  2. Announcements
  3. 💬 Battery Powered Sensors
battery
347 Posts 55 Posters 226.6k Views 53 Watching
  • N nekitoss
    @nekitoss said in 💬 Battery Powered Sensors:
    It would be great to add to this arctle that if you want to be battery powered outdoors with temperature below zero - you have to use lithium batteries (FR6 for AA) (yes, batteries, not li-ion accumulators!) (for example ultimate lithium energizer, also could be found lithium batteries from other vendors), because Alkaline (LR6 for AA) will be frozen and loose their capacity heavily. If i remember it is >50% at -10 C and death at -20 C. Same problem for li-ion accumulators - when liquid is frozen - electrons are stucked...
    Also would be great to add some link about battery/accumulator types, advanteges and disadvantages, but i have no links in english, easy-to-read and in one place...
    But i have very great link about battery-powering that really should be added here, but in advanced section:
    http://www.gammon.com.au/power
    @zboblamont how your alkaline batteries experience after 2 years(temperatures, lasting time)? my freshly installed (yes, it was long develop and test...) Lithium AA - when few weeks ago it was -20 .. stopped transmitting! Fixed resetting power when it become little warmer. Possibly same problem with 2.7V or exactly there may be wrong BOD...
    skywatchS
    skywatchS
    skywatch
    #304
    @nekitoss If I were you I;d reflash the bootloader and chec again. I got my pro mini with ebyte nrf24 to work and register with the gateway all the way down to 1.63V, so somethingi is wrong if you are loosing it at 2.7V (which is also as it happens, a BoD setting for atmel 328p). For the test I used minicore bootloader iwth Bod disabled and 2MHz clock. Bench power supply for the voltage variation.
    N 1 Reply Last reply
    • N nekitoss
      zboblamontZ
      zboblamontZ
      zboblamont
      @nekitoss No problems with alkaline power, 6 - 18 months now on 2xAA down to ca -15c, battery voltage reported ca 2 or 3 times per day.
      I vaguely recall reading an article on lithium and alkaline battery behaviour in extreme cold weather, the alkalines were the better performers.
      Note that the pro-minis here use onboard booster and LDO which provide stable 3.3v all the way down to ca 1.8v battery death, so battery voltage is unrelated to system voltage unlike your setup. They also use rfm69s (433MHz) which are better able to penetrate structural obstacles.
      Bear in mind that if you have comms problems this can substantially reduce battery life as it does not quickly waken, perform the task and go back to deep sleep
      • skywatchS
        skywatchS
        skywatch
        #306
        @mfalkvidd
        Nice job on updating the infor BTW :)
        • Puneit ThukralP
          Puneit ThukralP
          Puneit Thukral
          Adding on to this.. If we use a map function to convert the battery level like this, then it shows up as an attribute in HomeAssistant and Homekit
          Map function works and not the percent. The percent always shows as zero in Homekit.
          Hope this helps someone!
          void battery()
            long batteryMillivolts = hwCPUVoltage();
            int batteryV =batteryMillivolts /1000 + 0.5;
            auto batteryLevel = map(batteryV,EMPTY_BATTERY, FULL_BATTERY, 0, 100);
            if (batteryLevel > 100)
            {batteryLevel=100;}
          #ifdef MY_DEBUG
            Serial.print("Battery voltage: ");
            Serial.print(batteryMillivolts / 1000.0);
            Serial.println("V");
            Serial.print("Battery Level ");
            Serial.print(batteryLevel);
            Serial.println(" %");
            if (oldBatteryLevel != batteryLevel) {
              sendBatteryLevel(batteryLevel);
              send(msgV.set(batteryV,2));
              oldBatteryLevel = batteryLevel;
          ![Home Assistant](812c9e02-8b21-44dc-ab8d-04559bf38462-image.png image url)
          IHomeKit
          • skywatchS skywatch
            N
            N
            nekitoss
            @skywatch Thank you very much! Your advice helped. Not shure what it was on BOTH devices - my mistake or some corruption of fuses/program.
