  3. Node to Node Communication
36 Posts 6 Posters 24.5k Views 5 Watching
    Use the setDestination(desitnationNodeId) on message before sending it off:
    https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/MyMessage.h#L159
    In the receiving node you can pick it up just like the RelayActuator example does.
      sharath krishna
      then would it automatically be cleared ? or we need to change the destination again to the gateway for normal operation ??
      hekH 1 Reply Last reply
      • S sharath krishna
        :question:
        C 1 Reply Last reply
          :question:
          C
          C
          cleight
          wrote on last edited by cleight
          @hek I tried your suggestion above and got the following error message; "no matching function call" I used the following code in my sketch: Mymessage setDestination(11);
          Does anyone have a working example of node - node communication that we could all reference?
          So been playing arround a bit more and got this, does it look right?
          gw.send(msgHTTemp.setDestination(11).setSensor(i).set(temperature,1));
          and if this looks correct will it send to both node 11 and the gateway?
          • C
            C
            cleight
            So it looks like the code below did work:
            How ever in the serial monitor I am getting a bunch of ST=fail trying to send to node 11:
            T2: 71.90
            send: 1-1-0-11 s=0,c=1,t=0,pt=7,l=5,st=ok:71.4
            send: 1-1-0-11 s=0,c=1,t=0,pt=7,l=5,st=fail:71.4
            Here is the code I have in my Node 11 sketch to receive the messages:
            gw.begin(NULL, AUTO, true);
            I also don't fully understand how I capture the data coming into node 11 and present it to the LCD screen so any help with that as well would be great.
            • C cleight
              T2: 71.90
              C
              C
              cleight
              T2: 71.90
              Figured out the issue was in the repeater code on node 11. So now I am getting variable from Node1 being presented to Node11 but I am not sure how to capture this information and display it on the LCD Screen attached.
              read: 1-0-11 s=0,c=1,t=0,pt=7,l=5:84.2
              ChaoticC 1 Reply Last reply
              • C cleight
                T2: 71.90
                ChaoticC
                ChaoticC
                Chaotic
                @cleight I believe you would need to change your gw.begin
                http://www.mysensors.org/download/sensor_api_14
                To initialize radio and start the library, you must call begin(). Begin initializes the sensor node but you >can also configure the sensor node operating parameters manually. Call this before anything else in >the library
                void begin(void (*_msgCallback)(const MyMessage &), uint8_t nodeId, boolean repeaterMode,
                uint8_t parentNodeId, rf24_pa_dbm_e paLevel, uint8_t channel, rf24_datarate_e dataRate);
                incomingMessageCallback - Callback function for incoming messages from other nodes or >controller and request responses. Default is NULL.
                nodeId - The unique id (1-254) for this sensor. Default is AUTO(255) which means sensor tries to >fetch an id from controller.
                repeaterMode - Activate repeater mode. This node will forward messages to other nodes in the >radio network. Make sure to call process() regularly. Default in false
                parentNodeId - Use this to force node to always communicate with a certain parent node. Default is >AUTO which means node automatically tries to find a parent.
                paLevel - Radio PA Level for this sensor. Default RF24_PA_MAX
                channel - Radio channel. Default is channel 76
                dataRate - Radio transmission speed. Default RF24_250KBPS
                So instead of gw.begin(NULL,Auto,true) try gw.begin(ProcessMessage,Auto,true)
                And then just define ProcessMessage as a function.
                I'd look at the relay sketch which sets up incomingmessage as the function to handle incoming messages.
                https://codebender.cc/sketch:47528
                • ChaoticC Chaotic
                  C
                  C
                  cleight
                  @Chaotic I'm not following at all with what you said. I don't believe I need to change my gw.begin as I am receiving messages from the other node, I am now struggling with capturing that data to a variable that I can use to output the data to an attached LCD Screen.
