  3. Soil Sensor analog values differ on Uno vs Pro Mini
soil sensorunopro mini
28 Posts 8 Posters 17.6k Views 1 Watching
  • M murdog
    @daulagari Yes Uno is powered via USB@5v, but the soil sensor is connected to the 3.3v regulated supply.
    daulagariD
    daulagariD
    daulagari
    So is the full-ADC scale (1023) not the same as the voltage supply?
    682/1023 * 5 Volt = 3.33 Volt and that would clip the 3.3 V ADC of the Pro Mini so therefore it is giving 1023.
    • Z
      Z
      Zeph
      OK, the soil sensor is connected to a 3.3v regulated supply.
      But the Arduino sounds like it's still running at 5v, and by default the ADC reference is VCC. So at full scale soil sensor reading of 3.3v will be only about 2/3 of that 5v reference. (but 100% of a 3.3v reference).
      So they are both right, just using different ADC references.
      The 5V reference is probably fine, you lose a little bit of resolution (less than one bit) but soil moisture sensors are not exactly precise.
      If it mattered, you can connect the 3.3v supply to the Aref input and set the ADC to use Aref as it's reference, in which case you'll get the full resolution 0..1023 for 0..3.3v. In this case I probably wouldn't bother.
      • Z Zeph
        murdog
        @Zeph @daulagari Awesome thanks guys, that makes perfect sense!
        • daulagariD
          daulagariD
          daulagari
          @murdog: You should probably also have a look at the New library to read Arduino VCC supply level without resistors for battery powered sensor nodes that do not use a voltage regulator but connect directly to the batteries thread.
          If you want to make the code generic, you should have the code measure the VCC and scale the measured value according to what you read for VCC.
          • daulagariD daulagari
            @daulagari Finally someone who appreciates my little library ;-) :+1:
            • Moshe LivneM
              Moshe LivneM
              Moshe Livne
              Can you please share your sketch? I have tried modifying the digital version of the sketch to analog but I have no idea what to write in the sensor type.
              • Moshe LivneM
                Moshe LivneM
                Moshe Livne
                Managed to make it a humidity sensor, which is probably close enough. Here is my sketch:
                #define ANALOG_INPUT_SOIL_SENSOR A0
                #define CHILD_ID 0 // Id of the sensor child
                MyMessage msg(CHILD_ID, V_HUM);
                int lastSoilValue = -1;
                gw.begin();
                gw.sendSketchInfo("Soil Moisture Sensor - analog", "1.0");
                // sets the soil sensor analog pin as input
                pinMode(ANALOG_INPUT_SOIL_SENSOR, INPUT);
                gw.present(CHILD_ID, S_HUM);
                // Read analog soil value
                int soilValue = analogRead(ANALOG_INPUT_SOIL_SENSOR);
                if (soilValue != lastSoilValue) {
                Serial.println(soilValue);
                gw.send(msg.set(static_cast<int>(static_cast<float>(1023 - soilValue))/1023*100)); // Send the relative moisture. this will probably work only on nano or uno as I used 1023
                lastSoilValue = soilValue;
                // Power down the radio and arduino until analog input changes.
                gw.sleep(1000);
                F 1 Reply Last reply
                • Moshe LivneM
                  Moshe LivneM
                  Moshe Livne
                  Oh, sleep should probably be set to 3600000 or more to get long sleep periods between measurements as I don't think soil moisture should be measured every second....
                  • Moshe LivneM Moshe Livne
                    gw.begin();
                    gw.sleep(1000);
                    F
                    F
                    fred97
                    gw.begin();
                    gw.sleep(1000);
                    hello ,
                    i want to do same , but can you explaind the calcul is made ?
                    for now i use light sensor sketch with analog input , but i ant to modify by /10 for having a moisture meter reading value 0to100% or maybe there is a S_Percentage come in next version of mysensors ?
                    i use domotiz with gateway and for now only Light sensor work for read analog value .
                    thanks
                    • F fred97
                      gw.begin();
                      gw.sleep(1000);
                      hello ,
                      thanks
                      Moshe LivneM
                      Moshe LivneM
                      Moshe Livne
                      @fred97 , i also use domoticz. If you read this thread form the start, you will see that the arduino converts the moisture reading to something in the range 0-1023 (or 682 if you use mini pro). 1023 is 0 moisture, 0 is 100% moisture. so, moisture content is (1023 - reading)/1023*100.
                      Hope this answers your question!
                      Moshe
                      • F
                        F
                        fred97
                        thanks you ,
                        i have try your sketch but don't work send only O
                        send: 2-2-0-0 s=0,c=1,t=1,pt=2,l=2,st=ok:0
                        444
                        470
                        1023
                        i think the problem is inside converter in percentage ....
