  3. Pinging other MySensors fans
12 Posts 8 Posters 433 Views 7 Watching
  • OldSurferDudeO
    OldSurferDudeO
    OldSurferDude
    I check here a few times a week to see if there is someone that needs help. I think this is a great platform and I want to keep it alive.
    "Is there anybody out there?"
    -OSD
    • mfalkviddM
      Great to see you @oldsurferdude !
      I check in here regularly as well. Mostly I just ban spammers (a few per week) but I read all posts.
      • E
        E
        eiten
        Me to. I have to admit, most of my new sensors use openthread, but I still got some MySensors running.
        • E eiten
          @eiten sounds interesting. Could you share what your openthread setup looks like and what you have built? How would you compare it to the MySensors build experience?
          I haven’t built any sensors in a while but maybe I should try openthread next time.
          E 1 Reply Last reply
            Yes, I always have the "Unread" forum tab in my browser.
            • K
              K
              Kokosnoot
              wrote last edited by
              As a matter of fact, I have also moved on... To RFM69 😁. So currently in the process of migrating all my nodes from the NRF24 modules as they still, many year later just give issues. Few months ago purchased some RFM69 and was blown away how instantly these things work. I purchased some footprint adapters so I do not have to resolder everything from the easy MySensor boards.
              Now, armed with ChatGPT to also migrate the gateway to multi-core (which I already wrote myself before, but ChatGPT does it even better..) so P1 / gateway activities are on different cores, also integrating MQTT over SSL - while optimizing the heap, building a whole front end to toggle sensors through MQTT... it is quite a bit of fun actually! 😄
              • nagelcN
                nagelcN
                nagelc
                Still checking in fairly often. I just moved to a new house, so I'm using it as an opportunity to pair down from 4 different gateways that I made over the years to 2: nrf5 for shorter range and LoRa for longer range. I could probably go to just 1 gateway, but what would I do with all those other sensors : )
                • K
                  K
                  KevinT
                  I drop by every couple of weeks and I have a watch on some of the categories I'm interested in.
                    E
                    E
                    eiten
                    Hey @mfalkvidd,
                    Sorry for the massive delay in getting back to you! You know how it goes—day job, family, late summer madness... I promise to do better.
                    Where do I even begin? It all kicked off when I managed to snag two nRF52840-DKs on the cheap. And as the saying goes: when you have a hammer, every problem starts looking like a nail. The nRF52 series is absolute magic when it comes to battery life, and in theory, they’re totally MySensors-compatible. I know the MySensors codebase pretty well, mostly from the LoRa side of things (I contributed the ASR and SX126x drivers back in the day, if memory serves), though I never really dived deep into the nRF24 side.
                    Naturally, Zephyr RTOS is the obvious choice for the nRF52, and I’ve become a massive fan of it. Early on, I made a few half-hearted attempts to port MySensors over to Zephyr, but it never really panned out.
                    So, I pivoted to Zigbee. However, once you leave the standard clusters behind (like basic temperature or humidity), things get pretty tedious on the controller/backend side. The Nordic Connect SDK also supports Matter over Thread, which runs into the exact same headache for custom payloads. That’s how I finally landed on pure OpenThread—which, remarkably, runs completely fine on the exact same Thread mesh network alongside Matter devices.
                    Infrastructure
                    Living in a sprawling, 350-year-old Appenzeller house with a huge garden, having multiple Border Routers is a massive upgrade over a single Zigbee coordinator. Packets always find a way home via one route or another.
                    I currently have three Border Routers active:
                    • Basement: An old slae.sh stick (retired from its former life as a Zigbee coordinator) running an OTBR inside an LXC container on my Proxmox cluster.
                    • Roof / Outdoors: Two PoE Border Routers from AliExpress mounted under the bargeboards at opposite ends of the roof.
                    Sensors & Actuators
                    I’ve got a pretty wide zoo of nodes running now, including a few of rbaron’s b-parasites flashed with custom Thread firmware. Beyond those, I built a pool thermometer, a solar radiation sensor, a rain gauge, and several temp/pressure/humidity nodes.
                    They are all built around the EByte E73-2G4M08S1C module and powered in one of two ways:
                    1. Directly from a single CR123 (or its LiFePO4 equivalent) with zero voltage regulators.
                    2. From 3x AA/AAA cells, adding just an inductor and a capacitor so I can utilize the nRF52’s built-in DC/DC converter.
                    On the actuator side, I integrated our rainwater pump house and automated garden/raised-bed irrigation into Thread. Those nodes are beefier, powered either by a 24V PSU or an 8S LiFePO4 battery bank.
                    Transport & The MySensors Comparison
                    For transport, I usually stick to CoAP. It’s brilliant because downstream messages destined for Sleepy End Devices (SEDs) get buffered by their parent router and fired off the exact millisecond the node wakes up.
