  3. Motion & Relay Sensor issue
interruptsleep issuemultisensormotion sensorrelay
10 Posts 5 Posters 9.0k Views 2 Watching
  • K Offline
    K Offline
    kunall
    wrote on last edited by kunall
    I'm attempting to merge Relay & Motion Sensor sketches, and so far i'm partially succeeded. But..
    Here is the code that works for me: Relay and Motion both work.
    // Example sketch showing how to control physical relays.
    // This example will remember relay state even after power failure.
    REVISION HISTORY
    Version 1.0 - December 29, 2014 - Pete B - Adapted from MySensors Relay Code
    #define NODE_ID 20
    #define SN "Motion&LED"
    #define SV "1.0"
    #define RELAY_PIN  4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define MOTION_PIN  3
    #define RELAY_CHILD 2
    #define MOTION_CHILD 1
    #define INTERRUPT MOTION_PIN -2
    //unsigned long SLEEP_TIME = 120000;
    MyMessage msgRLY(RELAY_CHILD,V_LIGHT);
    MyMessage msgMO(MOTION_CHILD, V_TRIPPED);
      gw.begin(incomingMessage, NODE_ID);
      gw.sendSketchInfo(SN, SV);
    pinMode(MOTION_PIN, INPUT);
      gw.present(RELAY_CHILD, S_LIGHT);
      gw.present(MOTION_CHILD, S_MOTION);
      pinMode(RELAY_PIN, OUTPUT);
      // Read digital motion value
      boolean tripped = digitalRead(MOTION_PIN) == HIGH;
      Serial.println(tripped);
      gw.send(msgMO.set(tripped?"1":"0"));  // Send tripped value to gw
     // gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME);
      if (message.type==V_LIGHT) {
         // Change relay state
         digitalWrite(RELAY_PIN, message.getBool()?RELAY_ON:RELAY_OFF);
         // Store state in eeprom
    //     gw.saveState(message.sensor, message.getBool());
    //     // Write some debug info
    However, My problem is that Motion Sensor continuously sends the message and does not sleep like the following log shows: I want the motion sensor to only send message when triggered.
    If I uncomment the following line in the sketch, The Motion sensor sends message only when triggered (Perfect, thats what I want) but the Relay does not operate:
    I would really appreciate any help with this issue.
    Thank You
    • M Offline
      M Offline
      mikeones
      You should check if the value changed and only send updates when true. Something like this.
      if (lastTripped != tripped ) {
      • hekH Offline
        hekH Offline
        You cannot sleep a node that expects incoming messages.
        • K Offline
          K Offline
          kunall
          Got it. Thank you for your response. So I simply removed the sleep function and put if - else statement to stop my Motion sensor flooding my console window. :)
          • V Offline
            V Offline
            virgus1970
            To kunall
            Have You solved this problem?
            • V Offline
              V Offline
              virgus1970
              wrote on last edited by virgus1970
              I solved this problem by adding following code:
                tripped = digitalRead(DIGITAL_INPUT_SENSOR);
                  if(lastTripped != tripped)
                    if(lastTripped == 0)
                      Serial.print("Motion detected. Sensor value=");
                      lastTripped = 1;
                      Serial.print("Sensor value=");
                      lastTripped = 0;
                    gw.send(msg.set(tripped?"1":"0"));
              But now I have anorther problem.
              I test now two boards (Node1 & Node2). Node1 is Relay & Motion. Node2 is Relay with button. Everything is OK after start of Node1. But after motion sensor is trigged Vera begin to transmit to Node1 Asking Message constantly without any action from me. Like that:
              It stops only after couple of times pushing the button of Node2.
              Any ideas of solution?
              P.S. It doesn't interrupt work of both relays (Node1 & Node2) & reports of Motion sensor.
              • V Offline
                V Offline
                virgus1970
                The further observation shows that "this" comes more probably from Vera (from plugin IMHO). Then I connect GW to serial monitor nothing similar happens.
                May be reading logs of Vera can help? But I don't know where I can find them...
                • K Offline
                  K Offline
                  kunall
                  I'm using OpenHab. So not sure about Vera. But I have the same issue. After using the code you provided, The node constantly sends messages 1 (Motion) or 0 (No motion). So I conclude, as Hek mentioned, the node can not sleep because it is waiting for incoming messages, I guess.
                  • D Offline
                    dias
                    hello, desolated for my english
                      I want a code with 2 relays and 2 pir
                    Thank you
                    hekH 1 Reply Last reply
                    • D dias
                      Thank you
                      hekH Offline
                      hekH Offline
                      wrote on last edited by hek
                      @dias
                      You got to get started coding then :) If you bump into problem you can ask questions here.