                  • C
                    C
                    cleight
                    I tried the following code but doesn't appear to be working
                    if (message.sensor == 1)
                          if (message.type == V_TEMP)
                            testTemp = atoi(message.data);
                          DEBUG_PRINTLN(F("Test Temp recieved:"));
                          DEBUG_PRINTLN(testTemp);
                    • C cleight
                      C
                      C
                      cleight
                      Can anyone assist with this issue? I cannot figure out what I am missing to capture this data into an integer so I can parse it to my LCD Screen.
                      Message.sensor -- 1 is what I am defining right now as I was the data from Node ID1, Sensor ID0, I believe this is where my issue is but I cannot figure out the syntax needed to define Node 1 Child Sensor 0 and Variable type V_TEMP.
                      • AWIA
                        AWIA
                        AWI
                        Can you please show us the full code.? From what I read @cleight has a good suggestion. Try the relay sketch_ to learn how to use the incoming message in your code. . You need to define it in gwbegin else it is only noticed as incoming in the serial monitgor
                        • C
                          C
                          cleight
                          @Chaotic I understand what your saying as well as what @AWI is saying but I don't think everyone understands what I am trying to do. I would like to capture several node's child sensors data and use it on my LCD Screen to show me instant status of sensors. If I use code like the relay example how do I tell it which node and child sensor I want to capture the data from?
                          ^That code, per the relay sketch example doesn't allow me to specify I want data from Node 1, Child Sensor 0.
                          Here is my full sketch I am currently working on:
                          #define STATES 9
                          #define DEBUG
                          #ifdef DEBUG
                          #include <avr/pgmspace.h>
                          #include <Time.h>
                          #include <DS3232RTC.h>
                          #define RADIO_ID 11
                          #define CHILD_ID_SCENE 3
                          #define CHILD_ID_LED 4
                          #define BACKLIGHT 6 //available PWM capable pin
                          LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // set the LCD address to 0x27 for a 16 chars and 2 line display
                          void (*lcdDisplay[STATES])();
                          byte state = 0;
                          byte lastState;
                          byte timeCounter = 0;
                          int ledStatus = 1;// to toggle LCD backlight led
                          int ledLevel = 254;
                          unsigned long lastTime;
                          unsigned long refreshInterval = 3000UL;
                          unsigned long lastClockSet;
                          boolean isMessage = false;
                          float insideTemperature;
                          float humidity;
                          int OutdoorTemp = -99;
                          int OutdoorHumidity = -99;
                          int todayHigh = -99;
                          int todayLow = -99;
                          int HotTubTemp = -99;
                          int KWH = -99;
                          int testTemp = -99;
                          String conditions = "Not yet Reported";
                          String tomorrowWeather = "Not yet Reported";
                          String messageOfTheDay = "**Hello There!**";
                          String AlarmStatus = "No Data";
                          unsigned long motdTimer;
                          boolean buttonPushed = false;
                          MyMessage msgOn(CHILD_ID_SCENE, V_SCENE_ON);
                          MyMessage msgOff(CHILD_ID_SCENE, V_SCENE_OFF);
                          MyMessage msgVAR1(CHILD_ID_SCENE, V_VAR1);// outdoor temperature
                          MyMessage msgVAR2(CHILD_ID_SCENE, V_VAR2);// outdoor humidity
                          MyMessage msgVAR3(CHILD_ID_SCENE, V_VAR3);//today's low
                          MyMessage msgVAR4(CHILD_ID_SCENE, V_VAR4);// today's high
                          MyMessage msgVAR5(CHILD_ID_SCENE, V_VAR5);//conditions
                          MyMessage lightMsg(CHILD_ID_LED, V_DIMMER);
                          MyMessage msgMOTD(CHILD_ID_LED, V_VAR1); // Hot Tub KWH
                          MyMessage msgAlarm(CHILD_ID_LED, V_VAR2); // Tomorrow Forecast
                          MyMessage msgBrite(CHILD_ID_LED, V_VAR3);
                          MyMessage msgHTTemp(CHILD_ID_LED, V_VAR4); // Hot Tub Temp
                          MyMessage msgALARMSTATUS (CHILD_ID_LED, V_VAR5);// Alarm System Status
                            DEBUG_SERIAL(115200);
                            DEBUG_PRINTLN(F("Serial started"));
                            lcdDisplay[0] = lcdDisplay0;
