  3. repeater and sensor in one node.
4 Posts 2 Posters 1.8k Views 1 Watching
  • P Offline
    P Offline
    pawel
    wrote on last edited by pawel
    It is possible in one node is repeater and sensor?
    Thanx
    Pawel
    • hekH Offline
      hekH Offline
      Yes, repeaters can report sensor data.
      • P Offline
        P Offline
        pawel
        I should change:
        1. in setup():
          gw.begin() --> gw.begin(NULL, AUTO, true);
        2. in loop();
          gw.sleep(SLEEP_TIME); --> gw.process();
        this will be enough?
        when i use node as repeater with sensor . this will be work all time without sleep mode?
        And I should us timer (not delay) send sensors value.
        What else?
        • hekH Offline
          hekH Offline
          Yes, that should do it.
          And yes you shouldn't use delay() or sleep the node. Instead you use timer or your own millis() checks.