            On first device (where i found problem) - there were different fuse bits (but according to my eyes BOD was even disabed, but not shure). On the second (where i tested) fuses were checked and were correct. I tried to play with fuses and erase chip... and something strange happened - or chip memory was broken or i can't verify program when box "erase flash and eeprom" is checked... so i took fresh nano, programmed it and resoldered MCU into the second device.
            So both devices now are fixed and tested - both work till ~1.9V.
            Thanks, you saved my brains!
            skywatchS 1 Reply Last reply
            • N nekitoss
              skywatchS
              skywatchS
              skywatch
              @nekitoss Yay! :)
              Well done on getting it working!
              • G
                G
                Gilles BILLARD
                Hi from France;
                I've tried everything I could and no way to put My temp. sensor to deep sleep.
                so I went back to the very beginning with a bare Pro-Min 3.3v and I tryed this:
                #include <LowPower.h>
                pinMode(13, OUTPUT);
                digitalWrite(13, HIGH);
                delay(1000);
                digitalWrite(13, LOW);
                My boad is going to sleep;
                YEEEESSS ! the pb is NOT comming from the board itself....eating a bunch ou micro amp;
                Then I've added the minimum requested to make a MySensor extension and I tried this:
                #define MY_RADIO_NRF24 // Choix du module radio
                #define MY_RF24_PA_LEVEL (RF24_PA_HIGH) //CHOIX: RF24_PA_MIN; RF24_PA_LOW; RF24_PA_HIGH; RF24_PA_MAX
                #define RF24_CHANNEL 76
                #define RF24_DATARATE RF24_250KBPS
                delay(1000);
                The boad stays awaken (4 mA current)
                So may be the problem is comming from LowPower library...
                I tried this minimal prgm recommended in a tutorial, using MySensors library and SLEEP function:
                #define MY_RADIO_RF24
                uint32_t SLEEP_TIME = 900000; // sleep time between reads (in seconds * 1000 )
                int oldBatteryPcnt = 0;
                #define FULL_BATTERY 3 // 3V for 2xAA alkaline. Adjust if you use a different battery setup.
                sendSketchInfo("Battery Meter", "1.0");
                // get the battery Voltage
                int batteryPcnt = batteryMillivolts / FULL_BATTERY / 1000.0 * 100 + 0.5;
                oldBatteryPcnt = batteryPcnt;
                sleep(SLEEP_TIME);
                NO WAY AGAIN; The board is still eating 4mA all the way long.
                I'm lost !!!! Please HELP ME ....
                E 1 Reply Last reply
                • G Gilles BILLARD
                  Hi from France;
                  delay(1000);
                  delay(1000);
                  sleep(SLEEP_TIME);
                  E
                  E
                  evb
                  @Gilles-BILLARD Using the lowpower lib and mysensors lib together will probably give conflicts, so you should avoid it. MySensors lib implements the same low power tricks.
                  When doing the latest test sketch, are you doing this also with a bare pro-mini 3.3V?
                  So not connected to anything, no radio, no sensor?
                  Try the same latest sketch, but set everything inside the loop() in comment except the sleep line.
                  • G
                    G
                    Gilles BILLARD
                    Thanks EVB;
                    1. Yes; Last test with a bare pro-mini 3.3v
                    2. I did that...
                    //    // get the battery Voltage
                    //    long batteryMillivolts = hwCPUVoltage();
                    //    int batteryPcnt = batteryMillivolts / FULL_BATTERY / 1000.0 * 100 + 0.5;
                    //    if (oldBatteryPcnt != batteryPcnt) {
                    //      sendBatteryLevel(batteryPcnt);
                    //      oldBatteryPcnt = batteryPcnt;
                      sleep(SLEEP_TIME);
                    Again : 4.2mA (no sleep )
                    So sad ! :disappointed_relieved:
                    • skywatchS
                      skywatchS
                      skywatch
                      #313
                      @Gilles-BILLARD IT took me some time to work it out and get it working.
                      I suggest you install MiniCore library - it is easy to follow simple steps and takes a minute or two.
                      Then burn a bootloader into the atmega, I always use 3.3V, disable BoD and 4MHz or 8MHz internal clock. You can use one arduino to program another or just get a USB programmer from your preferred source (about $2).