                            lcdDisplay[1] = lcdDisplay1;
                            lcdDisplay[2] = lcdDisplay2;
                            lcdDisplay[3] = lcdDisplay3;
                            lcdDisplay[4] = lcdDisplay4;
                            lcdDisplay[5] = lcdDisplay5;
                            lcdDisplay[6] = lcdDisplay6;
                            lcdDisplay[7] = lcdDisplay7;
                            lcdDisplay[8] = lcdDisplay8;
                            pinMode(BACKLIGHT, OUTPUT);
                            gw.begin(getVariables, RADIO_ID);
                            //gw.begin(NULL, AUTO, true);
                            gw.sendSketchInfo("Home Status Panel", "2.1");
                            setSyncProvider (RTC.get);
                            gw.present(CHILD_ID_SCENE, S_SCENE_CONTROLLER);
                            gw.present( CHILD_ID_LED, S_DIMMER);
                            analogWrite(BACKLIGHT, 200); //LCD Backlight
                            lcd.begin(20,4);
                            lcd.clear();
                            lcd.backlight();
                            lcd.setCursor(0, 0);
                            lcd.print("Syncing Time");
                            lcd.setCursor(0, 1);
                            int clockCounter = 0;
                            while(timeStatus() == timeNotSet && clockCounter < 60)
                              gw.requestTime(receiveTime);
                              Serial.println("getting Time");
                              delay(1000);
                              lcd.print(".");
                              clockCounter++;
                              if (clockCounter > 16)
                                lcd.clear();
                                lcd.print(F("**Failed Clock**"));
                                lcd.setCursor(0,1);
                                lcd.print(F("*Syncronization*"));
                                delay(2000);
                            lcd.clear();
                            lastTime = millis();
                            if (millis() - lastClockSet >= 60000UL)
                              lastClockSet = millis();
                            if (millis() - lastTime >= refreshInterval)
                              state++;
                              if (state > STATES - 1) state = 0;
                              DEBUG_PRINTLN(F("State:"));
                              DEBUG_PRINTLN(state);
                              lastTime += refreshInterval;
                              getTempHumidity();
                            if (state != lastState)
                              fastClear();
                              lcdDisplay[state]();
                            lastState = state;
                            if (isMessage)
                              if (millis() - motdTimer > 86400 * 1000UL)
                                isMessage = false;
                          void fastClear() //Clear LCD Screen
                            lcd.setCursor(0,0);
                            lcd.clear();
                            lcd.setCursor(0,1);
                            lcd.clear();
                            lcd.setCursor(0,2);
                            lcd.clear();
                            lcd.setCursor(0,3);
                            lcd.clear();
                          void lcdDisplay0()
                            lcd.setCursor(0,0);
                            lcd.print(F("Time: "));
                            if (hourFormat12() < 10) lcd.print("0");
                            lcd.print(hourFormat12());
                            lcd.print(":");
                            if (minute() < 10) lcd.print("0");
                            lcd.print(minute());
                            if (isAM()) lcd.print(F("am"));
                            else lcd.print(F("pm"));
                            DEBUG_PRINT(F("Time:"));
                            DEBUG_PRINTLN(hourFormat12());
                            lcd.setCursor(0,1);
                            lcd.print(F("Date: "));
                            if (month() < 10) lcd.print("0");
                            lcd.print(month());
                            lcd.print("/");
                            if (day() < 10) lcd.print("0");
                            lcd.print(day());
                            lcd.print("/");
                            lcd.print(year());
                            DEBUG_PRINTLN(F("Date: "));
                            DEBUG_PRINT(month());
                            DEBUG_PRINT("/");
                            DEBUG_PRINT(day());
                            DEBUG_PRINT("/");
                            DEBUG_PRINTLN(year());
                          void lcdDisplay1()
                            lcd.setCursor(0,0);
                            lcd.print(F(" Indoor Temp:"));
                            lcd.print(int(round(insideTemperature)));
                            lcd.print(char(223));
                            DEBUG_PRINT(F("Indoor Temp:"));
                            DEBUG_PRINT(int(round(insideTemperature)));
                            DEBUG_PRINTLN(F("F"));
                          void lcdDisplay2()
