  3. DHT11 and Atmega 8MHz
11 Posts 7 Posters 9.1k Views 3 Watching
  • T Offline
    T Offline
    Thibthib02
    Hello everybody,
    I have trouble with DHT11 on Atmega328 3.3V 8MHz. I use the Humidity sketch and I have a lot of reading error.
    When I try the exemple sketch included in Arduino IDE, everything is ok, no error during 5 hours.
    With the humidity sketch, I have an error every 5 or 7 readings. Maybe an error in the library with timing communication with DHT11??
    Anybody can help me??
    Thank you in advance.
    • M Offline
      M Offline
      Magiske
      wrote on last edited by Magiske
      How often do you read from the DHT11, might not be an issue. But think you need to wait 1-2 sec pr. poll. (Depending on DHT11/22)
      • T Offline
        T Offline
        Thibthib02
        The sleeping time is 30 seconds.
        • S Offline
          sharath krishna
          @Thibthib02 Modify the arduino ide example sketch to work with mysensors and try it .
          • T Offline
            T Offline
            Thibthib02
            The example sketch is too complicated to modify to work with mysensors. Nobody here use the Humidity sketch with arduino @ 8MHz?
            • H Offline
              H Offline
              This DHT library claim to handle 8Mhz:
              https://github.com/Seeed-Studio/Grove_Temperature_And_Humidity_Sensor/tree/master/Humidity_Temperature_Sensor
              • ? Offline
                ? Offline
                A Former User
                Did you try what they suggest here:
                http://forums.adafruit.com/viewtopic.php?f=19&t=46863
                This is for the DHT22, but maybe it relates to the DHT11? They also use a different library I think, but you could integrate that easily, I suppose.
                • T Offline
                  T Offline
                  Totche
                  wrote on last edited by Totche
                  I use this one => Adafruit
                  #define HYGRO_PIN 4         // Pin DHT11
                  DHT dht(HYGRO_PIN, HYGRO_TYPE);
                  float hygrometrie_mem;
                  float hygro_temp_mem;
                  // hygrometrie
                  MyMessage msg_hygro(HYGROMETRIE_CHILD, V_HUM);
                   float hygro_temp = dht.readTemperature();
                   float hygrometrie = dht.readHumidity();
                   // isnan => Is Not A Number
                   if (isnan(hygro_temp) || isnan(hygrometrie))
                      Serial.println("Echec lecture du DHT");
                   else if (hygro_temp != hygro_temp_mem)
                     hygro_temp_mem = hygro_temp;
                    Serial.print("Temperature hygro : ");
                    Serial.print(hygro_temp);
                    Serial.println('C');
                    if (hygrometrie != hygrometrie_mem)
                      hygrometrie_mem = hygrometrie;
                      gw.send(msg_hygro.set(hygrometrie, 1));
                      Serial.print("Hygrometrie : ");
                      Serial.print(hygrometrie);
                      Serial.println('%');
                  • A Offline
                    A Offline
                    Andreas Maurer
                    no problem at all. The humidity scetch is running fine with a pure atmega328p-pu and a DHT11.
                    I have build it on a breadboard for you to see if it is working:
                    As you see, the sensor starts and sends temperature and humidity value:
                    sensor started, id 99
                    send: 99-99-0-0 s=255,c=0,t=17,pt=0,l=5,st=ok:1.4.1
                    send: 99-99-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
                    read: 0-0-99 s=255,c=3,t=6,pt=0,l=2:M
                    send: 99-99-0-0 s=255,c=3,t=11,pt=0,l=8,st=ok:Humidity
                    send: 99-99-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
                    send: 99-99-0-0 s=0,c=0,t=7,pt=0,l=5,st=ok:1.4.1
                    read: 99-1-0 s=0,c=0,t=7,pt=0,l=5:1.4.1
                    send: 99-99-0-0 s=1,c=0,t=6,pt=0,l=5,st=ok:1.4.1
                    read: 99-1-0 s=1,c=0,t=6,pt=0,l=5:1.4.1
                    send: 99-99-0-0 s=255,c=3,t=0,pt=1,l=1,st=ok:62
                    read: 99-1-0 s=255,c=3,t=0,pt=1,l=1:62
                    Normally I am using a DHT22 on my selfmade board.
                    Andreas
                    • T Offline
                      T Offline
                      Thibthib02
                      Maybe a bad DHT11. I will more investigate tomorrow. Thank you guys.
                      • A Andreas Maurer
                        Andreas
                        M Offline
                        M Offline
                        Magiske
                        @Andreas-Maurer Nice looking board!!
                        12.1k
