  3. nRF24Doctor
nRF24Doctor
transmission delayscompare modulespower consumptionradio qualitydoctorrangegateway locationdiagnosenrf24 radio
58 Posts 16 Posters 29.1k Views 26 Watching
  • B
    B
    broomnest
    Banned
    The output of the display could also be sent over serial, but the whole idea is you can walk around with the doctor and improve your results as you go.
    • ben999B
      ben999B
      ben999
      wrote on last edited by ben999
      #45
      Sorry to necro this old post :(
      I have just uploaded @yveaux's version of nRF24 doctor to a Nano.
      @Yveaux said in nRF24Doctor:
      https://github.com/TechNovation01/nRF24Doctor/blob/master/pcb/nRFDoctor_1.1_sch.pdf
      I got all the right libraries installed into IDE (especially LCDMenuLib2.h version 1.2.7, i also tried several other versions close to 1.2.7 just to be sure).
      But when compiling i get the following errors :
      /tmp/ccMpih6l.ltrans0.ltrans.o: In function `global constructors keyed to 65535_0_nRF24QualityMeter03.ino.cpp.o.3416':
      <artificial>:(.text.startup+0x19a): undefined reference to `lcdml_menu_display()'
      <artificial>:(.text.startup+0x19c): undefined reference to `lcdml_menu_display()'
      <artificial>:(.text.startup+0x1a6): undefined reference to `lcdml_menu_clear()'
      <artificial>:(.text.startup+0x1a8): undefined reference to `lcdml_menu_clear()'
      collect2: error: ld returned 1 exit status
      exit status 1
      Erreur de compilation pour la carte Arduino Nano
      That is a bit above my knowledge. Could someone please point me into the right direction? Could it be just a case of "wrong naming" of variables ?
      ben999B 1 Reply Last reply
      • ben999B ben999
        exit status 1
        ben999B
        ben999B
        ben999
        #46
        I might be able to answer that myself !
        Looks like i have forgotten to "combine" a .ino file (CharLcdMenu.ino) with the main one (nRF24DoctorNode.ino), which seems to be a bit like a sub-program.
        edit: that's it. Just had to create a second TAB with that sub-program, compile and success.
        Please forgive my lack of vocabulary and knowldge, i am a "copy-paste" engineer :D
        • OldSurferDudeO
          OldSurferDudeO
          OldSurferDude
          It's great when a project can be brought to life after 8 years!
            ben999B
            ben999B
            ben999
            #48
            @OldSurferDude as long as we’re using nRFs this project is still relevant :D
            I am now facing some more troubles:
            The nRFNode cannot connect to GW.
            Looks like a software issue. The exact same setup connects to GW when loaded with a very basic sketch (relay in my case). I am using @yveaux 's sketch from his Github.
            Could this sketch not be compatible with today's API ?
            OldSurferDudeO 1 Reply Last reply
            • ben999B ben999
              OldSurferDudeO
              OldSurferDudeO
              OldSurferDude
              @ben999
              @ben999 said:
              very basic sketch
              My guess is that because you're not using the LCD in the basic sketch that talking to the LCD is causing radio interference.
              To test this theory and assuming you have the LED connected, the LCD code could be replaced with flash-code code.
              My technique for doing this replacement is to use compiler directives to remove the LCD code and add flash-code code.
              To remove the LCD code, create a new compiler flag
              #define LCD_ENABLE
              Surround all LCD code with
              #ifdef LCD_ENABLE
              Then comment out the definition line which disables the LCD.
              Create another new compiler flag
              #define FC_PIN 4
              and comment out both the compiler directives that create TRIGGER_PIN and LED_PIN
              At the point in the existing code where the LCD is to display the quality, put a call to your new routine, This call will pass the quality number to the code that generates a flash code. So this new code can be easily disabled, surround your code with:
              #ifndef FC_PIN
              Yes, I make a huge assumption that you understand this (compiler directives, flash-code, etc.). If you don't, I, or others, can help out, but you'd learn more if you did it on your own.
                @ben999
                @ben999 said:
                very basic sketch
                #define LCD_ENABLE
                #ifdef LCD_ENABLE
                #define FC_PIN 4
                #ifndef FC_PIN
                ben999B
                ben999B
                ben999
                #50
                @OldSurferDude thank you very much for taking time to explain.
