  3. How to sleep the Arduino but still have it respond to the Vera?
23 Posts 6 Posters 15.3k Views 3 Watching
  • T
    twosh
    wrote on last edited by twosh
    @BulldogLowell Thanks - this sounds like a plan! :)
    I'm using this RFID-chip: http://www.ebay.com/itm/271316626820?rmvSB=true
    I've got a lot of these resistors lying http://www.ebay.com/itm/220954677122?rmvSB=true but are they too large? 5V / 4,7 kOhm ~ 1 mA, would it trigger? I've got D3 free on my arduino which interrupts, D2 is used by the radio.
    • T twosh
      BulldogLowellB
      BulldogLowellB
      BulldogLowell
      look at the data sheet from your reader.... there is an IRQ pin on the board. You should see how that works.
      • T
        twosh
        Thanks @BulldogLowell ! I can see that the chip has an IRQ pin and GND among others. SInce I'm not a hardware guy could you tell me if it would be enough to connect the IRQ to my arduino D3-pin? Would I need to connect some other pins as well, e.g. the RFID GND to Arduino GND? (The RFID is already connected to Arduino GND via the 4 pins mentioned in the MySensor guide for connecting the RFID.)
        • T
          twosh
          Hi all!
          Soldered a cable between D3 and the IRQ on the RFID-chip and it seems to have solved my problem. The response time is a bit slow - I need to keep my tag pressed to the RFID-chip for 2-5 seconds before it switches mode. Any idea why that would be? Note that I'm using the sleep function from http://forum.mysensors.org/topic/1112/how-low-can-arduino-can-go/20 and not gw.sleep();
          My sketch looks like this:
            RFID Lock sensor/actuator
            Henrik Ekblad <henrik.ekblad@mysensors.org>
            Use RFID tag to lock/unlock a door or trigger a scene on your controller.
            This example sketch allows you to add an optional relay or solenoid
            which can be activated/opened by RFID or controller.
            Use the I2C wiring option for your RFID module and connect to the following Arduino pins.
            RFID       Arduino
            GND   ->   GND
            VCC   ->   +5V
            SCL   ->   A5
            SDA   ->   A4
            Use normal wiring for NRF24L01 radio
            Attach a optional relay or solonoid lock to pin 4
          #include <PN532_I2C.h>
          #include <PN532.h>
          #include <avr/sleep.h>
          // Add your valid rfid keys here. To find you your key just run sketch; hold your new RFID tag in fron ot the reader;
          // and copy the key from serial output of this sketch.
          const uint8_t maxKeyLength = 7;
          uint8_t validKeys[][maxKeyLength] = {
                                //Removed my keys here when posting the sketch
          int keyCount = sizeof validKeys / maxKeyLength;
          #define CHILD_ID 99   // Id of the sensor child
          #define YELLOWLED 5  // Pin for the Yellow led.
          /*Pin definitions*/
          const int lockPin = 4;         // (Digital 4) The pin that activates the relay/solenoid lock.
          bool lockStatus;
          MyMessage lockMsg(CHILD_ID, V_LOCK_STATUS);
          PN532_I2C pn532i2c(Wire);
          PN532 nfc(pn532i2c);
            pinMode(lockPin, OUTPUT);
            pinMode(YELLOWLED, OUTPUT);
            nfc.begin();
            uint32_t versiondata = nfc.getFirmwareVersion();
            if (! versiondata) {
              Serial.print("Couldn't find PN53x board");
              while (1); // halt
            Serial.print("Found NFC chip PN5"); Serial.println((versiondata>>24) & 0xFF, HEX);
            Serial.print("Firmware ver. "); Serial.print((versiondata>>16) & 0xFF, DEC);
            Serial.print('.'); Serial.println((versiondata>>8) & 0xFF, DEC);
            // Set the max number of retry attempts to read from a card
            // This prevents us from waiting forever for a card, which is
            // the default behaviour of the PN532.
