  3. Mini Weather Station
42 Posts 18 Posters 26.0k Views 17 Watching
  • J
    J
    jtm312
    wrote on last edited by jtm312
    This is a new mini weather station that I have been working on.
    It provides Temperature, Humidity, Pressure, and Battery Voltage.
    The case is designed to be printed without the need for any support, has vents in the front and sides. The front slides on to make it easy to replace the 9v battery. It is designed to take a 50x70mm prototype board. This gives heaps of room for the sensors.
    The 3d files can be found on http://www.thingiverse.com/thing:704715
    The code is mostly a refactor from the examples in the MySensors libraries, with a simplification of the forecast algorithm to reduce the amount of memory that it uses.
    #include <Adafruit_BMP085.h>
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    #define CHILD_ID_BARO 2
    #define CHILD_ID_BARO_TEMP 3
    #define SLEEP_MINUTE 60000
    #define SLEEP_FIVE_MINUTES 300000
    DHT dht;
    Adafruit_BMP085 bmp = Adafruit_BMP085();      // Digital Pressure Sensor
    float   lastTemp = -1.0;
    float   lastHum = -1.0;
    float   lastBaroTemp = -1.0;
    int     lastForecast = -1;
    char    *weather[] = { "Stable", "Sunny", "Cloudy", "Unstable", "Thunderstorm",	"Unknown" };
    int     minutes;
    int     pressureSamples[5];
    float   lastPressureAvg = -1.0;
    int     lastPressure = -1;
    int     minuteCount = 0;
    float   pressureAvg;
    int     pressure;
    float   dP_dt;
    boolean metric = true;
    MyMessage msgBaroTemp(CHILD_ID_BARO_TEMP, V_TEMP);
    MyMessage msgBaro(CHILD_ID_BARO, V_PRESSURE);
    MyMessage msgForecast(CHILD_ID_BARO, V_FORECAST);
    	analogReference(INTERNAL);
    	gw.begin();
    	if (!bmp.begin()) {
    		Serial.println("Could not find a valid BMP085 sensor, check wiring!");
    	gw.sendSketchInfo("Mini Weather Station", "3.2");
    	gw.present(CHILD_ID_BARO, S_BARO);
    	gw.present(CHILD_ID_BARO_TEMP, S_TEMP);
      	Serial.print("minuteCount = ");
    	Serial.println(minuteCount);
            // The pressure Sensor Stuff
    	int forecast = SamplePressure();
            if ( minuteCount > 4 ) { // only every 5 minutes
                    // Process the barometric sensor data
            	float baro_temperature = bmp.readTemperature();
            	if (!metric) {    // Convert to fahrenheit
            		baro_temperature = baro_temperature * 9.0 / 5.0 + 32.0;
            	if (baro_temperature != lastBaroTemp) {
            		gw.send(msgBaroTemp.set(baro_temperature, 1));
            		lastBaroTemp = baro_temperature;
            	if (pressure != lastPressure) {
            		gw.send(msgBaro.set(pressure, 0));
                            //delay(1000);
    //        		gw.send(msgBaro.set(pressure));
            		lastPressure = pressure;
            	if (forecast != lastForecast) {
            		gw.send(msgForecast.set(weather[forecast]));
            		lastForecast = forecast;
                    // The humidity sensor stuff
            	if (isnan(temperature)) {
            		lastTemp = temperature;
          	        	if (!metric) {
          		        Serial.print("Temperature: ");
            	if (isnan(humidity)) {
            		lastHum = humidity;
            		Serial.print("Humidity: ");
            		Serial.println(humidity);
            	// get the battery Voltage
            	long sensorValue = analogRead(BATTERY_SENSE_PIN);
            	// 1M, 100K divider across battery and using internal ADC ref of 1.1V
            	// ((1e6+100e3)/100e3)*1.1 = Vmax = 12.1 Volts
            	// 12.1/1023 = Volts per bit = 0.011827957
            	// sensor val at 9v = 9/0.011827957 = 760.909090217
            	// float batteryV  = sensorValue * 0.011827957;
            	long batteryValue = sensorValue * 100L;
            	int batteryPcnt = batteryValue / 761;
            	gw.sendBatteryLevel((batteryPcnt > 100 ? 100 : batteryPcnt)); // this allows for batteries that have slightly over 9v
            	Serial.print("Batt %:");
            	Serial.println(batteryPcnt);
            if ( minuteCount < 5 )  // sleep a bit
    	        gw.sleep(SLEEP_MINUTE); //while pressure sampling
    	        gw.sleep(SLEEP_FIVE_MINUTES);
    int SamplePressure() {
    	// This is a simplification of Algorithm found here to same memory
    	pressure = bmp.readSealevelPressure(60) / 100; // 60 meters above sealevel
    	if (minuteCount > 9) { // we are going to test pressure change every 30 min (5*1min + 5*5min)
    		lastPressureAvg = pressureAvg;
    		minuteCount = 0;
    	if (minuteCount < 5) {
    		pressureSamples[minuteCount] = pressure; // Collect 5 minutes of samples every 30 min
                    Serial.print("  Sample(");
                    Serial.print(minuteCount);
                    Serial.print(") = ");
                    Serial.println(pressure);
    	if (minuteCount == 4) { // the 5th minute
    		// Avg pressure in first 5 min, value averaged from 0 to 5 min.