                      Once your pro mini is booeloaded and you have your sketch in installed , remove the Power LED (or the series resistor for the LED) and also remove the voltage regulator (or cut the tracks as shown in the battery powered page).
                      You won't get down to <10uA in sleep unless you do all of this.
                      G 1 Reply Last reply
                      • G
                        G
                        Gilles BILLARD
                        wrote on last edited by Gilles BILLARD
                        #314
                        Thanks Skywatch,
                        My Pro-Mini boards are comming from Aliexpress, so, I was also thinking about the bootloader... what else ?
                        I'll do what you explain ASAP and be back to say what...
                        BTW: I already have cut the tracks powering the LED & regulator
                          G
                          G
                          Gilles BILLARD
                          #315
                          @skywatch NO WAY ! So bad !
                          I burned the MiniCore bootloader quite eazily using a second Pro-Mini loaded with Arduino BootLoader ( juste a file name error; looking for optiboot_flash_atmega328p_UART1_115200_16000000L_B5.hex but only optiboot_flash_atmega328p_UART0_115200_16000000L_B5.hex on the folder, so I just changed 0-->1 in the file name) and the résult was:
                          avrdude: Version 6.3-20201216
                               System wide configuration file is "C:\Users\billa\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.0/avrdude.conf"
                               Using Port                    : COM7
                               Programmer Type : STK500
                               Hardware Version: 2
                               Firmware Version: 1.18
                               Topcard         : Unknown
                               Vtarget         : 0.0 V
                               Varef           : 0.0 V
                               Oscillator      : Off
                               SCK period      : 0.1 us
                          Reading | ################################################## | 100% 0.04s
                          avrdude: erasing chip
                          avrdude: reading input file "C:\Users\billa\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.0/bootloaders/empty/empty.hex"
                          avrdude: writing flash (0 bytes):
                          avrdude: 0 bytes of flash written
                          avrdude: verifying flash memory against C:\Users\billa\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.0/bootloaders/empty/empty.hex:
                          avrdude: load data flash data from input file C:\Users\billa\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.0/bootloaders/empty/empty.hex:
                          avrdude: input file C:\Users\billa\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.0/bootloaders/empty/empty.hex contains 0 bytes
                          avrdude: verifying ...
                          avrdude: 0 bytes of flash verified
                          avrdude: reading input file "0x0f"
                          Writing | ################################################## | 100% 0.04s
                          avrdude: verifying lock memory against 0x0f:
                          avrdude: load data lock data from input file 0x0f:
                          avrdude: input file 0x0f contains 1 bytes
                          avrdude done. Thank you.
                          Then I loaded it with Blink demo...
                          At this point all's OKay. Both Po-Mini are blinking
                          Blink
                          Then I've loaded the 2nd with that:
                          uint32_t SLEEP_TIME = 4000;  // sleep time (in seconds * 1000 )
                          pinMode(LED_BUILTIN, OUTPUT);
                            sendSketchInfo("Test Prgm", "1.0"); // Send the sketch version information to the gateway and Controller
                            digitalWrite(LED_BUILTIN, HIGH);
                          delay(1000);
                            digitalWrite(LED_BUILTIN, LOW);
                          delay(1000);
                          sleep(SLEEP_TIME);
                          and...
                          the result is...
                          No blinking
                          NO BLINK
                          (draining more or less 2mA; Varying quickly from 1600uA to 2000uA; I should put a scope probe on that....)
                          YveauxY T 2 Replies Last reply
                          • G Gilles BILLARD
                                 Using Port                    : COM7
                                 Hardware Version: 2
                                 Topcard         : Unknown
                                 Vtarget         : 0.0 V
                                 Varef           : 0.0 V
                                 Oscillator      : Off
                                 SCK period      : 0.1 us
                            Blink
                            delay(1000);
                            delay(1000);
                            sleep(SLEEP_TIME);
                            and...
                            the result is...
                            No blinking
                            NO BLINK
                            @Gilles-BILLARD from the photos it seems you didn't connect a radio. If that is the case, the loop will not be entered and your arduino won't sleep!
