  3. Node doesn't recieve message from gateway
12 Posts 3 Posters 926 Views 3 Watching
  • K Offline
    K Offline
    keczejo
    I have ethernet gateway based on arduino mega and w5100. I'm trying to connect node to the gateway but i have no success. My gateway recieves find parrent from node and sends message back but node doesn't recieve it. I tried lots of things. I have 220uf capasitors on both radios. Node uses arduino uno.
    Gateway log:
    8845 TSF:MSG:READ,10-10-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    8850 TSF:MSG:BC
    8851 TSF:MSG:FPAR REQ,ID=10
    8854 TSF:CKU:OK,FCTRL
    8856 TSF:MSG:GWL OK
    9560 !TSF:MSG:SEND,0-0-10-10,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
    10848 TSF:MSG:READ,10-10-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    10853 TSF:MSG:BC
    10855 TSF:MSG:FPAR REQ,ID=10
    10857 TSF:CKU:OK,FCTRL
    10859 TSF:MSG:GWL OK
    11517 !TSF:MSG:SEND,0-0-10-10,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
    12850 TSF:MSG:READ,10-10-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    12856 TSF:MSG:BC
    12857 TSF:MSG:FPAR REQ,ID=10
    12860 TSF:CKU:OK,FCTRL
    12862 TSF:MSG:GWL OK
    13475 !TSF:MSG:SEND,0-0-10-10,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
    14853 TSF:MSG:READ,10-10-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    14858 TSF:MSG:BC
    14860 TSF:MSG:FPAR REQ,ID=10
    14862 TSF:CKU:OK,FCTRL
    14864 TSF:MSG:GWL OK
    15432 !TSF:MSG:SEND,0-0-10-10,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
    Node log:
    16 MCO:BGN:INIT NODE,CP=RNNNA---,FQ=16,REL=255,VER=2.3.2
    26 TSM:INIT
    28 TSF:WUR:MS=0
    34 TSM:INIT:TSP OK
    36 TSM:INIT:STATID=10
    38 TSF:SID:OK,ID=10
    39 TSM:FPAR
    44 ?TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2052 !TSM:FPAR:NO REPLY
    2054 TSM:FPAR
    2058 ?TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    4065 !TSM:FPAR:NO REPLY
    4067 TSM:FPAR
    4071 ?TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    6078 !TSM:FPAR:NO REPLY
    6080 TSM:FPAR
    6084 ?TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    8091 !TSM:FPAR:FAIL
    8092 TSM:FAIL:CNT=1
    8094 TSM:FAIL:DIS
    8096 TSF:TDI:TSL
    TheoLT 1 Reply Last reply
    • K keczejo
      Gateway log:
      8850 TSF:MSG:BC
      8856 TSF:MSG:GWL OK
      10853 TSF:MSG:BC
      12856 TSF:MSG:BC
      14858 TSF:MSG:BC
      Node log:
      26 TSM:INIT
      28 TSF:WUR:MS=0
      34 TSM:INIT:TSP OK
      38 TSF:SID:OK,ID=10
      39 TSM:FPAR
      2054 TSM:FPAR
      4067 TSM:FPAR
      6080 TSM:FPAR
      8091 !TSM:FPAR:FAIL
      8092 TSM:FAIL:CNT=1
      8094 TSM:FAIL:DIS
      8096 TSF:TDI:TSL
      TheoLT Offline
      TheoLT Offline
      TheoL
      @keczejo what's the distance between the node and the gateway?
      K 1 Reply Last reply
      • TheoLT TheoL
        K Offline
        K Offline
        keczejo
        @TheoL about 50cm but i tried putting node few meters away
        • electrikE Offline
          electrikE Offline
          electrik
          @keczejo said in Node doesn't recieve message from gateway:
          This looks like the destination is 255. Can you post your node code?
          • electrikE electrik
            K Offline
            K Offline
            keczejo
            @electrik it's led dimmer code with node id 10 added
            • K keczejo
              TheoLT Offline
              TheoLT Offline
              TheoL
              wrote on last edited by TheoL
              @keczejo Could you please post the code and if it's not too hard the schematics. It makes it easier to help you find the problem.
              I have 2 fairy lights led dimmer approximately 2 - 3 meters from the node. But so far no problem with them. I upgraded to the latest recently and discovered that adding this config line solved my problems. Apparently I didn't have the good quality NRF radio's but this line solved it for me:
              #define MY_RADIO_RF24
              #define MY_RF24_DATARATE RF24_1MBPS // see (https://forum.mysensors.org/topic/4631/nrf24l01-can-t-find-parent-on-gateway/7)
              Needs to be on all nodes and Gateway
              • K Offline
                K Offline
                keczejo
                I added :
                but it didn't help.