    		pressureAvg = ((pressureSamples[0] + pressureSamples[1]
    				+ pressureSamples[2] + pressureSamples[3] + pressureSamples[4])
    				/ 5);
    		float change = pressureAvg - lastPressureAvg;
    		dP_dt = (((65.0 / 1023.0) * change) / 0.5); // divide by 0.5 as this is the difference in time from last sample 0.5 hours
    		Serial.print("dP_dt = ");
    		Serial.println(dP_dt);
    	minuteCount++;
    	if (lastPressureAvg < 0) // no previous pressure sample.
    		return 5; // Unknown, more time needed
    	else if (dP_dt < (-0.25))
    		return 4; // Quickly falling LP, Thunderstorm, not stable
    	else if (dP_dt > 0.25)
    		return 3; // Quickly rising HP, not stable weather
    		return 2; // Slowly falling Low Pressure System, stable rainy weather
    		return 1; // Slowly rising HP stable good weather
    	else if ((dP_dt > (-0.05)) && (dP_dt < 0.05))
    		return 0; // Stable weather
    RJ_MakeR 1 Reply Last reply
    • T
      TimO
      Nice!! I'm thinking about running a Nano + DHT22 with 9V block. What do you suppose, how long will the sensor run?
      J 1 Reply Last reply
        wrote on last edited by hek
        The box is really cool!
        Might print it in some other color though.. ;)
          BulldogLowellB
          BulldogLowellB
          BulldogLowell
          Are you kidding, all of the cool birdies would want to live there!
          @jtm312 Very nicely built!!
          • T TimO
            J
            J
            jtm312
            @TimO Its been running for about 2 weeks now, and used 5-6% of the battery. I have pulled the leds off of the nano to make it last longer (I was only getting 3 weeks with the leds on). It would be nice to think that I could get 20 weeks. I am also thinking of some more code changes to reduce them amount of power consumed.
            • raditvR
              raditvR
              raditv
              I would like to print that one for my pet ;)
              H 1 Reply Last reply
              • J jtm312
                BulldogLowellB
                BulldogLowellB
                BulldogLowell
                @jtm312
                So I've been working with temperature sensors a while and I worry about comparing floats, and their notorious precision triggering a true here and superfluously affecting the rate of the radio updates. The DHT22 is accurate to about 1 Celsius degree, so it may be unnecessary to transmit a change if there is a change to temperature at any precision of less than 1.
                maybe try something like:
                if (temperature > lastTemp + 0.5 || temperature < lastTemp - 0.5)
                  doSomething();
                Would reduce transmissions and save battery?
                same argument with your hygrometer and barometric pressure, but different level of precision. Not for the weather calculations, just for the decision to transmit updates, IMO.
                all easy to test with your serial monitor.
