  3. Mysensored Garageport
23 Posts 6 Posters 16.2k Views 2 Watching
  • AnticimexA
    AnticimexA
    Anticimex
    Pictures or it didn't happen :)
    • tbowmoT
      tbowmoT
      tbowmo
      @hek @Anticimex
      Keep calm, and don't panic :) Something happened when I made the initial post, so I couldn't add pictures.. :)
        Looks great!
        Hmm.. I don't have a garage door opener... This is a good reason to get one ;)
        • AnticimexA
          AnticimexA
          Anticimex
          And the datasheet is predictably veeery vague on the security aspects of that machinery...well, you got everything you need to fix that ;)
          Defining "locked" as when the door is closed and offer a completly unspecified remote dongle leaves some to be desired after all...but at least you should only need to secure the actuation of the motor to secure the garage.
          • tbowmoT
            tbowmoT
            tbowmo
            Only one problem left now, domoticz doesn't seem to support mysensored blinds (which I have set it up to mimick, as it has V_UP/V_DOWN/V_STOP as informed by @hek in another thread)
            Domoticz also spews out errors about unknown ID's when it received V_UP/V_DOWN/V_STOP. So I'll have to dig into the code of domoticz as well, to see if I can fix things. On that note, I decided to fetch the latest domoticz, but that is broken, and can't be build :(
            Oh well, the fun life of being a hardware/software "hacker" :)
            @hek I have two ports.. Only one of them with a port opener at the moment, the one I have modified is for the second port, which had been put away since I bought it last year.
            @Anticimex
            Yes, it's a china remote keyfob thing. Also wondering about security. But since I can't lock down the garage fully (It's an old barn, that has a lot of other entries which can't be locked). It's not that big a concern right now.
            AnticimexA 1 Reply Last reply
            • tbowmoT tbowmo
              @Anticimex
              AnticimexA
              AnticimexA
              Anticimex
              @tbowmo well, that makes you the perfect guinea pig for practical security application for MySensors then :D you got nothing to loose if bugs are found ;)
              • tbowmoT
                tbowmoT
                tbowmo
                @Anticimex
                The normal remotes is still working as well (I have to make this as seamless as possible, as to not confuse the wife, and kids :))
                • tbowmoT tbowmo
                  @Anticimex
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @tbowmo perhaps we should design a MySensors keyfob :) The sensebender board is a good base for that (although we probably want to offer RF69 variants as well in that case).
                  • tbowmoT
                    tbowmoT
                    tbowmo
                    now with Video, for @hek and @Anticimex, so they can see it in "motion"
                    https://www.youtube.com/watch?v=GRaK19IdCCc
                    • tbowmoT tbowmo
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @tbowmo Awesome! What approach did you take? Reverse-engineered the keyfob to route it through the MySensors network or do you use a separate keyfob for the "MySensor path" and retain the original?
                      Or maybe I am reading it the wrong way; you detect the door action and send the status to your controller (Domoticz)?
                      Anyway, it is hacking done properly :D
                      The light is an addition? Relay-actuator for that?
                      • tbowmoT
                        tbowmoT
                        tbowmo
                        @Anticimex
                        It's integrated into the opener control box itself. By poking around with a multimeter, I figured out which signals I could use.
                        For Open / Close / Stop status, I just look at the relay drivers, used for reversing the supply to the motor. It has two relays in it, one for each direction.
                        When it opens, it turns on relay 1, start ramping up the PWM to the motor, and when stopping, it ramps down the PWM, and finally turning off relay 1.
                        When it then closes again, it starts by turning on relay 2, ramping up / down PWM signals, and turn of relay 2 again.
                        So it's a "simple" hack :)
                        The unit has inputs for a wall switch, so you can operate it without a remote. This input happens to be 5V as well, that just needs to be grounded. So I have 1 pin for that.