                My node code:
                #include <Arduino.h>
                 * Copyright (C) 2013-2019 Sensnology AB
                 * Full contributor list: https://github.com/mysensors/MySensors/graphs/contributors
                 * Version 1.0 - February 15, 2014 - Bruce Lacey
                 * Version 1.1 - August 13, 2014 - Converted to 1.4 (hek)
                 * This sketch provides a Dimmable LED Light using PWM and based Henrik Ekblad
                 * <henrik.ekblad@gmail.com> Vera Arduino Sensor project.
                 * Developed by Bruce Lacey, inspired by Hek's MySensor's example sketches.
                 * The circuit uses a MOSFET for Pulse-Wave-Modulation to dim the attached LED or LED strip.
                 * The MOSFET Gate pin is connected to Arduino pin 3 (LED_PIN), the MOSFET Drain pin is connected
                 * to the LED negative terminal and the MOSFET Source pin is connected to ground.
                 * This sketch is extensible to support more than one MOSFET/PWM dimmer per circuit.
                 * http://www.mysensors.org/build/dimmer
                //#define MY_RADIO_NRF5_ESB
                //#define MY_RADIO_RFM95
                #define SN "DimmableLED"
                #define SV "1.1"
                #define LED_PIN 3      // Arduino pin attached to MOSFET Gate pin
                #define FADE_DELAY 10  // Delay in ms for each percentage fade up/down (10ms = 1s full-range dim)
                static int16_t currentLevel = 0;  // Current dim level...
                MyMessage dimmerMsg(0, V_DIMMER);
                MyMessage lightMsg(0, V_LIGHT);
                 *  This method provides a graceful fade up/down effect
                void fadeToLevel( int toLevel )
                	int delta = ( toLevel - currentLevel ) < 0 ? -1 : 1;
                	while ( currentLevel != toLevel ) {
                		currentLevel += delta;
                		analogWrite( LED_PIN, (int)(currentLevel / 100. * 255) );
                		delay( FADE_DELAY );
                 * Dimmable LED initialization method
                	// Pull the gateway's current dim level - restore light level upon node power-up
                	request( 0, V_DIMMER );
                	// Register the LED Dimmable Light with the gateway
                	present( 0, S_DIMMER );
                	sendSketchInfo(SN, SV);
                 *  Dimmable LED main processing loop
                	if (message.getType() == V_LIGHT || message.getType() == V_DIMMER) {
                		requestedLevel *= ( message.getType() == V_LIGHT ? 100 : 1 );
                		Serial.print( "Changing level to " );
                		Serial.print( ", from " );
                		Serial.println( currentLevel );
                		fadeToLevel( requestedLevel );
                		send(lightMsg.set(currentLevel > 0));
                		// hek comment: Is this really nessesary?
                		send( dimmerMsg.set(currentLevel) );
                Node nrf connection:
                CE - 9
                CS - 10
                MOSI - 11
                MISO - 12
                SCK - 13
                Gateway connections:
                NRF:
                CE - 13
                CS - 22
                MOSI - 11
                MISO - 10
                SCK - 12
                W5100:
                MOSI - 51
                MISO - 50
                SCK - 52
                NSS - 53
                • K keczejo
                  I added :
                  but it didn't help.
                  My node code:
                  #define SV "1.1"
                  CE - 9
                  CS - 10
                  MOSI - 11
                  MISO - 12
                  SCK - 13
                  NRF:
                  CE - 13
                  CS - 22
                  MOSI - 11
                  MISO - 10
                  SCK - 12
                  W5100:
                  MOSI - 51
                  MISO - 50
                  SCK - 52
                  NSS - 53
                  TheoLT Offline
                  TheoLT Offline
                  TheoL
                  @keczejo Not sure what the W5100 takes for power. I'd try to power the NRF on the gateway with a power regulator.
                  Also if you disconnect the W5100 and set the getway up as a serial gateway, will it be able to find the parent? I'd try that as a first step
                  • TheoLT TheoL
                    K Offline
                    K Offline
                    keczejo
                    @TheoL
                    W5100 is powered from 5V because it has own regulator. I changed to serial gateway and it's node still doesn't find parent.
                    • K keczejo
                      @TheoL
                      TheoLT Offline
                      TheoLT Offline
                      TheoL
                      @keczejo Finding the root cause is hard. Because you currently have no working device. If you have some spare try changing radios. Move the node further away from the gateway. And things like that.
                      • electrikE Offline
                        electrikE Offline
                        electrik
                        What module are you using? There are many flaky ones around.
                        • K Offline
                          K Offline
                          keczejo
                          I changed node arduino to mega and it worked first try. Thanks for help
                          11.9k
                          113.3k
