  3. Clone 2 skelets Relay and Button's
19 Posts 5 Posters 9.6k Views 2 Watching
  • T tomrask
    @hek
    Hey Hek I changed the code, but it will not help. Now I get 3 door sensor and nothing else. hope you will help a little so that I understand the code. thank you
    // 1 Door virker 2 relays virker
    #define NUMBER_OF_SWITCHES 3
    #define NUMBER_OF_RELAYS 2 // Total number of attached relays
    Bounce debouncer[NUMBER_OF_SWITCHES];
    int oldValue[NUMBER_OF_SWITCHES];
    byte switchPin[NUMBER_OF_SWITCHES] = {5,6,7}; //<<<<<<<<<<< set your switch pins here
    MyMessage msg(0,V_TRIPPED);
      gw.sendSketchInfo("Relay&Botton", "1.0");
    // Switches setup
      for (int i = 0; i < NUMBER_OF_SWITCHES; i++)
        pinMode(switchPin[i],INPUT_PULLUP);
        debouncer[i] = Bounce();
        debouncer[i].attach(switchPin[i]);
        debouncer[i].interval(5);
        gw.present(i, S_DOOR);
        delay(250);
      // Fetch relay status
      for (int sensor=3, pin=RELAY_1; sensor<=NUMBER_OF_RELAYS;sensor++, pin++) {
        gw.present(sensor, S_LIGHT);
        pinMode(pin, OUTPUT);
        digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
        debouncer[i].update();
        if (value != oldValue[i])
          gw.send(msg.setSensor(i).set(value == HIGH? true : false), false);
        oldValue[i] = value;
      if (message.type==V_LIGHT) {
         // Change relay state
         // Store state in eeprom
    ferpandoF
    ferpandoF
    ferpando
    wrote on last edited by ferpando
    @tomrask
    What Hek is trying to tell you is that you can't have 2 devices with the same number.
    Change your first loop for:
      for (int sensor=0, pin=RELAY_1; sensor<NUMBER_OF_RELAYS;sensor++, pin++) {
    Change your second presentation loop for this
      for (int i = NUMBER_OF_RELAYS; i < (NUMBER_OF_RELAYS+NUMBER_OF_SWITCHES); i++)
        delay(250);
    This way you are creating relays 0 and 1, and then switches 2, 3 and 4
    • T
      tomrask
      Hey Ferpando
      thanks, now the sensor is displayed on vera. but only one contact and a door sensor works .
      I have not quite mastered the code yet , help wanted.
      // 3 Door 1 virker 2 relays 1 virker
        // Switches setup
          delay(250);
      Here
      • T
        tomrask
        Is there anyone out there who just want to give me a hand by getting this skeleton to work. I will be very happy just a little help. It could be great.
        • Vladut GrecuV
          Vladut GrecuV
          Vladut Grecu
          Can you post the serial output of the Arduino?
          • Vladut GrecuV Vladut Grecu
            tomrask
            @Vladut-Grecu
            This is what I get from serial output
            repeater started, id 1
            send: 1-1-0-0 s=255,c=0,t=18,pt=0,l=5,st=ok:1.4.1
            send: 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
            read: 0-0-1 s=255,c=3,t=6,pt=0,l=1:M
            send: 1-1-0-0 s=255,c=3,t=11,pt=0,l=12,st=ok:Relay&Botton
            send: 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
            send: 1-1-0-0 s=0,c=0,t=0,pt=0,l=5,st=ok:1.4.1
            send: 1-1-0-0 s=1,c=0,t=0,pt=0,l=5,st=ok:1.4.1
            send: 1-1-0-0 s=2,c=0,t=0,pt=0,l=5,st=ok:1.4.1
            • Vladut GrecuV
              Vladut GrecuV
              Vladut Grecu
              wrote on last edited by Vladut Grecu
              There is something going on with you code. It tells your gateway that you only have 3 devices (0,1,2)
              I'll look into it when I get home, later this day.
              • T
                tomrask
                @Vladut-Grecu
                thanks, I 'll be glad if you will
                • Vladut GrecuV
                  Vladut GrecuV
                  Vladut Grecu
                  @tomrask said:
                  Please modify your sketch like this
                      Serial.print("\nThe nr ");
                      Serial.print(sensor);
                      Serial.print(" relay has been presented\n");
                  and
                      Serial.print(i);
                      Serial.print(" switch has been presented\n");
                      delay(250);
                  And post the serial output again.
                    and
                        Serial.print(i);
                        delay(250);
                    tomrask
                    @Vladut-Grecu
                    Hey Vladut
                    This is the seriel output on my Nano
                    send: 1-1-0-0 s=0,c=0,t=3,pt=0,l=5,st=ok:1.4.1
                    The nr 0 relay has been presented
                    send: 1-1-0-0 s=1,c=0,t=3,pt=0,l=5,st=ok:1.4.1
                    The nr 1 relay has been presented
                    The nr 2 switch has been presented
                    send: 1-1-0-0 s=3,c=0,t=0,pt=0,l=5,st=ok:1.4.1
                    The nr 3 switch has been presented
                    send: 1-1-0-0 s=4,c=0,t=0,pt=0,l=5,st=ok:1.4.1
                    The nr 4 switch has been presented
                    send: 1-1-0-0 s=4,c=1,t=0,pt=2,l=2,st=ok:0
                    send: 1-1-0-0 s=3,c=1,t=0,pt=2,l=2,st=ok:0
                    send: 1-1-0-0 s=4,c=1,t=0,pt=2,l=2,st=ok:1
                    send: 1-1-0-1 s=2,c=1,t=0,pt=2,l=2,st=ok:1
                    send: 1-1-0-1 s=3,c=1,t=0,pt=2,l=2,st=ok:1
                    send: 1-1-0-1 s=4,c=1,t=0,pt=2,l=2,st=ok:1
                    send: 1-1-0-1 s=4,c=1,t=0,pt=2,l=2,st=fail:1
                    read: 1-0-1 s=4,c=1,t=0,pt=2,l=2:1
                    send: 1-1-0-1 s=3,c=1,t=0,pt=2,l=2,st=fail:1
                    read: 1-0-1 s=3,c=1,t=0,pt=2,l=2:1
                    • Vladut GrecuV
                      Vladut GrecuV
                      Vladut Grecu
                      @tomrask said:
                      From your serial output, I think that the problem is with vera.(config, etc.. I don`t use vera)
                      The node presents your devices and the gateway recognizes them correctly.