                        240 when is in water and 1023 when completly dry .
                        • Moshe LivneM
                          Moshe LivneM
                          Moshe Livne
                          wrote on last edited by Moshe Livne
                          @fred97 did you change anything in the calculation? the values in the println seems correct. do not remove the static casts - they are essential.
                            BulldogLowellB
                            BulldogLowellB
                            BulldogLowell
                            how about just using the map() function...
                            gw.send(msg.set(map(soilValue, 0, 1023, 0 ,100));
                              Moshe LivneM
                              Moshe LivneM
                              Moshe Livne
                              @BulldogLowell would have used it if I knew it existed.... would it work is reverse? (1023,0, 0, 100)?
                                BulldogLowellB
                                BulldogLowellB
                                BulldogLowell
                                @Moshe-Livne
                                Try it!!
                                int soilValue = 250;
                                  Serial.println(map(soilValue, 1023,0,100,0));
                                have you run into 123dcircuits yet?
                                  @Moshe-Livne
                                  Try it!!
                                  Moshe LivneM
                                  Moshe LivneM
                                  Moshe Livne
                                  @BulldogLowell not yet!!! my first encounter with arduino was only a few weeks ago.... so much to learn! the wood are lovely dark and deep, but i have promises to keep....
                                  • F
                                    F
                                    fred97
                                    hello
                                    it's working but is not inverted :+1:
                                    314
                                    send: 2-2-0-0 s=0,c=1,t=1,pt=4,l=4,st=ok:30
                                    294
                                    send: 2-2-0-0 s=0,c=1,t=1,pt=4,l=4,st=ok:28
                                    287
                                    299
                                    send: 2-2-0-0 s=0,c=1,t=1,pt=4,l=4,st=ok:29
                                    313
                                    1023
                                    send: 2-2-0-0 s=0,c=1,t=1,pt=4,l=4,st=ok:100
                                    100 is when is dry and 220/250 is when the sensor is in water .
                                    i just need little more help for invert value , 100 = in water and 0 when is dry
                                    thx
                                    • F fred97
                                      hello
                                      314
                                      294
                                      287
                                      299
                                      313
                                      1023
                                      thx
                                      BulldogLowellB
                                      BulldogLowellB
                                      BulldogLowell
                                      #23
                                      @fred97
                                      like this:
                                      gw.send(msg.set(map(soilValue, 100, 250, 0, 100));
                                      it maps 100 to zero and 250 to 100
                                      Let me know if that works for you.
                                      or... you can try this to bound the returned value by zero and 100:
                                      gw.send((max(min(map(soilValue, 100,250,0,100), 100), 0)));
                                      confusing but is is mapping the value, and limiting to 100 and then making sure it is at least zero (i.e. non-negative).
                                      or just:
                                      gw.send(constrain(map(soilValue, 100,250,0,100), 0, 100));
                                      • F
                                        F
                                        fred97
                                        gw.send(msg.set(map(soilValue, 100, 250, 0, 100)));```
                                        you have forget one ) at last .
                                        sensor started, id 2
                                        send: 2-2-0-0 s=255,c=0,t=17,pt=0,l=5,st=ok:1.4.1
                                        send: 2-2-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
                                        read: 0-0-2 s=255,c=3,t=6,pt=0,l=1:M
                                        send: 2-2-0-0 s=255,c=3,t=11,pt=0,l=25,st=ok:Soil Moisture Sensor - an
                                        send: 2-2-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
                                        send: 2-2-0-0 s=0,c=0,t=7,pt=0,l=5,st=ok:1.4.1
                                        1023
                                        send: 2-2-0-0 s=0,c=1,t=1,pt=4,l=4,st=ok:615
                                        285
                                        send: 2-2-0-0 s=0,c=1,t=1,pt=4,l=4,st=ok:123
                                        250 is when is in water and 1023 is dry , it's alway inverted , i can test 2 other exemple because there is a problem in sketch maybe ;or ) when is try this
                                        and for other 2 exemple i can send to arduino compiling error
                                        sketch_may24a.ino: In function 'void loop()':
                                        sketch_may24a:31: error: no matching function for call to 'MySensor::send(long int)'
                                        C:\Program Files (x86)\Arduino\libraries\MySensors/MySensor.h:142: note: candidates are: bool MySensor::send(MyMessage&, bool)
                                        • F fred97
                                          1023
                                          285
                                          BulldogLowellB
                                          BulldogLowellB
                                          BulldogLowell
                                          @fred97
                                          Post your entire sketch.
