  3. How to sleep the Arduino but still have it respond to the Vera?
23 Posts 6 Posters 14.8k Views 3 Watching
  • T Offline
    T Offline
    twosh
    I'm trying to save some cpu cycles here! I'm using the pretty much unmodified rfid lock sketch, except I've added code for a LED diode to show if it's armed or disarmed. Since this puppy will only be used when you leave or enter the house, 99% of the time it could sleep. Here is the loop:
      gw.process(); // Process incomming messages
      boolean success;
      uint8_t key[] = { 0, 0, 0, 0, 0, 0, 0 };  // Buffer to store the returned UID
      uint8_t currentKeyLength;                        // Length of the UID (4 or 7 bytes depending on ISO14443A card type)
      // Wait for an ISO14443A type cards (Mifare, etc.).  When one is found
      // 'uid' will be populated with the UID, and uidLength will indicate
      // if the uid is 4 bytes (Mifare Classic) or 7 bytes (Mifare Ultralight)
      success = nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A, &key[0], &currentKeyLength);
      if (success) {
        Serial.print("Found tag id: ");
        for (uint8_t i=0; i < currentKeyLength; i++)
          if (i>0) Serial.print(",");
          Serial.print("0x");Serial.print(key[i], HEX);
        for (uint8_t i=currentKeyLength; i < maxKeyLength; i++)
          Serial.print(",0x00");
        Serial.println("");
        boolean valid = false;
        // Compare this key to the valid once registered here in sketch
        for (int i=0;i<keyCount && !valid;i++) {
          for (int j=0;i<currentKeyLength && !valid;j++) {
            if (key[j] != validKeys[i][j]) {
            if (j==currentKeyLength-1) {
              valid = true;
        if (valid) {
          // Switch lock status
          setLockState(!lockStatus, true);
        // Wait for card/tag to leave reader
        while(nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A, &key[0], &currentKeyLength));
      gw.sleep(2000);
    Using this loop the arduino works great when using the rfid-tag to trigger a change in armed / disarmed, but the arduino does NOT respond to commands from my Vera (UI7).
    I think I know what the problem is - basically the Arduino is sleeping when the command from the controller arrives, and thus it can't process it. Changing the last bit of code like this (moving the gw.sleep(2000) only to trigger if an rfid-tag has been read works:
        gw.sleep(2000);
    But then again, using this code it doesn't sleep at all except for the 2 seconds 2 times a day when I trigger it. :)
    So, how could I have the best of both worlds? I want to let it sleep until 1) there is an incoming command from my Vera or 2) an rfid-tag is recognized. Is it possible?
    As always, thanks in advance for any input!
    • F Offline
      F Offline
      fleinze
      If you want to receive commands, you need to keep the nrf24 in receive mode. In this mode the radio consumes about 12mA which is a lot for a battery powered node.
      I think it would be possible to send the Arduino to sleep while the radio stays in listening mode, waking up the arduino using the irq pin, but it would still consume the 12mA.
      • T Offline
        T Offline
        twosh
        Hi @fleinze , and thanks for your suggestion. I couldn't find anything in the API or during a quick search of the forum how to do this. Do you have some code for it or?
        However, when I checked the API again and I found something I could try, namely the interrupt variable in the sleep function:
        bool sleep(int interrupt, int mode, unsigned long ms=0);
        I'll try something like this and see how it works!
        • T Offline
          T Offline
          twosh
          Well, that was fast... It didn't work... :(
            gw.sleep(2, CHANGE, 1000);
          Am I missing something or am I trying to do something that isn't possible right now?
          • T Offline
            T Offline
            twosh
            Ok, using the code from http://forum.mysensors.org/topic/1112/how-low-can-arduino-can-go/20 (thanks @funky81 ) I get the Arduino sleeping peacefully while still reacting to interrupts.
