  2. Announcements
  3. 💬 Relay
💬 Relay
139 Posts 47 Posters 78.7k Views 45 Watching
  • J
    J
    jimmy loyens
    wrote on last edited by jimmy loyens
    #130
    • badmannenB
      badmannenB
      badmannen
      wrote on last edited by badmannen
      #131
      I am having this particular switch to be recognized in "Mozilla WEBTHINGS".
      IS there some issue with having a repeater node and sensors/switches etc attaches to it? .. it sends in the data as it should when I check with MYSController and I can switch it from there with sending "V_STATUS" messages. but no luck so far of getting the sensors appear in WEBTHINGS , every other sensor works fine.
      rPi 3 - UNO R3 - Mini - Nano - custom
        Seawolf
        #define MY_RADIO_RF24
        //#define MY_RADIO_RFM95
        #define MY_GATEWAY_ESP8266
        #define MY_WIFI_SSID "SSID"
        #define MY_WIFI_PASSWORD "PSW"
        // Enable UDP communication
        //#define MY_USE_UDP // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS or MY_CONTROLLER_URL_ADDRESS below
        #define MY_HOSTNAME "ESP8266_GW"
        //#define MY_IP_ADDRESS 192,168,0,0
        #define MY_PORT 5003
        //#define MY_CONTROLLER_URL_ADDRESS "my.controller.org"
        // Enable inclusion mode
        //#define MY_INCLUSION_MODE_BUTTON_PIN D1
        // Set blinking period
        // Flash leds on rx/tx/err
        //#define MY_DEFAULT_ERR_LED_PIN 16 // Error led pin
        //#define MY_DEFAULT_RX_LED_PIN 16 // Receive led pin
        //#define MY_DEFAULT_TX_LED_PIN 16 // the PCB, on board LED
        #define LWIP_OPEN_SRC whatever
        #define TCP_MSS whatever
        #define LWIP_IPV6 whatever
        #define LWIP_FEATURES whatever
        //DHT with autodetection
        #include <dhtnew.h>
        DHTNEW mySensor(5); // ESP 16 UNO 6
        uint32_t count = 0;
        uint32_t start, stop;
        uint32_t errors[10] = { 0,0, 0,0, 0,0, 0,0, 0,0 };
        //Domoticz
        #define CHILD_ID_HUM 2
        #define CHILD_ID_TEMP 3
        sendSketchInfo("TemperatureAndHumidity", "1.1");
        present(CHILD_ID_HUM, S_HUM);
        Serial.println("DHT_endless.ino");
        Serial.print("LIBRARY VERSION: ");
        Serial.println(DHTNEW_LIB_VERSION);
        Serial.println();
        count++;
        // show counters for OK and errors.
        if (count % 50 == 0)
        Serial.println();
        Serial.println("OK \tCRC \tTOA \tTOB \tTOC \tTOD \tSNR \tBS \tUNK");
        for (uint8_t i = 0; i < 9; i++)
        Serial.print(errors[i]);
        Serial.print('\t');
        Serial.println();
        Serial.println();
        if (count % 10 == 0)
        Serial.println();
        Serial.println("TIM\tCNT\tSTAT\tHUMI\tTEMP\tTIME\tTYPE");
        Serial.print(millis());
        Serial.print("\t");
        Serial.print(count);
        Serial.print("\t");
        start = micros();
        int chk = mySensor.read();
        stop = micros();
        switch (chk)
        case DHTLIB_OK:
        Serial.print("OK,\t");
        errors[0]++;
        case DHTLIB_ERROR_CHECKSUM:
        Serial.print("CRC,\t");
        errors[1]++;
        case DHTLIB_ERROR_TIMEOUT_A:
        Serial.print("TOA,\t");
        errors[2]++;
        case DHTLIB_ERROR_TIMEOUT_B:
        Serial.print("TOB,\t");
        errors[3]++;
        case DHTLIB_ERROR_TIMEOUT_C:
        Serial.print("TOC,\t");
        errors[4]++;
        case DHTLIB_ERROR_TIMEOUT_D:
        Serial.print("TOD,\t");
        errors[5]++;
        case DHTLIB_ERROR_SENSOR_NOT_READY:
        Serial.print("SNR,\t");
        errors[6]++;
        case DHTLIB_ERROR_BIT_SHIFT:
        Serial.print("BS,\t");
        errors[7]++;
        default:
        Serial.print("U");
        Serial.print(chk);
        Serial.print(",\t");
        errors[8]++;
        // DISPLAY DATA
        #ifdef MY_DEBUG
        Serial.print(mySensor.getHumidity(), 1);
        Serial.print(mySensor.getTemperature(), 1);
        Serial.print(stop - start);
        Serial.println(mySensor.getType());
        //send to gateway
        float humidity = mySensor.getHumidity();
        float temperature = mySensor.getTemperature();
        delay(3000);
        // -- END OF FILE --
          Seawolf
          I was so happy to have finaly a fonctionnal sketch for my esp8266 gateway whith the DHT22 that i post directly my code.
          I hope that it will help some people.
          based on: https://github.com/RobTillaart/DHTNew/blob/master/examples/dhtnew_endless/dhtnew_endless.ino
          • joaoabsJ
            joaoabsJ
            joaoabs
            Trying to go deep on the API and come this this doubt: The second example (with button) the child seems to be declared as "S_LIGHT" and the receiving messages are "V_LIGHT", while the first example seems better suitable for a relay (child as "S_BINNARY" and requests as "V_STATUS").
            I haven't found any "S_LIGHT" or "V_LIGHT" in the API, only "S_LIGHT_LEVEL" and "V_LIGHT_LEVEL". What is the most suitable type for a relay node with a local button?
            skywatchS 1 Reply Last reply
            • joaoabsJ joaoabs
              skywatchS
              skywatchS
              skywatch
              #135
              @joaoabs A realy usually has only 2 states, on and off. So I would use S-BINARY and V_STATUS every time.
              A changeover realy also has 2 states so again I would go for binary and status.
              Light_Level is more suited to getting light levels from a sensor or sending a light level to a dimmable light.
              • TheoLT
                TheoLT
                TheoL
                Not sure if it ever has mentioned before, but the first example contains
                Which results in a compile error
                MySensors.h:287:4: error: #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
                It should be:
                And then it compiles and works :)
                • TheoLT TheoL
                  It should be:
                  #137
                  @TheoL which version of MySensors are you using when compiling?
                  The change from NRF24 to RF24 was intentional.
                  https://github.com/mysensors/MySensorsArduinoExamples/commit/36bee0b7426cc3955d23b3f4918da64fd2cc49ad#diff-1252bb46b9b35d77138b7fd96c37e4d3efa629af89ac0d1c2302cde6cf755ea4
                  Documentation: https://www.mysensors.org/apidocs/group__RF24SettingGrpPub.html#gad9d7b3f6173e32fa96468e05b901acba
                  TheoLT 1 Reply Last reply
                    TheoLT
                    TheoLT
                    TheoL
                    @mfalkvidd I'm in an older version I discovered. Ran across more small differences.
                    • TheoLT TheoL
                      skywatchS
                      skywatchS
                      skywatch
                      @TheoL Sound like a good time to update to the latest version. it is the best yet and very stable.
