  3. smart sleep inconsistent?
21 Posts 3 Posters 3.6k Views 3 Watching
  • CrankyCoderC CrankyCoder
    additional information:
    • wemos d1 mini mqtt gateway
    • tried with and without repeater
    • tried moving gateway closer to node (easier than moving node)
    @CrankyCoder can you share the node sketch?
    You don’t happen to have gateway and/or node debug logs?
    CrankyCoderC 1 Reply Last reply
    • mfalkviddM
      Oh, and what hardware is your node? Atmega328?
        CrankyCoderC
        CrankyCoderC
        CrankyCoder
        @mfalkvidd sketch is here. I don't have the debug logs off the gateway, but ill hook up serial to it this weekend and get some logs. (i need to just make one of those bluetooth to ftdi adapters lol)
        hardware is 3.3v arduino pro mini for the node and wemos d1 mini for the gateway.
         * Copyright (C) 2013-2019 Sensnology AB
         * Full contributor list: https://github.com/mysensors/MySensors/graphs/contributors
         * Version 1.0 - Henrik Ekblad
         * Example sketch showing how to control physical relays.
         * This example will remember relay state after power failure.
         * http://www.mysensors.org/build/relay
        #define MY_RADIO_RF24
        //#define MY_RADIO_NRF5_ESB
        //#define MY_RADIO_RFM95
        #define MY_NODE_ID 18
        int BATTERY_SENSE_PIN = A0;
        //#define MY_REPEATER_FEATURE
        #define CHILD_ID_HOSE 0
        #define CHILD_ID_VOLT 1
        uint32_t SLEEP_TIME = 30000;
        MyMessage msg(CHILD_ID_HOSE, V_STATUS);
        #define HOSE_ON 1  // GPIO value to write to turn on attached relay
        #define HOSE_OFF 0 // GPIO value to write to turn off attached relay
        int oldBatteryPcnt = 0;
        int in1 = 5;
        int in2 = 6;
        unsigned long start_time;
        unsigned long timed_event = 1000;
        unsigned long current_time;
        void before()
        	pinMode(in1, OUTPUT);
          pinMode(in2, OUTPUT);
          analogReference(INTERNAL1V1);
          analogReference(INTERNAL);
         SendBatteryUpdate();
         directionControl(HOSE_ON);
         delay(100);
         directionControl(HOSE_OFF);
        	sendSketchInfo("Garden Soaker Hose Control", "1.0");
          present(CHILD_ID_HOSE,S_BINARY);
          present(CHILD_ID_VOLT, S_MULTIMETER);
        	digitalWrite(in1, LOW);
          digitalWrite(in2, LOW);
          current_time = millis();
          start_time = current_time;
          static bool first_message_sent = false;
          if ( first_message_sent == false ) {
            Serial.println( "Sending initial state..." );
            send_status_message();
            first_message_sent = true;
          current_time = millis(); // update the timer every cycle
          if (current_time - start_time >= timed_event) {
            start_time = current_time;  // reset the timer
          #ifdef MY_DEBUG
            Serial.println("Going to sleep");
          smartSleep(SLEEP_TIME);
          #ifdef MY_DEBUG
            Serial.println("Awake Now");
        void SendBatteryUpdate()
          // get the battery Voltage
          int runningTotal=0;
          for (int x=0;x<10;x++)
            runningTotal=runningTotal+analogRead(BATTERY_SENSE_PIN);
          int sensorValue=runningTotal / 10;
          //int sensorValue = analogRead(BATTERY_SENSE_PIN);
          #ifdef MY_DEBUG
            Serial.println(sensorValue);
            //973 = 4.05v
          #ifdef MY_DEBUG
            float batteryV  = (sensorValue * 3.34) / 1024;
            Serial.println(batteryV);
            batteryV = batteryV / 0.7802721088435374;
            //batteryV = batteryV / 0.4857457520453115;
            batteryV = batteryV / 0.5291330073696145;
            int batteryPcnt = (batteryV / 8.4) * 100;
            Serial.print(batteryV);
            Serial.println(" V");
            Serial.print(batteryPcnt);
            Serial.println(" %");
            // Power up radio after sleep
            send(msgVolt.set(batteryV,1));
            oldBatteryPcnt = batteryPcnt;
          Serial.print("sensorValue:");
        	if (message.getType()==V_STATUS) {
        		// Change relay state
            directionControl(message.getBool()?HOSE_ON:HOSE_OFF);
        		//digitalWrite(message.getSensor()-1+RELAY_PIN, message.getBool()?RELAY_ON:RELAY_OFF);
        		// Store state in eeprom
        		saveState(message.getSensor(), message.getBool());
        		Serial.print(message.getSensor());
        void send_status_message()
            send(msg.set(1));
