  3. Send data to other sensor
8 Posts 4 Posters 3.4k Views 1 Watching
  • ch3b7C Offline
    ch3b7C Offline
    ch3b7
    Can I send data to other sensors directly from the arduino serial window?
    H 1 Reply Last reply
    • ch3b7C ch3b7
      H Offline
      H Offline
      @ch3b7
      The gateway is the only place where you can send out data via serial window. The Sensor-class does not listen to serial input.
      But it is a two-liner to send a value (1.4 example below).
      MyMessage msg = new MyMessage(<chidldSensorId>,<dataType>).setDestination(<destinationNode>).set(<value>);
      gw.send(msg);
      Y 1 Reply Last reply
      • ch3b7C Offline
        ch3b7C Offline
        ch3b7
        This example work in 1.4b1 (18848a2) ?
        • H hek
          @ch3b7
          gw.send(msg);
          Y Offline
          Y Offline
          gw.send(msg);
          This will not compile, as the new()-operator returns a pointer to a MyMessage object.
          Better to compress the whole to:
          gw.send( MyMessage(<chidldSensorId>,<dataType>).setDestination(<destinationNode>).set(<value>) );
          J 1 Reply Last reply
          • ch3b7C Offline
            ch3b7C Offline
            ch3b7
            can i put values like this "gw.send( MyMessage("1","3").setDestination("2").set("1") );" ?
            • Y Yveaux
              gw.send(msg);
              J Offline
              J Offline
              jendrush
              @Yveaux Could you write sample messages to send from node, and receive value on another?
              • J jendrush
                Y Offline
                Y Offline
                @jendrush do you want some example code? I don't understand...
                • Y Yveaux
                  J Offline
                  J Offline
                  jendrush
                  @Yveaux Yes, example messages. Something like that - i have temperature from dht22 on one node, and i want to send this value to example node with radio id 2. Second thing, how to pick this value on radio node with id 2?
                  12.0k
