  3. Scene Controller
Scene Controller
52 Posts 20 Posters 35.3k Views 6 Watching
  • L
    L
    lunarok
    @hek : can you update the mysensors lib in codebenders ? On scene controller page you ask to modify SOFTSPI, it's not on codebenders (unless it makes a copy for me) but it is on git
      wrote on last edited by hek
      #29
      Codebender has a bug when library contains large files (UTFT in this case). This has been reported to them and they will fix it eventually. In the meantime I have just re-uploaded the libraries without these binary (pdf files). But I think they need to clear some caches before it actually compiles.
      Enabling SOFTSPI in the MySensors lib-config just for the SceneController is harder because we can only keep one version of the MySensors library at the time in our "repository" on codebender.
      Regarding the DateStrings compilation error .. I've just pushed an update which works in IDE 1.5.8 now.
      • tbowmoT
        tbowmoT
        tbowmo
        @hek
        Can't you define the SoftSPI settings in the sketch, before you load the library header file? (And then make some conditional defines in the library)
        (I admit, I don't know the arduino toolchain fully, so I could be mistaken here.. But in "normal" c/c++ compilers you can do it)
        Or is the libraries at codebender precompiled?
          Nope, it doesn't work in the crappy Arduino builder.
          And I thing codebender tries to simulate Arduino as much as possible.
          • HoffanH
            HoffanH
            Hoffan
            Does this look right?
            I ask because i have installed tge scene controller
            But i cant understand how i will set up a scene with this
              #33
              Looks right.
              1. Cretate a scene (under Automation).
              2. Create new trigger on "Arduino ScheneCtrl 2:1"
              3. Choose the appropriate scene action
              • T
                tbully
                I've been playing around with this quite a bit and have it working great. That said, I know I remember seeing a thread where cases (3D printed) were being discussed . However, I can't find the link.
                Anyone have it handy?
                • T
                  tbully
                  Still trying to find a case while tinkering and came up with another question.
                  Has anyone figured out how to "toggle" a scene? I think it'd be cool to have it somehow know if a scene was active and if so run an "off" version of that scene. Likewise, if the scene is "off", run an "on" version.
                  Maybe another way is to abandon the scene functionality altogether and just somehow control the zwave switch individually.
                  Just thinking out loud.
                  Very cool project.
                  • Q
                    Q
                    quocanhcgd
                    Can i use Arduino Uno to make scene controller? If okie, please teach me to do it? thanks
                    hekH 1 Reply Last reply
                    • Q quocanhcgd
                      @quocanhcgd
                      Yes, but you cannot use the touch screen. Here is a couple of example of scene activators using buttons:
                      http://forum.mysensors.org/topic/1018/contest-3d-printed-battery-powered-wall-remote-control
                      http://forum.mysensors.org/topic/93/weather-station-with-scene-activator
                      • T
                        tbully
                        Bringing back an old thread. As you can tell, I'm not much of a developer. ..... apologies....
                        I'm updating all of my sensors to 1.5 but am having issues with this one. When I compile (using IDE 1.6.5) and a new libraries directory, I get the following error.
                        Any ideas?
                        TouchDisplaySceneControllerSensor:67: error: no matching function for call to 'MySensor::MySensor(int, int)'
                        TouchDisplaySceneControllerSensor.ino:67:18: note: candidates are:
                        In file included from TouchDisplaySceneControllerSensor.ino:37:0:
                        C:\Users\tbully\Documents\Arduino\libraries\MySensors/MySensor.h:158:2: note: MySensor::MySensor(MyTransport&, MyHw&)
                        C:\Users\tbully\Documents\Arduino\libraries\MySensors/MySensor.h:158:2: note:   no known conversion for argument 1 from 'int' to 'MyTransport&'
                        C:\Users\tbully\Documents\Arduino\libraries\MySensors/MySensor.h:149:7: note: MySensor::MySensor(const MySensor&)
                         class MySensor
                        C:\Users\tbully\Documents\Arduino\libraries\MySensors/MySensor.h:149:7: note:   candidate expects 1 argument, 2 provided
                        AWIA 1 Reply Last reply
                        • T tbully
                          Any ideas?
