  3. smart sleep inconsistent?
21 Posts 3 Posters 3.2k Views 3 Watching
  • CrankyCoderC
    CrankyCoderC
    CrankyCoder
    I have a node I setup and configured for smart sleep. It's set to check in every 30 seconds. But it's not consistent. I understand without a real time clock ect that it may not be 100% on the wake up procedure... but i am getting BIG gaps of time where it just isn't reporting in. The below graph is monitoring my mqtt broker and you can see big gaps and that is just over the last hour. 1 gap was for 12 minutes then ok for a bit, then a gap for 15. I monitored during my last meeting so i could confirm it wasn't me messing with something.
    This has been going on for a couple weeks. The only thing I can think of is maybe it's doing the FPAR like I saw awhile back. I have changed out the arduino, changed the radio, changed to another radio from a different batch.
    Not sure if anyone has any experience with the smart sleep, but so far it doesn't seem super reliable. Not enough so for me to be willing to have it not turn off my water for a couple hours till it decides to wake up after flooding my neighbors drive way.... not speaking from experience or anything lol
    Home Automation Tinkerer
    www.CrankyCoder.net
    Gateway: MQTTClientGateway
    MySensors: 2.3
    • CrankyCoderC
      CrankyCoderC
      CrankyCoder
      additional information:
      • wemos d1 mini mqtt gateway
      • tried with and without repeater
      • tried moving gateway closer to node (easier than moving node)
      www.CrankyCoder.net
      MySensors: 2.3
      • CrankyCoderC CrankyCoder
        @CrankyCoder can you share the node sketch?
        You don’t happen to have gateway and/or node debug logs?
        CrankyCoderC 1 Reply Last reply
        • mfalkviddM
          Oh, and what hardware is your node? Atmega328?
            CrankyCoderC
            CrankyCoderC
            CrankyCoder
            @mfalkvidd sketch is here. I don't have the debug logs off the gateway, but ill hook up serial to it this weekend and get some logs. (i need to just make one of those bluetooth to ftdi adapters lol)
            hardware is 3.3v arduino pro mini for the node and wemos d1 mini for the gateway.
             * Copyright (C) 2013-2019 Sensnology AB
             * Full contributor list: https://github.com/mysensors/MySensors/graphs/contributors
             * Version 1.0 - Henrik Ekblad
             * Example sketch showing how to control physical relays.
             * This example will remember relay state after power failure.
             * http://www.mysensors.org/build/relay
            #define MY_RADIO_RF24
            //#define MY_RADIO_NRF5_ESB
            //#define MY_RADIO_RFM95
            #define MY_NODE_ID 18
            int BATTERY_SENSE_PIN = A0;
            //#define MY_REPEATER_FEATURE
            #define CHILD_ID_HOSE 0
            #define CHILD_ID_VOLT 1
            uint32_t SLEEP_TIME = 30000;
            MyMessage msg(CHILD_ID_HOSE, V_STATUS);
            #define HOSE_ON 1  // GPIO value to write to turn on attached relay
            #define HOSE_OFF 0 // GPIO value to write to turn off attached relay
            int oldBatteryPcnt = 0;
            int in1 = 5;
            int in2 = 6;
            unsigned long start_time;
            unsigned long timed_event = 1000;
            unsigned long current_time;
            void before()
            	pinMode(in1, OUTPUT);
              pinMode(in2, OUTPUT);
              analogReference(INTERNAL1V1);
              analogReference(INTERNAL);
             SendBatteryUpdate();
             directionControl(HOSE_ON);
             delay(100);
             directionControl(HOSE_OFF);
            	sendSketchInfo("Garden Soaker Hose Control", "1.0");
              present(CHILD_ID_HOSE,S_BINARY);
              present(CHILD_ID_VOLT, S_MULTIMETER);
            	digitalWrite(in1, LOW);
              digitalWrite(in2, LOW);
              current_time = millis();
              start_time = current_time;
              static bool first_message_sent = false;
              if ( first_message_sent == false ) {
                Serial.println( "Sending initial state..." );
                send_status_message();
                first_message_sent = true;
              current_time = millis(); // update the timer every cycle
              if (current_time - start_time >= timed_event) {
                start_time = current_time;  // reset the timer
              #ifdef MY_DEBUG
                Serial.println("Going to sleep");
              smartSleep(SLEEP_TIME);
              #ifdef MY_DEBUG
                Serial.println("Awake Now");
            void SendBatteryUpdate()
              // get the battery Voltage
              int runningTotal=0;
              for (int x=0;x<10;x++)
                runningTotal=runningTotal+analogRead(BATTERY_SENSE_PIN);
              int sensorValue=runningTotal / 10;