        void directionControl(int ONOFF) {
          // Set motors to maximum speed
          // For PWM maximum possible values are 0 to 255
          // Turn flip circuit on for 1/4 second
          if (ONOFF == HOSE_ON)
              Serial.print("turning hose: ");
              Serial.println(ONOFF);
              digitalWrite(in1, HIGH);
              delay(250);
              send(msg.set(HOSE_ON));
              // turn off circuit for 1/4 second
              digitalWrite(in2, HIGH);
              delay(250);
              send(msg.set(HOSE_OFF));
          // disable
        Home Automation Tinkerer
        www.CrankyCoder.net
        Gateway: MQTTClientGateway
        MySensors: 2.3
          int in1 = 5;
          int in2 = 6;
          void before()
           delay(100);
            #ifdef MY_DEBUG
            #ifdef MY_DEBUG
            int runningTotal=0;
            #ifdef MY_DEBUG
              //973 = 4.05v
            #ifdef MY_DEBUG
              send(msg.set(1));
                delay(250);
                delay(250);
            // disable
          @CrankyCoder if I understand correctly, the mqtt plot you provided is how often the battery status is sent?
          And your expectation is that the battery status would be sent approximately every 30,000 milliseconds?
          If so, the problem is that millis() is frozen during sleep. So the logic in the sketch is wrong. The sensor will report battery status after being awake 30000 milliseconds.
          You can verify this by printing or reporting the value of millis() on the node.
          • CrankyCoderC
            CrankyCoderC
            CrankyCoder
            The 30 seconds is what is passed to the smart sleep function based on the smartsleep() documentation. In this case SLEEP_TIME = 30000. The other stuff in the code around the millis() check i understand would be halted, but I believe the smart_sleep is different based on the documentation.
              #ifdef MY_DEBUG
              #ifdef MY_DEBUG
            www.CrankyCoder.net
            MySensors: 2.3
            • CrankyCoderC
              CrankyCoderC
              CrankyCoder
              Another quick update. I hooked my gateway up to my computer to get some debug logs off it. I am not seeing ANYTHING coming from that node using smartsleep at all. So it does appear the issue is specifically with that node.
              Since it's battery powered i am going to see if i can get serial connected up without a reset and see what's it saying but i have a feeling it's going to be what ive seen before and it's having a hard time finding a parent for some reason. Not sure how to fix that.
              www.CrankyCoder.net
              MySensors: 2.3
              skywatchS 1 Reply Last reply
                skywatchS
                skywatchS
                skywatch
                @CrankyCoder I have similar issue with a couple of nodes. Sometimes it looses signal for hours at a time...
                It might be external interference from other devices like wifi, bluetooth or microwave oven.
                It can also be connection issues especially with the push-on dupont connectors as when the temperature/humidity/air pressure change then the connectors can move slightly. Also they might be badly crimped in the first place.
                So check all connections are good and can't move (soldering is best here), and then look for sources that might be an issue.
                It could also be another node closer to the GW is sending at the exact same time as the problem node and masking the signal.
                Batteries are susceptable to variations due to temperature too, they are a chemical reaction. So try a better source of power for testing too.
                Looking at the code, send_status_message only ever sends 1 - is this what you want? It seems to never send anything else (like 0)....
                Also you are using sleep but have a receive function - what happens to messages when the node is asleep?
                You are sending battery level every second? That is too often. How long will the batteries last? This wastes battery power a lot. I check betteries once a day on my security sensors, they don't change for weeks at a time....
                Have you modified the pro mini as per the battery page on this site? Have you added capacitors to the radio module?
                directionControl seems like it will always turn off both digital pins regardless of the message as //disable are the last statements to be actioned?