            nfc.setPassiveActivationRetries(0x3);
            // configure board to read RFID tags
            nfc.SAMConfig();
            // Init mysensors library
            gw.begin(incomingMessage);
            gw.sendSketchInfo("RFID Lock", "1.0");
            gw.present(CHILD_ID, S_LOCK);
            lockStatus = gw.loadState(0);    // Read last lock status from eeprom
            setLockState(lockStatus, true); // Now set the last known state and send it to controller
            gw.process(); // Process incomming messages
            boolean success;
            uint8_t key[] = { 0, 0, 0, 0, 0, 0, 0 };  // Buffer to store the returned UID
            uint8_t currentKeyLength;                        // Length of the UID (4 or 7 bytes depending on ISO14443A card type)
            // Wait for an ISO14443A type cards (Mifare, etc.).  When one is found
            // 'uid' will be populated with the UID, and uidLength will indicate
            // if the uid is 4 bytes (Mifare Classic) or 7 bytes (Mifare Ultralight)
            success = nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A, &key[0], &currentKeyLength);
            if (success) {
              Serial.print("Found tag id: ");
              for (uint8_t i=0; i < currentKeyLength; i++)
                if (i>0) Serial.print(",");
                Serial.print("0x");Serial.print(key[i], HEX);
              for (uint8_t i=currentKeyLength; i < maxKeyLength; i++)
                Serial.print(",0x00");
              Serial.println("");
              boolean valid = false;
              // Compare this key to the valid once registered here in sketch
              for (int i=0;i<keyCount && !valid;i++) {
                for (int j=0;i<currentKeyLength && !valid;j++) {
                  if (key[j] != validKeys[i][j]) {
                  if (j==currentKeyLength-1) {
                    valid = true;
              if (valid) {
                // Switch lock status
                setLockState(!lockStatus, true);
              // Wait for card/tag to leave reader
              while(nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A, &key[0], &currentKeyLength));
              //gw.sleep(2000);
            sleep();
          // Unlocks the door.
          void setLockState(bool state, bool send){
            if (state) {
               Serial.println("close lock");
               digitalWrite(YELLOWLED, HIGH);}
            else {
               Serial.println("open lock");
               digitalWrite(YELLOWLED, LOW);}
            if (send)
              gw.send(lockMsg.set(state));
            digitalWrite(lockPin, state);
            gw.saveState(0,state);
            lockStatus = state;
            if (message.type==V_LOCK_STATUS) {
               // Change relay state
               setLockState(message.getBool(), false);
               Serial.print("Incoming lock status:");
          void sleep(){
             // disable ADC
            ADCSRA = 0;
            // clear various "reset" flags
            MCUSR = 0;
            // allow changes, disable reset
            WDTCSR = bit (WDCE) | bit (WDE);
            // set interrupt mode and an interval
            WDTCSR = bit (WDIE) | bit (WDP3) | bit (WDP0);    // set WDIE, and 1 second delay
            wdt_reset();  // pat the dog
            set_sleep_mode (SLEEP_MODE_PWR_DOWN);
            noInterrupts ();           // timed sequence follows
            sleep_enable();
            // turn off brown-out enable in software
            MCUCR = bit (BODS) | bit (BODSE);
            MCUCR = bit (BODS);
            interrupts ();             // guarantees next instruction executed
            sleep_cpu ();
            // cancel sleep as a precaution
            sleep_disable();
          • T twosh
            Hi all!