                • J jtm312
                  DHT dht;
                  int     minutes;
                  float   pressureAvg;
                  int     pressure;
                  float   dP_dt;
                  	gw.begin();
                  	if (!bmp.begin()) {
                                          //delay(1000);
                        	        	if (!metric) {
                          		lastHum = humidity;
                  		minuteCount = 0;
                  				/ 5);
                  	minuteCount++;
                  RJ_MakeR
                  RJ_MakeR
                  RJ_Make
                  @jtm312 Very Cool!
                  RJ_Make
                    @jtm312
                      doSomething();
                    J
                    J
                    jtm312
                    @BulldogLowell Thanks, that looks like it is worth a try, or just round to 0.5 degree. I am also going to cut down the sample interval. After the 1min samples to average for the pressure, the rest of the time 5min is probably good enough.
                    • J jtm312
                      BulldogLowellB
                      BulldogLowellB
                      BulldogLowell
                      @jtm312
                      maybe, but you may still have the same precision problem if you are using floats.
                      maybe just round and cast it to an int... DHT22 isn't precise to half a degree F or C...
                      int roundedTemperature = (int) floor(temperature + 0.5);
                      if (roundedTemperature != lastTemperature)
                        doSomething();
                        lastTemperature = roundedTemperature;
                      more on floats and their precision...
                      https://www.youtube.com/watch?v=PZRI1IfStY0
                      • raditvR raditv
                        H
                        H
                        hyla
                        @raditv Gotta ask: what sort of pet lives in that??
                        C.
                        • D
                          Dylano
                          @ jtm312
                          Dear..
                          Great project!
                          I print your station, very good quality!!!
                          How is the battery?
                          Do you have options to reduce the power?
                          Is this sketch the best option?
                          Do you have a list that i need to buy so i can build this nice station?
                          Thanks!!!
                          Domoticz, with a lot of working hardware, include mysensors :-)
                          OpenPLI, RuneAudio, Solarmeter, etc......
                          Not a great builder of software and hardware, more a user...
                          Only i try to do my best :-(
                          • D Dylano
                            @ jtm312
                            Dear..
                            Great project!
                            How is the battery?
                            Thanks!!!
                            J
                            J
                            jtm312
                            @Dylano Thanks.
                            I get 3-4 months from a battery by just removing the 2 LEDs from the arduino. Could probably do better running it from 2 AAA batteries and removing the voltage regulator as well. To save more power, you could also increase the interval between sending updates to the controller.
                            To build it you need:
                            • Arduino Pro Mini
                            • Humidity Sensor – DHT22 Aliexpress
                            • list itemPressure Sensor – BMP180 Aliexpress
                            • Prototype board & Battery Connector
                            Connections:
                            • Radio connected as http://www.mysensors.org/build/connect_radio
                            • 3.3V to sensors from arduino
                            • Battery Sense - A0 - connected as http://www.mysensors.org/build/battery R1=1M * R2=100k
                            • BMP085 - SCL - A5
                            • BMP085 - SCA - A4
                            • DHT22 - D3
                            • bjacobseB
                              bjacobseB
                              bjacobse
                              Think about to replace your DHT22 with a less current hungry sensor
                              HTU21D cold be a good choice (But only running 3,3V)
                              • bjacobseB bjacobse
                                J
                                J
                                jtm312
                                @bjacobse Thanks, they look interesting. I will grab some and have a play.
                                  MikeF
                                  wrote on last edited by MikeF
                                  ... and here's mine - in white:
                                  (now managed to upload pics in portrait!)
                                  I'm using a BME280 instead of a BMP180 and DHT22.
                                  • F
                                    F
                                    flopp
                                    Really cool.
                                    Is it possible to get the 3D file for this?
                                    korttomaK J 2 Replies Last reply
                                    • F flopp
                                      Really cool.
                                      korttomaK
                                      korttomaK
                                      korttoma
                                      @flopp There is a link in the first post
                                      • Tomas
                                      F 1 Reply Last reply
                                      • korttomaK korttoma
                                        F
                                        F
                                        flopp
                                        Thank you, I must have missed it 🙀
                                        • F flopp
                                          Really cool.
                                          J
                                          J
                                          jtm312
                                          @flopp I have added the FreeCAD file to the Thingiverse post so that people can make any changes they want.