                        The light is a bit more "trickier" :), as it's a built in light (which I will replace with a LED floodlight when I get around to put it up). It's also a relay driver like the motor control. I have put the mysensors module in between the original controller (connected to an input pin on the mysensor module), and then an output to the relay driver. This way I can detect when light is turned on by the original controller, and also switch it on / off from remote.
                        So you won't notice that it's there, until you activate it from domoticz (which I can't at the moment, as it is missing the V_UP/V_DOWN/V_STOP messages that I'm using)
                        • tbowmoT tbowmo
                          @Anticimex
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @tbowmo Yes WAF is an important factor. Changes are usually accepted if they are not noticed :D
                          Good work!
                            Mickey
                            Very nice work.
                            I notice that there are a lot of parts missing in the sensbender I understand you took out sensor and eeprom but I notice some caps and resistors also not attach.
                            can you specify what did you populate the board with only the atmega?
                            tbowmoT 1 Reply Last reply
                            • M Mickey
                              Very nice work.
                              tbowmoT
                              tbowmoT
                              tbowmo
                              @Mickey
                              On this one I only populated the atmega on the board. I removed the vcc pin on the radio module, before I soldered it back to back with the minimal sensebender module, and then put a le33 between vcc on sensebender board, and vcc on the radio (and added a capacitor on the radio, for good measures)
                              • tbowmoT tbowmo
                                @Mickey
                                Mickey
                                @tbowmo said:
                                @Mickey
                                and did you flash the the "official" sensebender bootloader ?
                                • tbowmoT
                                  tbowmoT
                                  tbowmo
                                  @Mickey
                                  For this particular one, I haven't used a bootloader at all, as I'm using jtagice3 to download my sketches.
                                  I have a serial terminal attached all the time for debugging, and I find it a bit irritating having to start up the terminal every time I have uploaded a new sketch (using normal arduino serial upload).
                                  So I have this setup when fiddling with stuff :) one window for serial terminal, one for shell where I upload using avrdude, and then the arduino env.
                                  • tbowmoT
                                    tbowmoT
                                    tbowmo
                                    Finally got around to mount the motor unit, after heavy modifications. Which also cut the standby power to under a 10th of the original unit.
                                    I ended up implementing my own 5v supply, that powers the logic in the original unit and my mysensor node, I then have a solid state relay, enabling / disabling the 38v rail for the engine part. This drops the standby from 7W to under 0.5W.
                                    I had to go a couple of loopholes to get it working, as the motor unit wouldn't respond to the remote when the 38v rail was missing. I then tapped into the remote signal, so when the remote is detected I power up the thing, I then need to press the button one more time to activate the opener. When the original unit switches of the light, I also power down the 38v rail.
                                    I can activate the port from domoticz, also the lights can be activated by domoticz. There are some small quirks, as the port is reported as open when the port actually is closed. I will have a look at the software for the next port that I have to modify
                                    And last a small demo video.
                                    From the outside with both ports in action (only the right port is mysensored for now)
                                    http://youtu.be/s9UuEDtNf5s
                                    RJ_MakeR 1 Reply Last reply
                                    • tbowmoT tbowmo
                                      RJ_MakeR
                                      RJ_MakeR
                                      RJ_Make
                                      @tbowmo Was the door on the left added after the building was built? Little strange for the garage door to "block" the smaller door.. :grinning:
                                      RJ_Make
                                      • C
                                        C
                                        Chester
                                        I'd say more likely the garage doors were originally "barn" type swinging doors, rather than sliding doors, and that personnel door was original.
                                        • tbowmoT
                                          tbowmoT
                                          tbowmo
                                          #22
                                          @ServiceXp, @Chester
                                          The previous owner rebuild the entire side of the barn, originally there where only a single swinging port in the middle (where the "personnel door" is now). Have also been thinking it was peculiar choice he made with the door back then.
                                          Anyways, when the port is open, you don't need the door.. so its not a big loss for me.
                                          Now I just need to get my tractor running, so I can put it aside and make room for my car :-)
