  3. Clone 2 skelets Relay and Button's
19 Posts 5 Posters 9.5k Views 2 Watching
  • T Offline
    T Offline
    tomrask
    wrote on last edited by tomrask
    I've tried to build together a relay and door sensor program from Hek one cloned program without success. I have a vera light. but I'm new about building sensors. Are there some who will look at the program and see where errors.
    What I see in vera is only one door sensors and 2 relay, where there should have been 3 door sensor. I use a Nano with series connection to vera.
    Hope some one can help me, last 3 weeks I have tried unsuccessfully various changes.
    // 1 Door virker 2 relays virker
    #define NUMBER_OF_SWITCHES 3
    #define NUMBER_OF_RELAYS 2 // Total number of attached relays
    Bounce debouncer[NUMBER_OF_SWITCHES];
    int oldValue[NUMBER_OF_SWITCHES];
    byte switchPin[NUMBER_OF_SWITCHES] = {5,6,7}; //<<<<<<<<<<< set your switch pins here
    MyMessage msg(0,V_TRIPPED);
      gw.sendSketchInfo("Relay&Botton", "1.0");
      // Fetch relay status
        gw.present(sensor, S_LIGHT);
        pinMode(pin, OUTPUT);
        digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
      // Switches setup
      for (int i = 0; i < NUMBER_OF_SWITCHES; i++)
        pinMode(switchPin[i],INPUT_PULLUP);
        debouncer[i] = Bounce();
        debouncer[i].attach(switchPin[i]);
        debouncer[i].interval(5);
        gw.present(i, S_DOOR);
        delay(250);
        debouncer[i].update();
        if (value != oldValue[i])
          gw.send(msg.setSensor(i).set(value == HIGH? true : false), false);
        oldValue[i] = value;
      if (message.type==V_LIGHT) {
         // Change relay state
         // Store state in eeprom
    • hekH Offline
      hekH Offline
      Please format code:
      http://forum.mysensors.org/topic/453/forum-upgraded/58
      • T Offline
        T Offline
        tomrask
        Hey Hek
        Thanks for a really exciting home page , I really got interested in building a sensor myself just need some start help.
        • hekH Offline
          hekH Offline
          First you present realys with id 1,2,3 and then you present switches with id 0,1,2. They overlap..
            T Offline
            T Offline
            tomrask
            @hek
            Hey Hek I changed the code, but it will not help. Now I get 3 door sensor and nothing else. hope you will help a little so that I understand the code. thank you
            // Switches setup
                delay(250);
              for (int sensor=3, pin=RELAY_1; sensor<=NUMBER_OF_RELAYS;sensor++, pin++) {
            ferpandoF 1 Reply Last reply
            • T tomrask
              @hek
              // Switches setup
                  delay(250);
              ferpandoF Offline
              ferpandoF Offline
              ferpando
              wrote on last edited by ferpando
              @tomrask
              What Hek is trying to tell you is that you can't have 2 devices with the same number.
              Change your first loop for:
                for (int sensor=0, pin=RELAY_1; sensor<NUMBER_OF_RELAYS;sensor++, pin++) {
              Change your second presentation loop for this
                for (int i = NUMBER_OF_RELAYS; i < (NUMBER_OF_RELAYS+NUMBER_OF_SWITCHES); i++)
                  delay(250);
              This way you are creating relays 0 and 1, and then switches 2, 3 and 4
              • T Offline
                T Offline
                tomrask
                Hey Ferpando
                thanks, now the sensor is displayed on vera. but only one contact and a door sensor works .
                I have not quite mastered the code yet , help wanted.
                // 3 Door 1 virker 2 relays 1 virker
                  // Switches setup
                    delay(250);
                Here
                • T Offline
                  T Offline
                  tomrask
                  Is there anyone out there who just want to give me a hand by getting this skeleton to work. I will be very happy just a little help. It could be great.
                  • V Offline
                    V Offline
                    Vladut Grecu
                    Can you post the serial output of the Arduino?