            Since my rfid doesn't generate an interrupt (attached to A4 and A5) I need to set a timer to wake the little beast up every couple of seconds just to check if there happen to be a tag nearby then. I'll let you know how this turns out! :)
            B 1 Reply Last reply
            • T Offline
              T Offline
              twosh
              wrote on last edited by twosh
              Meh...
              Trying bits and pieces from all over the web for using the hardware timer, but since I'm not exactly sure what I'm doing when it comes to this level of hardware interaction - well the following crude sketch doesn't work. :)
                RFID Lock sensor/actuator
                Henrik Ekblad <henrik.ekblad@mysensors.org>
                Use RFID tag to lock/unlock a door or trigger a scene on your controller.
                This example sketch allows you to add an optional relay or solenoid
                which can be activated/opened by RFID or controller.
                Use the I2C wiring option for your RFID module and connect to the following Arduino pins.
                RFID       Arduino
                GND   ->   GND
                VCC   ->   +5V
                SCL   ->   A5
                SDA   ->   A4
                Use normal wiring for NRF24L01 radio
                Attach a optional relay or solonoid lock to pin 4
              #include <PN532_I2C.h>
              #include <PN532.h>
              #include <avr/sleep.h>
              #include <avr/io.h>
              #include <avr/interrupt.h>
              // Add your valid rfid keys here. To find you your key just run sketch; hold your new RFID tag in fron ot the reader;
              // and copy the key from serial output of this sketch.
              const uint8_t maxKeyLength = 7;
              uint8_t validKeys[][maxKeyLength] = {
              int keyCount = sizeof validKeys / maxKeyLength;
              #define CHILD_ID 99   // Id of the sensor child
              #define YELLOWLED 5  // Pin for the Yellow led.
              /*Pin definitions*/
              const int lockPin = 4;         // (Digital 4) The pin that activates the relay/solenoid lock.
              bool lockStatus;
              MyMessage lockMsg(CHILD_ID, V_LOCK_STATUS);
              PN532_I2C pn532i2c(Wire);
              PN532 nfc(pn532i2c);
                pinMode(lockPin, OUTPUT);
                pinMode(YELLOWLED, OUTPUT);
                nfc.begin();
                uint32_t versiondata = nfc.getFirmwareVersion();
                if (! versiondata) {
                  Serial.print("Couldn't find PN53x board");
                  while (1); // halt
                Serial.print("Found NFC chip PN5"); Serial.println((versiondata>>24) & 0xFF, HEX);
                Serial.print("Firmware ver. "); Serial.print((versiondata>>16) & 0xFF, DEC);
                Serial.print('.'); Serial.println((versiondata>>8) & 0xFF, DEC);
                // Set the max number of retry attempts to read from a card
                // This prevents us from waiting forever for a card, which is
                // the default behaviour of the PN532.
                nfc.setPassiveActivationRetries(0x3);
                // configure board to read RFID tags
                nfc.SAMConfig();
                // Init mysensors library
                gw.begin(incomingMessage);
                gw.sendSketchInfo("RFID Lock", "1.0");
                gw.present(CHILD_ID, S_LOCK);
                lockStatus = gw.loadState(0);    // Read last lock status from eeprom
                setLockState(lockStatus, true); // Now set the last known state and send it to controller
                  // initialize Timer1
                  cli();          // disable global interrupts
                  TCCR1A = 0;     // set entire TCCR1A register to 0
                  TCCR1B = 0;     // same for TCCR1B
                  // set compare match register to desired timer count:
                  OCR1A = 15624;
                  // turn on CTC mode:
                  TCCR1B |= (1 << WGM12);
                  // Set CS10 and CS12 bits for 1024 prescaler:
                  TCCR1B |= (1 << CS10);
                  TCCR1B |= (1 << CS12);
                  // enable timer compare interrupt:
                  TIMSK1 |= (1 << OCIE1A);
                  // enable global interrupts:
                  sei();
                boolean success;
                if (success) {
                  Serial.println("");
                        valid = true;
                  if (valid) {
                  //gw.sleep(2000);
                sleep();
              // Unlocks the door.