                            • YveauxY Yveaux
                              G
                              G
                              Gilles BILLARD
                              @Yveaux
                              YESSSSSS !<
                              That was the last problèm to solve.
                              Back with my own MySensors routine all is perfect ! (8uA in sleep mode)
                              I am very happy now and I thank all those who assisted me.
                              You've made my day !
                              Gilles
                              • G Gilles BILLARD
                                @Yveaux
                                YESSSSSS !<
                                Gilles
                                skywatchS
                                skywatchS
                                skywatch
                                @Gilles-BILLARD @Yveaux beat me to it! - But I bet you are a very happy person after that - it is easy when you know how! :)
                                • G Gilles BILLARD
                                       Using Port                    : COM7
                                       Hardware Version: 2
                                       Topcard         : Unknown
                                       Vtarget         : 0.0 V
                                       Varef           : 0.0 V
                                       Oscillator      : Off
                                       SCK period      : 0.1 us
                                  Blink
                                  delay(1000);
                                  delay(1000);
                                  sleep(SLEEP_TIME);
                                  and...
                                  the result is...
                                  No blinking
                                  NO BLINK
                                  tssk
                                  @Gilles-BILLARD Damn! Why did I order UNO if I could use another Pro Mini for programming... :)
                                  • T tssk
                                    G
                                    G
                                    Gilles BILLARD
                                    @tssk My Pro-Mini's are 3.3V, so this way I avoid the resistors dividers wiring to change 5V (Uno) to 3.3 (Pro-Mini);
                                    May be you love creating problems where there are none ;-)
                                    • G
                                      G
                                      Gilles BILLARD
                                      #321
                                      Hy guys; So sorry but the procedure ran just once :-/
                                      When I reproammed my soldred Pro-Minis (via the radio socket + 1 air wire to the reset pin) none was running as expected; The issue was a kind of permanent reboot..????
                                      I tried to burn the MinCore bootloader and load my sketch into several brand new boards and the result was the same...
                                      So I simplified and simplified again the sketches until this one:
                                      /*This sketch is cycling wether you comment MY-DEBUG.....
                                      SERIAL MONITOR report:
                                                2021-04-04 17:20:04.426 Status: MySensors: Node: 20, Sketch Name: Temperature Sensor Test
                                                2021-04-04 17:20:04.426 Status: MySensors: Node: 20, Sketch Version: G.B.
                                                2021-04-04 17:20:15.378 (GiBi-Home) Temp (Temptest)
                                                2021-04-04 17:20:15.368 Status: MySensors: Node: 20, Sketch Name: Temperature Sensor Test
                                                2021-04-04 17:20:15.368 Status: MySensors: Node: 20, Sketch Version: G.B.
                                      ......or running as it should do if you uncomment MY-DEBUG
                                                2021-04-04 17:22:52.558 Status: MySensors: Node: 20, Sketch Name: Temperature Sensor Test
                                                2021-04-04 17:22:52.558 Status: MySensors: Node: 20, Sketch Version: G.B.
                                                2021-04-04 17:23:02.654 (GiBi-Home) Temp (Temptest)
                                                2021-04-04 17:23:12.717 (GiBi-Home) Temp (Temptest)
                                                2021-04-04 17:23:22.781 (GiBi-Home) Temp (Temptest)
                                      NOTA: wether bootLoader is ordinary AVR bootloader or MiniCore's one
                                      #include <OneWire.h>
                                      #define ONE_WIRE_BUS 3 // Pin E/S de mesure
                                      OneWire oneWire(ONE_WIRE_BUS); // Instanciation du OneWire
                                      DallasTemperature sensors(&oneWire); // Passage de l'instance du OneWire à Dallas Temperature.
