  3. Open Source Home Automation (Raspberry)
automationopen sourceraspberrycontroller
111 Posts 30 Posters 185.4k Views 15 Watching
  • JohnJ
    JohnJ
    John
    @bjornhallberg
    I think i've missed your mention. Yeah it would be a good idea, albeit not for exposure but for helping out if there are any issues with it (i already find my mailbox filling up with mysensors questions). So yeah i think it is handy to have a dedicated thread. But only if @hek agrees with having such a dedicated thread.
    If PIDOME wasn't making such progress...
    It still is going to slow (in my personal opinion).. especially with not having enough hardware to test with ;).
    hekH 1 Reply Last reply
    • JohnJ John
      @bjornhallberg
      wrote on last edited by hek
      #83
      I have created a "Controller" section and moved all relevant threads I've found.
      @John
      Please create a new PIDome thread here.
      • bjornhallbergB
        bjornhallbergB
        bjornhallberg
        I stumbled upon HouseMon the other day ... anyone here try that? Seems pretty damn great, but a bit obscure and very hard (for me at least) to make heads or tails of. Uses a slew of catchy, modern tech (Dataflow, MQTT, LevelDB, WebSockets, AngularJS, CoffeeScript/Jade/Stylus, Go) all across the board and, most importantly, is quicker on the Raspberry than I would have ever imagined possible, including the web front-end. At least for the test setup. Probably because it uses a pre-compiled binary.
        Installation:
        http://aka-lightbulb.com/2014/04/28/housemon-0-9-x-on-linux-binary-installation/
        Not exactly ready for public consumption yet but not so unlike OpenHAB in its design and complexity either.
          EasyIoT, Homeseer and Pimatic added to the list of supported controllers on the main site.
            MajorDoMo added to main site
            http://www.mysensors.org/controller/majordomo
              Perhaps this discussion should be taken to a more rudimentary level, trying to figure out which automation software we actually want to bet on. And what software will actually run WELL on the resource limited RPi. It would take some convincing before I ever installed java-based solutions for instance, like openHab.
              Has anyone actually tried Ago Control? Is it any good? Does it work well with the Pi? The installation is 130MB no less. A ton of dependencies. Makes you wonder about RAM and CPU usage.
              It feels like this entire market is a bit premature at the moment.
              G
              G
              GaryStofer
              @bjornhallberg I installed AGO and the Mysensor plugin on my RPI/b and after much head scratching and picking out little tidbits here and there on how to get this to load I have a MySensor sending data to it. -- The webgui is reasonably fast, but for the world I can't figure out what you actually can do with it or how you could use the GUI to configure any action to be taken depending on a Sensor reading. The Documentation is totally missing any hints as to how to use the thing.
              Without any clue as to how to make this do anything useful I will format the Rpi's SD card again...
              • G GaryStofer
                bjornhallbergB
                bjornhallbergB
                bjornhallberg
                @GaryStofer Haven't used Ago Control in a long time. I wouldn't have recommended it in the past. Didn't like the AMQP deal. And there were other nuisances. However with version 1.0 coming up perhaps they have made enough improvements to warrant a new look. Support for the ImperiHome Android app is a big deal for instance since their own Android app was pretty basic. If you're not using 1.0 from their testing repository I can understand your frustration.
                Personally I'm quite content with Domoticz for the time being. Easy to use and just works.
                G 1 Reply Last reply
                • Sean BrennanS
                  Sean BrennanS
                  Sean Brennan
                  Hello I am new to all of this but I was so happy that this library worked out of the box. I went with MySensors and AgoControl and was elated until I saw that my servo would not move. It reported the distance sensor and switches worked, but "drapes" and "dimmer" did not. It was not difficult to find out how to add support and now my servos turn but I have not submitted code.
                  https://github.com/mce35/agocontrol/blob/master/devices/MySensors/agoMySensors.cpp#L732
                  Actually MySensors seems to have an enormous amount of supported types, and AgoControl seems to have a good amount but the glue, seriously probably the easiest part, is missing.