              //int sensorValue = analogRead(BATTERY_SENSE_PIN);
              #ifdef MY_DEBUG
                Serial.println(sensorValue);
                //973 = 4.05v
              #ifdef MY_DEBUG
                float batteryV  = (sensorValue * 3.34) / 1024;
                Serial.println(batteryV);
                batteryV = batteryV / 0.7802721088435374;
                //batteryV = batteryV / 0.4857457520453115;
                batteryV = batteryV / 0.5291330073696145;
                int batteryPcnt = (batteryV / 8.4) * 100;
                Serial.print(batteryV);
                Serial.println(" V");
                Serial.print(batteryPcnt);
                Serial.println(" %");
                // Power up radio after sleep
                send(msgVolt.set(batteryV,1));
                oldBatteryPcnt = batteryPcnt;
              Serial.print("sensorValue:");
            	if (message.getType()==V_STATUS) {
            		// Change relay state
                directionControl(message.getBool()?HOSE_ON:HOSE_OFF);
            		//digitalWrite(message.getSensor()-1+RELAY_PIN, message.getBool()?RELAY_ON:RELAY_OFF);
            		// Store state in eeprom
            		saveState(message.getSensor(), message.getBool());
            		Serial.print(message.getSensor());
            void send_status_message()
                send(msg.set(1));
            void directionControl(int ONOFF) {
              // Set motors to maximum speed
              // For PWM maximum possible values are 0 to 255
              // Turn flip circuit on for 1/4 second
              if (ONOFF == HOSE_ON)
                  Serial.print("turning hose: ");
                  Serial.println(ONOFF);
                  digitalWrite(in1, HIGH);
                  delay(250);
                  send(msg.set(HOSE_ON));
                  // turn off circuit for 1/4 second
                  digitalWrite(in2, HIGH);
                  delay(250);
                  send(msg.set(HOSE_OFF));
              // disable
            www.CrankyCoder.net
            MySensors: 2.3
              int in1 = 5;
              int in2 = 6;
              void before()
               delay(100);
                #ifdef MY_DEBUG
                #ifdef MY_DEBUG
                int runningTotal=0;
                #ifdef MY_DEBUG
                  //973 = 4.05v
                #ifdef MY_DEBUG
                  send(msg.set(1));
                    delay(250);
                    delay(250);
                // disable
              @CrankyCoder if I understand correctly, the mqtt plot you provided is how often the battery status is sent?
              And your expectation is that the battery status would be sent approximately every 30,000 milliseconds?
              If so, the problem is that millis() is frozen during sleep. So the logic in the sketch is wrong. The sensor will report battery status after being awake 30000 milliseconds.
              You can verify this by printing or reporting the value of millis() on the node.
              • CrankyCoderC
                CrankyCoderC
                CrankyCoder
                The 30 seconds is what is passed to the smart sleep function based on the smartsleep() documentation. In this case SLEEP_TIME = 30000. The other stuff in the code around the millis() check i understand would be halted, but I believe the smart_sleep is different based on the documentation.
                  #ifdef MY_DEBUG
                  #ifdef MY_DEBUG
                www.CrankyCoder.net
                MySensors: 2.3
                • CrankyCoderC
                  CrankyCoderC
                  CrankyCoder
                  Another quick update. I hooked my gateway up to my computer to get some debug logs off it. I am not seeing ANYTHING coming from that node using smartsleep at all. So it does appear the issue is specifically with that node.
                  Since it's battery powered i am going to see if i can get serial connected up without a reset and see what's it saying but i have a feeling it's going to be what ive seen before and it's having a hard time finding a parent for some reason. Not sure how to fix that.
                  www.CrankyCoder.net
                  MySensors: 2.3
                  skywatchS 1 Reply Last reply
                    skywatchS
                    skywatchS
                    skywatch
                    @CrankyCoder I have similar issue with a couple of nodes. Sometimes it looses signal for hours at a time...
                    It might be external interference from other devices like wifi, bluetooth or microwave oven.
                    It can also be connection issues especially with the push-on dupont connectors as when the temperature/humidity/air pressure change then the connectors can move slightly. Also they might be badly crimped in the first place.
                    So check all connections are good and can't move (soldering is best here), and then look for sources that might be an issue.