                                      MyMessage msg(0,V_TEMP); // Init temp msg
                                      void before()
                                          sensors.begin();// démarre le OneWire
                                        sendSketchInfo("Temperature Sensor Test", "GB.1.0");
                                        present(0, S_TEMP);
                                          float (temperature) = sensors.getTempCByIndex(0);   // acquisition du résultat
                                          temperature = float(int(temperature * 10)) / 10;    // cast pour 1 seul chiffre après la virgule
                                          send(msg.setSensor(0).set(temperature,1));
                                          sensors.requestTemperatures(); // ordre de mesure
                                          // ************Sleeping test ***************
                                          #ifdef MY_DEBUG
                                              delay(10000); // 10 secondes
                                              sleep(10000);
                                      and then this one
                                      // Simplest test to to highlight my problèm
                                      // Ordinary delay function used on DEBUG
                                      // Sleep is used without DEBUG
                                      // Successiv Serial prints should be printed if loop entered
                                       Without DEBUG Serial monitor screen copy
                                       ⸮⸮ `_⸮       ⸮ߟ⸮
                                      ⸮  ⸮o  ⸮⸮   ⸮/ _⸮⸮⸮` ⸮⸮⸮ ⸮ ⸮⸮ `ߟ⸮  ⸮⸮⸮  ⸮ ⸮⸮`⸮⸮⸮
                                      ⸮ ⸮⸮/⸮ ⸮ ⸮ ⸮ ⸮_⸮⸮ ⸮ / ⸮ ⸮ `⸮ ⸮/ ⸮⸮⸮/ ⸮`⸮⸮ ⸮⸮⸮/ ⸮⸮⸮
                                      ⸮⸮⸮  ⸮_⸮⸮⸮⸮, |⸮_⸮⸮/ ⸮⸮ߟ⸮⸮⸮ ⸮⸮⸮_⸮⸮/⸮⸮⸮_/⸮⸮⸮  ⸮⸮⸮⸮/
                                              ⸮⸮ߟ/`                    `2.3.2
                                      ⸮é⸮u⸮ ⸮⸮ ⸮⸮⸮⸮
                                       ⸮⸮  ⸮⸮       ⸮ߟ⸮
                                      ⸮  ⸮/  ⸮⸮   ⸮/ ⸮⸮⸮⸮  ⸮⸮⸮ ⸮ ⸮⸮  ߟ⸮  ⸮⸮⸮  ⸮ ⸮⸮ ⸮_⸮
                                      ⸮ ⸮⸮/⸮ ⸮ ⸮`⸮ ܟ⸮⸮ ⸮ / ⸮ ⸮ ⸮⸮`⸮/`⸮⸮⸮/ ⸮ ⸮⸮ ⸮ߟ/ ⸮⸮⸮
                                      ⸮`⸮ `⸮`⸮ ⸮⸮⸮ ⸮⸮⸮⸮⸮ ⸮ `ߟ/ ⸮`⸮`ܟ⸮ ⸮ `⸮` ⸮ ⸮  ܟ⸮ ⸮
                                      ⸮⸮⸮ `⸮⸮⸮⸮⸮⸮, ⸮⸮⸮⸮⸮/ ⸮⸮ߟ⸮⸮⸮ ⸮⸮⸮⸮ߟ/ܟ⸮⸮o⸮⸮⸮` ⸮⸮⸮⸮o
                                       `  ` ` ⸮⸮ߟo`` `  `  `  ``        2.3.2
                                      ⸮⸮i⸮⸮⸮`⸮⸮`⸮⸮⸮⸮
                                      ⸮  ⸮/` ⸮⸮ ` ⸮/ ⸮ߟ⸮  ⸮⸮⸮`⸮ ߟ `⸮ߟ `⸮⸮⸮ `⸮`⸮⸮ ⸮ߟ
                                      ⸮ ⸮⸮/⸮ ⸮ ⸮ ⸮ ⸮ߟ⸮ ⸮ / ⸮ ⸮ ⸮⸮ ⸮o`ߟ⸮/`⸮`⸮⸮ ⸮ߟo ⸮⸮⸮
                                      ⸮`⸮  ⸮ ⸮ ⸮⸮⸮ ⸮_⸮⸮⸮`⸮``⸮⸮/`⸮ ⸮ ⸮⸮⸮ ⸮ `⸮` ⸮`⸮ `⸮ߟ`⸮
                                      ⸮⸮⸮` ⸮⸮⸮⸮ߟl`⸮⸮⸮⸮⸮o`⸮ߟ⸮⸮⸮⸮ ⸮⸮⸮ߟ⸮/⸮⸮⸮⸮o⸮⸮⸮ `⸮⸮⸮⸮/
                                       `      ⸮⸮⸮⸮/   `   ``` ```        2.3.r
                                      etc....