                    G
                    G
                    GaryStofer
                    @bjornhallberg I like to give Domoticz a try, but I can't find any mention of a MySensor plug-in anywhere in their Documentation nor on the Wiki. The only mentioning I see is on the MySensor.org controller page saying that it's supported.
                    How are your MySensors talking to it?
                    gary
                    AWIA 1 Reply Last reply
                    • G GaryStofer
                      gary
                      AWIA
                      AWIA
                      AWI
                      @GaryStofer Take a look at topic, you need the Domoticz beta feed. The Domoticz Wiki pages are not updated for the MySensors implementation. @hek was there any new documentation?
                        No, I haven't seen any new MySensors documentation on their wiki yet. Rob is on a business trip so I doubt there will be any the coming couple of weeks.
                          G
                          G
                          GaryStofer
                          @hek @AWI Ahhh beta feed! Yes, that helped. Now I need to figure out Why I get LUA / Blockly errors on all events. Something about a nil utilitidevice . Thanks !
                            A Former User
                            wrote on last edited by [[global:former-user]]
                            #94
                             It also has to be real AUTOMATION in the sense that you can build long and complicated scenes that can respond to changing condition in and around the house, preferably in some nice graphical interface where you just drag and drop the building blocks (Blockly).
                            The perfect solution to build such scenarios is to use Matlab/Simulink/Stateflow and model based design. In this way you can graphically develop control algorithms, state machines and simulate them in PC before you ever start testing them on real home. This is much faster, and it is also industry standard in automation, cars, avionics and space. Afterwards with just few clicks you can generate C code, which will run on any hardware. The code is totaly hardware independent - they have targets for Raspberry, Arduino, Lego Mindstorms etc.
                            The only problem - it costs some good money.
                            So finally all you need - is an automation software, which can execute C code.
                              Supported connection method in boldface (i.e. SERIAL, ETHERNET, MQTT, GPIO). Programming language in [brackets].
                              Free / Open source:
                              1. Ago Control [C++/PYTHON] (SERIAL)
                              2. Calaos [C++] (SERIAL/ETHERNET)
                              3. DomotiGa [GAMBAS] (SERIAL/ETHERNET/MQTT)
                              4. Domoticz [C++] (SERIAL/ETHERNET/MQTT) #RECOMMENDED#
                              5. EasyIoT [C# = REQUIRES MONO] (GPIO)
                              6. FHEM [PERL] (SERIAL/ETHERNET)
                              7. Freedomotic [JAVA] (SERIAL/MQTT)
                              8. Heimcontrol.js [NODE.JS]
                              9. Home Assistant [PYTHON] (SERIAL/ETHERNET)
                              10. Home Genie [C# = REQUIRES MONO] (MQTT)
                              11. HouseMon [GO] (MQTT)
                              12. ioBroker [NODE.JS] (MQTT)
                              13. Jeedom [NODE.JS] (SERIAL/ETHERNET)
                              14. MajorDoMo [PHP] (MQTT)
                              15. MisterHouse [PERL] (SERIAL/ETHERNET)
                              16. MyController.org [JAVA] (SERIAL/ETHERNET/MQTT)
                              17. OpenRemote [JAVA]
                              18. PiDome [JAVA] (SERIAL/MQTT/GPIO) #RECOMMENDED#
                              19. Pimatic [NODE.JS] (SERIAL/GPIO) [link]
                              20. Pytomation [PYTHON]
                              21. The Thing System [NODE.JS] (MQTT)
                              22. homA [NODE.JS]
                              23. home.pi [NODE.JS] (MQTT)
                              24. openHAB [JAVA] (MQTT)
                              25. openLuup [LUA] (ETHERNET)
                              Commercial Software
                              1. Homeseer [?] (SERIAL)
                              Currently not on the Raspberry. Might work with Windows10 and RPi2 in the future?
