  2. Announcements
  3. Sensebender Micro
Sensebender Micro
584 Posts 84 Posters 655.6k Views 35 Watching
  • korttomaK
    korttomaK
    korttoma
    What would be the best option to add an external temperature sensor to the Sensbender Micro?
    Another Si7021? Any thoughts?
    I could not find any other I2C temperature sensor with the same voltage range to a reasonable price.
    • Tomas
      Just ordered 6 for myself. I wouldn't want to miss out on the first batch. Only around 100 left.
      Talked to Itead today. They had to source the ATSHA204A from overseas and will start production when they arrive.
      K
      K
      kalle
      bought also 3 pieces :-)
        mvader
        I picked up 3 and 5 radios
        • hetbeestH
          hetbeestH
          hetbeest
          wrote on last edited by hetbeest
          Just ordered two to start with ;)
          • D
            Dean
            Hope this isn't too silly a question.... The temp/humidity sensing, that works 'out of the box' without requiring me actually connecting these sensors, right?
            And another question, would it be possible to turn the temp/hum function off and just have a motion sensor connected which would never do anything unless it sensed movement and then send a message to the gateway?
            I've been flat out at work for a couple months so I've been away from this for a while... :-)
            • tbowmoT
              tbowmoT
              tbowmo
              @Dean
              It will be programmed by the factory, with the "Sensebender micro" sketch, https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/examples/SensebenderMicro/SensebenderMicro.ino
              So it's plug'n'play as a sensor with temperature and humidity. You could always dump another sketch to the unit, if you want to use it for something else.
              • G
                G
                gol
                I have also ordered a couple of boards to be able to evaulate them as soon as possible.
                Just a question:
                • What is the expected lifetime of the batteries if you use 2 AA batteries, the default preloaded sketch and reports the temp and humidity values once per minute?
                • jeylitesJ
                  jeylitesJ
                  jeylites
                  wrote on last edited by jeylites
                  #24
                  Out of curiosity, can over the air updates be implemented on Arduino Nano? I'm going to get 3 to put Sense to the test. :smiley:
                    @gol
                    It was measured by @blacey to 0.05 mA while sleeping and 0.95 mA during transmit. @tbowmo got some higher figures but they were most probably related to running a NRF24L01+ clone.
                    @jeylites
                    Yes, have a look at the bootloader here:
                    https://github.com/mysensors/Arduino/tree/master/MYSBootloader
                    You can test OTA updates using the MYSController. It overwrites program memory in-place during boot. If communication goes down or fails during this process the node won't boot up again (you have to upload a new sketch while connected to you computer).
                    The sensbender has a external flash which means we can safely store the OTA firmware while normal sketch is running. When everything has been downloaded the DualOptiboot moves new firmware from flash to program memory during bootup. The code for this has been written (in development branch) but has not been tested yet (I failed handsoldering them :() .
                    tekkaT D 2 Replies Last reply
                    • D
                      Dean
                      Thankyou @tbowmo
                        @gol
                        @jeylites
                        tekkaT
                        tekkaT
                        tekka
                        wrote on last edited by tekka
                        #27
                        @hek said:
                        @jeylites
                        If the communication fails, the bootloader will remain "bootloading", i.e. will try to fetch a new firmware from the controller until the CRC matches - no need to upload a sketch via computer.
                        MYSBootloader 2.0 will have SHA signing implemented: for those nodes without ATSHA204 which need signed OTA updates :)
                        jeylitesJ 1 Reply Last reply
                        • tekkaT tekka
                          @hek said:
                          @jeylites
                          jeylitesJ
                          jeylitesJ
                          jeylites
                          Do I have to include those files into my sketch or just install MYS on windows and it will auto detect? In other words, do I have to make any changes to the sketch?
                          Is there any tutorial on MYS implementation?
                          hekH 1 Reply Last reply
                          • jeylitesJ jeylites
                            @jeylites
                            You should read up on what a bootloader is and how to install it.
                            http://www.arduino.cc/en/Hacking/Bootloader?from=Tutorial.Bootloader
                            Might be good to start another thread if you have more MYSController/bootloader questions,
                              @jeylites
                              marceltrapmanM
                              marceltrapmanM
                              marceltrapman
                              Nicely put :)
                              I would say 'please start another thread because this will never be found again and will help other as well'...
                              Just my 2 cents.
                              Fulltime Servoy Developer
                              • rvendrameR
                                rvendrameR
                                rvendrame
                                is 3V the absolute maximum or 3.3V is acceptable to power it? For non-battery operated sensors, it may be easier to find a 3.3V regulators instead 3V (at least in my country).
                                ESP8266 GW + mySensors 2.3.2
                                Alexa / Google Home
                                • tbowmoT
                                  tbowmoT
                                  tbowmo
                                  @rvendrame
                                  absolute maximum voltage is 3.6V, above that you'll let the magic smoke out of the following components:
                                  • Si7021
                                  • external flash
                                  • radio module.
                                  Only the atmega328 and atsha204 will survive.
                                  korttomaK 1 Reply Last reply
                                  • rvendrameR
                                    rvendrameR
                                    rvendrame
                                    But will all components work properly on 3.3V?
                                    Alexa / Google Home
                                    • tbowmoT
                                      tbowmoT
                                      tbowmo
                                      @rvendrame
                                      Yes they would
                                      • rvendrameR
                                        rvendrameR
                                        rvendrame
                                        @tbowmo thx a lot!
                                        Alexa / Google Home
                                        • D
                                          doblanch
                                          I didn't find mention of it. What is the expected battery life ?
                                          I was going to replace AA by CR123 to gain in space.
                                          thkx