                            lcd.setCursor(0,0);
                            lcd.print("Outdoor Temp:");
                            lcd.print(OutdoorTemp);
                            DEBUG_PRINT(F("Outdoor Temp:"));
                            DEBUG_PRINTLN(OutdoorTemp);
                            lcd.setCursor(0,1);
                            lcd.print(F("    Humidity:"));
                            lcd.print(OutdoorHumidity);
                            lcd.print(F("%"));
                            DEBUG_PRINT(F("    Humidity:"));
                            DEBUG_PRINTLN(OutdoorHumidity);
                          void lcdDisplay3()
                            lcd.setCursor(0,0);
                            lcd.print(F("Today's High:"));
                            lcd.print(todayHigh);
                            DEBUG_PRINT(F("Today's High: "));
                            DEBUG_PRINTLN(todayHigh);
                            lcd.setCursor(0,1);
                            lcd.print(F("         Low:"));
                            lcd.print(todayLow);
                            DEBUG_PRINT(F("Today's Low: "));
                            DEBUG_PRINTLN(todayLow);
                          void lcdDisplay4()
                            lcd.setCursor(0,0);
                            lcd.print(F("Today's Weather"));
                            DEBUG_PRINTLN(F("Today's Weather: "));
                            lcd.setCursor(0,1);
                            lcd.print(conditions);
                            DEBUG_PRINTLN(conditions);
                          void lcdDisplay5()
                            lcd.setCursor(0,0);
                            lcd.print(F("Forcast Tomorrow"));
                            DEBUG_PRINTLN(F("Tomorrow's Forecast: "));
                            lcd.setCursor(0,1);
                            lcd.print(tomorrowWeather);
                            DEBUG_PRINTLN(tomorrowWeather);
                          void lcdDisplay6()
                            if (isMessage)
                              lcd.setCursor(0,0);
                              lcd.print(F("**NEW  MESSAGE**"));
                              DEBUG_PRINTLN(F("****Message****"));
                              lcd.setCursor(0,1);
                              lcd.print(messageOfTheDay);
                              DEBUG_PRINTLN(messageOfTheDay);
                              motdTimer = millis();
                              lcd.setCursor(0,0);
                              lcd.print(F("****Welcome!****"));
                              lcd.setCursor(0,1);
                              lcd.print(F("Have a Nice Day!"));
                              DEBUG_PRINTLN(F("Have a Nice Day"));
                          void lcdDisplay7()
                            lcd.setCursor(0,1);
                            lcd.print("Alarm Status:");
                            DEBUG_PRINT("Alarm Status:");
                            DEBUG_PRINTLN(AlarmStatus);
                            lcd.setCursor(0,2);
                            lcd.print(AlarmStatus);
                          void lcdDisplay8()
                            lcd.setCursor(0,0);
                            lcd.print("Hot Tub KWH:");
                            lcd.print(KWH);
                            DEBUG_PRINT("Hot Tub KWH:");
                            DEBUG_PRINTLN(KWH);
                            lcd.setCursor(0,1);
                            lcd.print(F(" Hot Tub:"));
                            lcd.print(HotTubTemp);
                            DEBUG_PRINT(F("Hot Tub:"));
                            DEBUG_PRINT(HotTubTemp);
                            DEBUG_PRINT(F("F"));
                            lcd.setCursor(3,0);
                            lcd.print("Test Temp:");
                            lcd.print(testTemp);
                            DEBUG_PRINT(F("Test Temp:"));
                          void getTempHumidity()
                            insideTemperature = ((RTC.temperature()/4*9/5 + 32));
                            if (isnan(insideTemperature))
                              DEBUG_PRINTLN(F("Failed reading temperature from RTC"));
                            // Ok, set imcoming time
                            DEBUG_PRINTLN(F("Time value received: "));
                            DEBUG_PRINTLN(controllerTime);
                            RTC.set(controllerTime);
                            controllerTime = true;
                            if (message.sensor == CHILD_ID_SCENE)
                              if (message.type == V_VAR1) //Outdoor temp pulled from Weather Underground Vera Plugin
                                OutdoorTemp = atoi(message.data);
                                DEBUG_PRINTLN(F("OutdoorTemp recieved:"));
                              if (message.type == V_VAR2) //Outdoor Humidity pulled from Weather Underground Vera Plugin
                                OutdoorHumidity = atoi(message.data);
                                DEBUG_PRINT(F("OutdoorHumidity recieved:"));
                              if (message.type == V_VAR3) //pulled from Weather Underground Vera Plugin
                                todayLow = atoi(message.data);