                    • V Vladut Grecu
                      T Offline
                      T Offline
                      tomrask
                      @Vladut-Grecu
                      This is what I get from serial output
                      repeater started, id 1
                      send: 1-1-0-0 s=255,c=0,t=18,pt=0,l=5,st=ok:1.4.1
                      send: 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
                      read: 0-0-1 s=255,c=3,t=6,pt=0,l=1:M
                      send: 1-1-0-0 s=255,c=3,t=11,pt=0,l=12,st=ok:Relay&Botton
                      send: 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
                      send: 1-1-0-0 s=0,c=0,t=0,pt=0,l=5,st=ok:1.4.1
                      send: 1-1-0-0 s=1,c=0,t=0,pt=0,l=5,st=ok:1.4.1
                      send: 1-1-0-0 s=2,c=0,t=0,pt=0,l=5,st=ok:1.4.1
                      • V Offline
                        V Offline
                        Vladut Grecu
                        wrote on last edited by Vladut Grecu
                        There is something going on with you code. It tells your gateway that you only have 3 devices (0,1,2)
                        I'll look into it when I get home, later this day.
                        • T Offline
                          T Offline
                          tomrask
                          @Vladut-Grecu
                          thanks, I 'll be glad if you will
                          • V Offline
                            V Offline
                            Vladut Grecu
                            @tomrask said:
                            Please modify your sketch like this
                                Serial.print("\nThe nr ");
                                Serial.print(sensor);
                                Serial.print(" relay has been presented\n");
                            and
                                Serial.print(i);
                                Serial.print(" switch has been presented\n");
                                delay(250);
                            And post the serial output again.
                            • V Vladut Grecu
                              and
                                  Serial.print(i);
                                  delay(250);
                              T Offline
                              T Offline
                              tomrask
                              @Vladut-Grecu
                              Hey Vladut
                              This is the seriel output on my Nano
                              send: 1-1-0-0 s=0,c=0,t=3,pt=0,l=5,st=ok:1.4.1
                              The nr 0 relay has been presented
                              send: 1-1-0-0 s=1,c=0,t=3,pt=0,l=5,st=ok:1.4.1
                              The nr 1 relay has been presented
                              The nr 2 switch has been presented
                              send: 1-1-0-0 s=3,c=0,t=0,pt=0,l=5,st=ok:1.4.1
                              The nr 3 switch has been presented
                              send: 1-1-0-0 s=4,c=0,t=0,pt=0,l=5,st=ok:1.4.1
                              The nr 4 switch has been presented
                              send: 1-1-0-0 s=4,c=1,t=0,pt=2,l=2,st=ok:0
                              send: 1-1-0-0 s=3,c=1,t=0,pt=2,l=2,st=ok:0
                              send: 1-1-0-0 s=4,c=1,t=0,pt=2,l=2,st=ok:1
                              send: 1-1-0-1 s=2,c=1,t=0,pt=2,l=2,st=ok:1
                              send: 1-1-0-1 s=3,c=1,t=0,pt=2,l=2,st=ok:1
                              send: 1-1-0-1 s=4,c=1,t=0,pt=2,l=2,st=ok:1
                              send: 1-1-0-1 s=4,c=1,t=0,pt=2,l=2,st=fail:1
                              read: 1-0-1 s=4,c=1,t=0,pt=2,l=2:1
                              send: 1-1-0-1 s=3,c=1,t=0,pt=2,l=2,st=fail:1
                              read: 1-0-1 s=3,c=1,t=0,pt=2,l=2:1
                              • V Offline
                                V Offline
                                Vladut Grecu
                                @tomrask said:
                                From your serial output, I think that the problem is with vera.(config, etc.. I don`t use vera)
                                The node presents your devices and the gateway recognizes them correctly.
                                I guess you pressed the buttons to test them but when you press button nr 3 (child4) you got an error
                                You either wrongly configured vera to use child 4 as something else rather than a button (and it doesn't expect for an update, even if you present it as a button and it says that is ok) or it's beyond my understanding.
                                I will kindly ask @hek to to take a look over what I said and verify the integrity of the code presented but before that, I'll try to do your setup and report back.
                                • hekH Offline
                                  hekH Offline
                                  I suggest you start simple. It is important you understand each step of the code.
                                  • Remove loops (present each sensor separately).
                                  • Remove debounce code (just read the digital inputs directly). They complicate things and you will better grasp what is happening without it.
                                  • Same goes for incoming messages. Look at the incoming message and try to understand what digital output (relay) you want to set,
                                  I could probably write the code for you. But what is the point? If you manage it yourself you'll feel like superstar. Take it in small steps and ask more questions if you don't understand what the purpose a particular line has.