                I didn't make it clear enough from my side though.
                My "test" setup here is not the whole "nRF Doctor", as i got fed up with it !!
                Last night i just grabbed a Nano and a red nRF (eByte).
                Then loaded a random basic sketch and it got connected to GW straight away.
                After that i loaded @yveaux 's sketch and it never reached the GW (although changes were made to sketch, such as default channel (76), power level and transmission speed. These changes were made to files located in the "share" directory, that are called via "#include").
                Yveaux's sketch is based on API ver 2.2.0... latest stable is 2.3.2. So i tried different versions other than 2.3.2 but they all ended up with errors when compiling.
                I'll keep on digging tonight anyway (and report errors).
                • ben999B
                  ben999B
                  ben999
                  #51
                  Quick update:
                  -compiling with MySensors librairy ver 2.3.2 gives no error but my simple setup cannot reach GW with the following debug on serial monitor:
                  0 MCO:BGN:INIT NODE,CP=RNNNA---,FQ=16,REL=255,VER=2.3.2
                  4 MCO:BGN:BFR
                  35 TSM:INIT
                  36 TSF:WUR:MS=100
                  43 TSM:INIT:TSP OK
                  45 TSM:INIT:STATID=250
                  47 TSF:SID:OK,ID=250
                  49 TSM:FPAR
                  72 ?TSF:MSG:SEND,250-250-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  137 MCO:BGN:STP
                  151 TSF:WUR:MS=2000
                  2080 !TSM:FPAR:NO REPLY
                  2082 TSM:FPAR
                  2105 ?TSF:MSG:SEND,250-250-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  2166 MCO:BGN:INIT OK,TSP=0
                  4113 !TSM:FPAR:NO REPLY
                  4115 TSM:FPAR
                  4139 ?TSF:MSG:SEND,250-250-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  6147 !TSM:FPAR:NO REPLY
                  6149 TSM:FPAR
                  6172 ?TSF:MSG:SEND,250-250-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  8180 !TSM:FPAR:FAIL
                  8181 TSM:FAIL:CNT=1
                  8183 TSM:FAIL:DIS
                  8185 TSF:TDI:TSL
                  18187 TSM:FAIL:RE-INIT
                  18189 TSM:INIT
                  18195 TSM:INIT:TSP OK
                  18197 TSM:INIT:STATID=250
                  18200 TSF:SID:OK,ID=250
                  18202 TSM:FPAR
                  18225 ?TSF:MSG:SEND,250-250-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  20233 !TSM:FPAR:NO REPLY
                  20235 TSM:FPAR
                  20258 ?TSF:MSG:SEND,250-250-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  22266 !TSM:FPAR:NO REPLY
                  22268 TSM:FPAR
                  22291 ?TSF:MSG:SEND,250-250-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  24299 !TSM:FPAR:NO REPLY
                  24301 TSM:FPAR
                  24324 ?TSF:MSG:SEND,250-250-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  26332 !TSM:FPAR:FAIL
                  26333 TSM:FAIL:CNT=2
                  26335 TSM:FAIL:DIS
                  26337 TSF:TDI:TSL
                  36340 TSM:FAIL:RE-INIT
                  36342 TSM:INIT
                  36348 TSM:INIT:TSP OK
                  36350 TSM:INIT:STATID=250
                  36354 TSF:SID:OK,ID=250
                  36356 TSM:FPAR
                  36379 ?TSF:MSG:SEND,250-250-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  and so on
                  • compiling with MySensors librairy ver 2.2.0 (as mentionned in the sketch) gives me the following error:
                  Compilation error: 'RF24_PA_LOW' was not declared in this scope
                  • same error with MySensors librairy ver 2.3.0
                  • OldSurferDudeO
                    OldSurferDudeO
                    OldSurferDude
                    I vaguely remember that the RF24_PA_[power level] was given a different name. to something different. Basically the power level is 0,1,2, or 3 (MIN, LOW, HIGH, or MAX). see docs
                    To get it to compile, put this (a hack) line in
                    #define RF24_PA_LOW 1
                    before line 47
                    #include "shared/RadioConfig.h"
                    or before
                    radio.setPALevel(RF24_PA_LOW);
                    I had forgotten about this. Maybe the problem is that that power level is set to low. I see in RadioConfig.h it's set to LOW. This is done because the two radios could be close to one another and they would overdrive the other if they're set to MAX
                    Another thought (my little gray cells are not firing on all cylinders) It seems to me that line 47
                    should be after line 59
                    because the MySensors library is where the PA variables are set.
