  3. Arduino 220V AC wattmeter
arduino ac watt
21 Posts 11 Posters 42.2k Views 3 Watching
  • jocke4uJ jocke4u
    @stofakiller said:
    I found module from DX that i want to try, i dont want to mess with 220v cables So i waiting for this one to come
    http://www.dx.com/p/yqj010504-single-phase-ac-current-sensor-module-w-active-output-deep-blue-5a-294209#.VDOyK2d_t8E
    Hmm, how can you get the 230V cable into the transformer without mess with it ;)
    You need to get a split core CT that you can open without touching high voltage lines; something like this (the blue one)
    http://openenergymonitor.org/emon/buildingblocks/ct-sensors-interface
    AtomicGrogA
    AtomicGrogA
    AtomicGrog
    You cant... not only that you need a single wire so you cant for example shove a 3 wire 'kettle lead' through it. Stick to the split core approach, same principle and easier to implement.
      MarkV
      @stofakiller said:
      poweroutlet ac wattmeter
      I'm also searching for something like this and it should be possible.
      Look at the fibaro wall plug [(http://www.fibaro.com/en/the-fibaro-system/wall-plug)]
      Thats exactly what i want aldo then for less money or a arduino based plug.
      • daulagariD
        daulagariD
        daulagari
        That is quite challenging goal!
        If you do not mind the form size it should be possible and the component cost could be lower.
        ZWave devices are quite expensive (is that the Zwave license?) but companies have the economies of scale so they can spread fixed cost over more units and get volume discount on components.
        • epierreE
          epierreE
          epierre
          yes the zwave chip and license and dev kits are expensive and proprietary...
          z-wave - Vera -> Domoticz
          • daulagariD
            daulagariD
            daulagari
            Any idea what piece of the pricing is due to the zwave chip and license?
            Is that in the order of 2, 5, 10 or 15 Euro/Dollar?
            On implementing it using MySensors: As this is 230/110 Volts, I think a housing is essential. In that sense I think I would start buying a cheap energy/watt meter from Ebay, opening it and replace the electronics by your own electronics.
              MarkV
              Okay
              But isn't possible to make a similar device without the z-wave but with a arduino.
              instead of pussing the signals to a z-wave chip, push them to a arduino??
              Just a simple voltage en current measuring device and let the arduino calculate and store the wattage or kWh...
              That would be a nice and cheap sollution..
              • daulagariD
                daulagariD
                daulagari
                If you want something simple, see http://gizmosnack.blogspot.se/2014/11/power-plug-energy-meter-now-wireless.html.
                • D
                  Dean
                  @axillent looks like there are a few people like me who are interested in your set up... Would you mind sharing more details one what you did, actual hardware setup, sketch, issues, etc?
                  • axillentA axillent
                    I made one. It is not just wattmeter, it is a 3 channel power switch with meter function per each channel
                    in general you have just two solution while you want to keep your arduino be isolated from AC line:
                    1. using special chip like ACS712
                    2. using current transformer
                    in both ways you will need analog inputs to measure related voltage and you will be able to calculate current based on analog read
                    mainali
                    I have tried using ACS712 to check if current is passing through the circuit, from the sketch I am using, sometimes even though the switch is off I get readings, Is there a way to make it full proof so that if there is no current there should not be false reading.
                    Do you have any sketch related to the implementation?
                    • Vladut GrecuV
                      Vladut GrecuV
                      Vladut Grecu
                      When you implement it with your relay you can call the readings only when the relay is on. That way you get accurate measures and don`t overload the mcu :D
                        mainali
                        I have a relay connected to a two way switch, I want to know when the switch was pressed. Basically I want to control the device via both the switch and the app which controls the relay. In case someone switches on the device from physical switch I want to update the app to show that the device is switched on. Hence using the current sensor to sense the current between the switch.
                        • axillentA
                          axillentA
                          axillent
                          false readings from acs712 is a subject of electrical noise
                          I also faced it
                          coper&wires from acs712 to MCU have to be as short as possible
                          sense and drive