                                      * With DEBUG Serial monitor screen copy
                                      ⸮  ⸮/  ⸮⸮`  ⸮/ ⸮⸮⸮⸮  ߟ⸮`⸮ ⸮⸮` ⸮⸮⸮  ߟ⸮` ⸮ ⸮⸮`⸮⸮⸮
                                      ⸮ ⸮⸮o⸮ ⸮ ⸮ ⸮ ⸮_⸮⸮ \ / ⸮ ⸮ ⸮_ ⸮/ ⸮⸮⸮/ ⸮ ⸮| ⸮⸮⸮o ⸮⸮⸮
                                      ⸮ ⸮` ⸮`⸮ ⸮⸮⸮ ⸮⸮_⸮⸮ ⸮  ⸮⸮/ ⸮ ⸮ ⸮⸮⸮`⸮  ⸮ `⸮`⸮` ⸮ߟ ⸮
                                      ⸮⸮⸮` ⸮⸮⸮ܟ⸮,`⸮⸮ߟ⸮o ⸮ߟ⸮⸮⸮⸮`⸮⸮⸮⸮⸮⸮/\⸮⸮⸮o⸮⸮⸮` ⸮ߟ⸮/
                                              ⸮ߟ⸮/ ` ` `                2.3.2
                                      16 ̓⸮:⸮⸮⸮:⸮Ή⸮`⸮⸮⸮⸮,⸮⸮=⸮Ύ΁---,⸮Q=8,⸮⸮⸮=2u5,⸮E⸮=2.3.2
                                      28 ⸮⸮⸮:⸮⸮⸮⸮
                                      28 T⸮⸮:⸮⸮⸮:⸮⸮=0
                                      s6`⸮⸮⸮:⸮Ή⸮:⸮Ӑ ⸮⸮
                                      38`⸮⸮⸮:⸮I⸮:⸮K,⸮D=25
                                      40 ⸮⸮⸮z⸮Ё⸮
                                      45 ?⸮⸮⸮z⸮⸮⸮:⸮⸮⸮⸮,25-25-255-255,⸮=255,⸮=3,⸮=7,⸮t=0,l=0,⸮⸮}0l⸮⸮}0,⸮⸮=⸮⸮:
                                      10t0`ԓ⸮:⸮⸮⸮:⸮⸮⸮⸮,0-0-25,⸮=255,⸮}3,⸮=x,⸮⸮=1,⸮=1,sg=0:0
                                      1046 T⸮⸮:⸮⸮⸮:⸮⸮⸮R ⸮⸮,Ʉ=0,⸮=1
                                      20u4 ⸮⸮⸮:⸮Ё⸮zϋ
                                      2054 ⸮S⸮:⸮⸮
                                      2056 ⸮⸮⸮:⸮⸮:⸮⸮
                                      2058 ԓ⸮:⸮Ќ
                                      2064 ⸮⸮⸮:⸮⸮⸮:⸮⸮⸮⸮,25-25-0-0,⸮=255l⸮=s,⸮}24l⸮⸮=1,⸮=q,⸮⸮=0,⸮⸮=0l⸮⸮=⸮⸮:1
                                      2076 ⸮⸮⸮:⸮S⸮:⸮⸮⸮⸮,0-0-25,⸮=255l⸮=3,⸮=25,⸮⸮=1,⸮=1,⸮⸮=0:1
                                      2082 ⸮S⸮:⸮⸮⸮:⸮⸮⸮⸮ ⸮⸮C⸮,H⸮=1
                                      2084 ⸮⸮⸮zՐ⸮z⸮⸮
                                      2086 ⸮⸮⸮:⸮⸮⸮ę:⸮⸮=25,⸮⸮⸮=0,⸮⸮⸮=1
                                      2099 ⸮⸮⸮:⸮⸮⸮:⸮⸮⸮⸮,25-25-0-0,⸮=255,⸮=3,t=15,⸮⸮=6,⸮=2,⸮⸮=0,⸮⸮=0,⸮⸮=⸮⸮:0100
                                      2107 ⸮S⸮:⸮Ӈ:⸮Ł⸮,0-0-25,⸮=255,⸮=3,⸮=q5,⸮⸮}6l⸮}2,⸮⸮}0z0q00
                                      2117 ⸮⸮⸮:⸮Ӈ:⸮Ŏ⸮,ru-25-0m0,⸮=255,⸮=0,⸮=17,⸮⸮=0,⸮}5,⸮⸮}p,⸮⸮=p,⸮⸮}⸮⸮:2.3.2
                                      21r9 ⸮⸮⸮:⸮⸮⸮:⸮⸮⸮⸮,25-25-0-0,⸮=255,⸮=3,⸮=6,⸮⸮=1,⸮=1,⸮⸮}0,⸮⸮=0l⸮⸮=⸮⸮:p
                                      2142 ⸮⸮⸮:M⸮⸮:⸮E⸮⸮,p-p-25,⸮=255,⸮}sl⸮}vl⸮⸮}0,⸮=1,s⸮=0:⸮
