  3. repeater and sensor in one node.
4 Posts 2 Posters 1.9k Views 1 Watching
  • P
    P
    pawel
    wrote on last edited by pawel
    It is possible in one node is repeater and sensor?
    Thanx
    Pawel
      Yes, repeaters can report sensor data.
      • P
        P
        pawel
        I should change:
        1. in setup():
          gw.begin() --> gw.begin(NULL, AUTO, true);
        2. in loop();
          gw.sleep(SLEEP_TIME); --> gw.process();
        this will be enough?
        when i use node as repeater with sensor . this will be work all time without sleep mode?
        And I should us timer (not delay) send sensors value.
        What else?
          Yes, that should do it.
          And yes you shouldn't use delay() or sleep the node. Instead you use timer or your own millis() checks.
