  3. nRF24Doctor
nRF24Doctor
transmission delayscompare modulespower consumptionradio qualitydoctorrangegateway locationdiagnosenrf24 radio
58 Posts 16 Posters 29.1k Views 26 Watching
  • YveauxY Yveaux
    @benbidouille you can run W5100 with hardware spi but there are many revisions of the W5100 arduino shield available. Some of them eg require to have a defined state of the SD card select line before mySensors starts. Not a big problem, but you need to understand your hardware.
    That's why soft spi is suggested.
    B
    B
    benbidouille
    wrote on last edited by benbidouille
    #36
    @Yveaux
    Thanks a lot for your feedback.
    I used very basic W5100 HW as on below link link text.
    Why MySensor forum do mention "The W5100 ethernet module has problems sharing SPI with radio" recommending to use soft SPI with such unit without SD card ?
    I must admit, I implemented sketch and wiring as recommended by MySensor forum with no brainer.
    Lots of post like here link text seems also to confirm issues in the way W5100 handles SPI bus, a reel night mare, I haven't found any succesfull experience in forum yet.
    Should you have further information or maybe working sketch to share, I would very much appreciate.
    I have no logic analyzer so would prefer to avoid entering in long debug session but if you confirm W5100 and NRF on same SPI bus should work, i'll make a trial and rewire mine.
    Regards
    • B benbidouille
      @Yveaux
      Regards
      @benbidouille I've run multiple gateways using W5100 on hw spi with atmega328 and never had any issues apart from that SD card select line.
      I'm not sure why the docs mention there would be a sharing issue.
      B TRS-80T 2 Replies Last reply
      • YveauxY Yveaux
        B
        B
        benbidouille
        #38
        @Yveaux
        Thanks so much for confirmation,
        Seems a large community of people faced the issue here back in 2014 link text , and the recomendation comes from this past experience.
        My undertanding is nobody re-challenged the recomendation and possibly are we the only one interested in getting IRQ with NRFDoctor.
        So is a good news you confirm it works.
        Can I assume you use same W5100 HW shield as mine and that you have for HW connections:
        • W5100 (CS/MOSI/MISO/CLK) wired respectively on HW SPI (10,11,12,13)
        • NRF24 also on HW SPI for (MOSI/MISO/CLK) only and differentiated CS/CE/IRQ on for instance respectively 6/5/2
        Regards and thanks for these precious informations that will help me saving time.
        Regards
        • YveauxY Yveaux
          TRS-80T
          TRS-80T
          TRS-80
          @Yveaux said in nRF24Doctor:
          Very interesting. I just (few weeks ago) built an Ethernet gateway recently and at the time followed the recommendation for soft SPI. Then more recently I read about hardware SPI being required for MY_RX_MESSAGE_BUFFER_FEATURE which of course would be a valuable feature on a gateway.
          @benbidouille,
          Did you ever investigate further? Even if not, I will probably do so on my own, sooner or later, as I have a few of the various W5500 cheap modules here...
          • pw44P
            pw44P
            pw44
            Hya,
            correct me if i'm wrong.
            To make use of this, two units must be built. One for node and other for gateway.
            Is this undestanding correct? If not, how to use nRF24DoctorGateway and nRF24DoctorNode?
            Thx in advance.
            • pw44P pw44
              Hya,
              Thx in advance.
              @pw44 said in nRF24Doctor:
              Yes it is
              • C
                C
                canyouhearmenow
                I need some help.
                I just built an NRF24Doctor following the instruction in the post and on Github.
                • When no NRF24 module is connected, the device starts properly, displays the menu on the LCD, and when I try to select a menu item, it (correctly) displays "Radio init error. Replace radio".
                • When an NRF24 mode is connected (I tried several), the LCD is blank, the serial monitor shows "Channel:90 PaLevel:HIGH PaLevelGw:LOW DataRate:250KBPS Dest:0 Payload:2 Rate:10" in an endless loop.
                • when I run the older "nRf24L01+ connection quality meter" software, it starts ok and the LCD shows FAIL 0% and MISS 0% as expected.
                Any ideas for what might cause this problem? Almost looks like it resets in a loop, maybe because the watchdog triggers? or stack corruption?