                                DEBUG_PRINT(F("Received Today's LOW:"));
                              if (message.type == V_VAR4) //pulled from Weather Underground Vera Plugin
                                todayHigh = atoi(message.data);
                                DEBUG_PRINT(F("Received Today's HIGH:"));
                              if (message.type == V_VAR5) //pulled from Weather Underground Vera Plugin
                                int locator = newMessage.indexOf("@");
                                newMessage = newMessage.substring(0, locator);
                                conditions = newMessage;
                                DEBUG_PRINT(F("Received today's Conditions:"));
                              if (message.sensor == CHILD_ID_LED)
                              if (message.type == V_DIMMER) //Set LCD Brightness from Dimmer Device in Vera
                                ledLevel = message.getByte();
                                		lcd.setBacklight(ledLevel);
                          		Serial.print("Brightness Level recieved:");
                          		Serial.println(ledLevel);
                                          analogWrite(BACKLIGHT, (int)(ledLevel / 100. * 255) );
                              if (message.type == V_VAR1) //Hot Tub KWN Hours
                                KWH = atoi(message.data);
                                DEBUG_PRINT("Hot Tub KWH recieved:");
                                DEBUG_PRINTLN(KWH);
                              if (message.type == V_VAR2) //pulled from Weather Underground Vera Plugin
                                // Extended Forecast
                                tomorrowWeather = newMessage;
                                DEBUG_PRINT(F("Received Two Day Forecast:"));
                              if (message.type == V_VAR3) //Not sure what this will be used for just yet
                                // message of the day
                                messageOfTheDay = newMessage;
                                DEBUG_PRINT(F("Received Message of the Day:"));
                                isMessage = true;
                              if (message.type == V_VAR4) //Hot Tub Temp from Vera which comes from an Arduino
                                HotTubTemp = atoi(message.data);
                                DEBUG_PRINT(F("Received HotTubTemp:"));
                                DEBUG_PRINTLN(HotTubTemp);
                              if (message.type == V_VAR5) //Check on Alarm status
                                AlarmStatus = newMessage;
                                DEBUG_PRINT(F("Received Alarm Status:"));
                            wrote on last edited by hek
                            @cleight, the incoming message contains where it came from. So you could do something like:
                            #define TEMP_NODE_ID 42
                            #define HUMIDITY_NODE_ID 44
                            float temp = 0, hum =0;
                               switch (message.sender) {
                                     case TEMP_NODE_ID:
                                          temp = message.getFloat();
                                     case HUMIDITY_NODE_ID:
                                          hum = message.getFloat();
                               updateDisplay();
                            • C cleight
                              #define STATES 9
                              #define DEBUG
                              #ifdef DEBUG
                              #include <Time.h>
                              #define RADIO_ID 11
                              byte state = 0;
                              byte lastState;
                              int ledLevel = 254;
                              float humidity;
                              int todayLow = -99;
                              int KWH = -99;
                              int testTemp = -99;
                                lcd.begin(20,4);
                                lcd.clear();
                                lcd.backlight();
                                  delay(1000);
                                  lcd.print(".");
                                  clockCounter++;
                                    lcd.clear();
                                    lcd.setCursor(0,1);
                                    delay(2000);
                                lcd.clear();
                                  state++;
                                  getTempHumidity();
                                  fastClear();
                                lastState = state;
                                if (isMessage)
                                    isMessage = false;
                                lcd.setCursor(0,0);
                                lcd.clear();
                                lcd.setCursor(0,1);
                                lcd.clear();
                                lcd.setCursor(0,2);
                                lcd.clear();
                                lcd.setCursor(0,3);
                                lcd.clear();
                              void lcdDisplay0()
                                lcd.setCursor(0,0);
                                lcd.print(":");