                    It could also be another node closer to the GW is sending at the exact same time as the problem node and masking the signal.
                    Batteries are susceptable to variations due to temperature too, they are a chemical reaction. So try a better source of power for testing too.
                    Looking at the code, send_status_message only ever sends 1 - is this what you want? It seems to never send anything else (like 0)....
                    Also you are using sleep but have a receive function - what happens to messages when the node is asleep?
                    You are sending battery level every second? That is too often. How long will the batteries last? This wastes battery power a lot. I check betteries once a day on my security sensors, they don't change for weeks at a time....
                    Have you modified the pro mini as per the battery page on this site? Have you added capacitors to the radio module?
                    directionControl seems like it will always turn off both digital pins regardless of the message as //disable are the last statements to be actioned?
                    You can try changing
                    to.....
                    options for power are MIN, LOW, HIGH, MAX. - it might help.
                    • CrankyCoderC
                      CrankyCoderC
                      CrankyCoder
                      @skywatch said in smart sleep inconsistent?:
                      battery is only sent when there is a change in the voltage.
                      Where do you see that? i get 1 and 0 reported as needed based on the state.
                      That is what smartsleep does. It tells my controller (homeassistant) to queue up the messages. Which works fine, as long as the node wakes up.
                      Correct, modified for battery use, and capacitors to the radio module.
                      This is correct, this is a directional H-bridge controller to pulse a latching solenoid valve, so I do not need them on but very briefly.
                      www.CrankyCoder.net
                      MySensors: 2.3
                      • CrankyCoderC
                        CrankyCoderC
                        CrankyCoder
                        I have the node and gateway on my desk now for testing, so I am going to reflash with this now! Fingers crossed it helps. :)
                        www.CrankyCoder.net
                        MySensors: 2.3
                        • CrankyCoderC
                          CrankyCoderC
                          CrankyCoder
                          Got some more info. Here is some debug log off the gateway. The node in question is node 18
                          22:02:47.582 -> 28832653 TSF:MSG:SEND,0-0-18-18,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                          22:03:51.377 -> 28896448 TSF:MSG:READ,18-18-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                          22:03:51.422 -> 28896512 TSF:MSG:BC
                          22:03:51.422 -> 28896533 TSF:MSG:FPAR REQ,ID=18
                          22:03:51.468 -> 28896566 TSF:PNG:SEND,TO=0
                          22:03:51.513 -> 28896594 TSF:CKU:OK
                          22:03:51.513 -> 28896615 TSF:MSG:GWL OK
                          22:03:51.967 -> 28897026 TSF:MSG:SEND,0-0-18-18,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                          22:05:01.405 -> 28966464 GWT:IMQ:TOPIC=mygateway1-in/10/1/1/0/40, MSG RECEIVED
                          22:05:01.497 -> 28966569 !TSF:MSG:SEND,0-0-53-10,s=1,c=1,t=40,pt=0,l=6,sg=0,ft=0,st=NACK:FFFFFF
                          22:07:04.200 -> 29089296 TSF:MSG:READ,18-18-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                          22:07:04.246 -> 29089359 TSF:MSG:BC
                          22:07:04.292 -> 29089380 TSF:MSG:FPAR REQ,ID=18
                          22:07:04.337 -> 29089414 TSF:PNG:SEND,TO=0
                          22:07:04.337 -> 29089442 TSF:CKU:OK
                          22:07:04.382 -> 29089463 TSF:MSG:GWL OK
                          22:07:05.152 -> 29090214 TSF:MSG:SEND,0-0-18-18,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                          22:10:01.430 -> 29266499 GWT:IMQ:TOPIC=mygateway1-in/10/1/1/0/40, MSG RECEIVED
                          22:10:01.521 -> 29266604 !TSF:MSG:SEND,0-0-53-10,s=1,c=1,t=40,pt=0,l=6,sg=0,ft=0,st=NACK:FFFFFF
                          22:10:59.660 -> 29324730 TSF:MSG:READ,38-38-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                          22:10:59.706 -> 29324794 TSF:MSG:BC
                          22:10:59.706 -> 29324815 TSF:MSG:FPAR REQ,ID=38
                          22:10:59.751 -> 29324848 TSF:PNG:SEND,TO=0
                          22:10:59.797 -> 29324877 TSF:CKU:OK
                          22:10:59.797 -> 29324897 TSF:MSG:GWL OK
                          22:11:00.523 -> 29325594 !TSF:MSG:SEND,0-0-38-38,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                          Running it through the log parser it would appear the gateway is responding to the find parent request.