                • L
                  L
                  lyubo.assenov
                  Hello all,
                  First things first - this is a great device, kudos to everybody involved!
                  I built a buggy nrf24Doctor - it wasn't measuring the current consumption at all ("xxx Err" message). Trying to fix it led me to refactor the - splitting it into smaller "components" and adapting the project structure to VSCode/platform-io (ArduinoIDE is not my cup of tea).
                  If someone is interested, the code can be found at github.
                  Regards,
                  L.
                  • B
                    B
                    broomnest
                    Banned
                    The output of the display could also be sent over serial, but the whole idea is you can walk around with the doctor and improve your results as you go.
                    • ben999B
                      ben999B
                      ben999
                      wrote on last edited by ben999
                      #45
                      Sorry to necro this old post :(
                      I have just uploaded @yveaux's version of nRF24 doctor to a Nano.
                      https://github.com/TechNovation01/nRF24Doctor/blob/master/pcb/nRFDoctor_1.1_sch.pdf
                      I got all the right libraries installed into IDE (especially LCDMenuLib2.h version 1.2.7, i also tried several other versions close to 1.2.7 just to be sure).
                      But when compiling i get the following errors :
                      /tmp/ccMpih6l.ltrans0.ltrans.o: In function `global constructors keyed to 65535_0_nRF24QualityMeter03.ino.cpp.o.3416':
                      <artificial>:(.text.startup+0x19a): undefined reference to `lcdml_menu_display()'
                      <artificial>:(.text.startup+0x19c): undefined reference to `lcdml_menu_display()'
                      <artificial>:(.text.startup+0x1a6): undefined reference to `lcdml_menu_clear()'
                      <artificial>:(.text.startup+0x1a8): undefined reference to `lcdml_menu_clear()'
                      collect2: error: ld returned 1 exit status
                      exit status 1
                      Erreur de compilation pour la carte Arduino Nano
                      That is a bit above my knowledge. Could someone please point me into the right direction? Could it be just a case of "wrong naming" of variables ?
                      ben999B 1 Reply Last reply
                      • ben999B ben999
                        exit status 1
                        ben999B
                        ben999B
                        ben999
                        #46
                        I might be able to answer that myself !
                        Looks like i have forgotten to "combine" a .ino file (CharLcdMenu.ino) with the main one (nRF24DoctorNode.ino), which seems to be a bit like a sub-program.
                        edit: that's it. Just had to create a second TAB with that sub-program, compile and success.
                        Please forgive my lack of vocabulary and knowldge, i am a "copy-paste" engineer :D
                        • OldSurferDudeO
                          OldSurferDudeO
                          OldSurferDude
                          It's great when a project can be brought to life after 8 years!
                            ben999B
                            ben999B
                            ben999
                            #48
                            @OldSurferDude as long as we’re using nRFs this project is still relevant :D
                            I am now facing some more troubles:
                            The nRFNode cannot connect to GW.
                            Looks like a software issue. The exact same setup connects to GW when loaded with a very basic sketch (relay in my case). I am using @yveaux 's sketch from his Github.
                            Could this sketch not be compatible with today's API ?
                            OldSurferDudeO 1 Reply Last reply
                            • ben999B ben999
                              OldSurferDudeO
                              OldSurferDudeO
                              OldSurferDude
                              @ben999
                              @ben999 said:
                              very basic sketch
                              My guess is that because you're not using the LCD in the basic sketch that talking to the LCD is causing radio interference.
                              To test this theory and assuming you have the LED connected, the LCD code could be replaced with flash-code code.
                              My technique for doing this replacement is to use compiler directives to remove the LCD code and add flash-code code.
                              To remove the LCD code, create a new compiler flag
                              #define LCD_ENABLE
                              Surround all LCD code with
                              #ifdef LCD_ENABLE
                              Then comment out the definition line which disables the LCD.