                                lcd.setCursor(0,1);
                                lcd.print(month());
                                lcd.print("/");
                                lcd.print(day());
                                lcd.print("/");
                                lcd.print(year());
                                DEBUG_PRINT("/");
                                DEBUG_PRINT(day());
                                DEBUG_PRINT("/");
                              void lcdDisplay1()
                                lcd.setCursor(0,0);
                              void lcdDisplay2()
                                lcd.setCursor(0,0);
                                lcd.setCursor(0,1);
                                lcd.print(F("%"));
                              void lcdDisplay3()
                                lcd.setCursor(0,0);
                                lcd.setCursor(0,1);
                              void lcdDisplay4()
                                lcd.setCursor(0,0);
                                lcd.setCursor(0,1);
                              void lcdDisplay5()
                                lcd.setCursor(0,0);
                                lcd.setCursor(0,1);
                              void lcdDisplay6()
                                if (isMessage)
                                  lcd.setCursor(0,0);
                                  lcd.setCursor(0,1);
                                  lcd.setCursor(0,0);
                                  lcd.setCursor(0,1);
                              void lcdDisplay7()
                                lcd.setCursor(0,1);
                                lcd.setCursor(0,2);
                              void lcdDisplay8()
                                lcd.setCursor(0,0);
                                lcd.print(KWH);
                                DEBUG_PRINTLN(KWH);
                                lcd.setCursor(0,1);
                                lcd.setCursor(3,0);
                                    DEBUG_PRINTLN(KWH);
                                    isMessage = true;
                              ChaoticC
                              ChaoticC
                              Chaotic
                              @cleight You sensor nodes should handle sending the data.
                              The message coming to your LCD Node should have the node id that it started from which you can check against to do what you want for each message. The code @hek provided should allow you to tell what node the message is coming from.
                              I'm going to suggest since you seem to be doing non-standard things that you go and read the API which explains the different parts of the message.
                              http://www.mysensors.org/download/serial_api_14
                              • C
                                C
                                cleight
                                @hek Thank you for the example, one thing I am still confused on though is if all my nodes have child ID's of 0 and 1 that the code you presented above doesn't care about the Child sensor only the Node ID correct?
                                @Chaotic: I have read the API documentation about 100 times and I don't correlate it to what I want, I unfortunately do not have a programming background and what I have learned so far is by other users examples or trial and error.
                                • C cleight
                                  ChaoticC
                                  ChaoticC
                                  Chaotic
                                  wrote on last edited by Chaotic
                                  @cleight Your nodes should each have a unique ID. And then the child ID might be 0/1 for each one.
                                  Since you claimed you don't have a programming background I'll try to explain the API (as I understand it anyways) And how to get to each piece
                                  The message that gets passed by the radio is going to look like this
                                  12;6;1;0;0;36.5\n
                                  Looking at each part
                                  12: node-id The unique id of the node that sends or should receive the message (address) message.sender
                                  6: child-sensor-id Each node can have several sensors attached. This is the child-sensor-id that uniquely identifies one attached sensor message.sensor
                                  1: message-type Type of message sent - See table below message.command_ack_payload (I think)
                                  0: ack The ack parameter has the following meaning:
                                  Outgoing: 0 = unacknowledged message, 1 = request ack from destination node
                                  Incoming: 0 = normal message, 1 = this is an ack message message.isAck()
                                  0: sub-type Depending on messageType this field has different meaning. See tables below message.type
                                  36.5: payload The payload holds the message coming in from sensors or instruction going out to actuators.