                      I guess you pressed the buttons to test them but when you press button nr 3 (child4) you got an error
                      You either wrongly configured vera to use child 4 as something else rather than a button (and it doesn't expect for an update, even if you present it as a button and it says that is ok) or it's beyond my understanding.
                      I will kindly ask @hek to to take a look over what I said and verify the integrity of the code presented but before that, I'll try to do your setup and report back.
                        I suggest you start simple. It is important you understand each step of the code.
                        • Remove loops (present each sensor separately).
                        • Remove debounce code (just read the digital inputs directly). They complicate things and you will better grasp what is happening without it.
                        • Same goes for incoming messages. Look at the incoming message and try to understand what digital output (relay) you want to set,
                        I could probably write the code for you. But what is the point? If you manage it yourself you'll feel like superstar. Take it in small steps and ask more questions if you don't understand what the purpose a particular line has.
                        • T
                          tomrask
                          @hek
                          Hey Hek
                          Thank you for your good advice. I have a little vacation here in Easter. so I got it to work with 2 door sensors maybe it's not the best looking program . but it works .
                          Where can I learn more about these lines, I do not understand 100 % yet :
                          Bounce debouncer1 = Bounce();
                          debouncer1.attach(BUTTON_PIN1);
                          Thanks for the help .
                          Tom Rask
                          // Sketch control 4 physical relays and 2 Doorsensors.
                          // This example will remember relay state even after power failure.
                          #include <Bounce2.h> // button/reed switch program
                          #define CHILD_ID1 5 // Arduino Digital I/O pin for button/reed switch
                          #define CHILD_ID2 6 // Arduino Digital I/O pin for button/reed switch
                          #define BUTTON_PIN1 7 // Arduino Digital I/O pin for button/reed switch
                          #define BUTTON_PIN2 8 // Arduino Digital I/O pin for button/reed switch
                          Bounce debouncer2 = Bounce();
                          int oldValue1=-1;
                          int oldValue2=-1;
                          MyMessage msg1(CHILD_ID1,V_TRIPPED); // button/reed switch program
                          MyMessage msg2(CHILD_ID2,V_TRIPPED);
                            gw.sendSketchInfo("Relay and Door", "1.0");
                              gw.present(1, S_LIGHT);
                              gw.present(2, S_LIGHT);
                              gw.present(3, S_LIGHT);
                              gw.present(4, S_LIGHT);
                              pinMode(3, OUTPUT);
                              pinMode(4, OUTPUT);
                              pinMode(5, OUTPUT);
                              pinMode(6, OUTPUT);
                             // Setup the button
                              pinMode(BUTTON_PIN1,INPUT);// button/reed switch program
                              pinMode(BUTTON_PIN2,INPUT);// button/reed switch program
                              digitalWrite(3, gw.loadState(1)?RELAY_ON:RELAY_OFF);
                              digitalWrite(4, gw.loadState(1)?RELAY_ON:RELAY_OFF);
                              digitalWrite(5, gw.loadState(1)?RELAY_ON:RELAY_OFF);
                              digitalWrite(6, gw.loadState(1)?RELAY_ON:RELAY_OFF);
                              // Activate internal pull-up
                              digitalWrite(BUTTON_PIN1,HIGH);// button/reed switch program
                              digitalWrite(BUTTON_PIN2,HIGH);// button/reed switch program
                              debouncer1.attach(BUTTON_PIN1);// button/reed switch program
                              debouncer2.attach(BUTTON_PIN2);// button/reed switch program
                              debouncer1.interval(5);// button/reed switch program
                              debouncer2.interval(5);// button/reed switch program
                              gw.present(CHILD_ID1, S_DOOR); // button/reed switch program
                              gw.present(CHILD_ID2, S_DOOR); // button/reed switch program
                           debouncer1.update();
                            // Get the update value
                            int value1 = debouncer1.read();
                            if (value1 != oldValue1) {
                               // Send in the new value
                               gw.send(msg1.set(value1==HIGH ? 1 : 0));
                               oldValue1 = value1;
                          debouncer2.update();
                            if (value2 != oldValue2) {
                               gw.send(msg2.set(value2==HIGH ? 1 : 0));
                               oldValue2 = value2;
                          AWIA 1 Reply Last reply
                            @tomrask
                            Read more about bouncing here:
                            http://en.wikipedia.org/wiki/Switch#Contact_bounce
                            https://github.com/thomasfredericks/Bounce2/wiki
                            • T tomrask
                              @hek
                              Hey Hek
                              Tom Rask
                              int oldValue1=-1;
                              int oldValue2=-1;
                                  pinMode(3, OUTPUT);
                                  pinMode(4, OUTPUT);
                                  pinMode(5, OUTPUT);
                                  pinMode(6, OUTPUT);
                                 // Setup the button
                                   oldValue1 = value1;
                                   oldValue2 = value2;
                              AWIA
                              AWIA
                              AWI
                              @tomrask when you set the relays to the " last known state" the same value (1) is used for all the relays.
