  3. Soil Sensor analog values differ on Uno vs Pro Mini
soil sensorunopro mini
28 Posts 8 Posters 17.6k Views 1 Watching
  • M murdog
    Working towards my sensor network and seeing a bit of an odd difference when moving from my Uno board over to the Pro Mini.
    I have the Soil Sensor (3.3v powered) setup to output Analog values and am reading that via A0 pin on the Uno. The base line value I get is 682, as I add water that value drops. However when I move that sensor over to the Pro Mini (3.3v) and run the exact same sketch I get a base line value of 1023, as I add water it drops. I swapped in another Pro Mini just to rule that out and it also registers 1023 as the baseline output.
    So I guess the question is, which one is correct? My initial take is that the Pro Mini is giving me bad values as it is maxed at 1023 - am I overlooking a setting on the pro mini?
    I removed all other sensors including the radio and am using this bare bones sketch between the two:
    <pre><code>
    #define SOIL_SENSOR_ANALOG_PIN A0
    int soil = analogRead(SOIL_SENSOR_ANALOG_PIN);
    Serial.print("SOIL:");
    Serial.println(soil);
    delay(1000);
    </code></pre>
    daulagariD
    daulagariD
    daulagari
    @murdog You write the Pro Mini is powered at 3.3 V but you do not write how the Uno is powered but I guess it is powered at 5 V.
    If so, that can explain things I think.
    • daulagariD daulagari
      murdog
      @daulagari Yes Uno is powered via USB@5v, but the soil sensor is connected to the 3.3v regulated supply.
      daulagariD 1 Reply Last reply
        Did you try setting pit to input mode?
        pinMode(SOIL_SENSOR_ANALOG_PIN, INPUT);
          murdog
          @hek I was playing around with it alot last night and yes that is one of the things I did try before doing a read, but still 1023. I will confirm again when home. Any ideas of what I should be seeing for the baseline on the soil sensor?
          • M murdog
            daulagariD
            daulagariD
            daulagari
            So is the full-ADC scale (1023) not the same as the voltage supply?
            682/1023 * 5 Volt = 3.33 Volt and that would clip the 3.3 V ADC of the Pro Mini so therefore it is giving 1023.
            • Z
              Z
              Zeph
              OK, the soil sensor is connected to a 3.3v regulated supply.
              But the Arduino sounds like it's still running at 5v, and by default the ADC reference is VCC. So at full scale soil sensor reading of 3.3v will be only about 2/3 of that 5v reference. (but 100% of a 3.3v reference).
              So they are both right, just using different ADC references.
              The 5V reference is probably fine, you lose a little bit of resolution (less than one bit) but soil moisture sensors are not exactly precise.
              If it mattered, you can connect the 3.3v supply to the Aref input and set the ADC to use Aref as it's reference, in which case you'll get the full resolution 0..1023 for 0..3.3v. In this case I probably wouldn't bother.
              • Z Zeph
                murdog
                @Zeph @daulagari Awesome thanks guys, that makes perfect sense!
                • daulagariD
                  daulagariD
                  daulagari
                  @murdog: You should probably also have a look at the New library to read Arduino VCC supply level without resistors for battery powered sensor nodes that do not use a voltage regulator but connect directly to the batteries thread.
                  If you want to make the code generic, you should have the code measure the VCC and scale the measured value according to what you read for VCC.
                    @daulagari Finally someone who appreciates my little library ;-) :+1:
                    • Moshe LivneM
                      Moshe LivneM
                      Moshe Livne
                      Can you please share your sketch? I have tried modifying the digital version of the sketch to analog but I have no idea what to write in the sensor type.
                      • Moshe LivneM
                        Moshe LivneM
                        Moshe Livne
                        Managed to make it a humidity sensor, which is probably close enough. Here is my sketch:
                        #define ANALOG_INPUT_SOIL_SENSOR A0
                        #define CHILD_ID 0 // Id of the sensor child
                        MyMessage msg(CHILD_ID, V_HUM);
                        int lastSoilValue = -1;
                        gw.begin();
                        gw.sendSketchInfo("Soil Moisture Sensor - analog", "1.0");
                        // sets the soil sensor analog pin as input
                        pinMode(ANALOG_INPUT_SOIL_SENSOR, INPUT);
                        gw.present(CHILD_ID, S_HUM);
                        // Read analog soil value
                        int soilValue = analogRead(ANALOG_INPUT_SOIL_SENSOR);
                        if (soilValue != lastSoilValue) {
                        Serial.println(soilValue);
                        gw.send(msg.set(static_cast<int>(static_cast<float>(1023 - soilValue))/1023*100)); // Send the relative moisture. this will probably work only on nano or uno as I used 1023
                        lastSoilValue = soilValue;
                        // Power down the radio and arduino until analog input changes.
                        gw.sleep(1000);
                        F 1 Reply Last reply
                        • Moshe LivneM
                          Moshe LivneM
                          Moshe Livne
                          Oh, sleep should probably be set to 3600000 or more to get long sleep periods between measurements as I don't think soil moisture should be measured every second....
                          • Moshe LivneM Moshe Livne
                            gw.begin();
                            gw.sleep(1000);
                            F
                            F
                            fred97
                            gw.begin();
                            gw.sleep(1000);
                            hello ,
                            i want to do same , but can you explaind the calcul is made ?
                            for now i use light sensor sketch with analog input , but i ant to modify by /10 for having a moisture meter reading value 0to100% or maybe there is a S_Percentage come in next version of mysensors ?
                            i use domotiz with gateway and for now only Light sensor work for read analog value .
                            thanks
                            • F fred97
                              gw.begin();
                              gw.sleep(1000);
                              hello ,
                              thanks
                              Moshe LivneM
                              Moshe LivneM
                              Moshe Livne
                              @fred97 , i also use domoticz. If you read this thread form the start, you will see that the arduino converts the moisture reading to something in the range 0-1023 (or 682 if you use mini pro). 1023 is 0 moisture, 0 is 100% moisture. so, moisture content is (1023 - reading)/1023*100.
                              Hope this answers your question!
                              Moshe
                              • F
                                F
                                fred97
                                thanks you ,
                                i have try your sketch but don't work send only O
                                send: 2-2-0-0 s=0,c=1,t=1,pt=2,l=2,st=ok:0
                                444
                                470
                                1023
                                i think the problem is inside converter in percentage ....
                                240 when is in water and 1023 when completly dry .
                                • Moshe LivneM
                                  Moshe LivneM
                                  Moshe Livne
                                  wrote on last edited by Moshe Livne
                                  @fred97 did you change anything in the calculation? the values in the println seems correct. do not remove the static casts - they are essential.
                                    BulldogLowellB
                                    BulldogLowellB
                                    BulldogLowell
                                    how about just using the map() function...
                                    gw.send(msg.set(map(soilValue, 0, 1023, 0 ,100));
                                      Moshe LivneM
                                      Moshe LivneM
                                      Moshe Livne
                                      @BulldogLowell would have used it if I knew it existed.... would it work is reverse? (1023,0, 0, 100)?
                                        BulldogLowellB
                                        BulldogLowellB
                                        BulldogLowell
                                        @Moshe-Livne
                                        Try it!!
                                        int soilValue = 250;
                                          Serial.println(map(soilValue, 1023,0,100,0));
                                        have you run into 123dcircuits yet?
                                          @Moshe-Livne
                                          Try it!!
                                          Moshe LivneM
                                          Moshe LivneM
                                          Moshe Livne
                                          @BulldogLowell not yet!!! my first encounter with arduino was only a few weeks ago.... so much to learn! the wood are lovely dark and deep, but i have promises to keep....
