DHT11 and Atmega 8MHz
Hello everybody,
I have trouble with DHT11 on Atmega328 3.3V 8MHz. I use the Humidity sketch and I have a lot of reading error.
When I try the exemple sketch included in Arduino IDE, everything is ok, no error during 5 hours.
With the humidity sketch, I have an error every 5 or 7 readings. Maybe an error in the library with timing communication with DHT11??
Anybody can help me??
Thank you in advance.
The sleeping time is 30 seconds.
@Thibthib02 Modify the arduino ide example sketch to work with mysensors and try it .
The example sketch is too complicated to modify to work with mysensors. Nobody here use the Humidity sketch with arduino @ 8MHz?
Did you try what they suggest here:
http://forums.adafruit.com/viewtopic.php?f=19&t=46863
This is for the DHT22, but maybe it relates to the DHT11? They also use a different library I think, but you could integrate that easily, I suppose. -
I use this one => Adafruit
#include <DHT.h>#define HYGRO_PIN 4 // Pin DHT11DHT dht(HYGRO_PIN, HYGRO_TYPE);float hygrometrie_mem; float hygro_temp_mem;// hygrometrie MyMessage msg_hygro(HYGROMETRIE_CHILD, V_HUM);float hygro_temp = dht.readTemperature(); float hygrometrie = dht.readHumidity(); // isnan => Is Not A Number if (isnan(hygro_temp) || isnan(hygrometrie)) { Serial.println("Echec lecture du DHT"); } else if (hygro_temp != hygro_temp_mem) { hygro_temp_mem = hygro_temp; } Serial.print("Temperature hygro : "); Serial.print(hygro_temp); Serial.println('C'); if (hygrometrie != hygrometrie_mem) { hygrometrie_mem = hygrometrie; gw.send(msg_hygro.set(hygrometrie, 1)); Serial.print("Hygrometrie : "); Serial.print(hygrometrie); Serial.println('%'); } -
no problem at all. The humidity scetch is running fine with a pure atmega328p-pu and a DHT11.
I have build it on a breadboard for you to see if it is working:
As you see, the sensor starts and sends temperature and humidity value:
sensor started, id 99 send: 99-99-0-0 s=255,c=0,t=17,pt=0,l=5,st=ok:1.4.1 send: 99-99-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0 read: 0-0-99 s=255,c=3,t=6,pt=0,l=2:M send: 99-99-0-0 s=255,c=3,t=11,pt=0,l=8,st=ok:Humidity send: 99-99-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0 send: 99-99-0-0 s=0,c=0,t=7,pt=0,l=5,st=ok:1.4.1 read: 99-1-0 s=0,c=0,t=7,pt=0,l=5:1.4.1 send: 99-99-0-0 s=1,c=0,t=6,pt=0,l=5,st=ok:1.4.1 read: 99-1-0 s=1,c=0,t=6,pt=0,l=5:1.4.1 send: 99-99-0-0 s=255,c=3,t=0,pt=1,l=1,st=ok:62 read: 99-1-0 s=255,c=3,t=0,pt=1,l=1:62Normally I am using a DHT22 on my selfmade board.
Andreas
Maybe a bad DHT11. I will more investigate tomorrow. Thank you guys.
Andreas
@Andreas-Maurer Nice looking board!!