                                      2154 ⸮⸮⸮:⸮⸮⸮:⸮⸮⸮⸮,25-25-0-0,⸮=r55,⸮=3,⸮=11,⸮⸮=0,⸮}9,⸮⸮=0l⸮⸮=0,⸮⸮}⸮⸮z⸮⸮⸮⸮ ⸮⸮⸮⸮
                                      r1v6 ⸮⸮⸮:⸮⸮⸮:⸮⸮⸮⸮,25m25-0-0l⸮=r55,⸮=3,⸮=12,pt=0,⸮}6l⸮⸮=p,⸮⸮=0,⸮⸮=⸮⸮:⸮⸮.2np
                                      217t ̓⸮z⸮⸮⸮:⸮⸮Q
                                      2179 ⸮⸮⸮:M⸮⸮:⸮⸮⸮⸮,25-25-0-0,⸮=255,⸮=3,⸮=26,⸮⸮=1,l=1,⸮⸮=0,⸮⸮=0,⸮⸮}ϋ:2
                                      2187 ԓ⸮:͓⸮:⸮Ł⸮,p-0m2u,⸮=25u,⸮}3,⸮=27l⸮⸮=1,l=1,⸮⸮=0z1
                                      r1ys ⸮⸮⸮:Љ⸮z⸮⸮ą`⸮Ň=q
                                      2q97`⸮⸮⸮:⸮G⸮:⸮T⸮
                                      2199 ̓⸮z‡⸮:⸮⸮⸮T ⸮⸮,⸮⸮⸮=1
                                        Serial.println ("Début du test");
                                        sendSketchInfo("Test Prgm", "GB.2.0"); // Send the sketch version information to the gateway and Controller
                                      Serial.print (":.");
                                      #ifdef MY_DEBUG
                                              sleep(10000);
                                      I have included the Domoticz log in the 1st one and the serial monitor report for the 2nd.
                                      You can see, if "delay(xxx)" is in use, all's Okay, but if "sleep(xxx) is employed, the sketch is cycling in both sketches....
                                      What is happening?
                                      Prog.setup
                                      Test setup
                                      • G Gilles BILLARD
                                        void before()
                                          present(0, S_TEMP);
                                            #ifdef MY_DEBUG
                                                sleep(10000);
                                        and then this one
                                         ⸮⸮ `_⸮       ⸮ߟ⸮
                                                ⸮⸮ߟ/`                    `2.3.2
                                        ⸮é⸮u⸮ ⸮⸮ ⸮⸮⸮⸮
                                         ⸮⸮  ⸮⸮       ⸮ߟ⸮
                                        ⸮⸮i⸮⸮⸮`⸮⸮`⸮⸮⸮⸮
                                        etc....