                              1. HoMiDoM [?] (SERIAL)
                              2. zVirtualScenes
                              3. Opensourceautomation
                              Misc
                              1. pymysensors - Python code for interacting with the network
                              2. pymys - Another python solution
                              Personally, I'm still looking around for the perfect home automation software. And I have a fairly steep list of requirements, among them being a meaty and stylish Android app and notifications using Pushover (and Pushbullet for images?). It also has to be real AUTOMATION in the sense that you can build long and complicated scenes that can respond to changing condition in and around the house, preferably in some nice graphical interface where you just drag and drop the building blocks (Blockly). Not to mention taking advantage of the state of the art charting libraries that are available these days. I'd also like for it to interact with the Raspberry Pi camera module in an intelligent way, so it probably needs to be able to be able to allow extensive scripting, like being able to run raspivid, raspimjpeg and/or raspistill when motion sensors trigger or whatnot.
                              Finding the right controller software can be confusing and you seldom see the whole picture right away. Some automation software solutions are easy to install and boot up quickly but may slow down under the load of many sensors and rules. Some others may be a real hassle to install in terms of dependencies and slow to boot but may hold up better in the face of more complex home automation. Some are user-friendly but offer little control while others offer extensive control over interface and function but might drive you mad while you figure them out. It is safe to say that there is no obvious choice as of now and that the market is still far from mature. One should also note that the Raspberry Pi 1 is NOT a very fast platform and will not be ideal for many of the JAVA implementations above, unless the developers have had such platforms in mind when modelling their software (PiDome being the notable exception). Personally I am not very keen on software that will take minutes to boot up and effectively bog down the Pi in the meantime.
                              As for a faster hardware platform to replace the aging RPi I'm still looking around. The Pi has a support community that none of these other, newer platforms can claim after all. It would have to be a significantly faster system at basically the same price point for another ARM platform to make any sense. It's lucky that the Raspberry Pi 2 was announced at last then. Its IoT support for Windows 10 should provide more possibilities if it runs OK and most of the software above should continue to run on regular Raspbian or whatnot with little or no changes. Whether we ever get any multi-threaded support though for a real performance boost is another issue. Still waiting for the final verdict on the ODROID platforms, particularly the C1, but in my mind, the price including the eMMC module quickly approaches that of some cheaper x86 NUCs or one of those other Atom-powered boxes that keep turning up and are relatively quickly bridging the price gap.
                              J
                              J
                              jkandasa
                              @bjornhallberg @hek Can you add MyController.org in to Free / Open Source list as it is supporting for Raspberry PI?
                              • m26872M
                                m26872M
                                m26872
                                Why isn't ETHERNET listed with Fhem? I've been using eth-gw perfectly for two months now.
                                • m26872M m26872
                                  bjornhallbergB
                                  bjornhallbergB
                                  bjornhallberg
                                  @m26872 Ok. Changed!
                                  • JohnJ
                                    JohnJ
                                    John
                                    Hi @bjornhallberg,
                                    We have been updating our website from wordpress to a self hosted platform on http://pidome.org, This means the url pidome.wordpress.com will be obsoleted and http://pidome.org is the new location.
                                    Could you update the url?
                                    Thanks in advance and cheers,
                                    John.
                                      @bjornhallberg
                                      Please add Calaos and openLuup to the list.
                                      • JohnJ
                                        JohnJ
                                        John
                                        wrote on last edited by John
                                        #100
                                        @bjornhallberg Thanks for the change!
                                        P.S. i recently also added support for local /dev/tty* serial ports which weans that also the GPIO gateway solution is available (http://forum.mysensors.org/topic/2389/added-support-for-local-mysensors-rpi-direct-radio-connection). I know changes are a bit scattered but also is my implementation schedule, sorry ;).
                                        Cheers!
                                        • JohnJ John
                                          Cheers!
                                          bjornhallbergB
                                          bjornhallbergB
                                          bjornhallberg
                                          @John @hek Done! Now also alphabetized. 100% less OCD :-)
