  3. Arduino 220V AC wattmeter
arduino ac watt
21 Posts 11 Posters 42.2k Views 3 Watching
  • stofakillerS
    stofakillerS
    stofakiller
    That im will try to work with :-) I have seen the one in your post, and i hope the one from dx is the same, but i'll keep you posted :-)
    • jocke4uJ jocke4u
      @stofakiller said:
      I found module from DX that i want to try, i dont want to mess with 220v cables So i waiting for this one to come
      http://www.dx.com/p/yqj010504-single-phase-ac-current-sensor-module-w-active-output-deep-blue-5a-294209#.VDOyK2d_t8E
      Hmm, how can you get the 230V cable into the transformer without mess with it ;)
      You need to get a split core CT that you can open without touching high voltage lines; something like this (the blue one)
      http://openenergymonitor.org/emon/buildingblocks/ct-sensors-interface
      AtomicGrogA
      AtomicGrogA
      AtomicGrog
      You cant... not only that you need a single wire so you cant for example shove a 3 wire 'kettle lead' through it. Stick to the split core approach, same principle and easier to implement.
        MarkV
        @stofakiller said:
        poweroutlet ac wattmeter
        I'm also searching for something like this and it should be possible.
        Look at the fibaro wall plug [(http://www.fibaro.com/en/the-fibaro-system/wall-plug)]
        Thats exactly what i want aldo then for less money or a arduino based plug.
        • daulagariD
          daulagariD
          daulagari
          That is quite challenging goal!
          If you do not mind the form size it should be possible and the component cost could be lower.
          ZWave devices are quite expensive (is that the Zwave license?) but companies have the economies of scale so they can spread fixed cost over more units and get volume discount on components.
          • epierreE
            epierreE
            epierre
            yes the zwave chip and license and dev kits are expensive and proprietary...
            z-wave - Vera -> Domoticz
            • daulagariD
              daulagariD
              daulagari
              Any idea what piece of the pricing is due to the zwave chip and license?
              Is that in the order of 2, 5, 10 or 15 Euro/Dollar?
              On implementing it using MySensors: As this is 230/110 Volts, I think a housing is essential. In that sense I think I would start buying a cheap energy/watt meter from Ebay, opening it and replace the electronics by your own electronics.
                MarkV
                Okay
                But isn't possible to make a similar device without the z-wave but with a arduino.
                instead of pussing the signals to a z-wave chip, push them to a arduino??
                Just a simple voltage en current measuring device and let the arduino calculate and store the wattage or kWh...
                That would be a nice and cheap sollution..
                • daulagariD
                  daulagariD
                  daulagari
                  If you want something simple, see http://gizmosnack.blogspot.se/2014/11/power-plug-energy-meter-now-wireless.html.
                  • D
                    Dean
                    @axillent looks like there are a few people like me who are interested in your set up... Would you mind sharing more details one what you did, actual hardware setup, sketch, issues, etc?
                    • axillentA axillent
                      I made one. It is not just wattmeter, it is a 3 channel power switch with meter function per each channel
                      in general you have just two solution while you want to keep your arduino be isolated from AC line:
                      1. using special chip like ACS712
                      2. using current transformer
                      in both ways you will need analog inputs to measure related voltage and you will be able to calculate current based on analog read
                      mainali
                      I have tried using ACS712 to check if current is passing through the circuit, from the sketch I am using, sometimes even though the switch is off I get readings, Is there a way to make it full proof so that if there is no current there should not be false reading.
                      Do you have any sketch related to the implementation?
                      • Vladut GrecuV
                        Vladut GrecuV
                        Vladut Grecu
                        When you implement it with your relay you can call the readings only when the relay is on. That way you get accurate measures and don`t overload the mcu :D
                          mainali
                          I have a relay connected to a two way switch, I want to know when the switch was pressed. Basically I want to control the device via both the switch and the app which controls the relay. In case someone switches on the device from physical switch I want to update the app to show that the device is switched on. Hence using the current sensor to sense the current between the switch.
                          • axillentA
                            axillentA
                            axillent
                            false readings from acs712 is a subject of electrical noise
                            I also faced it
                            coper&wires from acs712 to MCU have to be as short as possible
                            sense and drive