                                                ⸮ߟ⸮/ ` ` `                2.3.2
                                        28 ⸮⸮⸮:⸮⸮⸮⸮
                                        28 T⸮⸮:⸮⸮⸮:⸮⸮=0
                                        s6`⸮⸮⸮:⸮Ή⸮:⸮Ӑ ⸮⸮
                                        38`⸮⸮⸮:⸮I⸮:⸮K,⸮D=25
                                        40 ⸮⸮⸮z⸮Ё⸮
                                        20u4 ⸮⸮⸮:⸮Ё⸮zϋ
                                        2054 ⸮S⸮:⸮⸮
                                        2056 ⸮⸮⸮:⸮⸮:⸮⸮
                                        2058 ԓ⸮:⸮Ќ
                                        2084 ⸮⸮⸮zՐ⸮z⸮⸮
                                        217t ̓⸮z⸮⸮⸮:⸮⸮Q
                                        2q97`⸮⸮⸮:⸮G⸮:⸮T⸮
                                        #ifdef MY_DEBUG
                                                sleep(10000);
                                        What is happening?
                                        Prog.setup
                                        Test setup
                                        @Gilles-BILLARD what pro minis are you using? The 3v3 version only goes to 57600 baud, so 115200 is likely too much
                                        • YveauxY Yveaux
                                          G
                                          G
                                          Gilles BILLARD
                                          @Yveaux Yes Yveaux, you're probably righ, but, if I use AVR bootloader and Test Nb 2 the serial monitor says:
                                           __  __       ____
                                                  |___/                      2.3.2
                                          16 MCO:BGN:INIT NODE,CP=RNNNA---,FQ=8,REL=255,VER=2.3.2
                                          28 TSM:INIT
                                          28 TSF:WUR:MS=0
                                          36 TSM:INIT:TSP OK
                                          38 TSF:SID:OK,ID=20
                                          40 TSM:FPAR
                                          45 ?TSF:MSG:SEND,20-20-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                          657 TSF:MSG:READ,0-0-20,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                          663 TSF:MSG:FPAR OK,ID=0,D=1
                                          2054 TSM:FPAR:OK
                                          2054 TSM:ID
                                          2056 TSM:ID:OK
                                          2058 TSM:UPL
                                          2062 TSF:MSG:SEND,20-20-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                                          2070 TSF:MSG:READ,0-0-20,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                          2076 TSF:MSG:PONG RECV,HP=1
                                          2080 TSM:UPL:OK
                                          2082 TSM:READY:ID=20,PAR=0,DIS=1
                                          2086 TSF:MSG:SEND,20-20-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                          2095 TSF:MSG:READ,0-0-20,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                          2105 TSF:MSG:SEND,20-20-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.3.2
                                          2115 TSF:MSG:SEND,20-20-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                                          2125 TSF:MSG:READ,0-0-20,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                                          2134 TSF:MSG:SEND,20-20-0-0,s=255,c=3,t=11,pt=0,l=9,sg=0,ft=0,st=OK:Test Prgm
                                          2146 TSF:MSG:SEND,20-20-0-0,s=255,c=3,t=12,pt=0,l=6,sg=0,ft=0,st=OK:GB.2.0
                                          2154 MCO:REG:REQ
                                          2156 TSF:MSG:SEND,20-20-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                                          2164 TSF:MSG:READ,0-0-20,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                          2170 MCO:PIM:NODE REG=1
                                          2174 MCO:BGN:STP
                                          Début du test
                                          2177 MCO:BGN:INIT OK,TSP=1
                                          and Domoticz log is:
                                          2021-04-08 08:08:24.328 Status: MySensors: Node: 20, Sketch Name: Test Prgm
                                          2021-04-08 08:08:24.329 Status: MySensors: Node: 20, Sketch Version: GB.2.0
                                          NB: On the Sérial monitor, only the last line matters
                                          One more point: Once the Pro-Minis are burnt with MiniCore library, I'm not able to revert on standard AVR bootloader; They are somehow bricked on MiniCore bootloader
                                          G skywatchS 2 Replies Last reply