                                  • T Offline
                                    T Offline
                                    tomrask
                                    @hek
                                    Hey Hek
                                    Thank you for your good advice. I have a little vacation here in Easter. so I got it to work with 2 door sensors maybe it's not the best looking program . but it works .
                                    Where can I learn more about these lines, I do not understand 100 % yet :
                                    Bounce debouncer1 = Bounce();
                                    debouncer1.attach(BUTTON_PIN1);
                                    Thanks for the help .
                                    Tom Rask
                                    // Sketch control 4 physical relays and 2 Doorsensors.
                                    // This example will remember relay state even after power failure.
                                    #include <Bounce2.h> // button/reed switch program
                                    #define CHILD_ID1 5 // Arduino Digital I/O pin for button/reed switch
                                    #define CHILD_ID2 6 // Arduino Digital I/O pin for button/reed switch
                                    #define BUTTON_PIN1 7 // Arduino Digital I/O pin for button/reed switch
                                    #define BUTTON_PIN2 8 // Arduino Digital I/O pin for button/reed switch
                                    Bounce debouncer2 = Bounce();
                                    int oldValue1=-1;
                                    int oldValue2=-1;
                                    MyMessage msg1(CHILD_ID1,V_TRIPPED); // button/reed switch program
                                    MyMessage msg2(CHILD_ID2,V_TRIPPED);
                                      gw.sendSketchInfo("Relay and Door", "1.0");
                                        gw.present(1, S_LIGHT);
                                        gw.present(2, S_LIGHT);
                                        gw.present(3, S_LIGHT);
                                        gw.present(4, S_LIGHT);
                                        pinMode(3, OUTPUT);
                                        pinMode(4, OUTPUT);
                                        pinMode(5, OUTPUT);
                                        pinMode(6, OUTPUT);
                                       // Setup the button
                                        pinMode(BUTTON_PIN1,INPUT);// button/reed switch program
                                        pinMode(BUTTON_PIN2,INPUT);// button/reed switch program
                                        digitalWrite(3, gw.loadState(1)?RELAY_ON:RELAY_OFF);
                                        digitalWrite(4, gw.loadState(1)?RELAY_ON:RELAY_OFF);
                                        digitalWrite(5, gw.loadState(1)?RELAY_ON:RELAY_OFF);
                                        digitalWrite(6, gw.loadState(1)?RELAY_ON:RELAY_OFF);
                                        // Activate internal pull-up
                                        digitalWrite(BUTTON_PIN1,HIGH);// button/reed switch program
                                        digitalWrite(BUTTON_PIN2,HIGH);// button/reed switch program
                                        debouncer1.attach(BUTTON_PIN1);// button/reed switch program
                                        debouncer2.attach(BUTTON_PIN2);// button/reed switch program
                                        debouncer1.interval(5);// button/reed switch program
                                        debouncer2.interval(5);// button/reed switch program
                                        gw.present(CHILD_ID1, S_DOOR); // button/reed switch program
                                        gw.present(CHILD_ID2, S_DOOR); // button/reed switch program
                                     debouncer1.update();
                                      // Get the update value
                                      int value1 = debouncer1.read();
                                      if (value1 != oldValue1) {
                                         // Send in the new value
                                         gw.send(msg1.set(value1==HIGH ? 1 : 0));
                                         oldValue1 = value1;
                                    debouncer2.update();
                                      if (value2 != oldValue2) {
                                         gw.send(msg2.set(value2==HIGH ? 1 : 0));
                                         oldValue2 = value2;
                                    A 1 Reply Last reply
                                    • hekH Offline
                                      hekH Offline
                                      @tomrask
                                      Read more about bouncing here:
                                      http://en.wikipedia.org/wiki/Switch#Contact_bounce
                                      https://github.com/thomasfredericks/Bounce2/wiki
                                      • T tomrask
                                        @hek
                                        Hey Hek
                                        Tom Rask
                                        int oldValue1=-1;
                                        int oldValue2=-1;
                                            pinMode(3, OUTPUT);
                                            pinMode(4, OUTPUT);
                                            pinMode(5, OUTPUT);
                                            pinMode(6, OUTPUT);
                                           // Setup the button
                                             oldValue1 = value1;
                                             oldValue2 = value2;
                                        A Offline
                                        A Offline
                                        AWI
                                        @tomrask when you set the relays to the " last known state" the same value (1) is used for all the relays.