                You can try changing
                to.....
                options for power are MIN, LOW, HIGH, MAX. - it might help.
                • CrankyCoderC
                  CrankyCoderC
                  CrankyCoder
                  @skywatch said in smart sleep inconsistent?:
                  battery is only sent when there is a change in the voltage.
                  Where do you see that? i get 1 and 0 reported as needed based on the state.
                  That is what smartsleep does. It tells my controller (homeassistant) to queue up the messages. Which works fine, as long as the node wakes up.
                  Correct, modified for battery use, and capacitors to the radio module.
                  This is correct, this is a directional H-bridge controller to pulse a latching solenoid valve, so I do not need them on but very briefly.
                  www.CrankyCoder.net
                  MySensors: 2.3
                  • CrankyCoderC
                    CrankyCoderC
                    CrankyCoder
                    I have the node and gateway on my desk now for testing, so I am going to reflash with this now! Fingers crossed it helps. :)
                    www.CrankyCoder.net
                    MySensors: 2.3
                    • CrankyCoderC
                      CrankyCoderC
                      CrankyCoder
                      Got some more info. Here is some debug log off the gateway. The node in question is node 18
                      22:02:47.582 -> 28832653 TSF:MSG:SEND,0-0-18-18,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                      22:03:51.377 -> 28896448 TSF:MSG:READ,18-18-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                      22:03:51.422 -> 28896512 TSF:MSG:BC
                      22:03:51.422 -> 28896533 TSF:MSG:FPAR REQ,ID=18
                      22:03:51.468 -> 28896566 TSF:PNG:SEND,TO=0
                      22:03:51.513 -> 28896594 TSF:CKU:OK
                      22:03:51.513 -> 28896615 TSF:MSG:GWL OK
                      22:03:51.967 -> 28897026 TSF:MSG:SEND,0-0-18-18,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                      22:05:01.405 -> 28966464 GWT:IMQ:TOPIC=mygateway1-in/10/1/1/0/40, MSG RECEIVED
                      22:05:01.497 -> 28966569 !TSF:MSG:SEND,0-0-53-10,s=1,c=1,t=40,pt=0,l=6,sg=0,ft=0,st=NACK:FFFFFF
                      22:07:04.200 -> 29089296 TSF:MSG:READ,18-18-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                      22:07:04.246 -> 29089359 TSF:MSG:BC
                      22:07:04.292 -> 29089380 TSF:MSG:FPAR REQ,ID=18
                      22:07:04.337 -> 29089414 TSF:PNG:SEND,TO=0
                      22:07:04.337 -> 29089442 TSF:CKU:OK
                      22:07:04.382 -> 29089463 TSF:MSG:GWL OK
                      22:07:05.152 -> 29090214 TSF:MSG:SEND,0-0-18-18,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                      22:10:01.430 -> 29266499 GWT:IMQ:TOPIC=mygateway1-in/10/1/1/0/40, MSG RECEIVED
                      22:10:01.521 -> 29266604 !TSF:MSG:SEND,0-0-53-10,s=1,c=1,t=40,pt=0,l=6,sg=0,ft=0,st=NACK:FFFFFF
                      22:10:59.660 -> 29324730 TSF:MSG:READ,38-38-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                      22:10:59.706 -> 29324794 TSF:MSG:BC
                      22:10:59.706 -> 29324815 TSF:MSG:FPAR REQ,ID=38
                      22:10:59.751 -> 29324848 TSF:PNG:SEND,TO=0
                      22:10:59.797 -> 29324877 TSF:CKU:OK
                      22:10:59.797 -> 29324897 TSF:MSG:GWL OK
                      22:11:00.523 -> 29325594 !TSF:MSG:SEND,0-0-38-38,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                      Running it through the log parser it would appear the gateway is responding to the find parent request.
                      BUT. The node it self seems to be failing to find parent periodically. Like it's not getting the message back from the gateway.
