  3. Code Garage to the rescue.
20 Posts 15 Posters 6.7k Views 14 Watching
  • MarcinM
    MarcinM
    Marcin
    I hope the project won't be buried due to the fact that the protocol is the basis of nippy devices (https://nippysmart.com/) I also hope that the development of mysensors won't be directed in 2 directions - one commercial only for nippy - the other for all the rest, which could result in the two versions diverging so much that they will be incompatible and the second one will simply be buried.
    • P
      P
      perfectom
      Hi, I'm glad CodeGarage is taking over! Please are there any updates since January what's happening? The GitHub repo hasn't gotten commits for over a year. Thanks!
      • H
        H
        hlehoux
        Thank you @CodeGarage , you really thrive !
        As for the suggestions, i would say most important point would be to look at the project code base.
        I guess the development branch has quiet evolved since the 2.3.2 release.
        Next would be to sort the features and decide a roadmap for mysensors because the project can live only if it evolves
        Long live MySensors!
        TheoLT 1 Reply Last reply
        • H hlehoux
          TheoLT
          TheoLT
          TheoL
          wrote on last edited by TheoL
          @hlehoux As I understand the limitation of the packet size is by the NRF radio. Maybe stop supporting NRF, so that we can get a bit bigger packet size. That would help my current project where I'm using MySensors as a transport layer. I know that is easier with wifi. But I want to use mysensors.
          Never mind: If I hexify everything, I can squeeze in all I need so far.
          F 1 Reply Last reply
          • TheoLT TheoL
            F
            F
            fsgraz
            @TheoL I wish nRF will be supported for longer time. Maybe just be free to specify the payload lenght instead ?
            But I am with you on wishing for MySensors protocol over wifi with extendable lenght.
            OldSurferDudeO 1 Reply Last reply
            • F fsgraz
              OldSurferDudeO
              OldSurferDudeO
              OldSurferDude
              @fsgraz As an alternative to MySensors using the nRF24 radio, look at the work that tmrh20 has done. I have used this code and found it works well enough. It's lower level than MySensors. I haven't tried to connect it to Home Assistant, but I think a determined person could make this happen.
              I would say it doesn't have the support that MySensors ha,s being only one person, but there isn't much support here anymore. :(
              • H
                H
                hlehoux
                Well, i've swiched all my sensors from nRF24 to RFM69 for longer range
                • OldSurferDudeO
                  OldSurferDudeO
                  OldSurferDude
                  @CodeGarage I am getting the message that www.mysensors.org is not responding (13h22 PDT 8 Aug 25) Is MySensors officially dead?
                  tekkaT 1 Reply Last reply
                    tekkaT
                    tekkaT
                    tekka
                    @OldSurferDude The website should be back again.
                    • F
                      F
                      fsgraz
                      it is up and running
                      • HonkH
                        HonkH
                        Honk
                        there is a problem with openhardware.io
                        The cert seems to be outdated. Is someone here who can do something about it? If not does anybody know who to ask?
                        • HonkH Honk
                          Thanks for reporting @Honk
                          @hek has fixed the cert issue now
