  3. Dimmable led actuator sketch enhancement
6 Posts 3 Posters 3.2k Views 1 Watching
  • ferpandoF Offline
    ferpandoF Offline
    ferpando
    wrote on last edited by ferpando
    I've been working on a simple mod of the dimmable led actuator available in the examples folder.
    I needed a few things that were not included, like the ability to set a more precise fade level, make longer fades and also being able to change those fade times dynamically.
    Also, as a result of longer dafe times, I had to modify the sketch so the node is still able to send/receive messages during fade time.
    You could send messages from VERA this way:
    luup.call_action("urn:upnp-arduino-cc:serviceId:arduino1", "SendCommand", {radioId="6;100", variableId="DIMMER", value="100,25"}, 130)
    This message is sent to node id 6, with parent node id 130, and tells the node to fade to 100% in 25 seconds.
    You could choose any number (0-100) to fade to, instead of the 10% increment Vera offers. Also the old functionality remains working as before.
    Here's the sketch in case someone is interested:
     * This sketch provides a Dimmable LED Light using PWM and based Henrik Ekblad
     * <henrik.ekblad@gmail.com> Vera Arduino Sensor project.
     * Developed by Bruce Lacey, inspired by Hek's MySensor's example sketches.
     * The circuit uses a MOSFET for Pulse-Wave-Modulation to dim the attached LED or LED strip.
     * The MOSFET Gate pin is connected to Arduino pin 3 (LED_PIN), the MOSFET Drain pin is connected
     * to the LED negative terminal and the MOSFET Source pin is connected to ground.
     * This sketch is extensible to support more than one MOSFET/PWM dimmer per circuit.
     * Version 1.0 - February 15, 2014 - Bruce Lacey
     * Version 1.1 - August 13, 2014 - Converted to 1.4 (hek)
     * Version 1.2 - April 13, 2015 - Added long dynamic and precise fade, also made fade non exclusive (ferpando)
     #include <Time.h>
    #define SN "DimmableLED"
    #define SV "1.2"
    #define LED_PIN 5      // Arduino pin attached to MOSFET Gate pin
    MySensor gw(9,10);
    static int currentLevel = 0;  // Current dim level...
    static int requestedLevel = 0;
    MyMessage dimmerMsg(0, V_DIMMER);
    MyMessage lightMsg(0, V_LIGHT);
    int FADE_DELAY;   // Delay in ms for each percentage fade up/down (10ms = 1s full-range dim)
     * Dimmable LED initialization method
      Serial.println( SN );
      gw.begin( incomingMessage );
      // Register the LED Dimmable Light with the gateway
      gw.present( 0, S_DIMMER );
      gw.sendSketchInfo(SN, SV);
      // Pull the gateway's current dim level - restore light level upon sendor node power-up
      gw.request( 0, V_DIMMER );
     *  Dimmable LED main processing loop
      fadeToLevel();
      // if delay is too long, it might stop the node from receiving/sending more messages for a long time.
      //doing it this way, the node can keep functioning regardless fade completition.
      if (message.type == V_LIGHT || message.type == V_DIMMER) {
        if(message.sensor == 100 ){ //fade special, addressed to node 100
          // Message payload: value to fade to, seconds to fade     example: "20,10"
          int commaIndex = msg.indexOf(',');
          String firstValue = msg.substring(0, commaIndex);
          String secondValue = msg.substring(commaIndex+1);
          requestedLevel=firstValue.toInt();
          int steps=abs(currentLevel-requestedLevel);
          if(commaIndex == -1){
             FADE_DELAY=10;
          }else {
             FADE_DELAY = 1000* secondValue.toInt() / steps;
        }else { //fade normal
              FADE_DELAY=10;
              requestedLevel = atoi( message.data );
          Serial.print( "Changing level to " );
          Serial.print( ", from " );
          Serial.println( currentLevel );
          gw.send(lightMsg.set(currentLevel > 0 ? 1 : 0));
          // hek comment: Is this really nessesary?
          gw.send( dimmerMsg.set(currentLevel) );
     *  This method provides a graceful fade up/down effect
    void fadeToLevel() {
      if ( currentLevel != requestedLevel ) {
        int delta = ( requestedLevel - currentLevel ) < 0 ? -1 : 1;
        currentLevel += delta;
        Serial.print( "analog write: " );
        Serial.println( currentLevel / 100. * 255 );
        analogWrite( LED_PIN, (int)(currentLevel / 100. * 255) );
        delay( FADE_DELAY );
    • ferpandoF Offline
      ferpandoF Offline
      ferpando
      A few bug fixes and also this sends back to gateway the value of 'requestedValue' instead of 'currentValue' as I think it should be.
      Delays and precise setpoint are now correct.
       #include <Time.h>
      #define SV "1.2"
      MySensor gw(9,10);
      boolean preciseFade = false;
        fadeToLevel();
          int steps;
          int multiplier;
            preciseFade = true;
            String msg=message.getString();
            steps = currentLevel-requestedLevel;
            multiplier = abs(1000 / steps);
               FADE_DELAY=multiplier * 10;
            }else {
               FADE_DELAY = multiplier * secondValue.toInt();
          gw.send(lightMsg.set(requestedLevel > 0 ? 1 : 0));
          gw.send( dimmerMsg.set(requestedLevel) );
          int pwmLevel;
          if(preciseFade){ //set to specific number
              pwmLevel = (int)currentLevel;
              }else  { //set to 10% increment level
                 pwmLevel=(int)(currentLevel / 100. * 255);
        Serial.println( pwmLevel );
        analogWrite( LED_PIN, pwmLevel );
      A 1 Reply Last reply
      • D Offline
        Drcashman
        Can this be expanded to include 2-3 more outputs?
        ferpandoF 1 Reply Last reply
        • ferpandoF ferpando
           #include <Time.h>
          #define SV "1.2"
          MySensor gw(9,10);
            fadeToLevel();
              int steps;
              int multiplier;
                preciseFade = true;
                }else {
              int pwmLevel;
          A Offline
          A Offline
          AWI
          @ferpando I maybe misinterpreting things but for me it looks like the "fadeToLevel" is still blocking with respect to the receipt of messages for a time as long as FADE_DELAY. would suggest making it non-blocking by means of a time counter.
          like
          // timer value for "once in a while" events
              unsigned long now = millis();
              gw.process() ;								// process MySensors messages (needed for repeater)
              // Read/update every "delay" (60) seconds
              if (now-lastUpdate > 60000) {
          		read_sensors();
          		lastUpdate = now;
          • A AWI
            like
            		read_sensors();
            		lastUpdate = now;
            ferpandoF Offline
            ferpandoF Offline
            ferpando
            @AWI
            You are right but now the blocking is just a few milliseconds instead of the whole fade time.
            I think messages are still received because the are interrupt driven, so in the next cycle message will arrive.
            You will be just delaying a few millis sending new messages.
            Your solutions is indeed an improvement to be considered.
            In my case I don't need that much control.
            • D Drcashman
              ferpandoF Offline
              ferpandoF Offline
              ferpando
              @Drcashman
              by outputs you mean to control 2-3 light fades?
              I guess it wouldn't be too difficult. Just add counters for current and requested values for each fade to keep them independent
              12.2k
