  3. Battery Sensor / Voltage Monitor
24 Posts 7 Posters 16.4k Views 3 Watching
  • jeylitesJ
    jeylitesJ
    jeylites
    wrote on last edited by jeylites
    Guys,
    This sketch compiled but doesn't work. I wondering if some one could have a look at it and see what I have done wrong. Cheers!
    Serial Logs
    sensor started, id 1
    send: 1-1-0-0 s=255,c=0,t=17,pt=0,l=5,st=ok:1.4.1
    send: 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
    send: 1-1-0-0 s=255,c=3,t=11,pt=0,l=13,st=ok:Battery Meter
    send: 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
    send: 1-1-0-0 s=20,c=0,t=38,pt=0,l=5,st=ok:1.4.1
    1023
    Battery Voltage: 3.44 V
    Battery percent: 102 %
    send: 1-1-0-0 s=255,c=3,t=0,pt=1,l=1,st=ok:102
    // This is an example that demonstrates how to report the battery level for a sensor
    // Instructions for measuring battery capacity on A0 are available in the follwoing forum
    // thread: http://forum.micasaverde.com/index.php/topic,20078.0.html
    #define CHILD_ID_BATT 20
    MyMessage msgBattery(CHILD_ID_BATT, V_VOLTAGE);
    unsigned long SLEEP_TIME = 900000;  // sleep time between reads (seconds * 1000 milliseconds)
    int oldBatteryPcnt = 0;
       analogReference(INTERNAL);
       gw.begin();
       gw.sendSketchInfo("Battery Meter", "1.0");
      gw.present(CHILD_ID_BATT, V_VOLTAGE);
       // get the battery Voltage
       Serial.println(sensorValue);
       Serial.print(batteryV);
       Serial.println(" V");
       Serial.print(batteryPcnt);
       Serial.println(" %");
         // Power up radio after sleep
         oldBatteryPcnt = batteryPcnt;
       gw.sleep(SLEEP_TIME);
    AWIA 1 Reply Last reply
    • jeylitesJ jeylites
      Guys,
      Serial Logs
      1023
         gw.begin();
      AWIA
      AWIA
      AWI
      @jeylites From what I see the sketch is working fine except that it is reporting a 102% battery level :) So it could be that your controller is not interpreting the message or that you are expecting the Voltage to show up as a sensor. To do the last you have to send it with your the 'msgBattery' message. Which controller are you using?
      • SweebeeS
        SweebeeS
        Sweebee
        wrote on last edited by Sweebee
        Everything looks fine.
        this is send to the gw send: 1-1-0-0 s=255,c=3,t=0,pt=1,l=1,st=ok:102
        Maybe the controller doesn't accept higher than 100.
        Your voltage is higher than 3.363V so thats why its 102%.
        add this just after int batteryPcnt - sensorValue / 10;
        if(batteryPcnt > 100)
           batteryPcnt = 100;
        or
        batteryPcnt = min(batteryPcnt, 100);
        • jeylitesJ
          jeylitesJ
          jeylites
          @ AWI
          good to hear from you :) Yes, I will like it to show up as a sensor, I'm using Vera Edge.
          @Sweebee
          I'm going to make the change and see if it works. Will report back guys!
          • jeylitesJ
            jeylitesJ
            jeylites
            It actually comes up as Arduino Door... very odd. Still can't get voltage or battery level to show up.
            jeylitesJ AWIA 2 Replies Last reply
              jeylitesJ
              jeylitesJ
              jeylites
              After restarting the node, I do see the battery % on Arduino Node . Question is, how do you make it to show up as a sensor. It will be great to have it show voltage too.
                AWIA
                AWIA
                AWI
                wrote on last edited by AWI
                @jeylites You are presenting the sensor as V_VOLTAGE (value=38). The sensor should present itself with a S_.... message. eg S_POWER (value=13) to be recognized correctly. Have a look at the API/ Serial spec
                  S_VOLTAGE has not been implemented on vera (someone needs to create the device-files).
                  But I don't think you need to present anything at all. The Battery level is added to the Node-device which is automatically created.
                  jeylitesJ 1 Reply Last reply
                    jeylitesJ
                    jeylitesJ
                    jeylites
                    @hek That explains why it's not working
                      Sidedote: Hmm.. the gui looks awful on UI7. Why doesn't it break the text into lines?
                        jeylitesJ
                        jeylitesJ
                        jeylites
                        @hek
                        I couldn't agree more. I saw somewhere in My Sensor someone posted a way to make that go away but I can't seem to find it.
                          You are running the UI7 branch right?
                            jeylitesJ
                            jeylitesJ
                            jeylites
                            @hek Yes sir!
                            I added all these files below into Luup Screen Shot 2015-05-12 at 12.46.27 AM.png
                              @hek Yes sir!
                              jeylitesJ
                              jeylitesJ
                              jeylites
                              @hek
                              I did not know what this does so I did not add....Screen Shot 2015-05-12 at 12.50.03 AM.png
                              hekH 1 Reply Last reply
                                @hek
                                No they should not be added.
                                If someone has the time to adjust the UI7 GUI a bit I would appreciate it. There are a lot of whitespace above the icon. I hope that space is available to use by the device. If not, is sucks.
                                • jeylitesJ
                                  jeylitesJ
                                  jeylites
                                  @hek out of curiosity, I was checking out the sketch for Sensebender and saw that it had a Child Id for Battery Sensor and Voltage sensor. How does this work as a Child id?
                                  Since Voltage is not available on Vera at this time , I'm assuming I will not be able to use this feature... correct?
                                    I think it is supported in Domoticz. But we better ping @tbowmo for a better explanation. It will simply be ignored in Vera.
                                    • tbowmoT
                                      tbowmoT
                                      tbowmo
                                      @jeylites @hek
                                      That battery ChildId is a leftover, from some earlier monitoring that I did, to monitor batteryvoltage decrease. Back then I used pidome as controler.
                                      For a long time it has only reported battery percentage with the following routine
                                       * Parameters
                                        if (force) lastBattery = -1;
                                        long vcc = readVcc();
                                        if (vcc != lastBattery) {
                                          lastBattery = vcc;
                                          // Calculate percentage
                                          long percent = vcc / 14.0;
                                          gw.sendBatteryLevel(percent);
                                      There are a couple of variable references back in the code at github, for the old battery voltage childId. These where removed last night, while I did some cleanup of the code. The changes are not pushed to github yet, as I haven't tested it yet.
                                        stamag
                                        How can I present the value in Voltage (for example 3.06 V)? I don't like the "Battery monitor".
                                        I have got the multiple temperature meter (DHT + Dallas) working very well. Would be nice to have battery level in volts also.
                                        Cheers!
                                        M AWIA 2 Replies Last reply
                                        • S stamag
                                          Cheers!
                                          mikemayers
                                          @stamag That depends on the kind of controller employed.
                                          There is no plugin for Vera according to @hek .