                              Create another new compiler flag
                              #define FC_PIN 4
                              and comment out both the compiler directives that create TRIGGER_PIN and LED_PIN
                              At the point in the existing code where the LCD is to display the quality, put a call to your new routine, This call will pass the quality number to the code that generates a flash code. So this new code can be easily disabled, surround your code with:
                              #ifndef FC_PIN
                              Yes, I make a huge assumption that you understand this (compiler directives, flash-code, etc.). If you don't, I, or others, can help out, but you'd learn more if you did it on your own.
                                @ben999
                                @ben999 said:
                                very basic sketch
                                #define LCD_ENABLE
                                #ifdef LCD_ENABLE
                                #define FC_PIN 4
                                #ifndef FC_PIN
                                ben999B
                                ben999B
                                ben999
                                #50
                                @OldSurferDude thank you very much for taking time to explain.
                                I didn't make it clear enough from my side though.
                                My "test" setup here is not the whole "nRF Doctor", as i got fed up with it !!
                                Last night i just grabbed a Nano and a red nRF (eByte).
                                Then loaded a random basic sketch and it got connected to GW straight away.
                                After that i loaded @yveaux 's sketch and it never reached the GW (although changes were made to sketch, such as default channel (76), power level and transmission speed. These changes were made to files located in the "share" directory, that are called via "#include").
                                Yveaux's sketch is based on API ver 2.2.0... latest stable is 2.3.2. So i tried different versions other than 2.3.2 but they all ended up with errors when compiling.
                                I'll keep on digging tonight anyway (and report errors).
                                • ben999B
                                  ben999B
                                  ben999
                                  #51
                                  Quick update:
                                  -compiling with MySensors librairy ver 2.3.2 gives no error but my simple setup cannot reach GW with the following debug on serial monitor:
                                  0 MCO:BGN:INIT NODE,CP=RNNNA---,FQ=16,REL=255,VER=2.3.2
                                  4 MCO:BGN:BFR
                                  35 TSM:INIT
                                  36 TSF:WUR:MS=100
                                  43 TSM:INIT:TSP OK
                                  45 TSM:INIT:STATID=250
                                  47 TSF:SID:OK,ID=250
                                  49 TSM:FPAR
                                  72 ?TSF:MSG:SEND,250-250-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                  137 MCO:BGN:STP
                                  151 TSF:WUR:MS=2000
                                  2080 !TSM:FPAR:NO REPLY
                                  2082 TSM:FPAR
                                  2105 ?TSF:MSG:SEND,250-250-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                  2166 MCO:BGN:INIT OK,TSP=0
                                  4113 !TSM:FPAR:NO REPLY
                                  4115 TSM:FPAR
                                  4139 ?TSF:MSG:SEND,250-250-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                  6147 !TSM:FPAR:NO REPLY
                                  6149 TSM:FPAR
                                  6172 ?TSF:MSG:SEND,250-250-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                  8180 !TSM:FPAR:FAIL
                                  8181 TSM:FAIL:CNT=1
                                  8183 TSM:FAIL:DIS
                                  8185 TSF:TDI:TSL
                                  18187 TSM:FAIL:RE-INIT
                                  18189 TSM:INIT
                                  18195 TSM:INIT:TSP OK
                                  18197 TSM:INIT:STATID=250
                                  18200 TSF:SID:OK,ID=250
                                  18202 TSM:FPAR
                                  18225 ?TSF:MSG:SEND,250-250-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                  20233 !TSM:FPAR:NO REPLY
                                  20235 TSM:FPAR
                                  20258 ?TSF:MSG:SEND,250-250-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                  22266 !TSM:FPAR:NO REPLY
                                  22268 TSM:FPAR
                                  22291 ?TSF:MSG:SEND,250-250-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                  24299 !TSM:FPAR:NO REPLY
                                  24301 TSM:FPAR
                                  24324 ?TSF:MSG:SEND,250-250-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                  26332 !TSM:FPAR:FAIL
                                  26333 TSM:FAIL:CNT=2
                                  26335 TSM:FAIL:DIS
                                  26337 TSF:TDI:TSL
                                  36340 TSM:FAIL:RE-INIT
                                  36342 TSM:INIT
                                  36348 TSM:INIT:TSP OK
                                  36350 TSM:INIT:STATID=250
                                  36354 TSF:SID:OK,ID=250
                                  36356 TSM:FPAR
                                  36379 ?TSF:MSG:SEND,250-250-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                  and so on
                                  • compiling with MySensors librairy ver 2.2.0 (as mentionned in the sketch) gives me the following error:
                                  Compilation error: 'RF24_PA_LOW' was not declared in this scope
                                  • same error with MySensors librairy ver 2.3.0
                                  • OldSurferDudeO
                                    OldSurferDudeO
                                    OldSurferDude
                                    I vaguely remember that the RF24_PA_[power level] was given a different name. to something different. Basically the power level is 0,1,2, or 3 (MIN, LOW, HIGH, or MAX). see docs
                                    To get it to compile, put this (a hack) line in
                                    #define RF24_PA_LOW 1
                                    before line 47
                                    #include "shared/RadioConfig.h"
                                    or before
                                    radio.setPALevel(RF24_PA_LOW);
                                    I had forgotten about this. Maybe the problem is that that power level is set to low. I see in RadioConfig.h it's set to LOW. This is done because the two radios could be close to one another and they would overdrive the other if they're set to MAX
                                    Another thought (my little gray cells are not firing on all cylinders) It seems to me that line 47
                                    should be after line 59
                                    because the MySensors library is where the PA variables are set.