              RFID       Arduino
              GND   ->   GND
              VCC   ->   +5V
              SCL   ->   A5
              SDA   ->   A4
            #include <PN532.h>
            /*Pin definitions*/
            bool lockStatus;
              nfc.begin();
                while (1); // halt
              nfc.SAMConfig();
              boolean success;
              if (success) {
                Serial.println("");
                      valid = true;
                if (valid) {
                //gw.sleep(2000);
              sleep();
              if (state) {
              else {
              if (send)
              lockStatus = state;
            void sleep(){
               // disable ADC
              ADCSRA = 0;
              MCUSR = 0;
              sleep_enable();
              MCUCR = bit (BODS);
              sleep_cpu ();
              sleep_disable();
            BulldogLowellB
            BulldogLowellB
            BulldogLowell
            I'd try gw.sleep( ) because you can attach the card read function to the interrupt/wakeup event, and avoid the MCU cycling through unnecessary code to get to card read (e.g. gw.process( )).
            • T
              twosh
              Earlier I tried using gw.sleep(2, CHANGE, 1000); but that didn't work then. Should I use it another way? And how do I make sure I listen for interrupts on both the D2 and D3 pins?
              • BulldogLowellB
                BulldogLowellB
                BulldogLowell
                attachInterrupt( )
                attachInterrupt( )
                • marceltrapmanM
                  marceltrapmanM
                  marceltrapman
                  @BulldogLowell Isn't that the part that the MySensors libs (should) take care of?
                  Fulltime Servoy Developer
                    BulldogLowellB
                    BulldogLowellB
                    BulldogLowell
                    Good point.
                    Does gw.sleep( ) accept both interrupts?
                      I see now that documentation is lacking the dual external pin sleep function (metal note). You'll find it in MySensors.h.
                      • T
                        twosh
                        Hi @hek and thanks for the info!
                        However, I'm not sure that I find anything regarding listening for both D2 and D3-pins in MySensors.h, I only find:
                        	 * Sleep (PowerDownMode) the Arduino and radio. Wake up on timer or pin change.
                        	 * See: http://arduino.cc/en/Reference/attachInterrupt for details on modes and which pin
                        	 * is assigned to what interrupt. On Nano/Pro Mini: 0=Pin2, 1=Pin3
                        	 * @param interrupt Interrupt that should trigger the wakeup
                        	 * @param mode RISING, FALLING, CHANGE
                        	 * @param ms Number of milliseconds to sleep or 0 to sleep forever
                        	 * @return true if wake up was triggered by pin change and false means timer woke it up.
                        	bool sleep(int interrupt, int mode, unsigned long ms=0);
                        Which is the same as the documentation, right?
                          https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/MySensor.h#L244
                          • T
                            twosh
                            Ah, there it is! I was looking at his:
                            https://github.com/mysensors/CodeBender/blob/master/MySensor.h
                            Big thanks @hek ! I'll try this when I get home!
                            • T
                              twosh
                              Hi again!
                              I've tried different approaches now with the gw.sleep(); func without success, using CHANGE, RISING or FALLING. No reaction either from tag or the Vera.
                                  // gw.sleep(2000);
                                gw.sleep(0, CHANGE, 1, CHANGE, 0); // int8_t sleep(uint8_t interrupt1, uint8_t mode1, uint8_t interrupt2, uint8_t mode2, unsigned long ms=0);
                              I've also tried adding this to setup();
                                interrupts();
                              as well as this:
                                attachInterrupt(0, loop, CHANGE);
                                attachInterrupt(1, loop, CHANGE);
                              Nothing happens. It just continues to sleep...
                              • YveauxY
                                According to the ATMega's datasheet only a Low-LEVEL interrupt can reliably wake the ATMega from sleep. See also http://forum.mysensors.org/topic/250/how-do-i-use-the-interrupt/5
                                • T
                                  twosh
                                  I'm back to choosing between no sleep, and the sleep(); function posted above. I can't get gw.sleep(); to work with either one or two interrupts, with or without declaring interrupts(); and/or attachInterrupt();.
                                  I'm ready to try more stuff if anyone got any ideas, but with my own limited understanding of both hardware in general and arduino in particular it feels like I'm running on fumes here. :o
                                  Thanks everyone for your contribution, and @hek - you've done a great job with MySensors! :clap:
