  3. Vera
  4. Mysensors Plugin - Lua Startup Failed
13 Posts 7 Posters 7.3k Views 2 Watching
  • 5546dug5
    5546dug5
    5546dug
    I think you have the same as I did
    From where you are you. Need to go under apps-dev apps-config port
    There, change the baud rate to 115200 and select the ' my sensors plugin ' under the 'used by' pull down list .
    Important now to save this in Vera and then Hit Save , and then hit reload. That should be it.
      Yes, it should be described here:
      http://www.mysensors.org/controller/vera#including-new-sensors
      • Sven WolfS
        Sven WolfS
        Sven Wolf
        Oh, maybe I should've scrolled XD
        Thanks a lot guys. This will probably fix it.
        //Sven
        • H
          H
          heeythere47
          Hi, I have the same problem but when I go to serial port configaration all I get up is
          "Serial Port configuration
          If you connected the USB/serial device and it's not displayed here, reload Luup.Reload Luup
          Not available"
          Any help appreciated. Using vera lite u17. Thanks
          blaceyB 1 Reply Last reply
          • H heeythere47
            Not available"
            blaceyB
            blaceyB
            blacey
            • H
              H
              heeythere47
              Tried this, hasn't helped. Same message as before. This from device page.mysensor.PNG
              Would chinese clones be causing this problem?
              Thanks Jamie
              DwaltD 1 Reply Last reply
              • H heeythere47
                Thanks Jamie
                DwaltD
                DwaltD
                Dwalt
                @heeythere47 Did you try what @5546dug suggested above? Your Vera is wanting you to "choose serial port". Check the baud rate and make sure the 'MySensors plugin' is selected.
                • H
                  H
                  heeythere47
                  I have gone to apps-dev apps-config port. but it is not opening the menu up to allow me to set anything.
                  I go into develop apps, create device & paste D_Arduino1.xml in Upnp Device Filename field.
                  Thats fine device is created. At this point it is an "Unnamed device"
                  Then I go back to develop apps Serial port configuration & get this
                  ClickReload Luup & the device becomes
                  but i am still not able to choose serial port & if click start on the device I get
                  lua startup failure message
                  Cheers Jamie
                  • H
                    H
                    heeythere47
                    Also have gone to z-wave settings & restarted luup engine. Thanks
                    • H
                      H
                      heeythere47
                      I have come to the conclusion that my vera does not recognise theses nanos & have ordered what I hope is a genuine one by the price. I will see how that goes.
                      Cheers Jamie
                      • mjunqueiraM
                        mjunqueiraM
                        mjunqueira
                        There is a cheaper version of the nano that uses the ch340 Usb to Serial, there is no driver on the open wrt, to recognize it,
                        Please take a look at the bottom of your nano,
                        if it´s the same of to photo, you will need to buy one with the FTDI chip:
                        • H
                          H
                          heeythere47
                          that is the chip on the nanos I bought. The serial gateway is working now I received a genuine nano & the cheap ones work fine with relays, motion sensors etc. All good.
                          Thanks Jamie