                                    I hope my rambling here hasn't further complicated the issue.
                                      before line 47
                                      or before
                                      ben999B
                                      ben999B
                                      ben999
                                      @OldSurferDude thanks once again for taking time to understand my problem !
                                      Moving
                                      after
                                      got me the following compile error
                                      In file included from /home/ben/Documents/Arduino/nRF24QualityMeter03/nRF24QualityMeter03.ino:58:0:
                                      /home/ben/Arduino/libraries/MySensors/MySensors.h:426:2: error: #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
                                      exit status 1
                                      Compilation error: exit status 1
                                      • OldSurferDudeO
                                        OldSurferDudeO
                                        OldSurferDude
                                        I'm thrashing on this, too, so I downloaded it and I compiled it.
                                        Downloading:
                                        1. From the web page I clicked on [Code] and then downloaded the zip file.
                                        2. I extracted the zip file to my Arduino directory.
                                        3. In a dos box (command line) I changed to Arduino\nRFDoctor-master
                                        4. I executed the batch program mklink.bat which created symbolic links in both nRF24DoctorGateway and nRF24DoctorNode to their sister directory shared. This is needed so that the compiler can find the project specific libraries, eg RadioConfig.h
                                        Then I opened nRF24DoctorNode in the Arduino IDE 2.3.10
                                        When first compiling, there were many libraries required which I installed.
                                        After all the libraries were installed, the code had the compiler check a value and if it was incorrect, it threw an error. When the line #define _LCDML_DISP_cfg_max_rows 2 was added to the the library LCDMenuLib2.h at line 42, the error no longer occurred. (Was this a good thing? Perhaps the line should have gone just before the error check?) This library is found in the directory Arduino\libraries\LCDMenuLib2\src
                                        Subsequently The compiler recommend changing the line 28 of CharLcdMenu.ino (tmp = LCDML.MENU_getObj()->getChild(LCDML.MENU_getScroll());) to tmp = LCDML.MENU_getRootObj()->getChild(LCDML.MENU_getScroll());
                                        After that, the code compiled.
                                          Downloading:
                                          ben999B
                                          ben999B
                                          ben999
                                          #55
                                          @OldSurferDude that is ever so kind of you to provide such quality support !!
                                          So far so good : i took a different path but got to the same point.
                                          Line 73 of nRF24DoctorNode.ino mentions
                                          #include <LCDMenuLib2.h>	// Download 1.2.7: https://github.com/Jomelo/LCDMenuLib2
                                          Compile error probably comes from here. I installed older version (current is 2.2.8, recommended is 1.2.7), as requested.
                                          I manually installed all the *.h files and got it to compile (with MySensors 2.3.2, any other older version would not compile).
                                          At that point did you upload that sketch to a nano+nrf for testing ?
                                          EDIT : that "mklink" thing is specific to Windows right ? Does it do more magic than just copying shared files at the root of the nRFdoctor's directory ? I only have Linux computers at home...
                                          12.5k