              void setLockState(bool state, bool send){
                if (state) {
                   Serial.println("close lock");
                   digitalWrite(YELLOWLED, HIGH);}
                else {
                   Serial.println("open lock");
                   digitalWrite(YELLOWLED, LOW);}
                if (send)
                  gw.send(lockMsg.set(state));
                digitalWrite(lockPin, state);
                gw.saveState(0,state);
                lockStatus = state;
                if (message.type==V_LOCK_STATUS) {
                   // Change relay state
                   setLockState(message.getBool(), false);
                   Serial.print("Incoming lock status:");
              void sleep(){
                 // disable ADC
                ADCSRA = 0;
                // clear various "reset" flags
                MCUSR = 0;
                // allow changes, disable reset
                WDTCSR = bit (WDCE) | bit (WDE);
                // set interrupt mode and an interval
                WDTCSR = bit (WDIE) | bit (WDP3) | bit (WDP0);    // set WDIE, and 1 second delay
                wdt_reset();  // pat the dog
                set_sleep_mode (SLEEP_MODE_PWR_DOWN);
                noInterrupts ();           // timed sequence follows
                sleep_enable();
                // turn off brown-out enable in software
                MCUCR = bit (BODS) | bit (BODSE);
                MCUCR = bit (BODS);
                interrupts ();             // guarantees next instruction executed
                sleep_cpu ();
                // cancel sleep as a precaution
                sleep_disable();
              ISR(TIMER1_COMPA_vect)
                boolean success;
                if (success) {
                  Serial.println("");
                        valid = true;
                  if (valid) {
                  //gw.sleep(2000);
              Help is appreciated...
              • T twosh
                B Offline
                B Offline
                BulldogLowell
                So, your RFID device communicates with I2C, so you may be able to do what you want here.
                You could always try to connect to a pin with an interrupt (D2 or D3) by a jumper from A4 or A5. Use a resistor across the pins to limit how much current the interrupt pin sinks.
                Attach in a similar way the radio to the other interrupt pin.
                so ideally, you are waking your arduino from its slumber on an interrupt from either the RFID scanner or the radio.
                Which RFID device are you using?
                • T Offline
                  T Offline
                  twosh
                  @BulldogLowell Thanks - this sounds like a plan! :)
                  I'm using this RFID-chip: http://www.ebay.com/itm/271316626820?rmvSB=true
                  I've got a lot of these resistors lying http://www.ebay.com/itm/220954677122?rmvSB=true but are they too large? 5V / 4,7 kOhm ~ 1 mA, would it trigger? I've got D3 free on my arduino which interrupts, D2 is used by the radio.
                  • T twosh
                    B Offline
                    B Offline
                    BulldogLowell
                    look at the data sheet from your reader.... there is an IRQ pin on the board. You should see how that works.
                    • T Offline
                      T Offline
                      twosh
                      Thanks @BulldogLowell ! I can see that the chip has an IRQ pin and GND among others. SInce I'm not a hardware guy could you tell me if it would be enough to connect the IRQ to my arduino D3-pin? Would I need to connect some other pins as well, e.g. the RFID GND to Arduino GND? (The RFID is already connected to Arduino GND via the 4 pins mentioned in the MySensor guide for connecting the RFID.)
                      • T Offline
                        T Offline
                        twosh
                        Hi all!