                    For the pump house, though, I use raw UDP. Inside the pump house, the valves and sensors talk over a CAN bus, and skipping the CoAP overhead makes the latency of my Thread-to-CAN bridge much more predictable. Sadly, it's running without DTLS—I couldn't for the life of me get DTLS working properly in Python (though I verified with openssl that my hardware implementation on the node was solid).
                    Compared to the MySensors build experience, the learning curve with Zephyr + OpenThread is definitely steeper—you're trading Arduino-style plug-and-play simplicity for a real-time OS, device trees, and Kconfig. It takes more upfront effort, especially wrap-your-head-around-IPv6 effort, but once it's running, the rock-solid stability, native IPv6 routing, and power profiling tools make it completely worth it.
                    Most of my repos are still... uh, let's say "creatively organized." However, if you want to give it a spin, I’d be happy to throw together a clean sample project using CoAP on an nRF52840-DK alongside a matching Python script and push it to my Forgejo server.
                    Side note: The most annoying boss fight in this entire setup was getting IPv6 multicast routing to behave properly between the Thread network, my server VLAN, and my IoT VLAN. If you ever go down this rabbit hole and hit a wall there, just ping me—I’m happy to share what worked!
                    HTH,
                    Edi
                    • Nick WillisN
                      Nick WillisN
                      Nick Willis
                      Hi I'm also a long time MySensors person who has gradually tried various radio systems to try to achieve a situation where everything works 100% of the time to not annoy the 'users' too much!
                      I still use MySensors for a few things including 'critical' tasks. I expanded on the library a bit to provide sensors that show how many NACKS my nodes get and it was certainly interesting.
                      I keep assessing to decide if I should cease MySensors since it doesn't seem to be going anywhere lately but I have a lot of hardware still around...
                      But up against ESPHome it is 'harder' and lacks over the air updates (that actually work that is). However I don't want wifi devices so I avoided ESPHome until OpenThread was added and have now expanded into that too.
                      To compare the radios I check my MySensors error rate sensors against 'Unavailable' time in Home Assistant for Thread and others....
                      So NRF24 radios is only good for passive sensors like temperature as the error rate is pretty high especially in my basement. I don't deploy these nodes anymore unless something that doesn't matter much to use up old hardware.
                      RFM69 is really good and will out perform Zigbee and Thread in terms of missed messages. But hardware can be tricky:
                      • Most Arduinos run at 5v so require level shifting for the most part to work with the 3.3v radio. And because of memory requirements it is better to use a Mega not Uno and others unless you just need a single sensor (then I can use the 3.3v Mini and the nice base PCB I found on this forum somewhere).
                      • I did find an Arduino shield for Mega with the RFM69 radio on it. Perfect it is and makes the hardware simple but that shield is very hard to find and was expensive for what it was.
                      So I've moved onto using ESP32-C6 boards with OpenThread on ESPHome. Generally its worked well, the ESPHome UI is now great, has over the air updates and is a mesh network so everything I add is making it better.
                      It's still unreliable at times however and sometimes just all the nodes go down for a few minutes before coming back. This never happens on MySensors nodes.
                      So for now I still run a MySensors dual radio Sensebender gateway (so beta version of MySensors to support dual radio) and use what hardware I have left without investing in anything new.
                      I'd probably go for it more if the RFM hardware were easier (perhaps it is and I don't know it) and MySensors was moving forward again.. There's only a few hundred of us left using the Home Assistant MySensors integration now!
                      • Nick WillisN Nick Willis
                        E
                        E
                        eiten
                        wrote last edited by eiten
                        @Nick-Willis sagte:
                        Hey! That’s a super interesting setup you've got there—tracking NACK rates as actual sensors to benchmark reliability against Home Assistant's "Unavailable" times is peak home-automation nerdery. Love it!
                        Have you ever tried the ASR650x-based boards, like the Heltec CubeCell series?
                        They run natively at 3.3V and have the LoRa transceiver (SX1262) built right onto the module, so you completely skip the whole 5V level-shifting headache and wiring mess you get with standalone RFM69s. Plus, you get way more flash and RAM than an ATmega328P, along with ultra-low deep sleep current.
                        Full disclosure: I haven't actively developed on them for the past two or three years, so I can't really vouch for the state of their current Arduino core support. However, I still have two CubeCells humming along reliably on my MySensors network today without any drama—so if you're looking for an easy, self-contained sub-GHz hardware option without soldering radio breakouts, they might still be worth a look!
                        Cheers,
                        Edi
                        • nagelcN
                          nagelcN
                          nagelc
                          @eiten Thanks for your SX1262 library. I have been using it with some tweaks to Run WIO-E5 modules (STM32WL LoRa). Great for range. Still working of the battery consumption. I love the NRF52 series for shorter ranges.
                          Looked at Zephyr, but as you say, the learning curve is a bit steep. Can it give you OTA programming? That is one thing I really would like.