                                  Various functions exist to get the payload
                                  char* getStream(char buffer) const;
                                  char
                                  getString(char buffer) const;
                                  const char
                                  getString() const;
                                  void* getCustom() const;
                                  uint8_t getByte() const;
                                  bool getBool() const;
                                  float getFloat() const;
                                  long getLong() const;
                                  unsigned long getULong() const;
                                  int getInt() const;
                                  unsigned int getUInt() const;
                                  So you might have a childID of 0/1 if you are only sending 1-2 items from the sensor but each sensor will have its own nodeID
                                  So using the example Hek provided and assuming temp is sensor 0 humidity is 1
                                  #define BEDROOM_NODE_ID 42
                                  #define KITCHEN_NODE_ID 44
                                  #define TEMP 0
                                  #define HUM 1
                                  float bdtemp = 0, bdhum =0, kntemp = 0, knhum =0;
                                           case BEDROOM_NODE_ID:
                                                switch (message.sensor){
                                                     case TEMP
                                                            bdtemp = message.getFloat();
                                                     case HUM
                                                            bdhum = message.getFloat();
                                       case KITCHEN_NODE_ID:
                                                     case TEMP
                                                            kntemp = message.getFloat();
                                                     case HUM
                                                            knhum = message.getFloat();
                                    updateDisplay();
                                  That will give you 4 variables bdtemp, bdhum, kntemp, knhum so you know the temp/humidity coming from 2 different sensors
                                  • ChaoticC Chaotic
                                    12;6;1;0;0;36.5\n
                                    char
                                    const char
                                    getString() const;
                                    int getInt() const;
                                    #define TEMP 0
                                    #define HUM 1
                                                       case TEMP
                                                       case HUM
                                                       case TEMP
                                                       case HUM
                                      updateDisplay();
                                    C
                                    C
                                    cleight
                                    @Chaotic I understand what you are saying and have the concept down of the message being sent to the gateway. What I don't understand is the code that Hek provided and how I seperate Node ID 1 Child Sensor 0 (temp Sensor) from Node ID 1 Child Sensor 1 (Humidity Sensor)
                                    Also I tried the code Hek provided but I cannot use Float to store the variable as I am out of room in my sketch, I tried changing to message.getInt(); without luck.
                                    • C cleight
                                      ChaoticC
                                      ChaoticC
                                      Chaotic
                                      I was putting in an example to do just that when you responded.
                                      as for getInt / getFloat it should let you switch but you might lose anything after the period.
                                        Make sure to send the same type as you're trying to getXXX on the receiving side. No automatic conversion is done except for the getString().
                                        https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/MyMessage.cpp#L62
                                          C
                                          C
                                          cleight
                                          #22
                                          @hek This is the code I am using on the sensor side to send to LCD Node (Node 11)
                                          And in serial monitor on node 11 I see the data being captured correctly, so I believe my issue still lies in my code on the LCD Screen side.
                                          read: 1-0-11 s=0,c=1,t=0,pt=7,l=5:66.2
                                          Here is my latest Sketch after I made changes again per Hek's suggestion, only thing is I couldn't use float as I am out of room in my sketch to hard to use INT instead for testTemp
                                          #define STATES 9
                                          #define DEBUG
                                          #ifdef DEBUG
                                          #include <Time.h>
                                          #define RADIO_ID 11
                                          //Define Additional Nodes that I would like to pull data from
                                          #define HOTTUB_NODE_ID 1
                                          byte state = 0;
                                          byte lastState;
                                          int ledLevel = 254;
                                          float humidity;
                                          int todayLow = -99;
                                          int KWH = -99;
                                          int testTemp = -99;
                                            lcd.begin(20,4);
                                            lcd.clear();
                                            lcd.backlight();
                                              delay(1000);
                                              lcd.print(".");
                                              clockCounter++;
                                                lcd.clear();
                                                lcd.setCursor(0,1);
                                                delay(2000);
                                            lcd.clear();
                                              state++;
                                              getTempHumidity();