                           class MySensor
                          AWIA
                          AWIA
                          AWI
                          @tbully It looks like you are using the "old" gw(pin,pin) call. This has been replaced with a separate initialisation for the radio. In case you use the default pin definitions gw(9,10) you can just replace gw(.., ..) ; by gw ;
                          • T
                            tbully
                            Thanks @awi. I meant to come back and correct my post. I did see that after going back and looking at the old 1.4 API (you are correct). It has been many months since I've looked at this sketch. However, I'm not using the default PINs here so I guess I have to change MyConfig for this sketch?
                            *  NRF24L01 Driver Defaults
                            #define RF24_CE_PIN		   9
                            #define RF24_CS_PIN		   10
                            • T tbully
                              AWIA
                              AWIA
                              AWI
                              @tbully The new API uses a separate radio class initiator Something like (from one of my own 'learnings' , Ceech board in this case)
                              MyTransportNRF24 transport(7, 8); // Sensoduino (8,7) Ceech board, 3.3v (7,8)  (pin default 9,10)
                              MySensor gw(transport);
                              • T
                                tbully
                                @awi , not surprisingly, this worked as expected.
                                I changed the following in Hek's script and it worked fine:
                                MyTransportNRF24 transport(17, 18);
                                • alexsh1A
                                  alexsh1A
                                  alexsh1
                                  #43
                                  Bringing back this old thread as I am building the scene controller now.
                                  I am having a problem with a lot of garbage like this:
                                  send: 7-7-0-0 s=255,c=3,t=15,pt=2,l=2,sg=0,st=ok:0
                                  send: 7-7-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,st=ok:1.5.2
                                  send: 7-7-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
                                  read and drop: 7-7-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                                  read and drop: 0-224-0 s=0,c=0,t=0,pt=0,l=0,sg=0:
                                  ver mismatch
                                  ver mismatch
                                  goes on and on
                                  I do not have different MySensors GW/nodes. All of my GW/Nodes have MYS 1.5.2 Where does ver mismatch come from? Also time is not getting pulled into the scene controller from the controller (Domoticz).
                                  Cannot get time from the controller either...
                                  alexsh1A 1 Reply Last reply
                                  • alexsh1A alexsh1
                                    ver mismatch
                                    ver mismatch
                                    goes on and on
                                    alexsh1A
                                    alexsh1A
                                    alexsh1
                                    #44
                                    OK, just to revive this project, I decided to modify it as follows:
                                    This would make the transmitter fit between the screen and the adapter
                                    The problem is that this sandwich is super thick. So I got a new screen from itead studio, which can be used without the adapter. In this photo I desoldered D14-D21 pins as they are not used in order to hook up nrf24l01+:
                                    • alexsh1A alexsh1
                                      alexsh1A
                                      alexsh1A
                                      alexsh1
                                      #45
                                      This is a semi finished project. The power is fed via ICSP through 662k (under the red tape):
                                      Now I need to isolate everything:
                                      This is how Mega + the screen looks:
                                      Now I need to figure out how to stick the battery between the screen and Mega :)
                                      Any suggestions welcome!
                                      • alexsh1A alexsh1
                                        alexsh1A
                                        alexsh1A
                                        alexsh1
                                        #46
                                        Additionally, I have recently received a new Enhanced Nextion screen (again from Itead Studio) and a new ESP8266 PCB:
                                        Much thinner :-) so watch this space....
                                          #47
                                          @alexsh1
                                          cool ;) I made one like this some time ago https://forum.mysensors.org/topic/2766/an-esp8266-nextion-scene-controller/5
                                          but it's not with the new nextion rev. i like these hmi screens, easy to use.