                          BUT. The node it self seems to be failing to find parent periodically. Like it's not getting the message back from the gateway.
                          22:12:10.465 -> Going to sleep
                          22:12:10.465 -> 44562 MCO:SLP:MS=30000,SMS=1,I1=255,M1=255,I2=255,M2=255
                          22:12:10.465 -> 44572 !MCO:SLP:TNR
                          22:12:20.399 -> 54491 TSM:FAIL:RE-INIT
                          22:12:20.399 -> 54493 TSM:INIT
                          22:12:20.399 -> 54499 !TSM:INIT:TSP FAIL
                          22:12:20.444 -> 54501 TSM:FAIL:CNT=5
                          22:12:20.444 -> 54503 TSM:FAIL:DIS
                          22:12:20.444 -> 54505 TSF:TDI:TSL
                          22:12:20.489 -> 54575 MCO:SLP:MS=19999
                          22:12:20.489 -> 54577 !TSF:SND:TNR
                          22:12:21.035 -> 55080 TSF:TDI:TSL
                          22:12:42.255 -> 55083 MCO:SLP:WUP=-1
                          22:12:42.301 -> 55085 TSF:TRI:TSB
                          22:12:42.301 -> 55091 !TSF:SND:TNR
                          22:12:42.301 -> Awake Now
                          22:12:42.301 -> 1010
                          22:12:42.301 -> 3.29
                          22:12:42.301 -> Battery Voltage: 7.98 V
                          22:12:42.301 -> Battery percent: 94 %
                          22:12:42.301 -> sensorValue:1010
                          22:12:42.301 -> Going to sleep
                          22:12:42.301 -> 55099 MCO:SLP:MS=30000,SMS=1,I1=255,M1=255,I2=255,M2=255
                          22:12:42.301 -> 55109 !MCO:SLP:TNR
                          22:12:51.744 -> 64509 TSM:FAIL:RE-INIT
                          22:12:51.744 -> 64512 TSM:INIT
                          22:12:51.744 -> 64518 !TSM:INIT:TSP FAIL
                          22:12:51.744 -> 64520 TSM:FAIL:CNT=6
                          22:12:51.744 -> 64522 TSM:FAIL:DIS
                          22:12:51.744 -> 64524 TSF:TDI:TSL
                          22:12:52.330 -> 65112 MCO:SLP:MS=19999
                          22:12:52.330 -> 65114 !TSF:SND:TNR
                          22:12:52.829 -> 65617 TSF:TDI:TSL
                          www.CrankyCoder.net
                          MySensors: 2.3
                            !TSM:INIT:TSP FAIL indicates that the radio chip is not responding to the arduino's commands.
                            The most common cause is unreliable wiring. But it could be something else. Define MY_DEBUG_VERBOSE_RF24 to get more details.
                            • mfalkviddM
                              Btw, are you using MySensors 2.3 on the node and the gateway?
                                skywatchS
                                skywatchS
                                skywatch
                                @CrankyCoder Do the data drop outs have any correlation to the solenoid valve operating and does the valave use the same power supply as the node MCU?
                                  CrankyCoderC
                                  CrankyCoderC
                                  CrankyCoder
                                  @mfalkvidd Will add this now.
                                  www.CrankyCoder.net
                                  MySensors: 2.3
                                    CrankyCoderC
                                    CrankyCoderC
                                    CrankyCoder
                                    @mfalkvidd said in smart sleep inconsistent?:
                                    Correct 2.3 on node and gateway.
                                    www.CrankyCoder.net
                                    MySensors: 2.3
                                    • skywatchS skywatch
                                      CrankyCoderC
                                      CrankyCoderC
                                      CrankyCoder
                                      @skywatch unfortunately no. This is for a sprinkler valve that I haven't set up any automations for yet since the questionable reliability at the moment would flood my yard lol
                                      www.CrankyCoder.net
                                      MySensors: 2.3
                                      • CrankyCoderC
                                        CrankyCoderC
                                        CrankyCoder
                                        Not sure if this helps or if anything jumps out, but here is the node and gateway side by side. Node does find parent request, gateway sees it, responds with 0. But node never gets it.
                                        www.CrankyCoder.net
                                        MySensors: 2.3
                                        mfalkviddM skywatchS 2 Replies Last reply
                                          @CrankyCoder I am not sure but to me it looks like it takes a bit more than 1 second for the gateway to send the response? And by then, the node has already gone to sleep so it can't receive the message.