                                              fastClear();
                                            lastState = state;
                                            if (isMessage)
                                                isMessage = false;
                                            lcd.setCursor(0,0);
                                            lcd.clear();
                                            lcd.setCursor(0,1);
                                            lcd.clear();
                                            lcd.setCursor(0,2);
                                            lcd.clear();
                                            lcd.setCursor(0,3);
                                            lcd.clear();
                                          void lcdDisplay0()
                                            lcd.setCursor(0,0);
                                            lcd.print(":");
                                            lcd.setCursor(0,1);
                                            lcd.print(month());
                                            lcd.print("/");
                                            lcd.print(day());
                                            lcd.print("/");
                                            lcd.print(year());
                                            DEBUG_PRINT("/");
                                            DEBUG_PRINT(day());
                                            DEBUG_PRINT("/");
                                          void lcdDisplay1()
                                            lcd.setCursor(0,0);
                                          void lcdDisplay2()
                                            lcd.setCursor(0,0);
                                            lcd.setCursor(0,1);
                                            lcd.print(F("%"));
                                          void lcdDisplay3()
                                            lcd.setCursor(0,0);
                                            lcd.setCursor(0,1);
                                          void lcdDisplay4()
                                            lcd.setCursor(0,0);
                                            lcd.setCursor(0,1);
                                          void lcdDisplay5()
                                            lcd.setCursor(0,0);
                                            lcd.setCursor(0,1);
                                          void lcdDisplay6()
                                            if (isMessage)
                                              lcd.setCursor(0,0);
                                              lcd.setCursor(0,1);
                                              lcd.setCursor(0,0);
                                              lcd.setCursor(0,1);
                                          void lcdDisplay7()
                                            lcd.setCursor(0,1);
                                            lcd.setCursor(0,2);
                                          void lcdDisplay8()
                                            lcd.setCursor(0,0);
                                            lcd.print(KWH);
                                            DEBUG_PRINTLN(KWH);
                                            lcd.setCursor(0,1);
                                            lcd.setCursor(3,0);
                                                DEBUG_PRINTLN(KWH);
                                                isMessage = true;
                                                  case HOTTUB_NODE_ID:
                                          Node ID 1 - Temperature Sensor that is sending to Node 11 (LCD Screen)
                                          #include <OneWire.h>
                                          #define CHILD_ID_HUM 1
                                          #define CHILD_ID_TEMP 2
                                          #define CHILD_ID_HTTEMP 3
                                          //Waterproof Sensor addition
                                          #define ONE_WIRE_BUS 4 //Pin where waterproof temp sensor is connected
                                          DHT dht;
                                          int numSensors=0;
                                          boolean receivedConfig = false;
                                          float lastTemp;
                                          float lastHum;
                                          boolean metric = false;
                                          MyMessage msgHTTemp(CHILD_ID_HTTEMP, V_TEMP);
                                            // Startup OneWire
                                            sensors.begin();
                                            gw.begin();
                                            gw.sendSketchInfo("Hot Tub Monitor", "2.0");
                                              gw.present(i, S_TEMP);
                                            // Process incoming messages (like config from server)
                                            //Fetch temperatures from Dallas sensors
                                            // Red temperatures and send them to the controller
                                              float temperature = static_cast<float>(static_cast<int>((sensors.getTempFByIndex(i)) * 10.)) / 10.;
                                              //Only send data if temperature has changed and no error
                                              if (lastTemperature[i] != temperature && temperature != -127.00) {
                                                delay(100);
                                                gw.send(msgHTTemp.setSensor(i).set(temperature,1));
                                                Serial.print("T2: ");
                                            //float temperature = dht.getTemperature();
                                            float temperature = dht.getTemperature()*9/5 + 32;
                                            if (isnan(temperature)) {
                                            else if (temperature != lastTemp) {
                                              lastTemp = temperature;
                                              if (!metric) {
                                                //temperature = dht.toFahrenheit(temperature);
                                              delay(100);
                                              Serial.print("T: ");
                                            if (isnan(humidity)) {
                                            else if (humidity != lastHum) {
                                              lastHum = humidity;
                                              delay(100);
                                              Serial.print("H: ");
                                              Serial.println(humidity);
