, remove leds and power regulator (or cut tracks) then burn MiniCore bootloader with 9600 baud, 3.3V, 8MHz INTERNAL, BoD DISABLED.
                                          Then add the radio module (you can try another if you have it - what radio modules are you using? - A link or photo might help, there are bad ones and fakes that could be a problem for you). Load your sketch and try again.
                                          You can measure the current to the whole set up and then just the radio to see if radio is not sleeping. ....