                      22:12:10.465 -> Going to sleep
                      22:12:10.465 -> 44562 MCO:SLP:MS=30000,SMS=1,I1=255,M1=255,I2=255,M2=255
                      22:12:10.465 -> 44572 !MCO:SLP:TNR
                      22:12:20.399 -> 54491 TSM:FAIL:RE-INIT
                      22:12:20.399 -> 54493 TSM:INIT
                      22:12:20.399 -> 54499 !TSM:INIT:TSP FAIL
                      22:12:20.444 -> 54501 TSM:FAIL:CNT=5
                      22:12:20.444 -> 54503 TSM:FAIL:DIS
                      22:12:20.444 -> 54505 TSF:TDI:TSL
                      22:12:20.489 -> 54575 MCO:SLP:MS=19999
                      22:12:20.489 -> 54577 !TSF:SND:TNR
                      22:12:21.035 -> 55080 TSF:TDI:TSL
                      22:12:42.255 -> 55083 MCO:SLP:WUP=-1
                      22:12:42.301 -> 55085 TSF:TRI:TSB
                      22:12:42.301 -> 55091 !TSF:SND:TNR
                      22:12:42.301 -> Awake Now
                      22:12:42.301 -> 1010
                      22:12:42.301 -> 3.29
                      22:12:42.301 -> Battery Voltage: 7.98 V
                      22:12:42.301 -> Battery percent: 94 %
                      22:12:42.301 -> sensorValue:1010
                      22:12:42.301 -> Going to sleep
                      22:12:42.301 -> 55099 MCO:SLP:MS=30000,SMS=1,I1=255,M1=255,I2=255,M2=255
                      22:12:42.301 -> 55109 !MCO:SLP:TNR
                      22:12:51.744 -> 64509 TSM:FAIL:RE-INIT
                      22:12:51.744 -> 64512 TSM:INIT
                      22:12:51.744 -> 64518 !TSM:INIT:TSP FAIL
                      22:12:51.744 -> 64520 TSM:FAIL:CNT=6
                      22:12:51.744 -> 64522 TSM:FAIL:DIS
                      22:12:51.744 -> 64524 TSF:TDI:TSL
                      22:12:52.330 -> 65112 MCO:SLP:MS=19999
                      22:12:52.330 -> 65114 !TSF:SND:TNR
                      22:12:52.829 -> 65617 TSF:TDI:TSL
                      www.CrankyCoder.net
                      MySensors: 2.3
                        !TSM:INIT:TSP FAIL indicates that the radio chip is not responding to the arduino's commands.
                        The most common cause is unreliable wiring. But it could be something else. Define MY_DEBUG_VERBOSE_RF24 to get more details.
                        • mfalkviddM
                          Btw, are you using MySensors 2.3 on the node and the gateway?
                            skywatchS
                            skywatchS
                            skywatch
                            @CrankyCoder Do the data drop outs have any correlation to the solenoid valve operating and does the valave use the same power supply as the node MCU?
                              CrankyCoderC
                              CrankyCoderC
                              CrankyCoder
                              @mfalkvidd Will add this now.
                              www.CrankyCoder.net
                              MySensors: 2.3
                                CrankyCoderC
                                CrankyCoderC
                                CrankyCoder
                                @mfalkvidd said in smart sleep inconsistent?:
                                Correct 2.3 on node and gateway.
                                www.CrankyCoder.net
                                MySensors: 2.3
                                • skywatchS skywatch
                                  CrankyCoderC
                                  CrankyCoderC
                                  CrankyCoder
                                  @skywatch unfortunately no. This is for a sprinkler valve that I haven't set up any automations for yet since the questionable reliability at the moment would flood my yard lol
                                  www.CrankyCoder.net
                                  MySensors: 2.3
                                  • CrankyCoderC
                                    CrankyCoderC
                                    CrankyCoder
                                    Not sure if this helps or if anything jumps out, but here is the node and gateway side by side. Node does find parent request, gateway sees it, responds with 0. But node never gets it.
                                    www.CrankyCoder.net
                                    MySensors: 2.3
                                    mfalkviddM skywatchS 2 Replies Last reply
                                      @CrankyCoder I am not sure but to me it looks like it takes a bit more than 1 second for the gateway to send the response? And by then, the node has already gone to sleep so it can't receive the message.
                                        skywatchS
                                        skywatchS
                                        skywatch
                                        @CrankyCoder How far apart are the node and gateway? What is between them? Can you post any photos of of each with the wiring?
                                        12.5k
