  3. Scene Controller
Scene Controller
52 Posts 20 Posters 35.3k Views 6 Watching
  • L
    L
    lunarok
    Will it be possible to use with 3.5 LCD instead of 3.2 ? Many differences for the code to make ?
    Because now we can find 3.5LCD directly connectable on 2560 and total is cheaper too.
    hekH 1 Reply Last reply
    • L lunarok
      @lunarok
      It depends on if the display is supported by the UTFT library I used in the example.
      • JohnJ
        JohnJ
        John
        Very cool display, well done!
        • L
          L
          lunarok
          Can't use the sketch.
          From codebender include on mysensors it just say there was an error compiling it.
          When I clone it, directly on codebenders it say there was a communication error.
          When try with local IDE, there is a lot of errors about the time library
          This type (for each month and day)
          libraries/Time/DateStrings.cpp:18:18: error: variable ‘monthStr1’ must be const in order to be put into read-only section by means of ‘attribute((progmem))’
          char monthStr1[] PROGMEM = "January";
          • L
            L
            lunarok
            @hek : can you update the mysensors lib in codebenders ? On scene controller page you ask to modify SOFTSPI, it's not on codebenders (unless it makes a copy for me) but it is on git
              wrote on last edited by hek
              #29
              Codebender has a bug when library contains large files (UTFT in this case). This has been reported to them and they will fix it eventually. In the meantime I have just re-uploaded the libraries without these binary (pdf files). But I think they need to clear some caches before it actually compiles.
              Enabling SOFTSPI in the MySensors lib-config just for the SceneController is harder because we can only keep one version of the MySensors library at the time in our "repository" on codebender.
              Regarding the DateStrings compilation error .. I've just pushed an update which works in IDE 1.5.8 now.
              • tbowmoT
                tbowmoT
                tbowmo
                @hek
                Can't you define the SoftSPI settings in the sketch, before you load the library header file? (And then make some conditional defines in the library)
                (I admit, I don't know the arduino toolchain fully, so I could be mistaken here.. But in "normal" c/c++ compilers you can do it)
                Or is the libraries at codebender precompiled?
                  Nope, it doesn't work in the crappy Arduino builder.
                  And I thing codebender tries to simulate Arduino as much as possible.
                  • HoffanH
                    HoffanH
                    Hoffan
                    Does this look right?
                    I ask because i have installed tge scene controller
                    But i cant understand how i will set up a scene with this
                      #33
                      Looks right.
                      1. Cretate a scene (under Automation).
                      2. Create new trigger on "Arduino ScheneCtrl 2:1"
                      3. Choose the appropriate scene action
                      • T
                        tbully
                        I've been playing around with this quite a bit and have it working great. That said, I know I remember seeing a thread where cases (3D printed) were being discussed . However, I can't find the link.
                        Anyone have it handy?
                        • T
                          tbully
                          Still trying to find a case while tinkering and came up with another question.
                          Has anyone figured out how to "toggle" a scene? I think it'd be cool to have it somehow know if a scene was active and if so run an "off" version of that scene. Likewise, if the scene is "off", run an "on" version.
                          Maybe another way is to abandon the scene functionality altogether and just somehow control the zwave switch individually.
                          Just thinking out loud.
                          Very cool project.
                          • Q
                            Q
                            quocanhcgd
                            Can i use Arduino Uno to make scene controller? If okie, please teach me to do it? thanks
                            • Q quocanhcgd
                              @quocanhcgd
                              Yes, but you cannot use the touch screen. Here is a couple of example of scene activators using buttons:
                              http://forum.mysensors.org/topic/1018/contest-3d-printed-battery-powered-wall-remote-control
                              http://forum.mysensors.org/topic/93/weather-station-with-scene-activator
                              • T
                                tbully
                                Bringing back an old thread. As you can tell, I'm not much of a developer. ..... apologies....
                                I'm updating all of my sensors to 1.5 but am having issues with this one. When I compile (using IDE 1.6.5) and a new libraries directory, I get the following error.
                                Any ideas?
                                TouchDisplaySceneControllerSensor:67: error: no matching function for call to 'MySensor::MySensor(int, int)'
                                TouchDisplaySceneControllerSensor.ino:67:18: note: candidates are:
                                In file included from TouchDisplaySceneControllerSensor.ino:37:0:
                                C:\Users\tbully\Documents\Arduino\libraries\MySensors/MySensor.h:158:2: note: MySensor::MySensor(MyTransport&, MyHw&)
                                C:\Users\tbully\Documents\Arduino\libraries\MySensors/MySensor.h:158:2: note:   no known conversion for argument 1 from 'int' to 'MyTransport&'
                                C:\Users\tbully\Documents\Arduino\libraries\MySensors/MySensor.h:149:7: note: MySensor::MySensor(const MySensor&)
                                 class MySensor
                                C:\Users\tbully\Documents\Arduino\libraries\MySensors/MySensor.h:149:7: note:   candidate expects 1 argument, 2 provided
                                AWIA 1 Reply Last reply
                                • T tbully
                                  Any ideas?
                                   class MySensor
                                  AWIA
                                  AWIA
                                  AWI
                                  @tbully It looks like you are using the "old" gw(pin,pin) call. This has been replaced with a separate initialisation for the radio. In case you use the default pin definitions gw(9,10) you can just replace gw(.., ..) ; by gw ;
                                  • T
                                    tbully
                                    Thanks @awi. I meant to come back and correct my post. I did see that after going back and looking at the old 1.4 API (you are correct). It has been many months since I've looked at this sketch. However, I'm not using the default PINs here so I guess I have to change MyConfig for this sketch?
                                    *  NRF24L01 Driver Defaults
                                    #define RF24_CE_PIN		   9
                                    #define RF24_CS_PIN		   10
                                    • T tbully
                                      AWIA
                                      AWIA
                                      AWI
                                      @tbully The new API uses a separate radio class initiator Something like (from one of my own 'learnings' , Ceech board in this case)
                                      MyTransportNRF24 transport(7, 8); // Sensoduino (8,7) Ceech board, 3.3v (7,8)  (pin default 9,10)
                                      MySensor gw(transport);
                                      • T
                                        tbully
                                        @awi , not surprisingly, this worked as expected.
                                        I changed the following in Hek's script and it worked fine:
                                        MyTransportNRF24 transport(17, 18);
                                        • alexsh1A
                                          alexsh1A
                                          alexsh1
                                          #43
                                          Bringing back this old thread as I am building the scene controller now.
                                          I am having a problem with a lot of garbage like this:
                                          send: 7-7-0-0 s=255,c=3,t=15,pt=2,l=2,sg=0,st=ok:0
                                          send: 7-7-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,st=ok:1.5.2
                                          send: 7-7-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
                                          read and drop: 7-7-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                                          read and drop: 0-224-0 s=0,c=0,t=0,pt=0,l=0,sg=0:
                                          ver mismatch
                                          ver mismatch
                                          goes on and on
                                          I do not have different MySensors GW/nodes. All of my GW/Nodes have MYS 1.5.2 Where does ver mismatch come from? Also time is not getting pulled into the scene controller from the controller (Domoticz).
                                          Cannot get time from the controller either...
                                          alexsh1A 1 Reply Last reply