                        Soldered a cable between D3 and the IRQ on the RFID-chip and it seems to have solved my problem. The response time is a bit slow - I need to keep my tag pressed to the RFID-chip for 2-5 seconds before it switches mode. Any idea why that would be? Note that I'm using the sleep function from http://forum.mysensors.org/topic/1112/how-low-can-arduino-can-go/20 and not gw.sleep();
                        My sketch looks like this:
                          RFID       Arduino
                          GND   ->   GND
                          VCC   ->   +5V
                          SCL   ->   A5
                          SDA   ->   A4
                        #include <PN532.h>
                                              //Removed my keys here when posting the sketch
                        /*Pin definitions*/
                        bool lockStatus;
                          nfc.begin();
                            while (1); // halt
                          nfc.SAMConfig();
                          boolean success;
                          if (success) {
                            Serial.println("");
                                  valid = true;
                            if (valid) {
                            //gw.sleep(2000);
                          sleep();
                          if (state) {
                          else {
                          if (send)
                          lockStatus = state;
                        void sleep(){
                           // disable ADC
                          ADCSRA = 0;
                          MCUSR = 0;
                          sleep_enable();
                          MCUCR = bit (BODS);
                          sleep_cpu ();
                          sleep_disable();
                        • T twosh
                          Hi all!
                            RFID       Arduino
                            GND   ->   GND
                            VCC   ->   +5V
                            SCL   ->   A5
                            SDA   ->   A4
                          #include <PN532.h>
                          /*Pin definitions*/
                          bool lockStatus;
                            nfc.begin();
                              while (1); // halt
                            nfc.SAMConfig();
                            boolean success;
                            if (success) {
                              Serial.println("");
                                    valid = true;
                              if (valid) {
                              //gw.sleep(2000);
                            sleep();
                            if (state) {
                            else {
                            if (send)
                            lockStatus = state;
                          void sleep(){
                             // disable ADC
                            ADCSRA = 0;
                            MCUSR = 0;
                            sleep_enable();
                            MCUCR = bit (BODS);
                            sleep_cpu ();
                            sleep_disable();
                          B Offline
                          B Offline
                          BulldogLowell
                          I'd try gw.sleep( ) because you can attach the card read function to the interrupt/wakeup event, and avoid the MCU cycling through unnecessary code to get to card read (e.g. gw.process( )).
                          • T Offline
                            T Offline
                            twosh
                            Earlier I tried using gw.sleep(2, CHANGE, 1000); but that didn't work then. Should I use it another way? And how do I make sure I listen for interrupts on both the D2 and D3 pins?
                            • B Offline
                              B Offline
                              BulldogLowell
                              attachInterrupt( )
                              attachInterrupt( )
                              • M Offline
                                M Offline
                                marceltrapman
                                @BulldogLowell Isn't that the part that the MySensors libs (should) take care of?
                                Fulltime Servoy Developer
                                • M marceltrapman
                                  B Offline
                                  B Offline
                                  BulldogLowell
                                  Good point.
                                  Does gw.sleep( ) accept both interrupts?
                                  • H Offline
                                    H Offline
                                    I see now that documentation is lacking the dual external pin sleep function (metal note). You'll find it in MySensors.h.
                                    • T Offline
                                      T Offline
                                      twosh
                                      Hi @hek and thanks for the info!
                                      However, I'm not sure that I find anything regarding listening for both D2 and D3-pins in MySensors.h, I only find:
                                      	 * Sleep (PowerDownMode) the Arduino and radio. Wake up on timer or pin change.
                                      	 * See: http://arduino.cc/en/Reference/attachInterrupt for details on modes and which pin
                                      	 * is assigned to what interrupt. On Nano/Pro Mini: 0=Pin2, 1=Pin3
                                      	 * @param interrupt Interrupt that should trigger the wakeup
                                      	 * @param mode RISING, FALLING, CHANGE
                                      	 * @param ms Number of milliseconds to sleep or 0 to sleep forever
                                      	 * @return true if wake up was triggered by pin change and false means timer woke it up.
                                      Which is the same as the documentation, right?
                                      • H Offline
                                        H Offline
                                        https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/MySensor.h#L244
                                        • T Offline
                                          T Offline
                                          twosh
                                          Ah, there it is! I was looking at his:
                                          https://github.com/mysensors/CodeBender/blob/master/MySensor.h
                                          Big thanks @hek ! I'll try this when I get home!
                                          12.1k