                    I hope my rambling here hasn't further complicated the issue.
                      before line 47
                      or before
                      ben999B
                      ben999B
                      ben999
                      @OldSurferDude thanks once again for taking time to understand my problem !
                      Moving
                      after
                      got me the following compile error
                      In file included from /home/ben/Documents/Arduino/nRF24QualityMeter03/nRF24QualityMeter03.ino:58:0:
                      /home/ben/Arduino/libraries/MySensors/MySensors.h:426:2: error: #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
                      exit status 1
                      Compilation error: exit status 1
                      • OldSurferDudeO
                        OldSurferDudeO
                        OldSurferDude
                        I'm thrashing on this, too, so I downloaded it and I compiled it.
                        Downloading:
                        1. From the web page I clicked on [Code] and then downloaded the zip file.
                        2. I extracted the zip file to my Arduino directory.
                        3. In a dos box (command line) I changed to Arduino\nRFDoctor-master
                        4. I executed the batch program mklink.bat which created symbolic links in both nRF24DoctorGateway and nRF24DoctorNode to their sister directory shared. This is needed so that the compiler can find the project specific libraries, eg RadioConfig.h
                        Then I opened nRF24DoctorNode in the Arduino IDE 2.3.10
                        When first compiling, there were many libraries required which I installed.
                        After all the libraries were installed, the code had the compiler check a value and if it was incorrect, it threw an error. When the line #define _LCDML_DISP_cfg_max_rows 2 was added to the the library LCDMenuLib2.h at line 42, the error no longer occurred. (Was this a good thing? Perhaps the line should have gone just before the error check?) This library is found in the directory Arduino\libraries\LCDMenuLib2\src
                        Subsequently The compiler recommend changing the line 28 of CharLcdMenu.ino (tmp = LCDML.MENU_getObj()->getChild(LCDML.MENU_getScroll());) to tmp = LCDML.MENU_getRootObj()->getChild(LCDML.MENU_getScroll());
                        After that, the code compiled.
                          Downloading:
                          ben999B
                          ben999B
                          ben999
                          #55
                          @OldSurferDude that is ever so kind of you to provide such quality support !!
                          So far so good : i took a different path but got to the same point.
                          Line 73 of nRF24DoctorNode.ino mentions
                          #include <LCDMenuLib2.h>	// Download 1.2.7: https://github.com/Jomelo/LCDMenuLib2
                          Compile error probably comes from here. I installed older version (current is 2.2.8, recommended is 1.2.7), as requested.
                          I manually installed all the *.h files and got it to compile (with MySensors 2.3.2, any other older version would not compile).
                          At that point did you upload that sketch to a nano+nrf for testing ?
                          EDIT : that "mklink" thing is specific to Windows right ? Does it do more magic than just copying shared files at the root of the nRFdoctor's directory ? I only have Linux computers at home...
                          • OldSurferDudeO
                            OldSurferDudeO
                            OldSurferDude
                            @ben999 said:
                            mentions
                            I suspect that the library has been included in the Arduino repository. I used the IDE library manager to install it.
                            I haven't done any hardware testing. I'll leave that for you.
                            Yes, mklink.bat is for Windows only. This script is the linux equivalent.
                            # assumes the existence of the folder shared in the current directory.
                            cd nRF24DoctorNode
                            ln -s ../shared shared
                            cd ..
                            cd nRF24DoctorGateway
                            cd ..
                            • ben999B
                              ben999B
                              ben999
                              #57
                              So i spent some time on that subject this past weekend...
                              Unfortunately I did not learn anything nor got any good outcome.
                              Every sketch has been tested on two seperate bits of hardawre : my custom built nRFDoctor and a random Arduino Nano.
                              Fresh install of Yveaux's sketches, with official script to create symbolic links.
                              All compiled nicely but none got to connect to GW.
                              On the other hand, both units managed to register to the GW with a very basic sketch (relay sketch).
                              • OldSurferDudeO
                                OldSurferDudeO
                                OldSurferDude
                                I see that the the nRFDoctor has a menu. Perhaps one of the menu items has to be selected?
                                12.5k
